Local Time 21:51 15 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : maxImouse
Posted: 05:58am 04 Jun 2020
The CMM2 has a nunchuk interface built in. It is ideal for fast game action but I have difficulty using them.
I find the mouse a much easier device to use.
I had a few PS2 mice in the collection so here is a PS2 to serial adapter.
The Arduino nano is cheap and ideal for the job.
It could also be achieved with a micromite but the Arduino was a cheaper choice and I have yet to tackle CFUNCTIONs
I tried to make it suitable for all of the maximite/micromite family but have only tested it on a CMM2 and micromite 170 with 320x240 display.
In the Arduino,
As usual, someone has already done the hard work.
3 buttons work but not scroll.
The PS2 routine takes about 13mS to read the mouse.
It takes 2mS to send the 3 bytes of data at 19200 baud.
19200 is the fastest that all mites can handle.
On the Arduino, pin 5 goes to PS2 data and pin 6 to PS2 clock.
The serial is at 5V so I used a resistor divider to bring the level down to ~3.3V
We could update as fast as 16mS to equal the nunchuk but that would cause unnecessary load on the maximite and is of little benefit.
I chose a delay of 100mS which is added to the 13mS giving a refresh rate of 114-115mS.
In the CMM2, I set the serial to interrupt with 3 bytes in the stream meaning the receiving is all done in the background. There is a chance of the stream getting interrupted so your program will need some way of recovering.
I used j$ = INPUT$(255,#2)
The interrupt Sub updates some global variables and sets flags to indicate mouse movement or button change.
The mousetrap sub takes about 0.15mS on the CMM2 and could be reduced a bit by shifting same of the code into the main loop. 0.15mS every 114mS is not much load.
In the demo, the mouse buttons change the colour of the dots.
L, R and L+R
 ' TassyJim Jun2020
 ' PS2 mouse to serial interface demo
 ' Arduino sends 3 bytes
 ' X movement - signed byte,Y movement - signed byte,Button states - byte
 ' for micromites that don't do sprites, comment out those lines.
 ' Maximite running V4.5 will have to change the CIRCLE and TEXT commands
 ' early Maximites will also need to change Colour and INTEGER
 DIM INTEGER mouseX, mouseY, mouseB, mouseR, mouseL, mouseM  ' mouse position and buttons
 DIM INTEGER mouseMove, mouseClick ' flags to indicate mouse movement or button change
 DIM INTEGER mc ' mouse colour
 SPRITE LOAD "mouse.spr",5
 OPEN "com1: 19200,256,mousetrap,3" AS #2 ' 19200 is the fastest that all Maximie/micromites can handle
 initM
 DO
   IF INKEY$ = " " THEN initM ' might be needed if the mouse interface is interrupted.
   IF mouseMove = 1 THEN
     IF mouseX < 0 THEN mouseX = 0 ' keep the pionter on the screen
     IF mouseY < 0 THEN mouseY = 0
     IF mouseX >= MM.HRES THEN mouseX = MM.HRES -1
     IF mouseY >= MM.VRES THEN mouseY = MM.VRES -1
     drawIt
     mouseMove = 0
   ENDIF
   IF mouseClick = 1 THEN
     mouseR = (mouseB AND 2)/2 ' extract the individual button states
     mouseL = (mouseB AND 1)
     mouseM = (mouseB AND 4)/4
     IF mouseL = 1 THEN mc = RGB(RED)
     IF mouseR = 1 THEN mc = RGB(GREEN)
     IF mouseL = 1 AND mouseR = 1 THEN mc = RGB(BLUE)
     drawIt
     mouseClick = 0
   ENDIF
 LOOP
 CLOSE #2
SUB initM
 LOCAL j$
 j$ = INPUT$(255,#2) ' flush the serial buffer
 mouseX = MM.HRES/2
 mouseY = MM.VRES/2
 CLS
 SPRITE SHOW 5,mouseX,mouseY,1
END SUB
SUB drawIt
 TEXT 10,10, STR$(mouseX)+" "+STR$(mouseY)+" "+STR$(mouseL)+" "+STR$(mouseM)+" "+STR$(mouseR)
 SPRITE HIDE 5 ' hide the cursor while we draw
 IF (mouseL + mouseR) > 0 THEN ' only draw if a button is pressed
   CIRCLE mouseX, mouseY, 3, 1,1,mc,mc
   'circle(mouseX, mouseY),3,mc,1,F ' CMM V1
 ENDIF
END SUB
SUB mousetrap
 LOCAL INTEGER deltaB, deltaX, deltaY
 deltaX = ASC(INPUT$(1,#2))  ' read 3 bytes
 deltaY = ASC(INPUT$(1,#2))
 deltaB = ASC(INPUT$(1,#2)) AND 7
 IF deltaX > 127 THEN deltaX = deltaX - 256 ' signed 8 bit integer
 IF deltaY > 127 THEN deltaY = deltaY - 256
 IF mouseB <> deltaB THEN    '  buttons have changed
   mouseClick = 1            ' set the flag
   mouseB = deltaB           ' remember button states
 ENDIF
 IF deltaX <>0 OR deltaY <> 0 THEN  ' mouse has moved
   mouseMove = 1             ' set the flag
   mouseX = mouseX + deltaX
   mouseY = mouseY - deltaY
 ENDIF
END SUB
 PS2 mouse to serial
 PS2 clock = pin 6
 PS2 data  = pin 5
 Time taken to read the mouse approx 13mS
 1 mS to send data at 38400 baud
#include "PS2Mouse.h"
PS2Mouse mouse(6,5);
void setup(){
 Serial.begin(19200);
 while(!Serial);
 Serial.print("Setup... ");
 mouse.begin();
 Serial.println("complete!");
void loop(){
 uint8_t stat;
 int x,y;
 mouse.getPosition(stat,x,y);
 Serial.write(x);
 Serial.write(y);
 Serial.write(stat);
 delay(100);
The attached ZIP contains all the Arduino code as well as the maximite code.
