JAQForum Ver 26.09
   Page 23 of 52
Posted: 11:45am
09 Apr 2025
toml_12953
  matherp said
  Quote  The Bit command / function are not listed, however FLAG() is listed but have been unable to test any further.
Forgot to mention. I've got rid of the bit command and replaced it with the FLAG command and function
FLAG(n)=0/1 'n=0 to 63
? FLAG(n)
This gives you 64 flag bits without having to allocate a variable
For a fast and easy lockup, try:
erase flag()
I know the syntax of the erase command doesn't allow parentheses, but they shouldn't lock up the interpreter.
Posted: 11:56am
09 Apr 2025
  Quote  I know the syntax of the erase command doesn't allow parentheses, but they shouldn't lock up the interpreter.
yes they should. If the interpreter tries to trap everything it will slow to a halt. This and many other things can cause a lockup. Press reset and it starts again and then you can fix your code.
Posted: 12:34pm
09 Apr 2025
58kk90
  Volhout said  Hi 58kk90,
This is RC8, and (just tested it) it still has the BIT command.
For me (RP2040 VGA user) this was a stable version. The only issue I found was with font 7. But as I learned later, the above I2C issue with 256 bytes exists in rc8.
6.00.02rc8
But I think (when you ask Peter politely) he may bring the BIT command and function back, in addition to the FLAGS.
Brilliant thank you very much, all downloaded and safely stored away.
I did ask the question of Peter in an earlier post, but never got a reply, nor did the others that asked a similar question after I did, hence assuming it was now taboo and not coming back.
Hopefully it will come back, as there is more than just me that wants it back from what I can see.
Thanks once again
Tony
Posted: 12:40pm
09 Apr 2025
58kk90,
Download RC11, and check if the BIT is working again.
Peter made a very quick fix, and BIT should work again. See 3 posts back.
I assume it is there to stay...
Thanks Peter!!!,
Posted: 04:37pm
09 Apr 2025
ville56
  matherp said  V6.00.02RC11 is available on
The Bit(ch) is back
+ > 255 i2c transfers should work - untested
Sorry Peter, I2C transfers > 255 still cause a hang.
N.B.: looking at the I2C bus protocol, all is normal, e.g. 256 bytes are tansfered and the transfer is normally terminated. Then the firmware "hangs", meaning no reboot but being completely unresponsive.
Edited 2025-04-10 03:03 by ville56
Posted: 04:40pm
09 Apr 2025
  Quote   I2C transfers > 255 still cause a crash.
Need some simple example code to test with
Posted: 06:44pm
09 Apr 2025
ville56
OPTION EXPLICIT
OPTION DEFAULT NONE
const i2c_addr = &H57     'any address will do, no matter if HW is connected
const xfr_size = 256      '<= 255 ok, > 255 crash/reboot or hang
dim integer eeprom_data(300)
i2c read i2c_addr, 0, xfr_size, eeprom_data()
end
Posted: 07:13pm
09 Apr 2025
circuit
The Bit(ch) is back
Peter, thank you.  I am delighted; as I was when this command/function first appeared.
Posted: 06:59am
10 Apr 2025
@Peter,
Tested on 2040 VGA design 2 with system I2C and RTC installed. RC11.
I2C ----------------------------------
DIM e%(300)
I2C2 READ &h57,0,255,e%()
Works
DIM e%(300)
I2C2 READ &h57,0,256,e%()
Does not work, crash (reboot).
