JAQForum Ver 26.09
   Page 42 of 43
Posted: 06:26pm
30 Sep 2026
analog8484
  Godoh said
It growls and varies in sound very unhappily.
When I am charging the car it is also AC coupled to two grid inverters that are helping supply the charge to the car.
The scary sounding growls are likely mainly due to the inverter being unhappy with AC coupled GTI injecting anti-islanding disturbances.  I have heard it many times in my testing.
The EV charging probably helped the system from total shutdown as it absorbs at least some of excess power from the GTI backfeed.  I have tested turning on large resistive loads with similar effects.
  Godoh said
The commercial Latronics inverter doesn't have a problem with it, but the home made 8010 inverter sounds like it may blow up, so i switch over to the latronics inverter whenever charging.
I believe the Latronics inverter is pretty old/obsolete?  If so, it's encouraging that an older inverter likely with limited control HW is able to compensate for the non-linear disturbances.  It gives me hope that perhaps the control HW horsepower required to compensate for non-linear loads might not be so high?
Posted: 09:10pm
30 Sep 2026
Godoh
Hi Analog, thanks for the reply.
The 8010 inverter doesn't make the same noises normally when the GTI inverters are back feeding through it. Only when the EV charger is connected.
When charging the EV there is often around 4kw of power or up to 5kw input from the GTI inverters.
Normally the batteries don't charge at more than about 2kw max as the regulators are already doing their job at that power
Latronics inverters are no longer made, the company shut down a couple of years back, the 3kw inverter is about 4 years old now, I have never taken the covers off to see just what is in there, it is a transformer based unit.
buy yes it runs the car charger fine. Doesn't seem to mind the GTI inverters doing their bit and back feeding.
Pete
Posted: 11:11pm
30 Sep 2026
KeepIS
There was nothing special about the Latronics I've looked at, I've tested a few and pulled them down for parts. You can't really compare how different inverters sound and imply a better or different control, different toroids, winding, caps, power levels, switching speed, dead time, cabling, chokes, etc, etc.
With ZERO control feedback the waveforms are still similar with a stupid Diode control HeatGun load.
If you want to redesign a new Inverter or Control system, then perhaps a new thread would be a good idea, as this Inverter works perfectly and does not have a problem with Half Wave corrupted AC Loads, and has not failed after years of over 35kW Peak DC inputs daily.
Posted: 07:24pm
01 Oct 2026
analog8484
I see so it's more likely an interaction between the EV charging and GTI input which is something I have also observed.
Does the inverter make any noise when charging EV without the GTI input?  That's the condition where I hear some buzzing.
So it works with 5kW GTI input and 2kW EV charging?  That would mean a solid 1:1 AC coupling ratio with a large load (relative to inverter capacity).
Posted: 07:33pm
01 Oct 2026
analog8484
  KeepIS said  There was nothing special about the Latronics I've looked at, I've tested a few and pulled them down for parts. You can't really compare how different inverters sound and imply a better or different control, different toroids, winding, caps, power levels, switching speed, dead time, cabling, chokes, etc, etc.
It's certainly not definitive but control differences, which would technically include things like switching speeds and dead time, are plausible.  In any case, I agree that further discussion on the subject should be in a separate thread to avoid further pollution of this great thread.
Posted: 11:55am
02 Oct 2026
InPhase
I am not in a position to test such things at the moment because I lack spare parts like toroids to do so. But it would seem to be a relatively simple addition to test a compensation winding circuit. Adding two or three turns of small wire would be sufficient. A precision op amp, a couple of resistors, a capacitor, and a power supply for them is pretty much all that would be needed in hardware. A bipolar power supply would be better. Then some code to adjust the SPWM timing in response to the analog signal from the op amp.
