JAQForum Ver 19.10.27
   Page 2 of 26
Posted: 08:25pm
05 May 2026
Geoffg
This is a typical example of floating point error.  Calculation errors in floating-point math are not "bugs" in the language but a fundamental limitation of storing infinite decimals in finite space.
The issue here is that 0.1 cannot be represented exactly in binary. Every time you press a key, a tiny rounding error is added to a. Eventually, you’ll see values like 0.3000000000000001 or 0.6999999999999999.In BASIC dialects (like MMBasic), the most reliable fix is to calculate with integers and scale the output for the display.
Posted: 09:18pm
05 May 2026
Some examples of programming around it often use a small value - search on epsilon (or floating point epsilon) as that's what it tends to be called.
Posted: 09:42pm
05 May 2026
DaveJacko
Thanks for beautify, Peter,
great help for hobbyists with older brains and eyes
along with fred777 and toml,
I do think that leaving blank lines intact for readability would be better
(more blank lines, for emphasis)
thanks, Dave
Posted: 05:37am
06 May 2026
terekgabor
@matherp
Peter!
Just a small idea. Can be good if we can use string variable (not only unquoted constant string) for object names in STAR and ASTRO commands.
Better way to build up a kind of epheneris program for example.
G@bor
Posted: 06:50am
06 May 2026
ville56
@Peter,
Beautify spoils labels ... in the attached code, after edit/^A/F2 there are spaces in front of the label b_loop: inserted and the code does fail with
[11] If in_str <> "" Then GoTo b_loop
Error : Cannot find label
Interestingly, there are seemingly 2 character positions inserted but if there is only one char to remove. The code runs again if the inserted chars (or char?) are removed.
Version is:
PicoMite MMBasic RP2350B V6.03.00RC1
failing code is:
 OPTION EXPLICIT
 OPTION DEFAULT NONE
 Option tracecache on 128
 b_test("test")
end
 ' ------------ END main ----------------------------------
sub b_test(in_str as string)
b_loop:
 print "in b_loop"
 pause 300
 if in_str <> "" then goto b_loop
end sub
Posted: 07:22am
06 May 2026
Will fix in next RC. I also want to fix the behaviour of program with line numbers. Please can someone post a fully line numbered example for me to test with. Intended behaviour will be:
The F12 Beautify command aligns code using 2-space block indentation. It detects whether a program is line-numbered by examining the first non-comment line:
If that line begins with a line number, the whole program is treated as numbered. All statements are aligned past the widest line number found, and block indentation is added on top of that base column.
Otherwise, the program is treated as unnumbered. Any stray numbered lines used purely as GoTo/GoSub targets will be pushed flush to the left margin and will not align with the surrounding block, since they are handled like labels.
Recommendation: in modern, mostly-unnumbered programs prefer named labels (e.g. retry:) over numeric line numbers as branch targets. Labels are also forced flush left by Beautify, but they read more clearly, are not confused with numbered-program formatting, and keep the rest of the block visually consistent.
The F12 Beautify command forces any line that begins with a label to column 0 — including anything written after the label on the same line — so a construct such as:
retry: Print "x"
will lose the indent of its surrounding block. Writing the label on a line by itself keeps both the label visible at the margin and the following code correctly indented within its Sub, For or If block.
When F12 Beautify is pressed and the program already contains blank lines other than those separating subroutines/functions, the editor asks KEEP BLANK LINES? (Y/N). Choose Y to preserve your blank lines (consecutive blanks are collapsed to one); choose N to strip them all. Either way, a single blank line is always ensured after every End Sub / End Function. Press Esc at the prompt to cancel.
Edited 2026-05-06 18:58 by matherp
Posted: 08:58am
06 May 2026
V6.03.00RC2
PicoMiteRP2040V6.03.00RC1.zip
PicoMiteRP2350V6.03.00RC1.zip
Fixes to Beautify as described above
Posted: 09:22am
06 May 2026
terekgabor
Peter!
File names hasn’t changed to RC2.
