Subject Topic: Armmite F4: programming the firmware Post ReplyPost New Topic
<< Prev Page of 12 Next >>
Posted: 07 June 2019 at 9:23pm | IP Logged Copy link to clipboard   Quote matherp
There is nothing in the flash memory. You can easily use it from Basic using normal SPI commands.
CaptainBoing
Posted: 07 June 2019 at 11:02pm | IP Logged Copy link to clipboard   Quote CaptainBoing
top news! Thanks
Posted: 08 June 2019 at 6:13am | IP Logged Copy link to clipboard   Quote lizby
matherp wrote:
If you post the file I'll have a look
Thanks for the offer. Since someone else has developed half the code I'd rather not post it here. I tried to send you a PM with a dropbox link, but your mailbox is full. What's the best way to get it to you?
Posted: 08 June 2019 at 7:46am | IP Logged Copy link to clipboard   Quote matherp
Cleared now
Posted: 08 June 2019 at 9:35am | IP Logged Copy link to clipboard   Quote lizby
Is there a 480x320 (or larger) lcd with the footprint to plug into this module?
Or is there a supported 480x320 SPI LCD?
Posted: 09 June 2019 at 12:02am | IP Logged Copy link to clipboard   Quote lizby
Here's my labeling of the usable pin numbers. I didn't include labels for the display or SD, and various others.
Please let me know if any corrections or additions should be made.
Posted: 09 June 2019 at 1:41am | IP Logged Copy link to clipboard   Quote matherp
You don't need to worry about pin numbers. Just use the pin names in all of the relevant commands
? tempr(PE2)
Posted: 09 June 2019 at 6:38am | IP Logged Copy link to clipboard   Quote lizby
I have a program which runs on pi, H7, F4, and L4 (and formerly on MM-64). It reads in 20-some pin numbers from a file so that it knows what to use on which platform (also DOS where pin numbers don't apply, but I/Os can still be simulated).
Posted: 10 June 2019 at 7:44am | IP Logged Copy link to clipboard   Quote lizby
With a new cable, I was able to flash a second F4 and get to the ">" prompt with the USB connection. A little experimenting gave some likely clues to my problems downloading a large basic program. Memory shown is 114K. The program is 121K.
If I try F10 and copy and paste the entire program, it stalls at 114K. Makes, sense--all ram is used. If I try F11 and in teraterm, xmodem send the file, it goes to about 93% and stalls--same explanation. If I omit the last 140 lines of comments and use F10, it succeeds (barely--114K-odd downloaded--112K flash used for program, 9K for fonts, 23K free).
So I guess instead of using teraterm I need to use MMEdit and crunch the comments out, especially since the program is likely to grow more.
I suspect this is also the reason why I can SAVE the file to the SD, but not LOAD it--some amount of ram overhead in the load routine. MMEdit to the rescue.
(74K program with MMEdit.)
Edited by lizby on 10 June 2019 at 8:00am
Paul_L
Posted: 12 June 2019 at 9:11am | IP Logged Copy link to clipboard   Quote Paul_L
I suppose lizby is talking about a code abortion written partially by yours truly.
That's what happens when you let a Polock ex mainframer from Brooklyn with a propensity for obfuscatory prose write a program for a micro. My half of the code is definitely the messiest.
I am slowly trying to clean the mess up a little bit. When it gets a little bit better organized and if lizby is agreeable we will post it and give you guys a good laugh.
Paul in NY
Back to Top View Paul_L's Profile Search for other posts by Paul_L
Posted: 13 June 2019 at 2:07am | IP Logged Copy link to clipboard   Quote lizby
Trying to set the DAC pins, 29 and 30, as digital outputs fails. May they not be used for digital I/O?
> setpin 29,dout
Error: Pin Px32 is invalid
> setpin 30, dout
(For the "invalid pin" message, which I've gotten before, is it possible to print the actual pin number?)
Posted: 13 June 2019 at 2:30am | IP Logged Copy link to clipboard   Quote matherp
New release:
2019-06-13_022213_ArmmiteF4.zip
New functionality:
Playing FLAC files now supported on the DACs. See the H7 manual for more details.
PLAY FLAC filename$ [,interrupt_on_completion]
Changed functionality:
Major rewrite of SDcard handling. Tested transferring multi-megabyte files over both UART and USB using XModem. Note MMEdit seems less robust than teraterm for this.
Bugs fixed:
Incorrect handling of programs too-big for memory. This should now give an out-of-memory error.
Error reporting of pin numbers for invalid pins
No: sorry they are dedicated for DAC use
Yes the ILI9481 Raspberry Pi display is supported. See H7 manual for syntax
Edited by matherp on 13 June 2019 at 2:31am
This page was generated in 0.1367 seconds.
Privacy Policy     Process times : 0, 0, 0, 0.14
