JAQForum Ver 19.10.27
   Page 12 of 27
Posted: 06:03pm
24 May 2026
toml_12953
  matherp said
To change the backlight you would need to change he code to match whatever the correct Basic calls are to do it.
I'm testing on a SSD1963_5_BUFF and everything works as expected.
Since the LCD backlight isn't controlled by a GP pin on PicoCalc, I had to change line 229 to read:
Option Backlight LCD CtrlVal(sb_bright)
Of course, the change remains after the program ends so if you want the backlight to be unaffected by the program after it ends, you can save the current value when the program starts and restore it when the program ends.
Posted: 06:14pm
24 May 2026
mozzie
G'day Peter,
As Phil said, this will keep many playing until late...
This is very close to perfect, HDMI Touchscreen with GUI controls is 99% working, bit() is working again and pos stays as pos.
During the process of writing a long and complicated response regarding the problem you have already updated a fix for, now I have read it and its time for bed.
Thanks again for making all this possible.
Regards, Lyle.
Posted: 06:26pm
24 May 2026
terekgabor
Is it possible somehow to get actual values of LCD/KBD backlight with PicoCalc?
Posted: 08:40pm
24 May 2026
  Quote  Is it possible somehow to get actual values of LCD/KBD backlight with PicoCalc?
Yes, it is what you set it to.
Or in other words: NO.
MMBasic can't spoon feed everything. If you set the backlight to 30 then it is 30. It isn't reasonable for the interpreter to include more and more code and get bigger and bigger to tell the user what they have themselves done.
Posted: 09:55pm
24 May 2026
When ever you manually set the backlight follow with VAR SAVE.
Make the last line of the program VAR RESTORE.
You could also put VAR RESTORE etc. in MM.STARTUP and save to the library to start with your preferred level.
To ensure you never have a blank screen check if the restored value is too low and set a default.
Posted: 01:43am
25 May 2026
JanVolk
Not working properly after WebMite MMBasic RP2350A Edition V6.03.00RC10.
> memory
Program:
  0K ( 0%) Program (0 lines)
192K (100%) Free
Saved Variables:
 16K (100%) Free
RAM:
  0K ( 0%) 0 Variables
  0K ( 0%) General
240K (100%) Free
WebMite MMBasic RP2350A Edition V6.03.00RC11
[CYW43] error: hdr mismatch 0300 ^ feff
        [CYW43] error: hdr mismatch 0d1c ^ fff7
           [CYW43] do_ioctl(2, 263, 1008): timeout
                                                  [CYW43] STALL(0;1-1): timeout
        [CYW43] CLM load failed
WebMite MMBasic RP2350A Edition V6.03.00RC12
Jan.
Posted: 03:29am
25 May 2026
toml_12953
  matherp said  The test and flow rate work if you use D and U
pointer trail shouldn't happen if the screen framebuffer is being read properly. Does PicoCalc properly wire the screen MISO and is it properly configured in the options?
I don't know if you did something specifically to fix it but now the Web version works with both WiFi and PSRAM active and there's no trail left by the mouse cursor in the GUI demo.  Thanks for a great job!
Posted: 05:43am
25 May 2026
mozzie
G'day,
This may be obvious to those with better MMbasic skills but posting it here in case anyone else spends hours trying to figure it out.
The setup is a 5" HDMI-Touch monitor being fed HDMI video from a PicoMiteHDMIUSB with a Pico-Zero connected to the XPT2046 touch panel sending co-ordinates back via the USB-CDC connection.
The Touch co-ordinates are recieved and an interrupt sub (RX_INT) parses the X/Y data and sets CLICK X,Y this is where the fun started.
It appears that if you set CLICK or CLICK X,Y in an interrupt sub (RX_INT) it doesn't fire the TOUCH routine on return. Strangely the GUI elements react as if touched but do not perform there function.
Next step, set CLICK DOWN in the RX_INT sub, this fires the first GUI element but no others.
Add CLICK UP at the end of the TOUCH_INT sub, this works for normal GUI elements but not the NUMBERBOX KEYPAD, only first key touched.
Add CLICK UP at the start of RX_INT now makes everything work but you can tell its a cludge, putting CLICK UP anywhere else or timing it doesn't seem to work.
The final solution was to set a flag in RX_INT and do CLICK X,Y in the main program loop and it all just works, although possibly only with the updated V6.03.00RC12
A question, can you set GUI CURSOR X,Y and call the TOUCH INTERRUPT SUB directly or will that cause headaches?
Regards, Lyle.
Posted: 05:55am
25 May 2026
mozzie
G'day Peter,
A minor niggle, the GUI CONTROLS option is not shown in OPTION LIST on PicoMiteHDMIUSBV6.03.00RC12, keep forgetting to set it on update.
Regards, Lyle.
Posted: 07:20am
25 May 2026
  Quote  A minor niggle, the GUI CONTROLS option is not shown in OPTION LIST
Will fix, works for PicoMite, just not VGA/HDMI
  Quote  It appears that if you set CLICK or CLICK X,Y in an interrupt sub (RX_INT) it doesn't fire the TOUCH routine on return. Strangely the GUI elements react as if touched but do not perform there function.
