Subject Topic: Pi-cromite Version 5.04.16 Post ReplyPost New Topic
Posted: 12 January 2018 at 7:27pm | IP Logged Quote matherp
Please find attached V5.04.16
for Stretch
2018-01-12_224620_mmbasicstretch.zip
and for Jessie
2018-01-12_224632_mmbasicjessie.zip
Manual
2018-01-13_192334_Pi-cromite_Manual.pdf
This fixes a bug in the PEEK command and also implements the USER display driver capability of Geoff's version 5.4.09. In addition it includes a new font #7 which is a small 6x8 font ideal for smaller displays. NB the Pi-cromite does not support loadable fonts.
This is a huge advantage on the Pi-cromite where we can't have CFunctions. MMBasic is very fast on the Pi-cromite and drivers in Basic perform well
The picture shows an ST7920 based 128x64 display (QC12864B) being driven by a SPI user driver on a Pi Zero-W. The code is attached below and will also work unchanged on any of the Micromites (other than adjusting the pin numbers)
userdisplayinit
Line 0,0,MM.HRes-1,MM.VRes-1
Line MM.HRes-1,0,0,MM.VRes-1
Box 0,0,MM.HRes,MM.VRes
Text MM.HRes/2,MM.VRes/2,"Hello World",CM
End
Sub userdisplayinit
  Option explicit
  Option default none
  On error skip
 'if OPTION is already set then ignore the error
  Option LCDPANEL USER, 128,64
  On error skip
 'don't error if Global variables not yet defined
  Erase S$(), tmaskarray(), bmaskarray(), LCD_RESET, LCD_CD, LCD_CMD, LCD_DATA
  Dim S$(MM.VRes-1) length MM.HRes\4
  Dim integer tmaskarray(3)=(240,112,48,16)
  Dim integer bmaskarray(3)=(128,192,224,240)
  Dim INTEGER LCD_RESET=22 ' pin for chip select
  Dim INTEGER LCD_CD=24 ' pin for Reset
  Dim INTEGER LCD_CMD=&B11111000
  Dim INTEGER LCD_DATA=&B11111010
  Local i%
  On error skip
 'don't error if SPI already open
  SPI open 100000,3,8
  Pin(LCD_RESET)=1
  Pin(LCD_CD)=1
  SetPin LCD_RESET,dout
  SetPin LCD_CD,dout
  Pin(LCD_RESET)=0
  Pause 200
  Pin(LCD_RESET)=1
  Pause 200
  Pin(LCD_CD)=1
 ' continuous enable for the moment
  LCD.CMD(1) 'DISPLAY CLEAR
  LCD.CMD(&B00001100) 'display on
  LCD.CMD(&B00100110) 'graphic mode
  For i% = 0 To MM.VRes-1
    s$(i%)=String$(MM.HRes\4,Chr$(&H0))
  Next i%
  update 0, 0, ((MM.HRes-1)\16), MM.VRes-1
End Sub
Sub MM.USER_RECTANGLE(x1%, y1%, x2%, y2%, fcol%)
  If x1%=0 And y1%=0 And x2%=MM.HRes-1 And y2%=MM.VRes-1 Then
    Local b$, i%
    If fcol% Then
      b$=String$(MM.HRes\4,Chr$(&HF0))
    Else
      b$=String$(MM.HRes\4,Chr$(0))
    EndIf
      s$(i%)=b$
    Next i%
  Else
    Local integer i, j, k, l, t, left_x,right_x, mask,emask
    Local b$
    'print "userrectangle ", x1%, y1%, x2%, y2%, fcol%
    If x2% <= x1% Then
      t = x1%
      x1% = x2%
      x2% = t
    EndIf
    If y2% <= y1% Then
      t = y1%
      y1% = y2%
      y2% = t
    EndIf
    If x1% < 0 Then x1% = 0
    If x1% >= MM.HRes Then x1% = MM.HRes - 1
    If x2% < 0 Then x2% = 0
    If x2% >= MM.HRes Then x2% = MM.HRes - 1
    If y1% < 0 Then  y1% = 0
    If y1% >= MM.VRes Then y1% = MM.VRes - 1
    If y2% < 0 Then y2% = 0
    If y2% >= MM.VRes Then y2% = MM.VRes - 1
    left_x=x1%\4
    right_x=x2%\4
    If left_x=right_x Then
      If (fcol%) Then
        mask =(tmaskarray(x1% Mod 4) And bmaskarray(x2% Mod 4))
      Else
        mask = notmask%(tmaskarray(x1% Mod 4) And bmaskarray(x2% Mod 4))
      EndIf
      For t=y1% To y2%
        l= Peek(var S$(t),left_x+1)
        If (fcol%) Then
