Posted: 08:19am 14 Dec 2025
Copy link to clipboard |
rogerdw Guru
Hi guys, I have a largish toroid I picked up at auction that comes from an Eguana 5kW inverter. A Canadian company that was building inverters and lithium battery systems in Adelaide, but closed up a while ago. I understand they were 48V systems. Anyway there appears to be one secondary winding and four separate primary windings. With 240VAC applied to the secondary, each primary winding is at 21.58V. I wound 8 turns and with 240 applied again, the 8 turn winding shows 11.47V ie. 1.43375 V/T With other guess work and manipulation, I came up with 167T for the sec and 15T for the primary. Does that sound right? Thanks. The toroid to the right is a 3kW Aerosharp toroid, so the Eguana one is markedly bigger ... and weighs a hefty 32kg.  |
