Hi All
I need some advise on the parameters of selection. Currently I have a number IRLZ44n N channel mosfets that I have been testing for my purpose. Basically I need to switch 5V at a max of 10A using pwm frequency of 100 hz.
When you look at the spec of the IRLZ44N it has Drain current of 33A to 47A. However when testing it with 5vdc and slowly ramping it up to 5A, it got uncomfortably hot. Although it appears that they are intended to run hot, however, I was hoping to use an over rated unit that would not need heat sinks.
Again looking at the spec, RDs(on) goes from 22 milli ohm to 35. I am using 1k in series on the Gate with 10k to ground. Others that I am looking at have a Rds(on) of 3.3 milli ohm.
Other factors that probably contribute to the heating is that I am driving it at 3.3v direct from the Rpi and it is probably not switched fully On. So I have ordered a couple of 4 channel level shifters. Basically a tiny board with mosfets to shift the logic level from 3.3 to 5v. I will also lower the series gate resistor to 330 ohm, although with the level shifter and the high impedance of the Gate, I may not need any series resistance.
I understand that the harder you switch it ON and the faster the rise time of the gate the less heat it creates. The gate charge spec also seems to contribute to the heating, but it goes down as the spec of the Rds(on) goes down.
So, my question is: How far should I go in over rating current and voltage to satisfy that need. The fact that I may pay a dollar or two more really doesn't make any difference, I just buy ten of them and test them.
Regards Regards Hervey Bay Qld. |
