JAQForum Ver 19.10.27
Forum Index : Microcontroller and PC projects : Silicon Chip Pico 2 Computer (April 2025 )
Posted: 02:29am
27 Mar 2025
zeitfest
I see Silicon Chip has an article (April 2025 copy)
"  PICO/2/Computer
   Design and firmware by Peter Mather
   Words and MMBasic by Geoff Graham       "
Presumably that is the PicoMiteHDMIUSB motherboard reference design
here + following pages  ?
Are there any changes ?  The article says two pre-populated pcbs as a kit with spares
can be ordered from their supplier in China for about $150 AUD.
Edited 2025-03-27 12:30 by zeitfest
Posted: 10:01pm
27 Mar 2025
Geoffg
Yes, the magazine project is the same as Peter's PicoMiteHDMIUSB motherboard reference design.  As the article says, you can buy two assembled versions from JLCPCB for approx Aust$150 or, as I understand it, Silicon Chip will be selling the assembled version individually (I'm not sure of the cost).
There are no changes from Peter's original design.  But since that version Peter has made some further changes as detailed in that thread.
Geoff
Edited 2025-03-28 08:06 by Geoffg
Posted: 10:31pm
27 Mar 2025
  Silicon Chip Shop - Kits / Part Sets said
An assembled Pico 2 PCB plus a separate Raspberry Pi Pico 2 and the front and rear panels for the case. Just solder the Pico 2 to the PCB, add feet or a case, and it's ready to use.
Note: the photo shows the fully assembled module (prototype version). Everything in the photo is provided but the PIco 2 and a header need to be soldered to the PCB. The SD card and CR2032 coin cell are not included.
Cat No SC7468. Price: AUD $120.00 1 add Add to trolley (available until stock is exhausted)
In stock: ? yes (7 available). Estimated dispatch time: 1-3 days
Related to: Project: The Pico 2 Computer (April 2025)
They also have the bare PCB for $5 + P&P.
Posted: 10:39pm
27 Mar 2025
Turbo46
They are selling! When I bought one yesterday there were 15 available. Now there are 7.
Bill
Posted: 02:55pm
29 Mar 2025
mozzie
G'day All,
Checked Tuesday they had 20 available
Ordered mine on Friday, they had 4 left
Just checked and only one left
Hopefully being this popular they will get another batch made.
I'd get in quick if you are procrastinating....
Lyle.
Posted: 01:03pm
31 Mar 2025
zeitfest
I am wondering if SC is doing a pico 2 W or 2350B project already, given the three month publication lag, which would then supersede it   .
Posted: 06:26pm
14 Apr 2025
cdeagle
I just received mine today. Assembly was straight-forward. However, I might have a bad RP2350. Getting a "Device Descriptor Request Failed" message from Windows 11 Device Manager when trying to upload the firmware. Probably should have checked it before soldering it to the motherboard.
I have a stand-alone RP2350 that works fine.
David
Posted: 09:37pm
14 Apr 2025
  Quote  Getting a "Device Descriptor Request Failed" message from Windows 11 Device Manager when trying to upload the firmware.
Have you removed the links on CN2? You can't upload with them in place
Posted: 08:07am
15 Apr 2025
cdeagle
Yes, the jumpers are removed.
Posted: 10:07am
22 Oct 2025
walshpj64
Hi, I also purchased a pre assembled board from SC for $81. RP23500B chip already soldered in. I used the firmware PicoMiteHDMIUSBV6.00.01.uf2 from SC which worked ok. Also set the DVDD volts to 0.1V above the 1.0V as stated.
The only problem i had was there was no HDMI output. Console was OK. Eventually tracked it down to Setting  OPTION HDMI PINS 1, 3, 5, 7  The wiring of the new on board to the HDMI was different from the old board with the plugin pico. Don't know if there will be a revised firmware for newbies like me. At least i have found this forum which is great.
