JAQForum Ver 19.10.27
Forum Index : Microcontroller and PC projects : PicoMiteHDMIUSB motherboard reference design
   Page 7 of 16
Posted: 02:45am
06 Nov 2024
mclout999
sorry repost.  I wish we could delete them.
Edited 2024-11-06 12:47 by mclout999
Posted: 03:24am
06 Nov 2024
Try pauses between each read, the hardware may need time to read the next value. Test various values to find the minimum.
Wii Nunchuck OPEN
P = 20 'pause length mS
 Print DEVICE(NUNCHUCK C);
 Pause P
 Print DEVICE(NUNCHUCK Z);
 Pause P
 Print DEVICE(NUNCHUCK JX);
 Pause P
 Print DEVICE(NUNCHUCK JY)
 Pause P
Posted: 02:32pm
06 Nov 2024
mclout999
  phil99 said  Try pauses between each read, the hardware may need time to read the next value. Test various values to find the minimum.
Wii Nunchuck OPEN
 Pause P
 Pause P
 Pause P
 Pause P
Thanks will do.  Next issue.  Matherp gave the labels for the inputs for the Nunchuck but not for the classic controller. I wanted to test those next.  The CMM3 Manual has a list of what he used there are those, right for the DEVICE(CLASSIC X)?
EDIT: even with this code I get the message to enter pin or 0 to restart when you break out of the program.  WHAT IS THAT and why is it happening?
Edited 2024-11-07 02:35 by mclout999
Posted: 03:57pm
06 Nov 2024
Hi,
The WII classic controller is documented in the 5.08.00 user manual (Geoff's site). Search for "WII" in the document. I think it is page 111.
All changes since then are in this writeup
summary of all changes
Thanks to tha hard work of Mixtel90
Edited 2024-11-07 02:02 by Volhout
Posted: 04:40pm
06 Nov 2024
See manual 5.08.00 and later
DEVICE WII OPEN [,interrupt]
Opens a WII Classic controller and implements background polling of the
device. The Wii Classic must be wired to the pins specified by OPTION
SYSTEM I2C which is a prerequisite. Open attempts to talk to the Wii
Classic and will return an error if not found. If found the firmware will
sample the Wii data in the background at a rate of 50Hz. If an optional
user interrupt is specified this will be triggered if any of the buttons
changes (both on and off).
See the DEVICE function for how to read data from the Wii Classic.
Posted: 09:15am
25 Nov 2024
bleep, tritonium, JohnS and romba6 please PM me with you addresses and I'll get the boards posted
Posted: 09:39am
25 Nov 2024
Thanks - done.
Posted: 01:28pm
25 Nov 2024
  Mixtel90 said  See manual 5.08.00 and later
Hi Mick,
It seems the DEVICE command is not present anymore in 6.0.0 RC 16.
It is now something along these lines
WII CLASSIC OPEN [,int]
WII NUNCHUCK OPEN [,int]
Also the DEVICE function has changed. I am eager to see how to read the controllers now.
Edited 2024-11-25 23:30 by Volhout
Posted: 01:43pm
25 Nov 2024
That's correct, DEVICE has changed. I can't keep up at the moment. :)
It changed in RC12:
WII NUNCHUCK OPEN [myint]
WII NUNCHUCK CLOSE
These commands enable use of a WII NUNCHUCK connected to the SYSTEM I2C pins
use the function
DEVICE(NUNCHUCK  x)
to read the nunchuck data where x=
AX acceleration in the x axis
AY acceleration in the x axis
AZ acceleration in the z axis
JX joystick x
JY joystick y
C status of C button
Z status of Z button
If the optional myint parameter is specified this is a subroutine which is called whenever the C or Z buttons are pressed
NB: because the Wii Nunchuck and Wii Classic use the same I2C address only one can be used at a time. If a second device is needed it must be connected to a different I2C channel to the SYSTEM I2C and will need to be configured and read in Basic.
Also in this version the following commands can now be used without the DEVICE qualifier
WS2812, HUMID, KEYPAD, LCD, WII CLASSIC, WII NUNCHUCK
Edited 2024-11-25 23:49 by Mixtel90
Posted: 02:22pm
25 Nov 2024
Please don't post non-relevant things on this thread. I'm trying to get people who want boards to respond and messages just get lost when overwhelmed
  Quote  bleep, tritonium, JohnS and romba6 please PM me with you addresses and I'll get the boards posted
Posted: 03:14pm
27 Nov 2024
Boards all posted - please PM me when they arrive and I'll let you have paypal details
Posted: 04:27pm
21 Dec 2024
homa
@Peter
Important soldering question!
  matherp said
Notes on use.
Solder the PICO2 direct to the motherboard ensuring it is completely tight to the PCB
On the rear side of the board there are 4 holes without solder mask. Apply liquid flux to these and solder through them. These connect the USB programming micro-USB, Pin GP23, and improve cooling for the USB HUB chip.
Are there really 4 holes or are there only 3 due to the redesign? My board arrived today and I can only see three!
I don't want to make a mistake.
Matthias
Posted: 05:13pm
21 Dec 2024
The other hole is under the USB hub - not important - just might help cooling
Posted: 05:30pm
21 Dec 2024
homa
ok, found it.
For others who have the same question, here again in dye and colour :-)
Posted: 10:31pm
21 Dec 2024
homa
My first board is finished :-)
The apertures are still missing, but I'll make them on Monday with the small CNC.
Thanks to Peter!
Now I'm enjoying my whisky ... and looking forward to it.
Matthias
Posted: 04:30pm
31 Dec 2024
twofingers
@Matthias
  homa said  ok, found it.
Thank you for solving the 4 holes puzzle (Peter's riddle.)! The board has just arrived. Thank you very much for that and for the good, careful packaging. Perfect!
And happy New Year!
Michael
Posted: 05:44pm
31 Dec 2024
Amnesie
This is a really cool design Peter,
will there be an option for socketing the Pico? Yes I am aware of the fact, that they
are for connecting the USB programming micro-USB! But if you would allow both (just put holes in the pad) then the user can decide whether he wants to put tiny wires onto the pico for those.
Just a suggestion, because you don't really loose anything by doing so, but getting a nice option for excessive pico testing in case it went up in flames
Greetings
Daniel
Posted: 10:58am
01 Jan 2025
Here you go. Same BOM and CPL as before
PicoComputer2V1.3.zip
Posted: 12:10pm
01 Jan 2025
Amnesie
Thank you a lot Peter,
I've ordered some with your recent changes! Can't wait to test them
Greetings
Daniel
Posted: 05:57pm
05 Jan 2025
mclout999
  Quote   Will there be an option for socketing the Pico? Yes I am aware of the fact, that they
Is there a possibility of using pogo pins in the Design so that we can socket them? I don't think I have the skills to deSolder The PICO, If it ever fails or if I want to install any of the new boards that have PSRAM.
   Page 7 of 16
