JAQForum Ver 19.10.27
   Page 27 of 52
Posted: 12:23pm
15 Apr 2025
@Peter,
This is a major step back....
Pro - Bubbles is another 10% faster (that is good).
Con - The filemanager does not show the highlight (focus) bar anymore..??
Con - Petrobot cannot find the image files..??
I stopped testing here.
This is after a Clear flash.
And full install.
P.S. just saw you found something wrong.
Edited 2025-04-15 22:24 by Volhout
Posted: 03:36pm
15 Apr 2025
OK: I think this is ready to test now. Certainly works with Petscii, LA_24_2, bubble, grainbench, and solar_eclipse
RP2040VGA
PicoMiteRP2040VGAV6.00.02RC14.zip
RP2350VGA
PicoMiteRP2350VGAV6.00.02RC14.zip
HDMIUSB
PicoMiteHDMIUSBV6.00.02RC14.zip
Edited 2025-04-16 01:42 by matherp
Posted: 05:24pm
15 Apr 2025
V6.00.02RC15 is available on
Thanks to bleep finding a very strange performance issue in his bubble universe code I've been able to track down an underlying day-1 inefficiency in the MMbasic memory handling. This release optimises around that and should give a performance improvement for most applications. The code change is very small and doesn't affect any functionality. I believe it to be robust but if you see anything strange please report your findings.
NB: there are known issues in 800x600 and 848x480 resolutions in RP2350 VGA and HDMI versions. I'm looking at this.
UPDATE Fixed at 18:05 UTC
Edited 2025-04-16 04:06 by matherp
Posted: 05:54pm
15 Apr 2025
toml_12953
  matherp said  V6.00.02RC15 is available on
This was a problem in WebMiteRP2350V6.00.02RC14 and is still a problem in RC15. When I run the logtable below, the processor reboots at about 9955.
110 LET W=0
120 FOR X=1 TO 9
130 PRINT X;
140 FOR Y=0 TO 9
150 LET Z=(10*X+Y)*.1
160 IF ABS(10^W-Z)>.001 THEN 210
170 LET T=INT(10000*W)
190 PRINT TAB(6*Y+4);T;
200 GOTO 230
210 LET W=W+.0001
220 GOTO 160
230 NEXT Y
240 PRINT
250 NEXT X
260 END
Here's my OPTION LIST:
WebMite MMBasic RP2350A Edition V6.00.02RC15
OPTION FLASH SIZE 4194304
OPTION LIBRARY_FLASH_SIZE  34000
OPTION COLOURCODE ON
OPTION CASE UPPER
OPTION TAB 8
OPTION KEYBOARD US
OPTION CPUSPEED (KHz) 252000
OPTION LCDPANEL VIRTUAL_C
OPTION WIFI MySpectrumWiFie0-2G, **************, PICORP2350
Edited 2025-04-16 03:59 by toml_12953
Posted: 06:02pm
15 Apr 2025
toml_12953
Another problem I'm having is that, when I left-click my mouse in TeraTerm (VT100), I get this:
Copyright 2011-2025 Geoff Graham
Copyright 2016-2025 Peter Mather
PICORP2350 connecting to WiFi...
Connected 192.168.1.144
ntp address 172.234.37.140
got ntp response: 15/04/2025 14:01:09
>[M &)[M#&)[M !!
Edited 2025-04-16 04:08 by toml_12953
Posted: 06:12pm
15 Apr 2025
  Quote  Another problem I'm having is that, when I left-click my mouse, I get this:
Those are the escape sequences the mouse is generating. Did you reboot while in the editor? Enter the editor and then exit cleanly and it should then be OK
  Quote  When I run the logtable below, the processor reboots at about 9955.
Put some diagnostics in and work out which command is causing the problem and what the variables are at the time - then report. Sounds like a overflow or divide by zero or similar that isn't being trapped
Can't replicate
Edited 2025-04-16 04:26 by matherp
Posted: 06:39pm
15 Apr 2025
toml_12953
I'm using a Dell wireless mouse connected to my Core i9 ASUS motherboard. The PicoMite 2W is connected via a USB 3.0 port.
When I turn TRACE ON, before the processor resets, I get the message:
Error: Invalid address - resetting
If I change line 170 to
T=INT(99*W)
the program completes. If I change it to INT(100*W), the crash occurs.
W=0.9956, x=9, y=9, z=9.9, t=99
In the statement
170 T=INT(nn*W)
Any number, nn, over 99 makes the crash occur.
Original program:
110 LET W=0
120 FOR X=1 TO 9
130 PRINT X;
140 FOR Y=0 TO 9
200 GOTO 230
210 LET W=W+.0001
220 GOTO 160
230 NEXT Y
240 PRINT
250 NEXT X
260 END
Posted: 06:48pm
15 Apr 2025
Don't understand. As per my previous post the program as you listed it works fine for me 170 LET T=INT(10000*W)
Posted: 06:54pm
15 Apr 2025
Bleep
Hi Peter,
I have been able to test all the 3 builds you did around 4pm, from above, 2040VGA, 2350VGA, HDMIUSB all appear to work great with the programs I've tested.
There is a definate improvement in speed, in the 2350 builds, however I am seeing really great speed ups in 2040 programs, In one case a loop timer, which used to give  607mS is now giving 415mS and another version was giving 683mS now gives 425mS so between 50 and 60% speed up, it seems especially good when using frame buffers, I never could understand why frame buffers were so much slower on a 2040, now they are not!.
Thanks for persuing this Peter.
Regards Kevin.
