JAQForum Ver 19.10.27
Forum Index : Microcontroller and PC projects : PicoMite 6.03.00 betas
   Page 3 of 6
Posted: 05:33pm
26 Apr 2026
The manual example worked for me on a RP2350B Pimoroni Plus W as did Geoff's watering controller (much bigger program)
What options have you got set? Try lowering the cpuspeed if above 200MHz. The RP2350B Pimoroni Plus W doesn't seem to like overclocking, or at least mine doesn't.
Posted: 05:50pm
26 Apr 2026
terekgabor
I lowered the CPU speed to 200MHz, same problem.
Options attached.
If I put End before json$ the program stops normally.
And from command prompt I can print json$, but in the program causes restart.
G@bor
Posted: 06:07pm
26 Apr 2026
Have you got a standard pico2-W you can test with?
Posted: 06:13pm
26 Apr 2026
terekgabor
Yes I have, and first I have to step back to B1 for a try. Then nuke again and B2 again.
I tried print json$(…) and also xy$=json$(…) in the program , restart immediately.
I also try to relocate this section of the program without success.
G@bor
Posted: 06:38pm
26 Apr 2026
List your version of the program - leave the code out I've got my own
Posted: 06:45pm
26 Apr 2026
terekgabor
Peter!
first test: I did step back to B1, no problem with it.
Then upgrade again to B2, problem came.
second test: I cut this part from my "big" program to a new one - only some lines I attached. Not working wiht B2, when reaches last line json$, restarting.
Same options,same Picocalc, same Pimoroni Pico Plus 2 W
test2.zip
If I will have time today I will change to normal Pico 2 W, if not I think next day is Thursday - I will leave for a business trip.
G@bor
Posted: 07:21pm
26 Apr 2026
terekgabor
Peter!
Third test: I put ‘end’ in the test2.bas program before the last line (which is containing json$).
Program ran without error. Then try Print json$(wthr(),”timezone_offset”) or also tzo$= json$(wthr(),”timezone_offset”) from command prompt. System restarted in both case. I think something with json function can cause this.
G@bor
Posted: 07:13am
27 Apr 2026
G@bor
Please try this version which has the cache functionality disabled and should be pretty much identical to B1
PicoMite.zip
The issue is almost certainly the build running out of C heap but I don't know why.
Edited 2026-04-27 17:14 by matherp
Posted: 08:55am
27 Apr 2026
@Peter - I had one of your 64-pin DIL modules running B1 this morning so decided to upgrade to B2.
I first ‘nuked’ it, then installed B2 (‘boot’-‘reset’ presses to get the module ready for the B2 .uf2.
The upgrade went as expected, but when checking the A: drive, I saw that the previous contents were still in tact.
Shouldn’t Nuke have totally cleared the whole Pico?
To add also that I loaded a .bas from A: (the one that was still unexpectedly there) and it ran perfectly!?!
Edited 2026-04-27 19:13 by WhiteWizzard
Posted: 09:39am
27 Apr 2026
Maybe the clear flash you used obly erases 2Mbyte, not 16...
Posted: 02:18pm
27 Apr 2026
terekgabor
Hello Peter!
Thanks! I can try it later in the week. I am on a business trip just now.
I will feed back immediately.
G@bor
Posted: 02:56pm
27 Apr 2026
PhenixRising
  matherp said  V6.03.00B1
PicoMiteRP2350V6.03.00B1.zip
Implements DO UNTIL condition .... LOOP
Fixes various bugs in the editor.
Fixes B0 bugs in the optimiser
Expands the scope of the optimiser significantly
Whoa...Whoa...Whoa
What the heck???
Older version NO optimizing: 16000/sec
Older version WITH optimizing: 12000/sec
V6.03.00B1 WITH optimizing:37000/sec
Awesome, many thanks Pete
Posted: 08:40pm
27 Apr 2026
JanVolk
Peter,
The freezing problems and issues with I2CLCD no longer occur after some hardware adjustments.
I switched to a standard Raspberry Pi Pico 2 and soldered the I2C pull-up resistors directly onto the Pico module due to the poor connections on the breadboard.
I also have a Raspberry Pi Pico 2 W on which I had mounted female connectors with long pins, which caused poor contact, so I replaced these with male long pins.
I am currently running a test with PicoMite MMBasic RP2350A V6.03.00B2 and PicoMite MMBasic RP2040 V6.03.00B2.
The program is far from finished, and I can continue working.
Thanks for your input and also for the great new developments in PicoMite MMBasic.
Jan.
Posted: 02:05am
28 Apr 2026
ville56
@Peter,
in the example attached below, the
select case asc(in_char)
is not properly executed if option tracecache is enabled
Option profiling on
Option tracecache on
Option EXPLICIT
Option DEFAULT NONE
Dim string in_char
On key key_isr
If Asc(in_char) = 13 Then End
Sub key_isr
'Local string in_char
in_char = Inkey$
Print Asc(in_char)
Select Case Asc(in_char)
 Case 10,13
 Print "cr/lf"
 Case Else
 Print "other char"
End Select
End Sub
environment is:
PicoMite MMBasic RP2350B V6.03.00B2
OPTION FLASH SIZE 16777216
OPTION COLOURCODE ON
OPTION PICO OFF
OPTION CPUSPEED (KHz) 292000
OPTION DISPLAY 40, 145
OPTION SDCARD GP9
OPTION PSRAM PIN GP8
NB: it works with SELECT CASE if TCF_IF is selectively set to 0. Otherwise only the CASE ELSE path is taken.
Edited 2026-04-28 16:05 by ville56
Posted: 09:14am
28 Apr 2026
ville56: thanks for the report - will look at it. It may be a few days as MMBasic is in bits at the moment with the attempt to get to B3.
Posted: 11:15am
28 Apr 2026
ville56
Thanks Peter, no hurry. MMBasic is still a hobby and not a professional project and I really admire what you have accomplished with MMBasic until now and the journey still goes on. Just incredible!!!
Gerald
NB: I wish all the professional (and really expensive) pieces of software I had to use during my 40-year IT-career had that kind of profound quality and quick support as you give. And I am talking about the big blue and grey companies. I'm not saying they were awfully bad in support, but you somehow play in your own league.
Posted: 10:36pm
28 Apr 2026
homa
@Peter
A small request or suggestion for improvement. When programs are launched via FM and finish running, the screen unfortunately clears immediately and returns to FM. It would be nice to have an option to wait for a key press first, so you can read the text or view the output in general if necessary. Perhaps this behavior could even be selected with an “OPTION CLI-WAIT ENABLE/DISABLE” or something similar.
Matthias
Posted: 03:38am
29 Apr 2026
EDNEDN
Yes.   An option would be nice.    But it would also be nice to have some keyboard behavior that overrides the option.
I know it is too much to hope for.   But if the option was "no wait, and close out the screen",   It would still be nice to have the file manager recognize the program was launched with a Shift_Enter (or any other convenient modified Enter) and override the default and wait.
Posted: 07:20am
29 Apr 2026
Do:Loop While Inkey$=""
Posted: 03:56pm
29 Apr 2026
homa
I had a feeling this would happen.
After all, we're lazy and don't want to have to update this in every single program.
But OK, you're the lead developer.
   Page 3 of 6
