Forum Index : Microcontroller and PC projects : SD card warning
A warning about using SD cards continuous. After 1 weekend running the ChessClient program (playing continuous chess games) the board this morning looked like this (check the horse). The photo is rotated (for some reason on the PC it was correct, before upload). ![]() The Chessclient program uses this code, to read the chess piece tiles from SD card. ![]() In other words, for each piece on the board, each move, each game, it opens a file, reads it, and uses the data. For 1000 games with average 53 moves, and showing 64 pieces (empty fields also) those are roughly 3.4 million file opens, reads, and close. And the files on SD card are corrupted. I repowered the pico, and still the problem existed. Then I have copied new tile files from the PC to the pico (MMCC) and now the problem is gone. The SD card tile files where actually bad. So files actually can get corrupt from just reading them too often. Maybe it is a bad SD card. But this is just a warning for others, who may use similar technique for other applications. Just reading a file, does not guarantee it is never corrupted. Volhout P.S. found on V60302b0 on PicoMiteVGA (RP2040) reference design 2, board revision V1.7. Edited 2026-08-31 17:32 by Volhout PicomiteVGA PETSCII ROBOTS |
Hi Harm, That's very surprising, I was always under the impression that reading there was basically no limit, it was only the writing, that potentially degraded the silicon! (in the 100s of thousands, depending on how good the wear leveling is) it would be interesting to see if it happens again. Maybe worth looking at a more efficient way of loading the pieces image, maybe only once per move, or cache them & once per game, I realise memory space is a problem, though not so much with the client. Regards Kevin Edited 2026-08-31 18:53 by Bleep |
What I'm amazed at is that all the corruption appears to be so localized. It's possible that the previous format operation didn't manage to map out all the bad blocks and you are seeing file corruption because of that. There's an interesting reply on This Quora page which, IMHO. points to possible charge loss in the cells as being the problem. This is worse on high capacity cards but will happen on all cards eventually. |
Maybe the horse just attracted some fleas I'll see myself out ![]() |
Hi Mick, It si not very localized. If you look at the photo, you see that the king graphics (harder to see, at edge of the photo) also shows similar artefacts. Not sure how the memory cells are geographically located inside the flash chip inside the SD card, but the file size is 256 bytes (containing 200 bytes of data). And there are 2 files corrupted (horse and king). Volhout Edited 2026-08-31 21:57 by Volhout |
You can't tell where the data is on flash. Bad blocks are mapped out in a table and clean ones mapped in to replace them, but any block can be anywhere, I believe. ValiDrive can test the card and show where bad or non-existent blocks are. It's a useful thing to run over a new card to show whether you are getting what you paid for! |
Will such corruption apply (eventually) to USB memory sticks too? John |
It doesn't sound right to me; here we are, debating CRC vs Checksum for serial comms and yet we can get garbage from a SD card? |
AFAIK, SD cards — like SSDs — have an FTL (Flash Translation Layer) managed by the controller chip on the card. This layer translates the physical flash blocks on the memory chips into logical blocks for the SD interface. Defective blocks are automatically marked as bad and replaced with spare blocks. During read operations, the controller chip attempts to correct individual bad bits using ECC. If flash blocks fail over time (due to erase and write cycles!), the card's capacity eventually decreases. SCSI hard drives always operated this way, and IDE drives adopted the practice as well. Consequently, a "DOS format" (such as formatting to FAT32 via the operating system) never sees the defective flash blocks. Charge loss in the gate capacitors of flash cells can occur over extended periods (months). However, it is highly unlikely to happen within just a few days! That said, the process can be accelerated by very high temperatures. To prevent data loss caused by "forgetful" FETs, some controller chips "transparently" relocate flash blocks via the FTL — meaning "very old" blocks are copied to different locations, and the original blocks are marked for erasure. Naturally, a voltage drop occurring during this process can have "fatal" consequences. A specific issue with high-capacity cards (and newer cards in general) is the use of Multi-Level Cell (MLC) chips, adopted to cut costs and increase capacity. Instead of storing just a single bit, these store 2 or 3 bits per cell using distinct voltage levels — a method that is naturally far more sensitive to charge loss! However, I rather suspect there is a hardware problem (voltage drops) or a software issue (e.g. data being written without one noticing). Or the SD card itself is actually faulty. Regards, bfwolf |
If this sort of error were to be seen again perhaps an independent check of the file could be done to ensure it isn't something to do with the Pico hardware or firmware. Using SAVE IMAGE to get a record of the corruption on the Pico then putting the card in a PC and displaying the image there to compare the spots. If they are still there the file is damaged. |
Would be a nice confirmation, to see the corruption on a PC. I will run the same test again next weekend, and see if the corruption occurs again. At this moment the files are okay (after they have been re-written yesterday). Volhout |
