JAQForum Ver 19.10.27
   Page 6 of 26
Posted: 09:22am
12 May 2026
V6.03.00RC7
PicoMiteRP2040V6.03.00RC7.zip
PicoMiteRP2350V6.03.00RC7.zip
Fixes bug introduced in rnd()
Fixes bug introduced in POS/pos used in strings
Improved error detection in WEB versions
Additional parameter in OPTION WIFI
If set correctly this will overcome issues with things like channel 12,13 usage by a router in countires where that is legal
  Quote  OPTION WIFI ssid$, passwd$ [,name$] [, country$]
OPTION WIFI ssid$, passwd$ [, name$] [, ipaddress$, mask$, gateway$] [, country$]
Configures the firmware to automatically connect to a WiFi network on
restart.
'ssid$' is the name of the network and 'password$' is the access
password. Both are strings and if string constants are used they should
be quoted.
Optionally a name for the device can be specified 'name$', otherwise a
name is created from the unique device ID.
Optionally, a static IP address, IP mask, and gateway address can be
specified as 'ipaddress$', 'mask$', 'gateway$'.
Optionally a 2-letter ISO country code 'country$' can be specified to
set the WiFi regulatory domain. The default is "XX" (worldwide), which
restricts the device to the most conservative subset of channels and
transmit power. Setting the local country code is recommended and is
often required to associate with EU routers (for example AVM Fritzbox)
which may use channels 12 or 13. If 'country$' is omitted the
previously stored value is preserved; "" or "WW" both select
worldwide. The country code is a regulatory setting and must match
the country in which the device is operated.
Supported country codes:
AU AT BE BR CA CH CL CN CO CZ DE DK EE ES FI FR GB GR HK HU IL IN
IS IT JP KE KR LI LT LU LV MT MX MY NG NL NO NZ PE PH PL PT SE SG
SI SK TH TR TW US ZA
XX or WW (worldwide, default)
eg. OPTION WIFI "mysid","mypassword","myPico","DE"
  "192.168.1.111","255.255.255.0","192.168.1.1","DE"
Edited 2026-05-12 19:22 by matherp
Posted: 12:12pm
12 May 2026
BarryH
Hi Peter,
LIST PINS is still faulty on 2350B DIL (unless I'm using the wrong firmware)
PicoMite MMBasic RP2350B V6.03.00RC7
OPTION FLASH SIZE 16777216
OPTION COLOURCODE ON
OPTION PICO OFF
OPTION CPUSPEED (KHz) 200000
GP0 1
GP1 2
GP19 25
GP20 26
GP21 27
GP22 29
GP23 41
GP24 42
GP25 43
GP26 31
GP27 32
GP28 34
GP29 44
GP30 45
I've done a bit of research, gone back through several previous versions, and found that even before LIST PINS was included in the V6.00.002 firmware, the use of the "FreePins" code snippet in V6.00.001 gives incorrect Pin / GPx associations.
Each time I have been using Clear_Flash_RP2350.uf2 and FLASH ERASE ALL
I could have sworn I've used the command successfully, previously.
Edited 2026-05-12 22:13 by BarryH
Posted: 01:05pm
12 May 2026
The firmware is correct. The pin mapping is for the Pico2 only. Pins above gp28 have "virtual" pin numbers that don't reflect any specific layout. The firmware can't know what variant of PCB a RP2350B is on and there isn't a Raspberry Pi standard for the RP2350B. Use GP designation and you can't go wrong and the code is transportable between different PCBs
Edited 2026-05-12 23:09 by matherp
Posted: 01:38pm
12 May 2026
BarryH
thanks Peter - I fully understand the principal now.
Edited 2026-05-12 23:38 by BarryH
Posted: 02:20pm
12 May 2026
dddns
Sorry, my webmite still does not reconnect after CPU Restart connected to a Fritzbox 7520 via DHCP:
> cpu restart
/usr/bin/cu: Got hangup signal
Disconnected.
dietmar@Intel-Desktop:~/Projekte/VT-100$ /usr/bin/cu -l /dev/ttyACM0 -s 115200
Connected.
de connecting to WiFi...
failed to connect.