          l=l Or mask
        Else
          l=l And mask
        EndIf
        Poke var S$(t),left_x+1, l
      Next t
    Else
      If (fcol%) Then
        mask =tmaskarray(x1% Mod 4)
        emask=bmaskarray(x2% Mod 4)
      Else
        mask = notmask%(tmaskarray(x1% Mod 4))
        emask= notmask%(bmaskarray(x2% Mod 4))
      EndIf
      For t=y1% To y2%
        If fcol% Then
          l=Peek(var S$(t),left_x+1)
          l=l Or mask
          l=Peek(var S$(t),right_x+1)
          l=l Or emask
          Poke var S$(t),right_x+1, l
        Else
          l=l And mask
          l=l And emask
        EndIf
      Next t
      If left_x+1<=right_x-1 Then
        If fcol% Then
          b$=String$(right_x-left_x-1, Chr$(240))
        Else
          b$=String$(right_x-left_x-1, Chr$(0))
        EndIf
        For t=y1% To y2%
          s$(t)=Left$(s$(t),left_x+1)+b$+Right$(s$(t),32-right_x)
        Next t
      EndIf
    EndIf
  EndIf
  update x1%\16, y1%, x2%\16, y2%
End Sub
Sub MM.USER_BITMAP(x1%, y1%, width%, height%, scale%, fcol%, bcol%, bitmap%)'bitmap is in string bitmap$
'  print  "userbitmap ", x1%, y1%, width%, height%, scale%, fcol%, bcol%
  Local INTEGER i, j, k, mask, m, l, ll, t, tt, vCd, hCd, x, y, a%=height% * width%, ln%, c2%, c3%, c4%
  vCd = y1%
  If y1% < 0  Then y1% = 0                                 ' the y coord is above the top of the screen
  For i = 0 To  height%-1                              ' step thru the font scan line by line
    ln%=i * width%
    For j = 0 To scale%-1                         ' repeat lines to scale the font
      vCd=vCd+1
      If vCd >= 0 Then  ' we are above the top of the screen
        y=vCd - 1
        If vCd > MM.VRes  Then GoTo D_UP                          ' we have extended beyond the bottom of the screen
        hCd = x1%
        For k = 0 To width%-1                         ' step through each bit in a scan line
          c2%=ln% + k
          c4%=(a% - c2% - 1) Mod 8
          t=Peek(BYTE bitmap% + c2%\8)
          tt = (t >> c4%) And 1 'we now know if the pixel is on or off
          For m = 0 To  scale% -1                      ' repeat pixels to scale in the x axis
            hCd = hCd +1' we have not reached the left margin
            If hCd >= 0 Then
              If hCd <= MM.HRes  Then                 ' check are we beyond the right margin
                x=hCd -1
                mask=1<<(7-(x Mod 4))
                c3%=notmask%(mask)
                ll= Peek(var S$(y),x\4+1)
                If tt Then
                  If fcol% Then
                    ll = ll Or mask
                  Else
                    ll = ll And c3%
                  EndIf
                Else
                  If bcol%<>-1 Then 'transparent text
                    If bcol% Then
                      ll = ll Or mask
                    Else
                      ll = ll And c3%
                    EndIf
                  EndIf
                EndIf
                Poke var S$(y), x\4+1, ll
              EndIf
            EndIf
          Next m
        Next k
      EndIf
    Next j
  Next i
D_UP:
  update x1%\16, y1%, x\16, y
End Sub
Sub LCD.CMD(databyte As integer)
  Local integer i,J
  SPI write 3,LCD_CMD, DATABYTE And &HF0, (DATABYTE And &H0F)<<4
  Pause 2
End Sub
Sub SetXY(x As integer, y As integer)
  Local integer xx=x<<4,yy=y
  If yy>31 Then
