At the end of the program perhaps:- END "OPTION HEARTBEAT ON" |
Hi, can I ask what about the current status of the Shared Memory functions? I can't seem to get that working at between two RP2350A devices. FW is PicoMiteHDMI MMBasic RP2350A Edition V6.03.00RC10 The connection is established but no data is transfered. > list pins GP0 1 OFF: Reserved for function GP1 2 OFF: Reserved for function GP2 4 OFF: Reserved for function GP3 5 OFF: Reserved for function GP4 6 OFF: Reserved for function GP5 7 OFF: Reserved for function GP6 9 OFF: Reserved for function GP7 10 OFF: Reserved for function GP22 29 OFF: Reserved for function I used the demo program from the forum where one device does a gui test lcdpanel and the example from "MEMORY_SHARE_User_Manual.pdf" |
It should work but I haven't tested recently. Are both RP2350s running at the same cpu speed?. |
Yes, they do: Host: > option list PicoMiteHDMI MMBasic RP2350A Edition V6.03.00RC10 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION KEYBOARD US OPTION PICO OFF OPTION RESOLUTION 640x480 @ 252000KHz Client: > option list PicoMiteHDMI MMBasic RP2350A Edition V6.03.00RC12 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION KEYBOARD US OPTION RESOLUTION 640x480 @ 252000KHz |
V6.03.00RC14 PicoMiteRP2040V6.03.00RC14.zip PicoMiteRP2350V6.03.00RC14.zip Add USB touch support. Should work on any USB build but obviously really makes sense for VGAUSB and HDMIUSB builds. If you have the screen and a USB build please test and let me know if it works on your display. Use the normal TOUCH(X), TOUCH(Y), TOUCH(UP), TOUCH(DOWN) functions to interrogate the screen. Later I will add support for multi-touch reporting and possibly limited gesture support. Edited 2026-05-28 01:27 by matherp |
Peter, the Webmite 2350 is still not running, after flash comes up with WebMite MMBasic RP2350A Edition V6.03.00RC14 Copyright 2011-2026 Geoff Graham Copyright 2016-2026 Peter Mather [CYW43] error: hdr mismatch 0300 ^ feff a few times and then loops with an error [CYW43] STALL(0;1-1): timeout Gerald |
Hi Peter, there are some problems with the editor on the resolution 720 (HDMI) others are not tested. I also tested the GUI Touch function with my china 7" "no name" touch display. It is properly recognized and works just perfect! I LOVE this option! I uploaded a video to my Dropbox, you can see the GUI working with touch and the editor problem (in the end) + my "OPTION LIST". Video (dropbox) Again: It is wonderful to have a combination of HDMI / VGA and Touch, as well as GUI with Mouse! Greetings Daniel |
Peter, there is still a minor but annoying bug with the LINE command: e.g. on a 320x240 display the command LINE 100,100,300,400 produces a line as expected but anlong the bottom (highest Y-value) border there are dots drawn as artefacts. This only happens with linewidth 1. Does not happen with e.g. LINE 100,100,400,400 or other 45 degree lines. The LINE AA command does not show this artefacts. Lines over any border are cut off cleanly, as far as I found out yet. Seems to be in any build AFAIK. Gerald |
Where can I find the description of the base$( function? This may have been added with V6.03.00RC12, or have I possibly missed something? Jan. |
This is what it has always done in all versions of MMbasic AFAIK. The code caps the x and y at MM.HRES/MM.VRES-1. The question has been asked and answered multiple times before. It would be a huge change to fix as every display driver does the same thing and there are dozens of them. there are some problems with the editor on the resolution 720 (HDMI) others are not tested. The system has an algorithm which decides which status line to used based on screen width - looks like it needs improvement. ![]() The Pimoroni Pico Plus 2W works perfectly (without psram enabled) so it can't be anything too difficult but I can't test/diagnose until after Wednesday next week when I have access to a normal Pico-2W Edited 2026-05-28 03:58 by matherp |
It's not an official definition but I played around with it and came up with this: BASE$(base,number) converts a number in base 10 to the specified base. Base must be in range 2 to 36 Example: ? BASE$(2,6300) 1001110110 ? BASE$(16,157) 9D To quickly change from base 2, 8 or 16 to another base: ? BASE$(16,VAL(&O77)) Convert from base 8 to base 16 3F Edited 2026-05-28 06:31 by toml_12953 |
