JAQForum Ver 19.10.27
Forum Index : Microcontroller and PC projects : Seeking Games Programmers
   Page 5 of 9
Posted: 09:38pm
02 Feb 2018
  Geoffg said
  robert.rozee said   how easy (or hard) would it be to have an mmbasic interrupt that is called at the start of the VGA vertical blanking interval? this would allow for doing some neat video tricks without need for double buffering and the likes.
What neat tricks?
Most people who ask for this are remembering the old 8-bit computers where writing to the display memory at the wrong time could cause interference on the display. In the Maximite this does not happen, you can update the display whenever you want.
smooth animation. even with the maximite, there will still be potential for 'tearing' in an animated object if the screen is updated mid-frame. for instance: try displaying a narrow vertical bar on the screen that is a good portion of the total screen height. animate this bar in the horizontal direction, and you'll see tearing that will move up or down the bar dependant on the relationship between scan rate and animation rate. note, the tear will only be one pixel wide.
there are two solutions to this: 1. double-buffering (as peter is doing in his MZ port) combined with NOT switching between buffers at times when redrawing an object is incomplete; 2. completing any drawing operations quickly during a period when you know the screen is not being used (ie, either during the VBI, or when the area of the frame buffer being redrawn is not also being scanned by the video circuitry).
the big advantage of allowing the user to work within an interrupt triggered off the VBI is that you don't need two frame buffers, hence halving your RAM requirements. since most games only animate small objects, moving them around only within a synchronized ISR is pratical. you can also have a go at creating fake colour effects by rapidly switching the colour of an object on alternate frames.
all the above assumes that creating an interrupt run off the VBI is even practical - it may well not be. if not practical, a 'claytons' alternative may be to simply provide a flag (MM.VBI) that is set true at the start of the VBI and false at the end of it. this would allow the main loop of a game to sit waiting for the VBI to start. a scan line counter (MM.SCAN) may also be useful :-)
rob :-)
Posted: 11:07pm
02 Feb 2018
Geoffg
Thanks for the input everyone. There are a lot of trade-offs here that need to be worked through.
Posted: 12:26am
03 Feb 2018
hitsware
Still the 'mod' format for sound ?
Posted: 12:54am
03 Feb 2018
Probably I would think. WAV playback too.
I seem to remember that MOD can play in the background.
Pete may have made that true of WAV now I think - I need to have another look at my MMX docs, but I am pretty sure WAV plays in the background.
If that is indeed the case, then MOD may be dropped in favour of the WAV format.
Posted: 12:57am
03 Feb 2018
  MicroBlocks said   Personally i would try to define the 'market' for the new efforts.
Is it only because some attention from 8-bit guy?
It is always hard to predict what will be popular and what will not.
Going against an Rpi, or even just a PC using Small Basic. Or every single browser using Javascript and canvas.
Is there actually a market?
I can see a market for embedded controllers. There is not that much available that is easy to program. But emulating an 80's computer has been done to death.
The great thing for me was that the VGA output (and composite! on those cheap small car monitors) could be shown on a simple old monitor, but who still has these? I'll bet less and less people every year. And i used it to control stuff, not writing games or anything else. Too many much better options available already.
The existing maximite could use a little upgrade by adding some usefull stuff from the micromite. But for the rest.... i am not sure it is worth the effort.
This post is very valid, and food for thought. Hmmmmmmmmm..............
Posted: 01:04am
03 Feb 2018
amitor
As much as I would like to see the "perfect" retro 80s computer, I get that the market is too small to invest too much time and money, unless it's your passion. It's funny in a way that microcontrollers are now serving second duty like that, since there isn't a lot of shared customers or interests.
However, besides the graphic primitives that are being worked on and sound great (my MMX is on the way, so no first-hand experience yet) 8 colors is the most limiting factor. I hope that in time, we can have a solution that has shading. Doesn't need anything crazy, but simple 256 or if you want to get fancy, 4096 colors, would be of huge benefit. Even something as basic as a Commodore 64, while only having 16 basic colors, was able to do up to 121 colors with clever programming. 8 colors is very limiting in the long run (I promise no ZX Spectrum jokes here!)
Anyway, I'm just very excited that something like MMX exists at all, and can't wait to dive straight in. I've spent far too many years fighting for few bytes and cycles in 6502 assembly, so now to have much higher speed in something like BASIC opens up a world of possibilities.
Posted: 08:01am
03 Feb 2018
LouisG
Instead of retro 80s computers to emulate, may I suggest looking in the direction of emulating small PLCs, which is very relevant today and which has a huge range of applications and users. MMX appears to be an excellent platform for this.
Only recently Allen Bradley started expounding the virtues of combining PLCs with MMIs.
Good morning A-B.
Posted: 09:25am
03 Feb 2018
the micromite, in its most basic forms (28-pin SDIP, E-28, etc) comes pretty close to the functionality of a PLC, except substituting mmbasic for ladder-logic. i do suspect that most micromites running out in the real world are performing tasks that a PLC would otherwise be doing.
rob :-)
Posted: 03:28pm
03 Feb 2018
hitsware
  Grogster said   Probably I would think. WAV playback too.
