Forum Index : Electronics : Build a Multi Phase PV Charger and 230Vac Inverter Using Pi Pico
   Page 2 of 2
Posted: 04:22am
22 Aug 2026
Solar Mike
While waiting for these pcb's to arrive, have been busy doing some work on an Inverter, that design is for a 100v system, however it is designed such that two H-Bridge boards can be paralleled to the same transformer primary, thus doubling the output without having to build one with bigger busbars when running on a lower voltage 48v setup. All future posts on the inverter will be on the other thread.
Expect these pcb's to be back here on Monday, will start working on them, as they need installation in the next couple of weeks.
Mike
   Page 2 of 2