This can't work. I will include code so that any attempt to use gui click/up/down from inside an interrupt routine generates an error and document accordingly
If you really really need to queue an interrupt from within an interrupt routine you could configure an I/O pin with gui click pin and loop another pin to it then set the other pin in the interrupt. This will then queue the interrupt.
  Quote  Not working properly after WebMite MMBasic RP2350A Edition V6.03.00RC10.
Haven't got a RP2350A web board to test with but works perfectly on a rp2350B. Will be mid next week before I can test on a Pico2-W
Edited 2026-05-25 17:30 by matherp
Posted: 08:39am
25 May 2026
homa
In principle, that's correct, but unfortunately, with the PicoCalc, the user can adjust the brightness—and thus the value—using the keyboard. That's why it's definitely worth reading this value within the program.
Up until now (<RC9), I wasn't able to dim the screen (turn off the backlight) when I set the value to 0. Is that possible now?
Posted: 09:21am
25 May 2026
  Quote  Up until now (<RC9), I wasn't able to dim the screen (turn off the backlight) when I set the value to 0. Is that possible now?
No idea, for the PicoCalc I just incorporated the routines from Ernst and borrowed a unit while I got it all working. As to the behaviour of the stm32 and what it can or can't do - I've no idea. You should assume that the PicoCalc integration is fixed and final although it will benefit from ongoing normal firmware changes.
Posted: 12:02pm
25 May 2026
toml_12953
Why not try it and see?
Option Backlight LCD 0
only makes the backlight very dim. It doesn't turn it off.
Edited 2026-05-25 22:03 by toml_12953
Posted: 03:58pm
26 May 2026
homa
  matherp said  Minor re-compile to fix gui click not triggering the MMBasic down/up interrupts
PicoMiteRP2040V6.03.00RC12.zip
PicoMiteRP2350V6.03.00RC12.zip
> option list
PicoMiteHDMI MMBasic USB RP2350A Edition V6.03.00RC12
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION KEYBOARD US
OPTION RESOLUTION 640x480 @ 252000KHz
> option reset hdmiusb
PicoMiteHDMI MMBasic USB RP2350A Edition V6.03.00RC12e - are you sure (Y/N) ? y
OPTION SYSTEM I2C GP20,GP21
OPTION KEYBOARD US
OPTION RESOLUTION 640x480 @ 315000KHz
OPTION DISPLAY 24, 80
OPTION SDCARD GP22, GP26, GP27, GP28
OPTION AUDIO GP10,GP11', ON PWM CHANNEL 5
OPTION RTC AUTO ENABLE
OPTION MODBUFF ENABLE  192
OPTION PLATFORM HDMIUSB
Formatting the A: drive
> US USB Keyboard Connected on channel 1
> USB Mouse Connected on channel 2
There's something wrong with this version. There's no picture! My monitor is showing H = 00 kHz and V = 00 Hz!?!
Is anyone else having this problem on the HDMIUSB reference board? I've also run "flash_nuke.uf2"
Matthias
Posted: 04:08pm
26 May 2026
Will look at it Wednesday next week, can't test til then - sorry. In the meantime use a previous version
Posted: 04:25pm
26 May 2026
homa
Matthias
SORRY – I’ve got too many cables on my desk, and I actually picked up the wrong one.   **Shame on me**. It’s cost me an hour of my time, though.
  matherp said  Will look at it Wednesday next week, can't test til then - sorry. In the meantime use a previous version
Yes, I did, and then I wondered why there was no picture on the one that had last been working
Matthias
Posted: 04:28pm
26 May 2026
homa
My break went on too long. But unfortunately, work called.
Now, in RC12, when running the GUI demo on the HDMIUSB reference board, I get the following error message:
> run
[82] GUI Caption c_head, "Pump Control", 10, 0
Error : No memory allocated for GUI controls
What do I need to change here?
OPTION GUI CONTROLS 50
Edited 2026-05-27 02:30 by homa
Posted: 04:46pm
26 May 2026
option gui controls 50 is correct. Doesn't show on option list at the moment - will do soon.
Posted: 05:13pm
26 May 2026
ville56
  Quote  * `sb_bright` — feeds its value (10–100 in steps of 10) straight to
the firmware `Backlight` command. On firmware without a controllable
backlight, `Backlight` is a no-op.
not quite ... in version
PicoMiteHDMI MMBasic USB RP2350B Edition V6.03.00RC12
this throws an error:
[219] Backlight CtrlVal(sb_bright)
Error : Unknown command
an "on error skip" in the line before cures this but the backlight command is not a no-op if not applicable.
Posted: 04:28am
27 May 2026
toml_12953
Is OPTION HEARTBEAT OFF supposed to be permanent?  I use it and the heartbeat is off until I do a power cycle. Then it's back on again.
This is on a PicoCalc using the Pimoroni Pico Plus 2 W and Web version of RC12.
   Page 12 of 27
