JAQForum Ver 19.10.27
   Page 18 of 52
Posted: 05:34pm
31 Mar 2025
electricat
HDMI/USB/2350 RC8
Being in Picomite editor, I made too long line (you know, when you are editing and spliting too long lines then joining again) I needed dummy data for some test ~ 240 symbols in string variable.
After F2, system message informed :Not enough memory"
On return to editor all program lines below that too long line were completely deleted.
Had some hope to see full program again after power cycle, but no joy.
2 hrs lost
So this was bad traps next time remember to avoid.
Easy to rpelicate with or without program loaded.
I understand, what I did, but did not expected such drastic punishment
Did not tested what would happen if too long line created in notepad++ and loaded.
It`s. OK for me. Will be carefull next time.
Posted: 07:51pm
31 Mar 2025
@Peter,
RC8 on one of your  latest ‘reference design’ PCBs (I2S HDMI USB) and am seeing an error (screenshot below) with ‘LIST PINS’.
Note I seem to remember this being reported already so maybe you’ve fixed it but not for RC8?
Edited 2025-04-01 05:52 by WhiteWizzard
Posted: 09:16am
01 Apr 2025
@Peter,
Played with RC8 last night on 2040 VGA PS2 platform and found absolutely nothing.
Everything worked stable. Ran the (stack/heap hungry) MMBasic chess program over night, and no issues.
We have a winner here.
I will see if this week I get to put it on as 2350 USB/HDMI platform and see how that performs (although I have the opinion many /have done/are doing/ that already).
I assume Tom will try this on his Game*Mite platform. There may be need for some tweaking since the A:/ drive got a bit smaller.
Posted: 10:03am
01 Apr 2025
Harm: thanks for the report - good news. I just need to post the LIST PINS fix and we should be good to go for 6.00.02
Posted: 10:12am
01 Apr 2025
bfwolf
I hope, you left the new "FRAME" command out for this release, so it couldn't introduce new incompatibilities/bugs?
https://www.thebackshed.com/forum/ViewTopic.php?PID=236676#236676#236691
And my idea for a "ON CONOUT target" was also for a possible future release..
https://www.thebackshed.com/forum/ViewTopic.php?PID=236676#236676#236676
Greetings and many thanks again for your (and Geoff's) great work so far!
bfwolf
Posted: 06:56am
02 Apr 2025
mozzie
G'day Peter,
Have finally been able to load V6.00.02 on to a Pico and have a play, so far so good with everything thrown its way.
The new byte / bit commands mentioned in the intro sound like a great addition, especially to those who have come across from PICs / PLCs etc.
The BYTE command / function lists and works as shown in the example.
The Bit command / function are not listed, however FLAG() is listed but have been unable to test any further.
As others have mentioned, subs/funcs written and stored in the library for bit manipulation work but having it built in would be far superior, and I imagine faster.
My thanks once again for the time and effort put in to this truly great project by all involved.
Lyle.
P.S. Library routines:
Modbit, Sub, Set = Variable
SetBit, Sub, Set
ClrBit, Sub, Clr
TogBit, Sub, Toggle
ChkBit, Fun, Check bit status
These are modified versions from "Fruit of the Shed".
Posted: 06:59am
02 Apr 2025
Library routines run a bit faster than the same routines in the main program. That's a bonus. :)
Posted: 07:01am
02 Apr 2025
  Quote  The Bit command / function are not listed, however FLAG() is listed but have been unable to test any further.
Forgot to mention. I've got rid of the bit command and replaced it with the FLAG command and function
FLAG(n)=0/1 'n=0 to 63
? FLAG(n)
This gives you 64 flag bits without having to allocate a variable
Posted: 07:10am
02 Apr 2025
@Peter, others,
Did any of you have problems (using v6.00.02RC8) with XMODEM SEND ?
I am using MMEdit/MMCC and it is happy to work with RC8. Except the MMCC filemanager, that throws block errors when transferring data from Pico to PC.