G@bor
Posted: 09:23am
06 May 2026
fred777
Getting there
  matherp said  the editor asks KEEP BLANK LINES? (Y/N). Choose Y to preserve your blank lines (consecutive blanks are collapsed to one); choose N to strip them all. Either way, a single blank line is always ensured after every End Sub / End Function. Press Esc at the prompt to cancel.
but as DaveJacko says
thanks, Dave
Lets try to overcome that irrational fear of empty lines.
Empty lines are the quiet breaths of a program—
the pauses where thought gathers before becoming logic.
They are the whitespace between heartbeats,
where structure reveals itself not by what is written,
but by what is allowed to rest.
In their silence, complexity untangles.
In their absence, even brilliance feels crowded.
An empty line is a small act of kindness
from one mind to the next—
a reminder that clarity is not only about words,
but about the space that lets them be understood.
Posted: 09:40am
06 May 2026
RC2 with correct filenames, also fixes bug in comment lines not being removed in the library. Programs in the library should be re-loaded.
PicoMiteRP2040V6.03.00RC2.zip
PicoMiteRP2350V6.03.00RC2.zip
Posted: 10:53am
06 May 2026
toml_12953
  matherp said  Will fix in next RC. I also want to fix the behaviour of program with line numbers. Please can someone post a fully line numbered example for me to test with. Intended behaviour will be:
retry: Print "x"
10 DIM X(126),K(2)
20 FUNCTION FNA(X,Y,Z): FNA=X*SIN(Y*0.01745329)*Z-16*Z^2: END FUNCTION
30 PRINT "INPUT MUZZLE VELOCITY (FT/SEC) AND ANGLE (DEGREES)"
40 LET F2=0
50 INPUT M,A
60 LET X(0)=0
70 FOR T=0.2 TO 25 STEP 0.2
80 LET L=INT(5*T+0.001)
90 LET X(L)=FNA(M,A,T)
100 IF X(L)<0 THEN GOTO 150
110 IF X(L)-X(L-1)<=0 AND F2=0 THEN GOTO 250 ELSE GOTO 350
120 LET K(1)=X(L-2)
130 LET W4=T-0.4+J
140 GOTO 280
150 LET W=L-1
160 FOR J=0.01 TO 0.2 STEP 0.01
170 LET K(1)=FNA(M,A,T-0.2+J)
180 IF K(1)<0 THEN GOTO 200
190 NEXT J
200 PRINT "MAXIMUM HEIGHT IS ";K1;" FEET"
210 LET Y=M*COS(A*0.01745329)*(T-0.2+J-0.01)
220 PRINT "RANGE IS ";Y;" FEET"
230 PRINT "TOTAL TIME AIRBORNE IS ";T+J-0.01;" SECONDS"
240 GOTO 360
250 IF X(L-1)-X(L-2)<X(L)-X(L-1) THEN GOTO 120
260 LET K(1)=X(L-1)
270 LET W4=T-0.2+J
280 LET F2=1
290 FOR J=0.01 TO 0.2 STEP 0.01
300 LET K(2)=FNA(M,A,W4)
310 IF K(1)-K(2)<=0 THEN GOTO 340
320 LET K(1)=K(2)
330 NEXT J
340 LET K1=MAX(K(1),K(2))
350 NEXT T
360 IF K1+10>60 THEN GOTO 470 ELSE LET M1=1
370 FOR D=1 TO 62
380 PRINT TAB(10);"+";
390 NEXT D
400 PRINT : PRINT "0";TAB(10);"+"
410 FOR N=1 TO W
420 PRINT 0.2*N*M*COS(A*0.01745329);TAB(10);"+";TAB(X(N)*M1+10);"*"
430 NEXT N
440 PRINT "ANYMORE (YES OR NO)";
450 INPUT A$
460 IF A$="YES" THEN GOTO 30 ELSE GOTO 500
470 LET M1=1/(INT(K1/60+1))
480 PRINT "SCALE OF HEIGHT IS 1 SPACE = ";1/M1;" FEET"
490 GOTO 370
500 END
Edited 2026-05-06 21:00 by toml_12953
Posted: 11:54am
06 May 2026
Thanks, output of B2, On the screen lines 20 to 90 are properly aligned but pasting to TBS removes this.
