Subject Topic: Pi-cromite V5.4.14: Direct output to HDMI Post ReplyPost New Topic
Page of 2 Next >>
Posted: 30 October 2017 at 7:06pm | IP Logged Quote matherp
Please find attached version 5.4.14
2017-10-30_185432_mmbasicjessie.zip
2017-10-30_185448_mmbasicstretch.zip
This includes the ability to use a conected HDMI display as a LCDPANEL
OPTION LCDPANEL HDMI
See the video to watch GUI test running on a 1600x1200 HDMI display
The code automatically reads in the display size and MM.HRES and MM.VRES are set automatically for you. The display is in full 32-bit colour (RGBA).
The code works best on a Pi running Raspbian Lite as the Pixel GUI will break through the Pi-cromite display - anyone know how to fix this?
On a Lite install it works best if you disable the login prompt and the cursor
To disable the login prompt use
sudo systemctl disable getty@tty1.service
to disable the flashing cursor use:
sudo su
setterm -cursor off > /dev/tty1
All normal graphics commands are available including transparent text and BLIT and GUI commands will work as normal. Of course there is no TOUCH capability and mouse control of the cursor is a problem for another day.
Posted: 30 October 2017 at 7:45pm | IP Logged Quote WhiteWizzard
BRILLIANT!
Do you know what the performance is like on a RPi ZeroW? I don't want to erase my test SD card if its 'too slow' (i.e. best run on a RPi3 only).
Regarding TOUCH; there are many RPi 7" capacitive Touch TFTs. Do you think a single point TOUCH could be implemented somehow on these screens (i.e. no need for all the fancy multi-touch stuff that a capacitive allows for). These TFTs are much less 'reflective' as they don't have the horrible shiny resistive 'overlay' making for a much better colour contrast.
I will email you some more Q's . . .
Posted: 30 October 2017 at 8:30pm | IP Logged Quote WhiteWizzard
Peter,
Will OPTION LCDPANEL CONSOLE work by any chance?
Posted: 30 October 2017 at 8:44pm | IP Logged Quote WhiteWizzard
Sorry if this seems like a silly question; so in the above example, is MM.HRES = 1600, and MM.VRES=1200?
IF SO, then does this mean we can use LOAD IMAGE to display much higher resolution images?
Thanks . . .
Phil23
Posted: 30 October 2017 at 8:44pm | IP Logged Quote Phil23
Superb,
Before reading the entire post I felt a Touch feature coming on,
somewhere down the track.
Phil.
Posted: 30 October 2017 at 9:15pm | IP Logged Quote matherp
Yes but I don't have one to develop/test
No. that is a lot of boring grunt work and I'm not sure it gives any advantage over a separate SSH session
Yes, works perfectly now
are there any other 'niggles' you have with this version?
Raspberry Pi blanks the screen after a timeout if no kbd/mouse input. Haven't solved this yet for Lite but have for Pixel
Posted: 30 October 2017 at 9:35pm | IP Logged Quote WhiteWizzard
OK - thanks for those answers.
I will try and arrange a capacitive Touch Screen for you but it won't be this week I'm afraid (funds tied up already).
Let me know if you have a preference in type of TFT - I was thinking of the 'Official RPi Touch Screen', but there are others!
Last question tonight - can you measure how long (in mS) to load a 1600x1200 hi-res bmp when you get a chance. I am curious as to the speed for use as a digital photo frame for my kiddies
(RPi 3 coming tomorrow from RS)
WW
Posted: 31 October 2017 at 8:19am | IP Logged Quote matherp
241mSec on a Pi Zero W
Posted: 31 October 2017 at 8:29am | IP Logged Quote WhiteWizzard
Thanks for that info - thats great.
I have a RPi3 coming today and was going to put on Lite OS. However, IF I were to install full GUI OS instead, you mentioned about the GUI 'breaking through'. What do you mean by this? Put another way; is MMBASIC useable on a full GUI install enough to see the graphics on the HDMI output.
Courier just been but wasn't the Pi3
WW
Posted: 31 October 2017 at 8:48am | IP Logged Quote matherp
It is fully usable but the clock and the load meter update in the top right and overlay the image - only a tiny area on a 1920x1080 screen. This can be largely negated by doing BLIT READ of this area and then BLIT WRITE at frequent intervals. This restores the contents of the mmbasic framebuffer to the screen
Of course, if you start clicking with the mouse other areas of the desktop will "break through".
To stop screen blanking on Lite
sudo nano /boot/cmdline.txt
Append " consoleblank=0" to the end of the line
To stop screen blanking on Pixel (Stetch: not tried on Jessie)
sudo nano /etc/lightdm/lightdm.conf
in the "[Seat:*]" section insert the line
"xserver-command=X -s 0 dpms"
In both cases reboot for the change to take effect
Edited by matherp on 31 October 2017 at 8:57am
Posted: 31 October 2017 at 10:32am | IP Logged Quote matherp
Updated manual with OPTION LCDPANEL HDMI and details of helpful Raspbian mods in Appendix E
2017-10-31_110439_Pi-cromite_Manual.pdf
I've also now found how to get a clear screen on a Pi with the Pixel desktop
First stop the desktop:
sudo systemctl stop lightdm
Then stop the flashing cursor:
sudo su
setterm -cursor off > /dev/tty0
NB this is a different tty device than used in Lite
To re-enable the desktop
sudo systemctl start lightdm
This version of the manual also includes details of the JSON$() function
Edited by matherp on 31 October 2017 at 11:07am
plasma
Posted: 31 October 2017 at 7:30pm | IP Logged Quote plasma
Wow , great Work matherp
Edited by plasma on 31 October 2017 at 7:31pm
Back to Top View plasma's Profile Search for other posts by plasma
Page of 2 Next >>
Privacy Policy     Process times : 0.02, 0, 0, 0.12