So XMODEM RECEIVE has no problems, but XMODEM SEND has.
Anyone experience the same ?
This is on 2040 VGA PS2 version.
Posted: 07:12am
02 Apr 2025
mozzie
G'day,
@Mick
Thanks Mick, wasn't aware of that so I'll embed more in the library in future.
@Peter,
Thanks Peter, I imagine 64 should be heaps for nearly all use cases.
Is the FLAG variable accessible in any other way? just curious...
Lyle.
Posted: 07:37am
02 Apr 2025
  Quote  Is the FLAG variable accessible in any other way? just curious...
No: that's the whole point. As it is an internal value it makes the command much faster. I could add an MM.FLAGS to return all the bits if it would be of any use
Edited 2025-04-02 17:47 by matherp
Posted: 07:41am
02 Apr 2025
Re Xmodem Send,  haven't got a 2040 VGA PS2 version setup at the moment but it works with a 2350 VGA PS2 version. Tested with both MMCC File Manager & Tera Term.
Posted: 07:42am
02 Apr 2025
ville56
at least not on
PicoMite MMBasic RP2350A Edition V6.00.02RC8
tried file sizes between 1kb and 1 Mb, no problems
Gerald
Posted: 07:52am
02 Apr 2025
  Quote  So XMODEM RECEIVE has no problems, but XMODEM SEND has.
Just tested 70K file in RP2040 VGA to teraterm - both from A: and from loaded program  - works fine
Posted: 08:05am
02 Apr 2025
About XMODEM SEND:
Thanks for your quick response, I will do some more testing.
Also tried duplicate the problem on a GEEK (2040) but have not seen it.
See if I can find out a bit more. After a re-power of the VGA unit it went away (all works fine now). Maybe something I did before the XMODEM caused this problem.
I will try to trace back my steps...
Edited 2025-04-02 18:08 by Volhout
Posted: 10:33am
02 Apr 2025
V6.00.02RC9 is available on
Fixes bug in LIST PINS
Removes BIT command and BIT functions
Adds
? FLAG(n)
? MM.FLAGS
This gives you 64 flag bits without having to allocate a variable. MM.FLAGS returns the value of all 64 flag bits. NB: this will appear as a negative integer is flag 63 is set. All flags are set to zero when a program is run.
Posted: 10:51am
02 Apr 2025
dddns
Beside that I can confirm, that after more than 20 hours playing with RC8, it runs rock solid at 360Mhz. Just tried shortly and the PGA2350 also runs at RESOLUTION 640,378000
Hello,
after now 60 hour net usage time I can confirm that it runs solid on a PGA2350 at RESOLUTION 800 in MODE 3. I was testing framebuffer usage so I think, that PSRAM is involved all the time. I also attached a SSD1963 to it some time ago testing BLIT and using PSRAM in full extend. This never showed a problem but on VGA and RC8 the problem persist that it crashes continuously when exiting the editor.
Now I like to use this editor very much! And these crashes make me
But as nobody has confirmed yet, I will take it as it is.
Editor: I have a wish, would it be possible to have "find and replace"? And the question if there is a way, to copy/paste more than one line?
edit:
..I'll test RC9 immediatly
Edited 2025-04-02 20:55 by dddns
Posted: 11:06am
02 Apr 2025
  Quote  This never showed a problem but on VGA and RC8 the problem persist that it crashes continuously when exiting the editor.
Please post your full option list and a program that when you edit causes a crash
Posted: 11:06am
02 Apr 2025
Hi dddns,
Use MMEDit (on Windows or Linux). It has find/replace.
Posted: 11:18am
02 Apr 2025
Copy/paste more than one line: Use F4 to mark a block of text.
Manual pages 19/20
Once you have copied a block you can paste it multiple times.
There's no find/replace in the internal editor but you can jump to the next found point very fast with <shift>F3.
I'm another fan of the internal editor. I've loved it since I first used it on the Micromite. :)
Edited 2025-04-02 21:20 by Mixtel90
   Page 18 of 52