The voltage on the winding is proportional to the flux in the core. If the flux is going too far in one direction, the op amp will produce a signal that causes the code to add or decrease dead time, adding or reducing volt-seconds of flux on the opposite side to restore balance. The math suggest that a 100 kohm input resistance and a 100 nF feedback capacitor in parallel with a 3.3 Mohm resistor should give about 10 ms of "width". The coding part... Well that's a different story. Someone else would have to think about that
Edited 2026-10-02 21:59 by InPhase
Posted: 12:28pm
02 Oct 2026
  Quote  The voltage on the winding is proportional to the flux in the core.
It isn't that simple.
1) The voltage on the winding is proportional to the rate of change of the flux in the core.
2) The full-cycle average voltage on any secondary winding is always 0V, no matter how  asymmetric the the core flux may be.
There can never be a DC offset to measure.
Posted: 04:58pm
02 Oct 2026
InPhase
The flux average isn't ALWAYS zero. When the flux is walking towards saturation, the is a cycle to cycle imbalance that can be detected and corrected by an integrating circuit telling the control loop to back off one way or the other.
Posted: 09:39pm
02 Oct 2026
As suggested by others have moved discussion to a new thread.
Edited 2026-10-03 09:51 by phil99
Posted: 06:36am
04 Oct 2026
KeepIS
Been very busy, more shed work as soon as it's finished I'm starting the task of winding two large Toroids cores for a backup Dual Inverter.
@phil99 Thank you for moving that bad load detection discussion over to it's own thread
Posted: 11:26am
04 Oct 2026
rogerdw
  KeepIS said  Been very busy, more shed work as soon as it's finished I'm starting the task of winding two large Toroids cores for a backup Dual Inverter.
Cool. How big's large?
Posted: 05:57am
05 Oct 2026
KeepIS
Hi Rodger, still with little time on the PC or new Inverter build, almost finished lining the extension and then hook up another dust extraction blast gate and port.
The new single toroids are a bit larger than the current combined 3 stack toroid, and have  100 mm centres. I still have to check the idle and other specs, secondary winding around 120 turns for 1 tesla, I have two to wind for the dual Inv.
Posted: 12:41am
06 Oct 2026
rogerdw
Yep understood, life gets busy.
Sounds like 100mm ID is a pretty common size  ...  and 120 turns too for that matter. I think my large toroid in the Warpverter was 112T with 22T primary.
Posted: 01:54am
06 Oct 2026
KeepIS
I've seen some large toroids wound with 90 to 120 turns on the forums over the years, but when you calculate the maximum flux density for the toroid Core size, some came out at 1.2 to 1.4 Tesla, I'm leaning torwards 130 turns.
I figure if I'm breaking my back and arms winding it, then a few extra turns to get down to one Tesla is worth the effort, but likely another $50 for the extra meter or two of copper wire, copper prices are really crazy
Edited 2026-10-06 13:09 by KeepIS
Posted: 10:17am
07 Oct 2026
KeepIS
At Last I had a chance to wind the China toroid core with a 130 turn secondary and a 15 turn primary, some quick ac testing for mag current, same as we have all done in the past, so the comparison is valid with the 3 stack toroid of similar cross sectional value.
The power values were within meter error of each other from 225Vac out to 280Vac, that's as high as I tested the 3 stack toroids too.
In these new cores, I tested out to 320Vac, the power was still increasing in linear steps from 220v to 320Vac with no sudden jumps in current. This core is wound very close to one Tesla.
I fitted the toroid to the Test Power board (38,000uF caps) and controller, it ran fine, the small single toroid had an idle current of 19.3 watts, this huge core idled at 24.2 watts.
I found a 15 turn primary had an idle SPWM of 72%, so I added a turn, with 16 turns the idle SPWM went up to 79%, a much better figure, and 16 turns bought the turns ratio from 8.6:1 back close to 8:1, that extra turn also reduced primary reactive current by 200mA.
As I'm using a single thick copper wire for the 130 turn secondary, I plan on winding it as two 65 turn winding's connected in series.
Although the test winding's are only rated for a few amperes, I dumped a 600 watt load onto it and the controller regulated it and ran fine, all wave forms were correct and stable.
It will be interesting to see if there is Idle hum with the correct heavy winding's, as it was absolutely dead silent in all testing with the small test wiring.