> option list
WebMite MMBasic RP2040 Edition V6.03.00RC7
OPTION CPUSPEED (KHz) 252000
OPTION WIFI PicoLan, *********, de
OPTION TELNET CONSOLE ON
  BarryH said  Hi Peter,
Not for me, but if length of the list exceeds local console/screen terminal rows then it won't wait for a key press. On local screen lines are gone..
Edited 2026-05-13 00:30 by dddns
Posted: 02:40pm
12 May 2026
Nothing more I can do about the Fritzbox. I've done everything that the various AIs suggest. Re-purpose it as a boat anchor?
Question:
Does the Fritz!Box UI still show the device as “connected” for several minutes after the RP2350 has rebooted?
Also, try this:
Disable “PMF required” (802.11w)
Set it to Optional, not “Required”.
On Fritz!Box:
Wi‑Fi → Security → “Protected logins” → set to Optional
Edited 2026-05-13 00:58 by matherp
Posted: 03:27pm
12 May 2026
dddns
Ok. My current setup is DHCP and FB assigns hostname and IP address based on MAC and support for legacy devices is enabled. I will look at all possible setups and report asap.
Posted: 04:27pm
12 May 2026
The possible critical one is:
✔️ The real fix that works with Fritz!Box and keeps a stable MAC
There is exactly one robust solution that does not rely on deauth and does not require MAC changes:
➜ Force Fritz!Box to drop stale sessions immediately
This is done by disabling or relaxing one Fritz!Box feature:
On Fritz!Box:
Why this works:
When PMF is required, Fritz!Box must treat missing deauth frames as suspicious.
When PMF is optional, Fritz!Box is allowed to clear the session when the client disappears.
This single setting fixes reconnect issues for:
ESP32
ESP8266
CYW43 (RP2040/RP2350)
many IoT devices
older Android phones
some laptops with buggy drivers
It’s the closest thing to a “universal fix”.
✔️ The second fix (if PMF is already optional)
Disable “WPA3 transition mode”
Fritz!Box sometimes mishandles WPA2/WPA3 mixed‑mode replay counters after a client reboot.
Set Wi‑Fi security to:
WPA2 only, or
WPA3 only, but not mixed mode.
✔️ The third fix (if you want to keep PMF and WPA3)
Shorten the Fritz!Box association timeout
Hidden setting:
Home Network → Network → Network Settings → Additional Settings → “Idle timeout for inactive devices”
Set it to 1 minute.
This forces Fritz!Box to drop stale sessions quickly.
🎯 Summary: Why Fritz!Box is “contrary”
Because it:
strictly enforces WPA2 replay counters
strictly enforces PMF
strictly enforces association state
does not clear stale sessions quickly
assumes reconnecting without deauth is suspicious
treats embedded clients as potential attackers
This is good security, but bad interoperability.
Posted: 05:28pm
12 May 2026
ville56
@dddns:
are you on the latest firmware level? I'm running 8.25 on a FB 7590 and fighting with similar probs. Tried to use Peters latest mod and supplied the country code, also had channel 12/13 enabled in the FB (disabled now). Before had the problem that the Pico lost connection sometimes (every 2 to 3 days), now I have the situation that the Pico does not always connect on CPU restart, mostly each second try works.
It is too early to say if the connection is now stable, but if not I will try using WPA2 only (current setting  WPA2 + WPA3) with the setting
 "Unterstützung für geschützte Anmeldungen von WLAN-Geräten (PMF) aktivieren"
deactivated which is currently ticked and greyed out because of WPA3 enabled.
Posted: 09:12pm
12 May 2026
JanVolk
toml_12953 and ville56,
Thanks for the reply and the translation. The help.txt in English has been updated to V6.03.00
Copy it to MMEdit and edit it, then copy it to the PicoMite board to flash drive with the filename help.txt
help.txt-V6.03.00-eng.txt.zip
Jan.
Posted: 12:02am
13 May 2026
toml_12953
  JanVolk said  toml_12953 and ville56,
Jan.
Thanks!