Peter
Posted: 10:39am
22 Oct 2025
On the board, there should be a OPTION RESET command silkscreened. If you execute this at the command prompt it should fully configure the board for you. Note that for higher HDMI resolutions you will need to set DVDD to 1.3V. measure between the DVDD test point and any convenient ground (SDcard socket cover)
Posted: 10:58am
22 Oct 2025
walshpj64
Thanks for the reply. Yes I tried OPTION RESET HDMIUSBI2S  and it wouldn't accept the command. It replied invalid board for this firmware. I tried OPTION RESET HDMIUSB and it worked but did not show or set the HDMI pin option. After i entered it manually it worked. May have to get an updated firmware. I tried PicoMiteHDMIUSBV6.00.03.uf2 from https://geoffg.net/picomitevga.html but it did not work (heartbeat LED did not start after loading).
May have to look around for a more compatible version on the forum
Yes i did also find i had to slightly increase the DVDD voltage when using 1024 x 768 the pico was stopping without it.
just in the process of getting the SD card to work and it looks like i have to change the GPIO pins from 22, 26, 27, 28 to 29, 31, 30, 32.
I found the schematic which helps greatly.
Thanks for the tips.
Peter.
Posted: 11:01am
22 Oct 2025
Please post a picture of the board so I can help further.
Posted: 11:03am
22 Oct 2025
November SC has the updated version (I2S audio) fully assembled PCB $AU90, front and back panels $AU7.50 + P&P.
Posted: 11:08am
22 Oct 2025
walshpj64
Hopefully the pics are OK.
Also the following is the options list
> option list
PicoMiteHDMI MMBasic USB RP2350B Edition V6.00.01
OPTION SYSTEM I2C GP20,GP21
OPTION FLASH SIZE 16777216
OPTION COLOURCODE ON
OPTION KEYBOARD US
OPTION PICO OFF
OPTION CPUSPEED (KHz) 315000
OPTION SDCARD GP29, GP31, GP30, GP32
OPTION AUDIO GP10,GP11', ON PWM CHANNEL 5
OPTION RTC AUTO ENABLE
OPTION MODBUFF ENABLE  192
OPTION PLATFORM HDMIUSB
Hope that helps.
Cheers Peter
Posted: 11:23am
22 Oct 2025
Upgrade to a later version of the software. V6.01.00RC4 that I have just posted seems robust so try that. Then do the OPTION RESET HDMIUSBI2S and you should get
OPTION KEYBOARD US
OPTION PICO OFF
OPTION RESOLUTION 640x480 @ 252000KHz
OPTION DISPLAY 24, 80
OPTION SDCARD GP29, GP30, GP31, GP32
OPTION AUDIO I2S GP10,GP22', ON PWM CHANNEL 11
OPTION COUNT GP0,GP1,GP2,GP3
OPTION MODBUFF ENABLE  512
OPTION PLATFORM HDMIUSBI2S
OPTION HEARTBEAT PIN GP25
Posted: 11:52am
22 Oct 2025
walshpj64
Awesome thanks, could not find V6.01.00RC4 but found V6.01.00RC5
unzipped and uploaded PicoMiteHDMIUSBV6.01.00RC5.uf2 OK. Noticed the heartbeat led did not start but the console session worked after dip switched restored and restarted.
did the  OPTION RESET HDMIUSBI2S
and WOW Yes all the following happened. Only issue is the USB devices will not work. No green LEDS and keyboard not working. SD CARD works though which is a bonus.
PicoMiteHDMI MMBasic USB RP2350B Edition V6.01.00RC5
OPTION KEYBOARD US
OPTION PICO OFF
Posted: 11:58am
22 Oct 2025
walshpj64
Just found the USB problem. Programming cable was still plugged in. Now All good Much appreciated.
Posted: 11:58am
22 Oct 2025
Make sure you have unplugged the micro-usb and plugged in a USB-C to provide power. Also make sure the switches are both set to on
Posted: 06:27am
24 Oct 2025
karlelch
I just ordered 5 boards (the latest PicoMiteHDMIUSB design from Peter) from JLCPCB. I don't need 5, so I would be happy to give 2-3 away for the cost price (~40 €) to people in Germany/ the EU.
© JAQ Software 2025