10  Dim X(126),K(2)
20  Function FNA(X,Y,Z): FNA=X*Sin(Y*0.01745329)*Z-16*Z^2: End Function
30  Print "INPUT MUZZLE VELOCITY (FT/SEC) AND ANGLE (DEGREES)"
40  F2=0
50  Input M,A
60  X(0)=0
70  For T=0.2 To 25 Step 0.2
80    L=Int(5*T+0.001)
90    X(L)=FNA(M,A,T)
100   If X(L)<0 Then GoTo 150
110   If X(L)-X(L-1)<=0 And F2=0 Then GoTo 250 Else GoTo 350
120   K(1)=X(L-2)
130   W4=T-0.4+J
140   GoTo 280
150   W=L-1
160   For J=0.01 To 0.2 Step 0.01
170     K(1)=FNA(M,A,T-0.2+J)
180     If K(1)<0 Then GoTo 200
190   Next J
200   Print "MAXIMUM HEIGHT IS ";K1;" FEET"
210   Y=M*Cos(A*0.01745329)*(T-0.2+J-0.01)
220   Print "RANGE IS ";Y;" FEET"
230   Print "TOTAL TIME AIRBORNE IS ";T+J-0.01;" SECONDS"
240   GoTo 360
250   If X(L-1)-X(L-2)<X(L)-X(L-1) Then GoTo 120
260   K(1)=X(L-1)
270   W4=T-0.2+J
280   F2=1
290   For J=0.01 To 0.2 Step 0.01
300     K(2)=FNA(M,A,W4)
310     If K(1)-K(2)<=0 Then GoTo 340
320     K(1)=K(2)
330   Next J
340   K1=Max(K(1),K(2))
350 Next T
360 If K1+10>60 Then GoTo 470 Else M1=1
370 For D=1 To 62
380   Print Tab(10);"+";
390 Next D
400 Print : Print "0";Tab(10);"+"
410 For N=1 To W
420   Print 0.2*N*M*Cos(A*0.01745329);Tab(10);"+";Tab(X(N)*M1+10);"*"
430 Next N
440 Print "ANYMORE (YES OR NO)";
450 Input A$
460 If A$="YES" Then GoTo 30 Else GoTo 500
470 M1=1/(Int(K1/60+1))
480 Print "SCALE OF HEIGHT IS 1 SPACE = ";1/M1;" FEET"
490 GoTo 370
500 End
Edited 2026-05-06 21:56 by matherp
Posted: 12:07pm
06 May 2026
twofingers
Just for fun:
' Projectile trajectory calculator
Dim Float x(126), k(2), m, a, t, l, f2, w, j, k1, m1, d, n, y, w4
Dim String answer
' Define height calculation function
Function CalcHeight(vel As Float, ang As Float, time As Float) As Float
 CalcHeight = vel * Sin(ang * 0.01745329) * time - 16 * time^2
End Function
 Input m, a
 f2 = 0
 x(0) = 0
 ' Calculate trajectory
 For t = 0.2 To 25 Step 0.2
   l = Int(5 * t + 0.001)
   x(l) = CalcHeight(m, a, t)
   If x(l) < 0 Then
     w = l - 1
     ' Peak search if ground hit
     For j = 0.01 To 0.2 Step 0.01
       k(1) = CalcHeight(m, a, t - 0.2 + j)
       If k(1) < 0 Then Exit For
     Next j
     Print "MAXIMUM HEIGHT IS "; k1; " FEET"
     y = m * Cos(a * 0.01745329) * (t - 0.2 + j - 0.01)
     Print "RANGE IS "; y; " FEET"
     Print "TOTAL TIME AIRBORNE IS "; t + j - 0.01; " SECONDS"
     Exit For
   EndIf
   ' Logic for finding peak or continuing
   If x(l) - x(l - 1) <= 0 And f2 = 0 Then
     If (x(l - 1) - x(l - 2)) < (x(l) - x(l - 1)) Then
       k(1) = x(l - 2)
       w4 = t - 0.4 + j
       f2 = 1
     Else
       k(1) = x(l - 1)
       w4 = t - 0.2 + j
       f2 = 1
     EndIf
     ' Refine peak calculation
       k(2) = CalcHeight(m, a, w4)
       If k(1) - k(2) <= 0 Then Exit For
       k(1) = k(2)
     Next j
     k1 = Max(k(1), k(2))
   EndIf
 Next t