    xx=xx+128
    yy=yy-32
  EndIf
  SPI write 5, LCD_CMD, (yy And &H10) Or &H80, yy<<4, &H80, xx
  Pause 1
End Sub
Sub update(x1%, y1%, x2%, y2%)
  Local b$, i%
    Pin(LCD_CD)=1 ' enable
    For i% = y1% To y2%
      If i%<MM.VRes Then
        SetXY(x1%,i%)
        b$=Chr$(LCD_DATA)+Mid$(s$(i%),x1%*4 +1, (x2%-x1%+1)*4)
        SPI WRITE Len(b$),b$
      EndIf
    Next i%
    Pin(LCD_CD)=0 ' disable
End Sub
Function notmask%(x%)
  notmask% = (-1 Xor x%) And &HFF
End Function
Edited by matherp on 13 January 2018 at 7:23pm
Micro-80
Posted: 01 February 2018 at 5:52pm | IP Logged Quote Micro-80
The manual says that there are two serial ports COM1 and COM2. COM2 on the 7-Tx and 11-Rx pins. Can I reassign COM2Rx to a different PIN? The project needs COM2, and pin 11 is occupied by HAT.
Back to Top View Micro-80's Profile Search for other posts by Micro-80
vegipete
Posted: 02 February 2018 at 5:58am | IP Logged Quote vegipete
In your sample code, you have the following:
<skip>
It appears the bottom right corner of the screen is in different places for the Line and Box commands. Why is that?
Back to Top View vegipete's Profile Search for other posts by vegipete
Posted: 02 February 2018 at 8:09pm | IP Logged Quote matherp
Check the MM+ manual
line x1,y1,x2,y2
box x,y,w,h
At the moment this is hardwired. I'll look at it in a future release
Micro-80
Posted: 03 February 2018 at 6:47pm | IP Logged Quote Micro-80
Thank you Peter!
lew247
Posted: 12 May 2018 at 4:06am | IP Logged Quote lew247
Peter I've been reading the manual as well as all the pages I can find about using a Pi on here
I only have 1 question (at the moment)
IF I wanted to make an interface board for an SDD1963 I know you've put the pin numbers in the manual but it doesn't say if you can use the SD card on there that I can see
Can you? and if you can is there specific pin numbers to use?
Or am I going stupid and you actually just use the SPI pins?
(I know nothing about how SD cards work in reading/writing yet but I plan on learning)
By the way, Amazing work, it's prompted me to buy a Raspberry Pi Zero W today/
EDIT:
Can you use the SD card on the Pi to store pictures to be used with Pi-cromite?
And Can you use touch if you use a HDMI display with touch built in?
Edited by lew247 on 12 May 2018 at 5:51am
Back to Top View lew247's Profile Search for other posts by lew247
Posted: 12 May 2018 at 7:34am | IP Logged Quote matherp
No, you just use the SDcard that is on the Pi
Yes
No
Posted: 26 November 2018 at 12:57pm | IP Logged Quote lizby
As of now, the link in the manual (v5.4.16) for installing pigpio software version 64 is timing out: http://abyz.co.uk/rpi/pigpio/download.html
I've just loaded the latest raspbian stretch lite and I think the latest mmbasic (11/17). How do I install the right version of pigpio?
Never mind. I found it here: http://abyz.me.uk/rpi/pigpio/download.html
Edited by lizby on 26 November 2018 at 1:09pm
disco4now
Posted: 26 November 2018 at 1:08pm | IP Logged Quote disco4now
Last time I installed Raspbian it was already included.
You can check with the command below to see if its already installed
pigpiod -v
Not sure if you have seen this one.
This thread has latest versions of MMBasic for Pi
Edited by disco4now on 26 November 2018 at 1:35pm
Back to Top View disco4now's Profile Search for other posts by disco4now
