Forum Index : Microcontroller and PC projects : PicoMite V6.01.00 release candidates
Much Better!!!!!! But we aren't quite out of the woods yet! It takes 10x or 15x times as long to lock it up, but the little MMBasic program up above can still lock up the PicoMite. (Same story with MMDebug. It is MUCH MUCH better, but resizing the debug window can lock it up quickly.) I also tried the WebMiteRP2040V6.01.00RC5.uf2 file. It seems to flash OK, but it never boots up and gives a command prompt. |
When using FM and heavily scroll up/down where it permanently reads from disk with high input rate with keyboard pressing constantly, it starts reading wrong data and then errors with "SDcard not found". I did this often before and never has been a problem. |
Hrmmpf ... I just discovered that I am using a Pico 2 W .... It's hidden under a display and I was so sure that it's just a Pico 2, because I am currently not using the WiFi option.This may explain the "problem" with MM.SUPPLY. With the latest firmware (WebMiteRP2350V6.01.00RC5.uf2), MM.SUPPLY outputs a 0, independent of heartbeat on/off. Sorry for the confusion Best Thomas |
The introduction of MM.SUPPLY prompts a question. For consistency, is it worth changing Pin(temp) to MM.TEMP or MM.INFO(temp)? |
Peter, Problem with WebMite MMBasic RP2040 V6.01.00RC5. It no longer starts. See the size of the .uf2 file compared to V6.01.00RC4? Regards, Jan. |
Thanks - will fix |
Peter, Also having a problem with WebMite MMBasic RP2350A Edition V6.01.00RC5. Flashing didn't work the first time. I tried Flash_nuke.uf2. After that, it worked. Everything worked again. I noticed that MM.SUPPLY isn't in the functions list and returns 0 when I test > ? mm.supply. But after a reset: WebMite MMBasic RP2350A Edition V6.01.00RC5 Copyright 2011-2025 Geoff Graham Copyright 2016-2025 Peter Mather No more cursor? Heartbeat works, but no USB connection? Then I loaded PicoMite RP2350A V6.01.00RC5 in the same Web module. PicoMite MMBasic RP2350A V6.01.00RC5 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION CPUSPEED (KHz) 200000 This is now working normally, and the cursor appears immediately after a reset. Regards, Jan. |
Testing with a Pimoroni PGA2350 RC5 With psram pin not configured, the attached program loads without any problems. As supplied, the program does nothing but it does load. When I set OPTION PSRAM PIN GP47, a program previously loaded runs but the same program fails to load. As soon as the ^Z is sent after the AUTOSAVE, the pico resets with Error: Invalid address - resetting Ada_VL53L1X.zip Other programs load OK Jim |
Jim, please try to nuke the flash before flashing the RC5. I've got the same error as you befor nuking, ran the "universal_flash_nuke.uf2" utility than reflashed RC5 and now it loads the files without error on the hardware I had troubles before. The hardware it worked on now was a Waveshare RP2350-Plus lookalike (chinese clone) ------------------- Edit: just tried it on a Pimoroni "pico plus 2". Could not get it to work, always fails with Upload completed 201 ***TIMEOUT*** ------------------- and tried again on the before working RP2350-Plus Upload completed 201 Error: Invalid address - resetting Total of 6 Mbytes PSRAM available > ------------------- My conclusion: RC5 doesn't resolve the problem. The effect seems to be a spoiled USB and on other hardware a firmware crash. Maybe something related to the PSRAM PIN as they are different on the 2 types of hardware I tested. GP47 ... timeout GP19 ... Invalid address GP0 ... is to be tested Gerald Edited 2025-10-23 18:25 by ville56 |
I am having problems with my RP2040-GEEK and playing WAV files. I nuked my GEEK and have the following options: PicoMite MMBasic RP2040 V6.01.00RC5 OPTION SYSTEM SPI GP10,GP11,GP24 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION HEARTBEAT OFF OPTION PICO OFF OPTION CPUSPEED (KHz) 200000 OPTION LCDPANEL ST7789_135, RLANDSCAPE,GP8,GP12,GP9,GP25 OPTION LCD BACKLIGHT 1 OPTION SDCARD GP23, GP18, GP19, GP20 OPTION AUDIO GP2,GP3', ON PWM CHANNEL 1 OPTION PLATFORM RP2040GEEK The WAVs are located on b: > play wav "ey.wav" Error: Invalid address - resetting This happens with all my WAV files. I had previously copied them from a: to b: using miniFM. When I call it up from a:, I don't get an error. Is it because of the firmware or the copying??? Frank |