Edited 2026-10-08 19:22 by KeepIS
Posted: 12:41am
09 Oct 2026
KeepIS
The new toroid was test wound for 1T and has absolutely zero hum, even when suddenly stepping the DC input up/down in 1, 5, or 10 volt increments, which caused the other 2.5kW test toroid to hum noticeably, the new toroid is completely and utterly silent.
A caveat though, the test secondary is wound with 2 ampere cable, a 16 turn primary is 3A cable, I have no idea if that has an effect on the hum in the Core running at idle, phil99 or wiseguy might be able to answer that one accurately, as it will be a few weeks before I can confirm this after the toroid is wound correctly for full power load testing.
Could this be another reason why some inverter builds have less or no hum at idle, and others have a noticeable hum, I'm obviously not talking about higher power unbalanced load growl from the Toroid Core.
Posted: 12:55am
09 Oct 2026
  Quote  Could this be another reason why some inverter builds have less or no hum at idle
Quite possibly. The reactance of an inductor at 0Hz (DC) is 0Ω so the primary circuit impedance to a DC offset voltage is just the resistance of the whole primary circuit. A very small DC voltage across a very small resistance could produce a significant current.
Adding even 1/10 Ω might reduce it significantly.
Posted: 11:27pm
11 Oct 2026
KeepIS
Just kicking the can down the road and looking back as I save up for the copper wire to wind the toroids, we might have to sell one of the cars
I've been looking back again at some of the big toroid builds over the past 10 years, back to when we used the rule of thumb for some calculations for the secondary (240v) turns for toroid area, the turns ratio, cable etc.
Surprisingly most of the toroids were actually wound to 1.2T to 1.4T. The 8:1 turns ratio for primary and secondary was almost spot on when looking at PWM % @ Idle, which IMHO is around 78% to 81%, and the %PWM under very high loads, obviously these figures are dependant on toroid efficiency and Losses like Wire size, core size, core quality, supply impedance and voltage delta from No to full load, etc.
Early builds and testers were always looking at Core loss via AC across the Secondary winding for (nominal) 240vac, power loss with increasing applied AC voltages from 200vac to 280vac and the increase power and Toroid Hum as the core came closer to saturation.
Many reported a quite hum (ear against the core) to an audible hum in close proximity to the core in the final toroid testing (Core and Secondary winding only), and it seems that very few cores have been wound for 1T.
Of course for most of us, we can only guess at the quality of our cores and the loss per Kg rating before we actually wind it and start testing.
Some of the good core material at around 0.3mm thickness, the thickness typically used in our cores, is around 1 watt per Kg @ 1.5T and 1.4 watts per Kg @ 1.7T.
That data is from years ago and for quality grain oriented steel, it's likely that our salvaged cores are a lot worse than that, and with many cores coming from China over the past 10 years, who knows what the actual steel quality is, or how well it's assembled in the toroid.
Currently printing thin toroid end caps with matching inner and outer notches for the number of turns, it should make winding a lot neater and protect the winding even more as it wraps around the top and bottom edges of the toroid, I've seen others do something similar, and yes, the toroid edges were already chamfered.
Edited 2026-10-12 10:22 by KeepIS
Posted: 10:10pm
13 Oct 2026
KeepIS
A slight annoyance, and maybe it's just me?
But lately, some questions, replies and comments on the forums appear to be almost AI generated verbatim?
It's starting to read and feel very hollow, disconnected and even condescending.
I'm fine with using AI searched answers and questions, but say so!
Posted: 11:26pm
13 Oct 2026
wiseguy
AI?  +1   Re copper costs, recently an order to JLCPCB for 10 PCBs that 6 months ago cost ~ $42.80 to manufacture, now costs $90.85. It is a 2oz board that also has enig finish. They blamed substrate and copper costs when I queried the 112% rise. However, interesting that the prototype cost for 1oz has not changed (yet....), leaves you wondering if they mainly want to discourage anything except simple 1oz prototypes?
   Page 42 of 43
