OPTION LCDPANEL VIRTUAL_C appears to have a bug on the basic RP2040. Continued on RC0... option lcdpanel virtual_c > option list PicoMite MMBasic RP2040 V6.02.00RC0 OPTION FLASH SIZE 16777216 OPTION COLOURCODE ON OPTION CPUSPEED (KHz) 200000 OPTION DISPLAY 52, 150 OPTION LCDPANEL VIRTUAL_C,GP16,GP18 > cls rgb(red) > box 1,1,320,240,1,rgb(green),rgb(red) > box 66,66,111,111,33,rgb(blue),rgb(green) > save image "test.bmp" > xmodem s "test.bmp" > gui test lcdpanel > save image "test2.bmp" > xmodem s "test2.bmp" > cls rgb(red) Error : Not enough Heap memory Error : Not enough Heap memory Error : Not enough Heap memory Error : Not enough Heap memory The first test image worked properly but the second was blank then CLS crashed it. Note the same OPTION LCDPANEL VIRTUAL_C,GP16,GP18 in option list. Edit. "gui test lcdpanel" was stopped with Ctrl-C which usually retains the image. Edit 2 Did a clear_flash and reloaded RC0. Just default options plus "option lcdpanel virtual_c" and same result, though it took an extra Save Image to crash. Edited 2026-01-06 20:54 by phil99 |