Jim Looks like an issue with trying to write from psram to flash. I'll change the memory allocation so autosave only gets its memory from true ram |
GP0 ... Timeout interstingly, I cannot nuke the version with PSRAM CE on GP0. It is a WeAct mini module (square shape) RP2350B A4 stepping with all IOs on the connector (4x 15 pins). No matter which nuke version I use, it does not clear the flash. Flashing MMBasic works without any problem. |
V6.01.00 PicoMiteV6.01.00RC6.zip More minor changes to USB console handling and memory allocations. Tested with Jim's download on a Pico Plus 2 with psram enabled and it works for me. Webmite RP2040 should also be OK |
Been able to brake down my problem! This works error free: PicoMite MMBasic USB RP2350B Edition V6.01.00RC6 OPTION SERIAL CONSOLE COM1,GP28,GP29 OPTION FLASH SIZE 16777216 OPTION COLOURCODE ON OPTION KEYBOARD US OPTION PICO OFF OPTION CPUSPEED (KHz) 200000 OPTION SDCARD GP32, GP33, GP34, GP35 OPTION AUDIO GP30,GP31', ON PWM CHANNEL 7 And this messes up reading with: Line input # , input # or system commands PicoMite MMBasic USB RP2350B Edition V6.01.00RC6 OPTION SERIAL CONSOLE COM1,GP28,GP29 OPTION FLASH SIZE 16777216 OPTION COLOURCODE ON OPTION KEYBOARD US OPTION PICO OFF OPTION CPUSPEED (KHz) 200000 OPTION SDCARD GP32, GP33, GP34, GP35 OPTION AUDIO GP26,GP27', ON PWM CHANNEL 5 My "impression:" it does not recognize EOF/EOL correctly edit 2: with configured LCD holding a letter in console till end of input and then press backspace continuously causesd a complete failure of LCD, only power cycling helped Edited 2025-10-24 00:39 by dddns |
RC6 loads now without problems with all my different modules !!! Thank you Peter |
dddns what hardware are you using? |
I'm using 2 PGA2350 for testing this at the moment and 2 different hardware systems holding the PGAs. All these test followed: clear_flash - flash firmware - configure per hand One more: this one works error free: PicoMiteVGA MMBasic RP2350B Edition V6.01.00RC6 OPTION FLASH SIZE 16777216 OPTION COLOURCODE ON OPTION KEYBOARD US OPTION PICO OFF OPTION RESOLUTION 640x480 @ 252000KHz OPTION SDCARD GP24, GP25, GP26, GP27 OPTION VGA PINS GP32,GP34 And this one overwrites _some_ variables(memory for variables 103Kb) - or - reads wrong values from disk, can't find out that quick: PicoMiteVGA MMBasic USB RP2350B Edition V6.01.00RC6 OPTION SERIAL CONSOLE COM1,GP28,GP29 OPTION FLASH SIZE 16777216 OPTION COLOURCODE ON OPTION KEYBOARD US OPTION PICO OFF OPTION RESOLUTION 640x480 @ 252000KHz OPTION SDCARD GP24, GP25, GP26, GP27 OPTION VGA PINS GP32,GP34 |
Sounds like something going on in H/W relating to GP27 and GP28 both being used. In both your examples which error that looks like the common factor. There is nothing I can think of in the firmware that could create that as a problem. I haven't won't have access to any H/W that can mimic your configuration for another 9 days |
No problem I can easily use different pins but from January untill now I have used these both with this configuration so the problem is new for me. This was more meant as bug report or help to find the bug. I will reconfigure serial to different pins |
Peter, Version V6.01.00RC6 hasn't yet resolved the cursor and reset issue with the WebMite firmware on both an RP2040 and RP2350 Web module. The firmware can be loaded, but the cursor doesn't appear after a reset, nor after power cycling during startup. I tested the two WEB modules with PicoMite firmware and they work properly with the RP2040 and RP2350, including the reset. After startup, I see a format A: message, but after that, no cursor ">". Perhaps you missed my message about the reset and cursor? Regards, Jan. |
