I noticed a couple of posts from others showing some IR images, and thought it would be comforting to know how hot everything was running, without having to stick my finger on it. So I purchased a HK micro camera which plugs into the phone and has a manual focus ring. After recieving it, I ran the inverter at about 3500w for 10ish minutes and then opened it up to see what would be revealed. (I doubt the unit is fully heat soaked, but this is enough time to get things warmed up) Here is the transformer. Although I had siliconed the transducer deep as I could into the windings, the inner windings are about 40F hotter than what the sensor is reading. I knew there was going to be a difference, so it's good to know what it is.  No issues or hot spots with the wiseguy inverter board itself.  Further scanning of the rear internal panel wiring revealed the following alarming picture. I know it's hard to see exactly what is going on from the picture, but I am pretty sure that 1/2 of the 120v split phase circuit breaker is bad and is running quite hot. The heat then propagates into the surrounding wiring attached to that terminal. I still need to pull it apart to confirm as the wiring is difficult to get to without the rear panel. Nothing else in my setup is a concern at this point, but I am quite glad I picked one of these cameras. |