mouse.zip
Edited 2020-06-04 18:01 by TassyJim
CaptainBoing
Posted: 08:33am 04 Jun 2020
Nice! brings mouse support to literally everything (with a serial link)
Edited 2020-06-04 18:36 by CaptainBoing
Posted: 08:35am 04 Jun 2020
Excellent work, Jim.
I will have to dig out a nano and try it - I am sure I have one around here somewhere....
CaptainBoing
Posted: 08:38am 04 Jun 2020
Hey Grogs, you build panel systems - how about a PS2 trackball mounted in the panel with this gadget. touch is nice but sometimes...
on second thought the economies and the complexity around a pointer don't really stack up. but I would be tempted to try
Edited 2020-06-04 18:40 by CaptainBoing
Posted: 09:01am 04 Jun 2020
Food for thought.....
I DO like trackballs over mice, but they are even harder to find in PS/2 then standard PS/2 mice are!
Posted: 09:55am 04 Jun 2020
I used to modify trackballs for handicapped users.
That was an interesting exercise. All done for no charge, just a feel good for me and some very grateful recipients.
I wish I had a few of the trackballs in the shed now.
My next exercise will be analogue joysticks.
I have a nice Microsoft Sidewinder to put to use.
Turbo46
Posted: 12:59pm 04 Jun 2020
Jim, A mouse is the main reason I would have loved the CMM2 to have a second serial port! Are you aware of the Silicon Chip USB Keyboard & mouse adaptor? Also this post and this one? I programmed the 270 chip with the Microbridge.
I would still like to add a second serial port to the CMM2 but it all seems a bit clumsy. I could multiplex the one port to produce 2 or more or use a Micromite as a "data concentrator" - not ideal.
Bill
Posted: 01:12pm 04 Jun 2020
  Quote   I would have loved the CMM2 to have a second serial port!
The CMM2 has three serial ports including the console
Turbo46
Posted: 01:29pm 04 Jun 2020
Sorry Peter.   I must have looked at that I/O connector diagram a dozen times and still missed it, Thanks.
Bill
Posted: 09:48pm 04 Jun 2020
  Turbo46 said  Jim,Are you aware of the Silicon Chip USB Keyboard & mouse adaptor? Also this post and this one? I programmed the 270 chip with the Microbridge.
Bill
I had forgotten Raros's serial mouse interface and don't subscribe to SC any more.
Seeing that some hardware is needed for the interface, a nano works out just as simple.
If you are short of serial ports, the Arduino could be changed to act as an I2C slave. That was my first idea - make it emulate the nunchuk. I still might try that sometime.
Raros
Posted: 01:36pm 06 Jun 2020
Great
Byez
Posted: 08:33am 07 Jun 2020
I have added joysticks to the mix.
The common Arduino joystick module has it's pots connected between Vcc and Ground so a simple analog read is all that's needed to get the relative position. They usually have one button which switches to ground.
The real joysticks from 20 years ago are different.
In the real joysticks, there is a ~100k pot connected to 5V but not connected to ground so we get a variable resistance we need to read.
In the original systems, there weren't many ADC converters so they measured to time taken to charge a capacitor. This is directly proportional to the resistance.
This is the method I used.
With minimum resistance, it takes 40uS to charge the 0.01uF capacitor to V/2 and at the maximum resistance about 1200uS
My cheap joystick has higher value resistances so it takes up to 1600uS to charge.
