JAQForum Ver 26.09
   Page 13 of 52
Posted: 11:49am
17 May 2020
nickskethisniks
Hi, don't know if it's a good suggestion or already to late, but maybe we can have the option to solder the wires directly to the pcb. Screw terminals are good for debugging and changing boards, but once up they will stay there. :)
Something like this:
If I understand correctly we just need an auxiliary 12V power supply, I'm thinking of using more stuff like this in the future:
https://www.tme.eu/be/nl/details/ddr-15l-12/voedingen-op-din-rail/mean-well/
They should be more reliable  then the Chinese supplies, although they are probably designed/produced in China as well. Now finding one with the right input range, or adding a Zener in series with it.
Or could we design a simple supply ourselves?
Posted: 12:21pm
17 May 2020
wiseguy
Hi Nicks, I will provide a 4mm plated through hole and masked off area.
I had thought of this but was alittle concerned about impedance, but maybe a brass or nickel/brass screw soldered from the underside or screw and nut soldered both sides of the PCB facing upwards would allow a terminal and another nut screwed down to fasten it effectively ?
Another PCB update coming shortly Peter.....
Posted: 12:41pm
17 May 2020
poida
I like solder onto PCB. Just a preference.
Posted: 01:56pm
17 May 2020
mason
Poida, if you parallel two or three of these will you need two or three control boards or can you just use one?
Posted: 02:36pm
17 May 2020
nickskethisniks
You can order 2 boards for me Peter.
Thanks in advance.
Posted: 12:19am
18 May 2020
poida
Manson, I think each board needs a controller. By all means experiment with parallel if you like. I find it easier to see how things work if there are one or more self contained boards, doing what they individually are required to do.
Limit output current, maximise output power, look after battery voltage limits etc.
Posted: 01:12am
18 May 2020
mason
Thanks for the info Poida.
Posted: 12:06am
19 May 2020
poida
The brainboard is completed for Wiseguy's PCB of the converter.
Through hole components.
WG's PCB
Edited 2020-05-19 12:44 by poida
Posted: 03:04am
19 May 2020
poida
Ordered 25 of both boards.
Posted: 08:19am
19 May 2020
Boards are looking nice.
Some 470uf 200v capacitors can be scrounged from (about half a dozen) old ATX power supplies, if need be.
Posted: 08:21am
19 May 2020
poida
that's the whole idea!
Posted: 10:54am
19 May 2020
mason
Poida, I'll take a couple sets if there are some left, tried to pm you a couple days ago but don't think it worked.
Posted: 02:56pm
19 May 2020
tinyt
Hi Poida,
If it is not yet too late, I would like to have a set. Thanks.
Posted: 01:33am
20 May 2020
poida
Tinyt: For sure you can have 2. I ordered 25, which is 5 extra. Now it's 3 extra.
Mason: I have 2 for you as well. I included your 2 in the total of 20.
Posted: 01:45am
20 May 2020
ryanm
How would you like to get payment poida? If I can get a acc no & bsb I can direct transfer the money.
Posted: 01:56am
20 May 2020
mason
Thanks Poida, when you have time let me know what I owe you.
They will be posted to Canada, Ontario.
Posted: 02:07am
20 May 2020
poida
Once I get the boards I will know post and packaging costs. They will go into a good quality postpack (internal bubble wrap, tough outer cardboard).
Last time when I did the nanoverter board, I sent PMs to the recipient after I posted since only then did I know the cost.
Posted: 11:35pm
20 May 2020
renewableMark
Probably need a list of components to order.
Control board
Electro caps 10uf x6 16v?
2k2 x2
1k x6
10k x2
U1 ?
P1 10 pin socket like here
Nano
header pins like here
Power board
13x 470uf electro caps 200v or above.
The rest on the board isn't marked with values.
Choke, I was thinking this but they are out of stock for a while
These are in stock but dearer
Posted: 12:00am
21 May 2020
Mark, make absolutely certain those 470uF electrolytics are of the correct physical size, and have the right footprint.
Posted: 12:34am
21 May 2020
poida
U1 is a 7805 linear regulator (TO-220)
The chokes I am developing the project with are based on
1 of the expensive ones  with zero gap a
and another of them with a 1mm gap.
I have 7 1/2 turns, giving about 47uH
This inductor with 1mm gap and 7 1/2 turns saturates at about 80A or 90A
from testing with the pulse inductor test rig.
I have not seen saturation at 2200W at 57V input for the prototype charge controller.
This ends up costing more than 4x the ones out of stock but that's the way it goes.
I was happy to spend $52 on a choke if it prevented the inverter blowing up.
Now I build inverters using 2 of these chokes in series.
RS have stock of these which are the same size, zero gap but less Al rating, 8700 instead of 9700. Maybe good enough, certainly good enough if you use 2 in series.
   Page 13 of 52