true, but my hope was it would be easy to solve as it only occurs with linewidth=1 |
The CMM2 doesn't move off-screen pixels from lines and draw them on the edge of the screen. Instead, they never appear. This can result in confusion if you unintentionally draw lines off-screen and see no results - it appears as a bug in the MMBasic firmware, and not in your own code. If you are curious, here are some of the routines that are used as the low-level code to put pixels on the various displays. (There are more in other files.) All of these, except for the one noted in "SPI-LCD.c", clamp the x & y coordinates to the screen. Also, I only saw one routine that uses a "clamp()" function - all the rest have in-line code. That's a lot of instances that would need changing. Curiously, the circle command is not affected. Draw.c void DrawRectangle555(int x1, int y1, int x2, int y2, int c) void DrawRectangle256(int x1, int y1, int x2, int y2, int c) void DrawRectangle2(int x1, int y1, int x2, int y2, int c) void MIPS16 DrawRectangleUser(int x1, int y1, int x2, int y2, int c) SSD1963.c void DrawRectangleSSD1963(int x1, int y1, int x2, int y2, int c) SPI-LCD.c void DrawRectangleSPI(int x1, int y1, int x2, int y2, int c) // doesn't clamp pixels void DrawRectangleSPISCR(int x1, int y1, int x2, int y2, int c) void DrawRectangleMEM(int x1, int y1, int x2, int y2, int c) void DrawRectangleMEM332(int x1, int y1, int x2, int y2, int c) // uses clamp() |
Peter, I still have not come closer to the PIO "not working" issue in MINI600300rc9. I checked all registers of the PIO for initialization failures (such as &h50300008, even modified some during PIO running, to get to a solution. But have no clue yet. And the pattern is consistent. A new pico (hardware) shows the problem, and after some diagnosis, PIO starts working, and that pico is "repaired". It never shows the problem anymore. And I am running out of virgin pico's. I tried converting a repaired one back to an older version, nuke flash, and re-install 60300rc9. But the pico keeps working (as far as I have tested). I have seen this on - GEEK (has OPTION PICO OFF) - Pico zero (has OPTION PICO OFF) 3x - RP2040 Game*Mite with genuine RP2040 pico - Bare RP2040 boards (2x) I will do a test soon with RC14 (hoping it accidentally fixed) since I have one more genuine Pico Zero. Volhout P.S. could it be related to some speed optimizations in MINI60300rc9, where PIO FIFO becomes cached ? But how can it "repair". No idea. |
Harm, please post a program that demonstrates the problem. I think I have a virgin pico at home. Does it happen on rp2040 and rp2350 or only one? Is it only on PICOMITEMIN or normal PICOMITE as well? Edited 2026-05-29 18:40 by matherp |
G'day Peter, Some quick testing with a Pico Computer USB-HDMI-Mk1 and 7" HDMI / CAP touch, the following message is displayed on plugging it in: > Multi-touch Screen Connected on channel 4 (10 contacts, 1024x600) But no touch is registered with the following code: 'prog to test USB touch Option default integer GUI Cursor on GUI Cursor Link Mouse GUI interrupt TouchDown,TouchUp Do If Touch(down)=1 Then Print Touch(x),Touch(y) EndIf Loop Until Inkey$<>"" End Sub TouchDown Print "Touched" End Sub Sub TouchUp Print "Untouched" End Sub The keyboard and mouse work as expected and the mouse buttons generate interrupts / touch events. Display is WaveShare 70H-1024600-QLED-CT-B (SKU22684) 7" 1024x600 5 point cap touch, unfortunately they don't specify the touch chip in the online data and it is buried under tape on the board. Not sure why it is reporting 10 point touch when only advertised as 5 point? Is there any way we can interrogate from the PicoMite? This unit works fine plugged into my WIN7-32bit PC. > option list PicoMiteHDMI MMBasic USB RP2350A Edition V6.03.00RC14 OPTION SERIAL CONSOLE COM2,GP8,GP9 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION MOUSE SENSITIVITY 1.0000 OPTION KEYBOARD US OPTION RESOLUTION 1024x768 @ 375000KHz OPTION DISPLAY 32, 64 OPTION GUI CONTROLS 96 OPTION DEFAULT FONT 3, 1 > Away driving trucks again for the next 2 days so may not be able to test further until Monday. Regards, Lyle. |
Hello! Is there any way to use GP25 (heartbeat) as a normal output with Webmite? I read not, but what is the reason? Can somehow solve it? Thx, G@bor |