There are 2.2k resistors on all inputs to limit charging current.
The button inputs have 0.01uF filter capacitors.
I used a LM324 for the comparitors but any one that runs of 5V single supply will do.
To start the timing, the capacitors are discharged for 100uS (this could be shortened a bit).
The transistors are not critical and mosfets could be used.
We then record when the outputs of the comparitors return low.
I divide the result by 4 because the nano has a 4uS resolution. The upper 2 bits of the reading are stored in the button byte to give up to 10 bits resolution.
We need the spare room to cater for different joysticks.
The MMBasic interrupt routine has changed:
SUB mousetrap
 LOCAL INTEGER deltaB, deltaX, deltaY, device
 deltaB = ASC(INPUT$(1,#2))  ' read 3 bytes
 device = (deltaB AND 192 )/ 64  'top 2 bits determine devcie sending data
 IF device = 0 THEN ' its a mouse
   PRINT "Mouse "; STR$(deltaX,6,0);STR$(deltaY,6,0);"  ";BIN$(deltaB,8) 'DEBUG
   deltaB = deltaB AND 7
   ENDIF
   ENDIF
 ELSEIF device = 1 THEN ' its joystick A
   deltaX = deltaX + (deltaB AND &B00110000)*16
   deltaY = deltaY + (deltaB AND &B00001100)*64
   PRINT "Joy A "; STR$(deltaX,6,0);STR$(deltaY,6,0);"  ";BIN$(deltaB,8) 'DEBUG
 ELSEIF device = 2 THEN ' its joystick B
   PRINT "Joy B "; STR$(deltaX,6,0);STR$(deltaY,6,0);"  ";BIN$(deltaB,8) 'DEBUG
 ENDIF
 PRINT
END SUB
and the Arduino code:
 PS2 mouse to serial
 PS2 clock = pin 3
 PS2 data  = pin 2
const int trigPin = 4;
const int axPin = 5;
const int ayPin = 6;
const int bxPin = 7;
const int byPin = 8;
const int ab1Pin = 9;
const int ab2Pin = 10;
const int bb1Pin = 11;
const int bb2Pin = 12;
 uint8_t stat;
 int x,y,s,so;
unsigned long timeZero, timeWait;
signed long axt,ayt,bxt,byt;
signed long axto,ayto,bxto,byto;
int p,ab,bb, abo,bbo;
PS2Mouse mouse(3,2);
void setup(){
 pinMode(axPin, INPUT);
 pinMode(ayPin, INPUT);
 pinMode(bxPin, INPUT);
 pinMode(byPin, INPUT);
 pinMode(ab1Pin, INPUT_PULLUP);
 pinMode(ab2Pin, INPUT_PULLUP);
 pinMode(bb1Pin, INPUT_PULLUP);
 pinMode(bb2Pin, INPUT_PULLUP);
 pinMode(trigPin, OUTPUT);
 digitalWrite(trigPin, LOW);
 mouse.begin();
void loop(){
 s = stat & 0x3F;        //make sure the top 2 bits are zero
 if(x != 0 || y != 0 || s != so){
   Serial.write(s);
   Serial.write(x);
   Serial.write(y);
   so = s;
 axt = 0;
 ayt = 0;
 bxt = 0;
 byt = 0;
 digitalWrite(trigPin, HIGH); // discharge the capacitors
 delayMicroseconds(100);
 timeZero = micros();
 timeWait = timeZero + 2050; // set timeout
 while (micros() < timeWait) {
   if (axt == 0 && digitalRead(axPin) == LOW) {
     axt = micros()-timeZero;
   if (ayt == 0 && digitalRead(ayPin) == LOW){
     ayt = micros()-timeZero;
   if (bxt == 0 && digitalRead(bxPin) == LOW){
     bxt = micros()-timeZero;
   if (byt == 0 && digitalRead(byPin) == LOW){
     byt = micros()-timeZero;
 /* nano only has 4 uS resolution so divide by 4
    add high byte bits to button byte
   2 bits to identify mouse or joystick, 2 bits for x axis,
   2 bits for y axis 2 bits for buttons
 axt = axt / 4;
 ayt = ayt / 4;
 bxt = bxt / 4;
 byt = byt / 4;
 ab = (highByte(axt) & 3 )*16 + (highByte(ayt) & 3 )*4 + 64;
 ab = ab + (1-digitalRead(ab2Pin)) *2;
 ab = ab + 1-digitalRead(ab1Pin);
 bb = (highByte(bxt) & 3 )*16 + (highByte(byt) & 3 )*4 + 128;
 bb = bb + (1-digitalRead(bb2Pin)) *2;
 bb = bb + 1-digitalRead(bb1Pin);
 if (ab != abo || axt != axto || ayt != ayto) {
   Serial.write(ab);
   Serial.write(lowByte(axt));
   Serial.write(lowByte(ayt));
   abo = ab;
   axto = axt;
   ayto = ayt;
 delay(3);    // give the micromite time to digest
 if (bb != bbo || bxt != bxto || byt != byto) {
   Serial.write(bb);
   Serial.write(lowByte(bxt));
   Serial.write(lowByte(byt));
   bbo = bb;
   bxto = bxt;
   byto = byt;
 delay(1000);
I will bundle it all together once I have transferred the circuitry from breadboard to veroboard and played a bit more.
