JAQForum Ver 26.09
Forum Index : Microcontroller and PC projects : Homemade Pico Computer 3 clone
   Page 4 of 6
Posted: 03:57pm
16 Aug 2026
It's still in the tweaking stage at the moment. Since that picture I've tidied up some traces that I wasn't happy with, moved the fuse to a cooler place, moved the Heartbeat link (which was colliding with the RTC), moved the VUSB light, tucked resistors under the hub to tidy things up and added a diode for the HDMI 5V feed.
It's coming along nicely but I've spotted something else I'd like to change a bit...
Posted: 05:05pm
16 Aug 2026
dddns
@Doktorn
Is your build done with the Waveshare Core2350B Core Board?
Posted: 06:59pm
16 Aug 2026
Doktorn
@dddns
Yes it is the Waveshare CoreBoard, ( step A2 )
Posted: 08:20pm
16 Aug 2026
JanVolk
A simple test program to measure the core temperature and possibly apply cooling with a cooling plate or fan.
> save "core temperature.bas
> run
> F1=help F2=run F3=list F4=edit F5=clear F9=fm Ctrl+C=stop
> OPTION CPUSPEED xxx000 (kHz) 48-348 MHz for RP2350B + PSRAM
The room temperature :? 26.2
The core temperature of the PicoMite RP2350B is 47.2°C at 348 MHz at room 26.2°C
The core temperature of the PicoMite RP2350B is 45.8°C at 348 MHz at room 26.2°C
> list
Dim Float temp, Tin
Print "> F1=help F2=run F3=list F4=edit F5=clear F9=fm Ctrl+C=stop"
Print "> OPTION CPUSPEED xxx000 (kHz) 48-348 MHz for RP2350B + PSRAM"
Input "The room temperature :";t
 Tin = Pin(temp)
 Print "The core temperature of the ";MM.DEVICE$;" is ";
 Print Str$(Tin,2,1);Chr$(176);"C at ";
 If Len(MM.Info(cpuspeed)) < 9 Then
   Print LEFT$(MM.Info(cpuspeed),2);
 Else
   Print LEFT$(MM.Info(cpuspeed),3);
 EndIf
 Print " MHz at room";t;Chr$(176);"C"
 Pause 6000
Jan.
Posted: 09:56pm
16 Aug 2026
For an automatic approximation of Room Temperature you could replace
With
RTC GetReg 17,Tdeg : RTC GetReg 18,Tdec : t = Cint((Tdeg + Tdec / 256)*10)/10
if you are using a DS3231 RTC. It reads the temperature every 64 seconds, holding the value in registers 17 & 18.
Edit.
A bit shorter:-
RTC GetReg 17, T : RTC GetReg 18, T.25 : t = T + (T.25 >> 6) / 4
Edited 2026-08-17 10:22 by phil99
Posted: 09:45pm
17 Aug 2026
Done more tidying up, most of the BOM (I need to add a pic or nine), changed the PROG socket to micro USB (trickier than it sounds), moved the power switch slightly and sorted out the silkscreen. Realized that the RTC was the wrong way up for easy installation and access so turned that over.
I'm not intending to do a manual as such for this, just a BOM (with some pics of the more awkward components) and a schematic. After that I'll probably release the gerbers for anyone who fancies fault finding an untested design. :) I'll probably order some boards too.
Posted: 08:52pm
18 Aug 2026
JanVolk
phil99,
Thanks for sharing. I’ve tested it with various PicoMite modules, and it works perfectly.
Do keep in mind the type of DS3231 you are using, as this affects accuracy.
Jan.
Posted: 06:54am
19 Aug 2026
Yesterday was quite fruitful:
Did the circuit diagram. I think that's all completed now.
Did the bill of materials with pictures and a couple of notes done.
GPIO port changed to include the system I2C pins, as on the later PC3 versions.
Added PCB holes in case someone wants to screw the RTC down.
Ran the DRC checks again, and a lot of the point to point checks. Almost there now.
Posted: 08:43am
19 Aug 2026
Right, here we are.
PC3x construction pack.zip
This hasn't been built or tested at this stage, it's hot off the design table. If anyone wants to have a play they are welcome. I don't claim any originality for the original design, I've only done my best to translate it into modules. There's obviously no guarantee that it will work in an identical way to a PC3 (or even work at all for that matter!).
Posted: 09:10am
19 Aug 2026
Looks great Mick. I've done a cursory review of the schematic and it all looks OK but I can't check the module pinouts. One question: have you checked whether the pinout of the PGA2350 the same as the Waveshare version ? If it is it would give non-UK buyers another source.
Posted: 09:31am
19 Aug 2026
It doesn't seem to be. I had a glance and there don't seem to be the same GND pins on the Waveshare. I will check further though.
Edit:
No, they aren't pin compatible at all. Only the physical size is the same.  :(
Edited 2026-08-19 19:37 by Mixtel90
Posted: 09:44am
19 Aug 2026
WARNING!
Something might be odd with the gerbers. Some of the oval pads on the USB connectors seem to rotate for no apparent reason, even after I've reset them. I need to sort something out there.
Posted: 10:18am
19 Aug 2026
I *think* I can make a version of this board for the Waveshare CORE2350B. I'll have a look. There are a few pin changes but generally down the "controls" side.
I reloaded my SL6 file from the last save before I did the gerbers and it loaded ok. No pads had spun round.
Posted: 11:39am
19 Aug 2026
Any idea, Mick, why JLCPCB would add C$11.38 for "Material Type"?
I did note that upon import, it said the width was 100.01mm.
Posted: 12:16pm
19 Aug 2026
I'll be surprised if 0.01mm concerns them. I must confess that SL6 measures this at 100.008mm, but I've already had several boards made using this outline already without incurring extra charges.
Posted: 12:17pm
19 Aug 2026
Conversion for the CORE board isn't as easy as I thought. They have changed a lot more pins.
Posted: 01:20pm
19 Aug 2026
  Mixtel90 said  I'll be surprised if 0.01mm concerns them
Me too, and it's not clear that it did. I still wonder what the "Material" charge is for.
Posted: 01:29pm
19 Aug 2026
What have you selected? 1.6mm FR4 in green?
Posted: 01:38pm
19 Aug 2026
dddns
After all basic components work, I have no success getting the Pimoroni RM2 Breakout board to work. I've tried it with the latest WebMite firmware and get:
WebMite MMBasic RP2350B Edition V6.03.01
Total of 6 Mbytes PSRAM available
[CYW43] error: hdr mismatch 0100 ^ ffff
[CYW43] error: hdr mismatch 040e ^ fffb
[CYW43] Bus error condition detected 0x2002
[CYW43] do_ioctl(2, 263, 1008): timeout
[CYW43] STALL(0;1-1): timeout
[CYW43] CLM load failed
It obviously recognizes PC3 setup.
IC ID of the Wifi chip is:
20953-RMC2GW4B52
I have tried it with WebMiteRP2040 and an all pinout RP2040 clone. It doesn't say hdr mismatch but immediately fails with initialization.
Edit: if I unplug the RM2 module on my PC3 clone the output is:
[CYW43] Failed to start CYW43
repeated forever
Edited 2026-08-19 23:56 by dddns
Posted: 02:01pm
19 Aug 2026
I would suspect a duff board with either a short or dry joint where the rm2 mounts on the carrier. Assuming you have followed the wiring precisely as per the Pimoroni website there is nothing else obvious that could be the cause (unless the rm2 module itself is duff or the resistor values on the carrier are wrong)
   Page 4 of 6