 ' Charting Logic
 m1 = 1
 If k1 + 10 > 60 Then
   m1 = 1 / (Int(k1 / 60 + 1))
   Print "SCALE OF HEIGHT IS 1 SPACE = "; 1 / m1; " FEET"
 EndIf
 For d = 1 To 62
   Print Tab(10); "+";
 Next d
 Print
 Print "0"; Tab(10); "+"
 For n = 1 To w
   Print 0.2 * n * m * Cos(a * 0.01745329); Tab(10); "+"; Tab(x(n) * m1 + 10); "*"
 Next n
 Input answer
Loop Until UCase$(answer) <> "YES"
End
Posted: 12:10pm
06 May 2026
toml_12953
  matherp said  RC2 with correct filenames, also fixes bug in comment lines not being removed in the library. Programs in the library should be re-loaded.
LOAD"mybasprog" used to work. Now we need LOAD"mybasprog.bas"
Is that a conscious decision?
EDIT: On one of my PicoCalcs it still works the old way. I nuked both before loading RC2 so I don't know what's going on.
Edited 2026-05-06 22:26 by toml_12953
Posted: 12:27pm
06 May 2026
Still works for me
Posted: 04:00pm
06 May 2026
ville56
Peter,
is there any reason why a label has to start at position 1 in a line? Actually it cannot have any whitespace before the label name.
In V6.02.01 it works fine when a label has some leading spaces.
Posted: 04:00pm
06 May 2026
JanVolk
Is the display for MM.Info(version) still correct?
Print " "; MM.Info(device); MM.Info(version); MM.Info(option flash size)
 PicoMite RP2350A 6.03 4194304
> option list
PicoMite MMBasic RP2350A V6.03.00RC2
OPTION SYSTEM I2C GP20,GP21
OPTION FLASH SIZE 4194304
OPTION COLOR CODE ON
OPTION HEARTBEAT OFF
OPTION PICO OFF
OPTION CPU SPEED (KHz) 200000
OPTION DISPLAY 50, 100
OPTION RTC AUTO ENABLE
OPTION F1 help
OPTION F5 list commands
OPTION F6 list functions
OPTION F7 list pins
OPTION F8 list system i2c
OPTION F9 fm
Jan.
Posted: 04:13pm
06 May 2026
bfwolf
  ville56 said  Peter,
From the manual:
  Quote  A label is an identifier that marks part of the program. It must be the first thing on the line and it must be terminated with the colon (:) character.
The name that you use can be up to 31 characters long and must follow the same rules as for a variable's name. For example, in the following program line LoopBack is a label:
LoopBack: a = a + 1
So if it worked before, it was more likely "unintentionally".
bfwolf
Edited 2026-05-07 02:14 by bfwolf
Posted: 04:19pm
06 May 2026
toml_12953
  matherp said  Still works for me
I swapped the SD card between the systems and the problem followed. I formatted the problem SD card and copied all the files from the good one to it. Problem gone.
I have no idea what could have been happening but at least it's fixed for now.
Posted: 05:39pm
06 May 2026
javavi
@matherp Peter,
Since things are moving forward, can I ask too?
Is it possible to make a built-in calculator for PicoMite, using the CALC command?
A calculator like the one in PicoTop
https://github.com/7west/PicoTop
   Page 2 of 26
