Posted: 08:33am 19 Jan 2026
Copy link to clipboard |
Godoh Guru
If both then new boards cause the same thing to happen, then I would be looking elsewhere. It depends on what speed you are running the motor at, now that you are varying the speed. Some motors have inbuilt thermal cutouts, if your motor is overheating with the new speed controller then maybe it is getting hot and the thermal cutout is opening.
I would have suggested that checking the connections on the motor terminal block would be worthwhile, but if it ran fine with the fixed speed controller and only fails on the variable speed controllers, then that should rule out faulty motor connections. good luck Pete |