MATH V_PRINT ------------------------
DIM e%(300)
MATH V_PRINT e%()
Crashes (reboot)
Posted: 07:13am
10 Apr 2025
electricat
Couldn`t resist
This is part of some code I wrote while testing new BIT & FLAG
Idea came to my restless head first time noticed new FLAG com/fn
EXX`changes pair of FLAG 'registers'
'feed stray cats!! =(^^)=
CLS
Dim flag_%
For n=0 To 63
Flag(n)=1
Next n
For n=0 To 63
Print Flag(n);
Next n
Print Chr$(10)+"EXX"+Chr$(10)
EXX
For n=0 To 63
Print Flag(n);
Next n
Flag(15)=1
EXX
For n=0 To 63
Print Flag(n);
Next n
EXX
For n=0 To 63
If n=15 Then
Color RGB(red),RGB(black)
Print Flag(n);
Color RGB(white),RGB(black)
Else
Print Flag(n);
End If
Next n
EXX
For n=0 To 63
Print Flag(n);
Next n
Sub EXX(flag_%)
Local swp%
Static tmp_exx%
Static tmp_ex%
For n=0 To 63
iisset%=Flag(n)
Bit(tmp_exx%,n)=iisset%
Next n
For n=0 To 63
iisset%=Bit(tmp_ex%,n)
Flag(n)=iisset%
Next n
swp%=tmp_exx%
tmp_exx%=tmp_ex%
tmp_ex%=swp%
End Sub
Posted: 07:26am
10 Apr 2025
I've found and fixed the I2C issue - uint8_t variable used as the loop counter. Will update the downloads later
Posted: 08:32am
10 Apr 2025
  Quote  MATH V_PRINT ------------------------
DIM e%(300)
MATH V_PRINT e%()
Crashes (reboot)
Perhaps it is device specific, ok on PicoMiteVGA MMBasic RP2350A Edition V6.00.02RC11 (first one)
> DIM e%(300)
> MATH V_PRINT e%()
116, 121, 32, 66, 97, 114, 102, 97, 114, 115, 116, 32, 84, 72, 69, 32, 66, 65, 67, 75, '------etc
Edited 2025-04-10 18:35 by phil99
Posted: 08:44am
10 Apr 2025
bfwolf
@Peter
Question about the Flag(n) "register": Is there a possiblility, to set/clr all (or multiple) flags in one step/assignment?
bfwolf
Posted: 10:07am
10 Apr 2025
RC11 updated if you re-download.
Should fix the I2C issue
Also adds
FLAGS=n 'set/clear all the flag bits as required
Edited 2025-04-10 20:07 by matherp
Posted: 11:24am
10 Apr 2025
ville56
I2C issue now fixed, thanks Peter. Great work.
Posted: 01:16pm
10 Apr 2025
@Peter,
RC11_2 on RP2040 VGA DESIGN 2 with RTC installed at GP14/15 (I2C2)
I2C problem is fixed, MATH V_PRINT issue is not fixed.
DIM e%(300)
MATH V_PRINT e%()
Error: Invalid address
Then crashes (reboot)
Posted: 01:57pm
10 Apr 2025
Completely unrelated to the I2C issue. Bug that's been in V_Print for some time.
Try this
PicoMiteRP2040VGAV6.00.02RC11.zip
Posted: 04:48pm
10 Apr 2025
Peter,
Yes that fixed it. Indeed have not used MATH V_PRINT since the thermal camera where I had to check if all the math worked as I expected. That would have been 6.00.00, even before the change to 6.00.01.
Thanks for fixing it. V_PRINT is a handy tool during development.
Posted: 04:53pm
10 Apr 2025
All versions in the download updated with V_PRINT fix. AFAIK no identified bugs in this version
Posted: 10:36pm
10 Apr 2025
toml_12953
  TassyJim said
  Quote  If that isn't suitable.
try
DIM a(3,2) and fill the second row/column with zeros
OPTION BASE 1
DIM a(3,3)
DIM i(3,3)
DIM b(2,3)
DIM c(2,3)
a(1,1)=1
a(2,1)=2
a(3,1)=3
a(1,2)=2
a(2,2)=4
a(3,2)=5
a(1,3)=3
a(2,3)=5
a(3,3)=6
b(1,1)=3
b(1,2)=4
b(1,3)=5
MATH M_INVERSE a(),i()
MATH M_PRINT a()
MATH M_PRINT i()
MATH M_PRINT b()
MATH M_MULT i(),b(),c()
MATH M_PRINT c()
FOR n = 1 TO 3
PRINT c(1,n)
NEXT n
RUN
  1.0000,    2.0000,    3.0000
  2.0000,    4.0000,    5.0000
  3.0000,    5.0000,    6.0000
  1.0000,   -3.0000,    2.0000
 -3.0000,    3.0000,   -1.0000
  2.0000,   -1.0000,    0.0000
  3.0000,    0.0000
  4.0000,    0.0000
  5.0000,    0.0000
  1.0000,    0.0000
 -2.0000,    0.0000
  2.0000,    0.0000
1
-2
2
For your purpose a second row of zeros seems to work
I think that you can use MATH INSERT and MATH SLICE to interface to singe dimension arrays
Silly me! The solution was staring me in the face all the time! Instead of a matrinx, I can use a vector:
10 OPTION BASE 1
15 DIM C(3),B(3,3)
25 DIM A(3,3)=(1,2,3,2,4,5,3,5,6), X(3)=(3,4,5)
30 MATH M_INVERSE A(),B()
45 MATH M_PRINT B()
50 MATH V_MULT B(),X(),C()
60 PRINT "SOLUTIONS ARE "
65 PRINT
70 MATH V_PRINT C()
100 END
   Page 23 of 52