Posted: 03:50am
13 May 2026
toml_12953
Is there any way to change the width of listings on a PicoCalc (40-column LCD display)? I have an 80-column serial printer and it's a waste to have 40-column listings come out. I'd like to leave PRINT as is but be able to change the output of the LIST command only. Maybe even have LLIST and LPRINT commands that print to a serial port rather than the console.
Edited 2026-05-13 13:51 by toml_12953
Posted: 06:05am
13 May 2026
ville56
Jan, many thanks for the new help file.
Posted: 06:56am
13 May 2026
ville56
Peter,
the report of the line causing an error seems to be 1 line off.
running
   mx=MOUSE(x,2)
   my=MOUSE(y,2)
   If mx <> tx Or my <> ty Then Print mx, my
   tx = mx : ty = my
gives
RUN
[1] mx=MOUSE(x,2)
Error : MOUSE is not declared
the correct error line should be [2]
Version: PicoMiteHDMI MMBasic USB RP2350B Edition V6.03.00RC7
BTW, the example is taken from the manual
"Advanced Graphics Functions for the PicoMite Firmware" which IMHO should be revised.
Or is the manual already invalidated?
Gerald
Edited 2026-05-13 16:57 by ville56
Posted: 06:59am
13 May 2026
Frank N. Furter
  toml_12953 said  Is there any way to change the width of listings on a PicoCalc (40-column LCD display)? I have an 80-column serial printer and it's a waste to have 40-column listings come out. I'd like to leave PRINT as is but be able to change the output of the LIST command only. Maybe even have LLIST and LPRINT commands that print to a serial port rather than the console.
How did you connect the printer to the PicoCalc???
Frank
Posted: 07:46am
13 May 2026
toml_12953
Frank
It's an Oki Microline 184 Turbo serial printer connected to serial port 1 on pins GP0 and GP1 at 19200 baud. I use a TTL to RS-232 converter (about $3.00 USD). I had an Epson receipt printer on there at 115200 baud (you should see the paper fly out of that thing!) but wanted a standard paper printer rather than thermal paper.
Edited 2026-05-13 17:49 by toml_12953
Posted: 07:55am
13 May 2026
bfwolf
If you could live with only being able to "list" programs on the printer that are already saved as files:
The programs are, after all, stored in the files as "ASCII streams" (using CR as the line separator).
So, write a program that reads a file line by line and then outputs it line by line via the serial interface.
Check the manual under "PRINT #nbr, expression [[,; ]expression] … etc."
The "LLIST" program could also be stored as a "resident" subroutine within the library. It could accept the filename as a string parameter.
Posted: 10:12am
13 May 2026
dddns
  matherp said  The possible critical one is:
I tried all I could. With disabled PMF, static and DHCP, WPA2 and WPA2+3
without success but:
Doing a  CPU Restart for the first time and the connection fails, doing it a second time and it connects. I found that it connects very robust every second attempt..I tested it 10 times in a row
EDIT: I tested it with Android mobile as hotspot and it shows the same. Doing CPU Restart in a row let every second try be successfully connected..it toggles
Edited 2026-05-13 20:27 by dddns
Posted: 10:47am
13 May 2026
ville56
@dddns,
I think what you've achieved, is the best you can get with MMBasic and FB. Same here. MMBasic and Fritz!Box are no friends, even though ESP32 with Annex Basic connects without a hitch as well as other ESP8266 boards. It's probably an issue with the SDK or wherever the IP stack comes from.
What I do is test at the very beginning of the program if the Pico has an IP address other than 0.0.0.0. If not--> CPU RESTART. This works for me since long time and is reliable. As long as you don't have unexpected disconnects as I do, which are not easy to discover, you should consider to live with it .... btw, from my experiance, this behaviour has already changed to normal and back in the last 3 to 4 years serveral times, I think with the updates of the FB firmware but I have no way to prove that theory.
Currenty the actual RC version of MMBasic looks good as far as disconnects are concerned. First time connects are rare though.
Gerald
Posted: 10:57am
13 May 2026
dddns
Thanks. As it really toggles _every_ time between failure and connection after CPU Restart I think there is hope
   Page 6 of 26
