| Menu | JAQForum Ver 26.09 |
Forum Index : Microcontroller and PC projects : PicoMite V6.00.01 release candidates - please test thoroughly
Hi Mark, These games are in my local archive. A link to the archive is also in the PicoMite VGA thread. Once 6.00.01 is released I will validate and update these games again to create a stable foundation for 6.00.01. Note these are tested on RC1, not RC9. local archive Volhout P.S. I will look into your other problem later Edited 2024-12-21 05:42 by Volhout |
Hi Mark, A program on disk is nice readable ASCII code. When a program is put in FLASH is is in binary (tokenized) form. The FLASH DISK LOAD function loads binary data from DISK into the binary FLASH. But if you load an ASCII file into FLASH using FLASH DISK LOAD you cannot execute it, since it is not tokenized. The normal way to put a program into FLASH is: LOAD "Blocks.bas" 'to load it into RAM FLASH SAVE 3 'this converts the AsCII program to binary, and stores it into FLASH you can now execute the program with FLASH RUN 3 Volhout Edited 2024-12-21 06:14 by Volhout |
Hi Peter, In the 2040 VGA rc9 this does not work anymore (eats heap). 'start endless music now Play volume 50,50 'adjust for best gameplay (0-100) restartplay 'start music (endless loop) 'timed interrupt to restart the gameboy tetris tune when ended (1:16 duration) Sub restartplay Play wav "tet16cut.wav",restartplay 'start music, and restart when end End Sub The WAV file is large (2.4Mbyte). This is the background music for Geoff's Blocks. Result is that the next command (and IF/THEN) cannot find the return (the THEN). blocks local zip Any idea ? I it worked on 2350 VGA rc9, but not 2040. Volhout Edited 2024-12-21 06:52 by Volhout |
Volhout, Thanks for the link to your archives. As for the flash issue, thanks for the explanation, it does indeed work your way. Mark |
iv is optional because the firmware has a value built in but it isn't all zeroes as that website assumes. To match the website you have to specify it as all zeroes to override the internal default. Dimming an array iv% sets it to zeroes > list 'TEST aes128 cbc ' Dim integer out2(15) key$ = "1234567812345678" in$ = "1234567890123456" 'iv$ = "1234567812345678" iv$ = String$( 16, 0 ) 'nbr, ascii ' Math aes128 encrypt cbc key$,in$,out2(),iv$ Math v_print out2(), hex > run 74, 74, A4, 9E, 44, 98, B2, 49, D8, F6, 2E, F4, CF, 55, 41, A9 > Yes, then it is a match :-) Is this IV defined in the firmware? Or is it generated as a hash from the KEY? For transparency and security reasons, I would be interested to know how the default value is generated. Thank you very much! |
Peter, I suspect it would be better if the default IV were 0 rather than being an arbitrary constant in the firmware. YMMV, Tom |
From http://www.ietf.org/rfc/rfc3602.txt. 2.1. Mode NIST has defined 5 modes of operation for AES and other FIPS-approved ciphers [MODES]: CBC (Cipher Block Chaining), ECB (Electronic CodeBook), CFB (Cipher FeedBack), OFB (Output FeedBack) and CTR (Counter). The CBC mode is well-defined and well-understood for symmetric ciphers, and is currently required for all other ESP ciphers. This document specifies the use of the AES cipher in CBC mode within ESP. This mode requires an Initialization Vector (IV) that is the same size as the block size. Use of a randomly generated IV prevents generation of identical ciphertext from packets which have identical data that spans the first block of the cipher algorithm's block size. The IV is XOR'd with the first plaintext block before it is encrypted. Then for successive blocks, the previous ciphertext block is XOR'd with the current plaintext, before it is encrypted. More information on CBC mode can be obtained in [MODES, CRYPTO-S]. For the use of CBC mode in ESP with 64-bit ciphers, see [CBC]. ... 3. ESP Payload The ESP payload is made up of the IV followed by raw cipher-text. Thus the payload field, as defined in [ESP], is broken down according to the following diagram: +---------------+---------------+---------------+---------------+ | | + Initialization Vector (16 octets) + | | +---------------+---------------+---------------+---------------+ | | ~ Encrypted Payload (variable length, a multiple of 16 octets) ~ | | +---------------------------------------------------------------+ The IV field MUST be the same size as the block size of the cipher algorithm being used. The IV MUST be chosen at random, and MUST be unpredictable. Including the IV in each datagram ensures that decryption of each received datagram can be performed, even when some datagrams are dropped, or datagrams are re-ordered in transit. To avoid CBC encryption of very similar plaintext blocks in different packets, implementations MUST NOT use a counter or other low-Hamming distance source for IVs. A random iv is the correct way to go. Jim |