I still have one digital pin free on the Arduino and all the analogue pins so I could add code for the new modules as well.
vegipete
Posted: 08:52pm 07 Jun 2020
Since you are creating what could likely become the standard interface, may I make a suggestion before it gets too locked in?
Boost the size of the data payload a bit.
Your current implementation only allows 4 devices, with 2 bytes and 6 bits of info each.
Consider the following:
- a scroll wheel mouse needs 4 bytes of data.
- 2 joysticks (4 axis, 4 buttons) needs 5 bytes of data
If you changed to a 6 byte data packet, this would allow 256 devices (or 127 to relate somewhat to I2C) with 5 bytes of data each.
Or maybe round to 8 bytes total, because computers like powers of 2.
Just a thought.
Posted: 10:09pm 07 Jun 2020
The Arduino doesn't have enough pins for more than 4 devices realistically so I prefer to leave it at 4 for my purposes.
I am considering a 4th byte to cater for scroll wheel mice and as a 'spare'. I need to investigate why my scroll mouse isn't playing fair.  Too many different standards between mice.
I already cater for 2 joysticks or joysticks with more than 2 axis. My Microsoft stick has a throttle which I read easily.
Device 2 is joystick A and device 3 is joystick B.
While more precision sounds like a good idea, I have found that the joysticks send data even when left alone. The output jitters by a couple of bits so I am going to try adding a dead zone so there has to be some definite movement before updating the position. This makes more than 8 bits for position superfluous once a particular stick is calibrated.
This is the output from my Microsoft joystick sitting idle:
Joy B     81     0  10000000
Joy B     80     0  10000000
Joy A    136   142  01000000
Joy A    138   144  01000000
Joy B     81     0  10000000
Joy A    137   144  01000000
Joy B     80     0  10000000
Joy A    136   143  01000000
Joy B     82     0  10000000
Joy B     80     0  10000000
Posted: 07:07am 08 Jun 2020
I found a PS2 library that works with my scroll mouse so I have changed to that library and changed the data sent to 4 bytes.
I also discovered that trying to do timing while data is being sent in the background is not a good idea so I made a few changes.
I also added a 'dead zone' in the joystick routines to limit the number of packets sent while at rest.
That allowed me to send data more often.
The full Arduino code and the MMBasic demo are included in the ZIP
PS2Mouse2.zip
A good source for PS2 info is https://isdaman.com/alsos/hardware/mouse/ps2interface.htm
Posted: 01:48pm 08 Jun 2020
Hi TassyJim,
Maybe I missed the point but why are you decoding the old joysticks the same way it was done 30 years ago(timing)  ?
It is also possible to use the ADC of the arduino (or whatever) to read the value of the variable resistor in the joystick. Simply connect the old 5V pin to ground, and add 10k pullup resistors to 3.3V to the signal pins.
The result may not be linear or full range, but that can be overcome in the arduino code.
Posted: 09:58pm 08 Jun 2020
  Volhout said  Hi TassyJim,
2 reasons. Not very linear which made repeatability on one side difficult and some of the hybrid joysticks which were able to work as digital or analogue would not like that arrangement.
The third reason (and the most important) was, it was something I hadn't tried before now.
vegipete
Posted: 05:59pm 11 Jun 2020
How are you interfacing this with the CMM2 given that the mouse and Nano run at 5 volts and the serial ports on the CMM2 external I/O connector are indicated in the manual as being NOT 5 volt tolerant? (Open drain output and pull-ups?)
Posted: 10:36pm 11 Jun 2020
  vegipete said  How are you interfacing this with the CMM2 given that the mouse and Nano run at 5 volts and the serial ports on the CMM2 external I/O connector are indicated in the manual as being NOT 5 volt tolerant? (Open drain output and pull-ups?)
1.8k and 3.3k is my usual choice.
We only need Tx from Arduino, I didn't bother connecting the Arduino Rx.