Posted: 07:05pm
15 Apr 2025
toml_12953
Reboot problem discovered!
The problem was that I had
OPTION ESCAPE
SUB MM.END
 PRINT "\n\nEND PROGRAM\n"
END SUB
in the library. I don't know why that should cause a program crash but when I removed it from the library, the logtable program stopped crashing.
When I put that in the program itself, it crashed again.
Even a null sub with no print statement in it
SUB MM.END
END SUB
will make the program crash.
Edited 2025-04-16 05:12 by toml_12953
Posted: 08:06pm
15 Apr 2025
homa
> option list
PicoMiteHDMI MMBasic USB RP2350A Edition V6.00.02RC15
OPTION SYSTEM I2C GP20,GP21
OPTION KEYBOARD GR
OPTION CPUSPEED (KHz) 283200
OPTION RESOLUTION 720x400
OPTION DISPLAY 33, 90
OPTION SDCARD GP22, GP26, GP27, GP28
OPTION AUDIO GP10,GP11', ON PWM CHANNEL 5
OPTION RTC AUTO ENABLE
OPTION MODBUFF ENABLE  1024
OPTION PLATFORM HDMIUSB
In the editor, when exiting with ESC, at the confirmation prompt, there is a shift in the text display.
Posted: 08:38am
16 Apr 2025
@Peter,
RC15 looks good up til now. From the MMBasic chess program (that shows C-stack) I have the impression it uses slightly more C-stack, but never the less, chess runs still fine. Have tested 2040 VGA only up to now.
Edited 2025-04-16 18:39 by Volhout
Posted: 08:46am
16 Apr 2025
  Quote  This was a problem in WebMiteRP2350V6.00.02RC14 and is still a problem in RC15. When I run the logtable below, the processor reboots at about 9955.
This was a bug that I've now fixed and will be in the next version. I asked Cortana to rewrite your code in "modern" Basic and this is the result
W = 0
For X = 1 To 9
   Print X;
   For Y = 0 To 9
           Z = (10 * X + Y) * 0.1
           If Abs(10 ^ W - Z) <= 0.001 Then
               T = Int(10000 * W)
               Print Tab(6 * Y + 4); T;
               Exit Do
           End If
           W = W + 0.0001
   Next Y
   Print
Next X
End
  Quote  RC15 looks good up til now.
Good news. I was pretty hopeful as the change is very minor but the small bit of code was complex to get right. The way it works is that variable data grabs memory from the top of the heap down and previously temporary system data did the same. Now system data grabs memory from the bottom of the heap up. System data is inherently more transient so the search for memory is much faster if it doesn't have to compete with static variables (arrays, framebuffers etc.)
  Quote  In the editor, when exiting with ESC, at the confirmation prompt, there is a shift in the text display.
Now we are really splitting hairs
This is because height of 400 (720x400) doesn't divide by the font height of 12. Geoff's original code places the status line characters by reference to the bottom of the screen. This doesn't work for tile colouring and I adjusted the placement to be n characters down the screen but missed that one. Will fix in the next RC (or will that be the release?)
  Quote  I have been able to test all the 3 builds you did around 4pm, from above, 2040VGA, 2350VGA, HDMIUSB all appear to work great with the programs I've tested.
Great: You may find RC15 is a little bit faster again
Edited 2025-04-16 20:10 by matherp
Posted: 01:05pm
16 Apr 2025
homa
Due to the many RCs, this version has been put through its paces. Hopefully a good stable version for further development. I'm already looking forward to the text framebuffer.
Edited 2025-04-16 23:07 by homa
Posted: 01:12pm
16 Apr 2025
PhenixRising
  matherp said  I asked Cortana to rewrite your code in "modern" Basic
Thank you
Posted: 01:26pm
16 Apr 2025
mace
Hi!
Something is different in PORT command in versions picomite_firmware v5.08.00 and picomiterp2040v6.00.01.
Test:
Port(gp4,4)=15 in V5 Works ok.
Port(gp4,4)=15 in V6 not working right.
Something changed between versions?
Posted: 01:36pm
16 Apr 2025
This is known bug and is noted in the bug list on Geoff's site. Use the latest RC and it is fixed
Posted: 01:39pm
16 Apr 2025
circuit
Test:
I have just tried it in v.5.08.00 and in version 6.00.02RC15 and it works identically.  No problems observed.
Edit. And Peter answered it in the couple of minutes that I took to test.
Edited 2025-04-16 23:41 by circuit
Posted: 01:54pm
16 Apr 2025
Bleep
Hi Peter,
I have now loaded RC15 onto a 2040 VGA USB, 2350 VGA, 2350 HDMI USB, no problems found, in my tests this version is *very* slightly slower than the previous RC14 with the memory fix, about the sort of difference you see between different compiles.
For example Basic Chess, running Bench to 2 ply 2040 VGA was taking 2:05 (two minutes and 5 seconds), now 2:07, Solar Clock 26.6mS now 26.8mS so basically nothing, compared to the memory fix gains.
All in all looking great. Thanks. :-)
Kevin.
Posted: 02:05pm
16 Apr 2025
toml_12953
W = 0
For X = 1 To 9
   Print X;
   For Y = 0 To 9
               T = Int(10000 * W)
               Exit Do
           End If
           W = W + 0.0001
   Next Y
   Print
Next X
End
Thanks for spending time on this. For new programs, I write them that way myself but I have literally thousands of legacy BASIC programs. I'm pretty old so if I converted 10 programs a day, I wouldn't have time to convert them all!
   Page 27 of 52