@Peter, Just tested the last Pico Zero with 2040_V60300 MIN rc14. After programming, load following program. On terminal, it should show 0's until you connect a quadrature encoder signal to GP0/GP1. In stead it shows a random number, and with encoder connected, it does not increment. The set to zero is by executing directly a PIO command in SM0, while the program is running. It feels a bit as if the PIO program is not running at all. A running program would constantly shift data in FIFO. Note: this PIO program runs from address &h10 (not zero). In case you connect a stepper motor to GP2...5 (direct drive the 4 coils with an ULN2003) it follows the rotary encoder changes. Option default integer 'system initialisation ------------------------------------------------------- 'init the stepper control pins initio ' variables for stepper Dim phases(7)=(&b0001,&b0011,&b0010,&b0110,&b0100,&b1100,&b1000,&b1001) Dim steps2go=0, quadra, quadra_old, delta 'set the max speed of the stepper at 1ms per step (1kHz) SetTick 1,step_it 'program PIO 1 program_PIO 'program the code in PIO 1 'start quadrature decoder start_sm0 'start decoder on GP0 and GP1 zero_sm0 'zero quadrature 'main program loop -------------------------------------------------------- Do 'read PIO FIFO for quadrature changes quadra = read_fifo(0) 'debug print str$(quadra,12,0) 'get data from decoder 'add delta fifo since last read to stes2go (pos or neg) delta=quadra_old-quadra:quadra_old=quadra Inc steps2go,delta*8 '8 = software gain 'add delta fifo to servo pos 'send delta to UART Pause 100 Loop While Inkey$="" PIO stop 1,0 PIO clear 1 End ' subroutines --------------------------------------------------------------- 'zero counter state machine 0 Sub zero_sm0 PIO execute 1,0,&hA023 '= assembly "mov X, null" (zero X reg) End Sub 'this function returns the actual count of decoder n Function read_fifo(n) As integer Local dat%(3) PIO read 1,n,4,dat%() 'read whole fifo read_fifo = dat%(3) 'last data in fifo If read_fifo>2147483647 Then Inc read_fifo,-4294967296 '2'th complement End Function 'this subroutine programs the quadrature decoder program for PIO1 into PIO program memory Sub program_PIO 'this is the PIO program in machine code dim p%(7)=(&h001A00170015001A,&h0015001A001A0017,&h0017001A001A0015, &h001A00150017001A,&h4042A0404042A0C3,&hA029001A005AA0A6,&h8000A0C1A0290059,0) 'here the program is programmed in memory PIO program 1,p%() wrap=27 'end of the program wrp_tgt=16 'start of the program loop End Sub 'this subroutine starts state machine 0 quadrature decoder on gp12 and gp13 Sub start_sm0 'uses GP0,GP1, assign pins in MMBasic SetPin gp0,pio1 SetPin gp1,pio1 'quadrature decoders generic settings PIO_f%=63e6 'frequency = 63MHz PIO_s%=0 'shift register (shift in left) PIO_e%=Pio(execctrl gp0,wrp_tgt,wrap) 'start and stop of the loop 'assign pins in PIO pin_sm0%=Pio(pinctrl 0,0,0,gp0) 'configure and start PIO PIO init machine 1,0,PIO_f%,pin_sm0%,PIO_e%,PIO_s%,wrp_tgt PIO start 1,0 End Sub 'inits stepper output signals on GP2...5 Sub initio 'init stepper pins to dout and low For i=2 To 5 SetPin "GP"+Str$(i),dout :Pin("gP"+Str$(i))=0 Next End Sub 'moves the stepper until step2go is zero Sub step_it Static ps=0 Local dn If steps2go<>0 Then Inc steps2go,Choice(steps2go<0,1,-1) dn=Choice(steps2go<0,7,1) Inc ps,dn:ps=ps Mod 8 Port(GP2,4)=phases(ps) End If End Sub The code may look more complex than needed, but it is because the quadrature was stolen from the 4 encoder software for Phenix. Up to now I have not fiddled with this Pico Zero, so it still fails. Some of the failing pico's I have programmed with V60201 release, and then it all works. Volhout. P.S. Just checked, the normal 2040 V60300 rc14 works fine. It is just the MIN version. And when I go back from the normal version to the MIN version, PIO refuses to work again. . . Edited 2026-05-30 05:29 by Volhout |
No,it is the chip select pin for the CYw43 |
Lyle Later today I'll post a version with some added diagnostics. If you could run this and capture the output that should help to understand why the Waveshare is misbehaving. The way the code works is to read the report descriptor of the device and then use that to interpret the actual touch reports. This tries to be general but is obviously missing something. Unlike for a I2C or SPI touch chip, the actual touch chip shouldn't matter because the report descriptor should give the firmware the information it needs to correctly decode the position reports |