Jim Very interesting. I'd assumed the IV was like a second key that had to be known by the recipient but including it in the message makes much more sense. I'll make the changes to the encrypt code to use a random IV unless overridden and get rid of the IV option on the decrypt as I will include it in the message as the first block. Does the same approach apply to CTR encryption? |
Sorry Peter, I have now exceeded my knowledge of encryption. It just happens that PureBasic help had the link to the RFC so I could appear smarter than I really am. PureBasic decrypt does have the IV field so don't throw it away totally just yet. The problems will be when you are trying to communicate with something other than another picomite. Jim |
Please test the attached. RP2040 base version PicoMite.zip MATH AES128 All coding can now accept arrays of any length (subject to memory). Strings for encrypting are limited to 240bytes (EBR) and 224bytes (CTR and CBC) For CTR and CBC encryption an output array, if used, must now be 16 elements BIGGER than the input. You can optionally specify an initialisation vector, otherwise a random vector is created. For CTR and CBC decryption an output array, if used, must now be 16 elements SMALLER than the input (which now includes the IV). Therefore you no longer specify the initialisation vector for decoding as this is now included in the message as the first block New functionality MATH(BASE64 ENCRYPT/DECRYPT in$/in(), out$/out()) This base64 encrypts or decrypts the data in 'in' and puts the result in 'out'. This is a function that returns the length of the 'out' data. Where arrays are used as the output they must be big enough relative to the input and the direction so encryption increases length by 4/3 and decryption decrease it by 3/4 e.g. Dim a$="1234567890",b$,c$ ? math(base64 encrypt a$,b$) ? b$ ? math(base64 decrypt b$,c$) ? c$ |
The message is correct. Heap memory is full. Variable space for simple variables consumes the other 48K In this case, the bad thing is that the MEMORY command does not display this. Is it possible to introduce a separate display of the HEAP memory and the simple variable memory separately? Also, when developing programs and configuring PicoMite, it would be good to have a built-in PINS command displaying information about their current state? Edited 2024-12-21 22:23 by javavi |
mm.info(heap) tells you how much is free For the pins use the MMbasic subroutine Local n,gp$,p,pu$ For n=0 To Choice(Instr(MM.Device$,"RP2350B"),47,29) gp$ = "GP"+Str$(n) p = MM.Info(pinno gp$) pu$ = MM.Info(pin p) Print gp$, p, pu$ Next End Sub That has a huge amount of C-code behind it which I am not going to replicate when it is so easy in Basic |
I found some (for me) interesting information about the IV. and wikipedia What I can see (AFAIK) is that the IV (initialization vector) can be embedded as plain text in the encrypted file or is supplied with the key and is supposed to be random. Thoughts on that? Michael |
Yesterday: Talking to yourself or thinking out loud How are the input values for AES actually filled according to the standard if they are not multiples of 128 bits? Ok, it needs a bit of padding ... https://www.cryptosys.net/pki/manpki/pki_paddingschemes.html Because of the Base64 question I found this ... https://fruitoftheshed.com/wiki/doku.php?id=mmbasic:base64_mime_encode_and_decode_functions Incidentally, is it planned and possible to use 'LONGSTRINGs' sometime? Then, for example, a really small password management system is not far away... Peter is already delivering today :-) It's amazing! All that remains is the question of long strings. |
and wikipedia What I can see (AFAIK) is that the IV (initialization vector) can be embedded as plain text in the encrypted file or is supplied with the key and is supposed to be random. Thoughts on that? Michael In any case, you need to know IV, otherwise you cannot decrypt the secret on another system, even if you know the key! Matthias |
My earlier reference to rfc3602 had a dot at the end. The correct link should be https://www.ietf.org/rfc/rfc3602.txt The more I read, the more confusing it gets... Jim |
Hi Peter, There is a serious issue with PLAY WAV on RP2040 VGA 6.00.01rc9 On the commandline you can type PLAY WAV "yoursong.wav" and it plays. In a program you can not. Below is a minimal code to show the problem. It uses the tetris sound for Blocks. PLAY WAV "tet16cut.wav" if a=0 then print "a" This errors with "Error : IF without THEN" and does not play any sound. Volhout Edited 2024-12-22 06:58 by Volhout |
2350 hdmi usb is ok ![]() Edited 2024-12-22 07:36 by stanleyella |
Do you still have an RP2350 version? At the moment I only have these on the playing field. |
Just need to finish off some work on AES128 and then I'll look at it. Pretty sure I know what the issue will be - firmware has outgrown the space allocated so programs are overwriting the firmware |