It would be neat (for me anyways) to have something like
this
so as to be able create the notes in a more algorhythmic fashion.
Posted: 08:20pm
03 Feb 2018
djuqa
what you are competing with
C64 reborn with 64 builtin games $149
http://bit.ly/2rYrIV8
VK4MU MicroController Units
Posted: 02:24am
04 Feb 2018
MicroBlocks
For every person that likes to develop a game there are a hundred thousand who just want to play the game.
A game developer starts to have the mood to write something when there are hundreds of thousands potential users.
Windows Phone was a good example of that dilemma. We all know how that went, despite millions being spend.
Maybe remind ourselves that in the 80's those computers where just a few that were available and pretty high prices too.
Games would cost 10$ or much more.
Now we have games on internet in the browser, steam, rpi, etc... all mostly for free.
On the PC there are game engines with built in physics and 3d capabilities which can be downloaded for free. (Unity for example)
Why would anyone want a "computer" based on a single chip?
Maybe because he wants to build a controller to switch on his coffee machine at a certain time. Make a weather station, an alarm clock, a house automation system, etc, etc...
Try that with a C64, or TRS-80 or any other retro computer.
Try it with an Atmel, or PIC chip and you need to learn a C like language, study how the internals work, or just hook up a xxxMite and type a few lines of understandable code and be done with it.
The ability to have a screen with a GUI is phenomenal! None of the other embedded systems is offering that.
Should the attention not be on the strength what it offers (Serial, I2C, SPI, CAN, RS485 etc..) and make it even better instead of trying to get the weakest part (VGA) a tiny bit less weak?
Posted: 02:31am
04 Feb 2018
djuqa
Exactly more focus on the MAKER/Hackaday style projects, leave games/games computers for the many emulation/retro developers already saturating the market.
Posted: 02:41am
04 Feb 2018
[Quote=djuqa]what you are competing with
http://bit.ly/2rYrIV8[/Quote]
Now that's interesting!
How about the Atari Flashback 8 with 120 built-in games for $80?
Posted: 02:58am
04 Feb 2018
djuqa
exactly no way can compete with those prices with that many games
Posted: 03:20am
04 Feb 2018
To be fair, I don't expect that Geoff was wanting to make the new beast a retro games machine, more just to get some games written to show off what is possible with the new beast.
At least, that's the feeling I get.
A few games by way of demonstration more then trying to sell it off as a games machine you can write games on, if you catch my drift.
Posted: 04:27pm
04 Feb 2018
Boppa
I'd like to build an old 80's style machine one day, but so far I have just been using the 28 pinners only, as programmable easy to use 'modules'
like my current project- got a garage door opener, but you still have to get out of the car to open the gates first- kinda defeats the purpose of the door opener....
so 28 pinner is currently being programmed and built up (just a veroboard pcb at this stage and probably going to stay that way) to drive the garage door opener, plus 2 actuators to open and close the gates- opening isnt an issue, but closing them has to be done in the right 'order', plus with 2 cars, only one remote is to open the garage, the other is to just open the gates...
bitch with electronics only- I started this a couple of years ago with steering diodes etc etc), now its a single MM with a relay board and everything else is done in easy to understand BASIC (I looked at a PI, but at the time I wasnt interested in learning how to program it, I know basic and its easy to use- even if I still insist on using line numbers
:-P
eta I actually started playing with home automation back in the 80's- with a Vic20- it could drive 5v out of the user port (4 channels) with peeks and pokesEdited by Boppa 2018-02-06
Posted: 10:54pm
04 Feb 2018
panky
I'm not big on games myself but I think the ideas behind the graphics are a great advancement to the 'mite environment. In particular, the terrific work done by Peter with Sprites and Blit recently opens up a great new opportunity for animated graphics as a user interface for all the great microcontroller type projects that shedders have put up - a simple idea - with Boppa's gate and garage door project, why not have an animated display showing the doors opening?
For weather stations, watering systems, and so on, animated graphics could really enhance the user experience. The nice thing is that for any gamers, the features are there - for others the features are there for other types of projects.
By all means keep the retro games in mind but I think more importantly, the animated graphic possibilities for new projects should be front and centre. For this, I feel the graphics on the various LCD displays are more important than VGA.
I love this stuff - great work Geoff and Peter and others - please, PLEASE, keep it coming.
Doug.
Posted: 12:15am
05 Feb 2018
hitsware
Also those 4 channels could each deliver frequencies
throughout the audio band with crude ( 8 bit 'words' )
PWM .......
Posted: 04:33am
05 Feb 2018
Boppa
Yeah but why would you want to do that, when it had a polyphonic sound chip anyway
Posted: 02:31pm
05 Feb 2018
hitsware
  Boppa said   Yeah but why would you want to do that, when it had a polyphonic sound chip anyway
Not the Vic-20
   Page 5 of 9
