Local Time 16:16 21 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V5.07.00b0 - beta firmware
     Page 3 of 13
Glen0
Posted: 03:04am 21 Jul 2021
  palcal said  You have to download this file and put it in the MMEdit folder in 'Program Files'
File
I'm in, thanks a lot
Posted: 07:09am 21 Jul 2021
OK, that took quite some time to get my backpack tracer program running again on the b2 release ....
I used a variable called 'ADC'. And that coincides with the new ADC command, but did not give a message such as "syntax error". I would have expected that. But
ADC = pin(ADC_pin)
is perfectly accepted.. strange....
Anyway, here is the backpack tracer program adapted for pi-pico release V0.5.07b2 (sorry for the long listing).
If you are not planning on building the hardware, a simple check can be done by adding a 10k resistor from GP18 (PWM1A) to GP26 (ADC0) and a 2.2nF capacitor from GP26 to GND. This is an elementary low pass filter.
I have chosen these pins so I don't have to change the code to keep it compatible between MX170, F4, and pico. Only defines in the start of the program change.
'huntron
'|                         BACKPACK TRACKER                    |
'| 21-7-2021                         Volhout @ TheBackShed.com |
' Curve tracer type huntron tracker
' For ILI9341 LCD backpack on 28 pin MX170
' Uses pin 24 as analog input
' Uses pin 4 as pwm output
' Uses pin 9 and 10 to set amplifier gain
' all values scaled to 'resolution'
' there are 'samples' measurements per period
'------------------------- Version History ------------------
' V00       Proof of concept with 640 samples 100 resolution
' V01       Increase resolution to 1000, decrease samples to 200
' V02       Implemented touch for REF and ZOOM buttons, REF added
' V03       Optimized main loop from 400msec to 300msec
' V04       Implemented support for HW zoom
' V05       Zoom implemented in SW
' V06       Restructure code to support samples and resolution as constants
' V07       Tune performance on MX170 ( 8 frames / second )
' V08       Improved code for readability, remove obsolete DIM's
' V09       Screen resolution independent (untested), added header
' V10       Add dynamic measurement values
' V11       Support for ArmiteF4 (untested with hardware)
' V12       Support for PicoMite (MMbasic 0.5.07 alpha48)
'------------------------------ init ------------------------
Option explicit
init:
 If MM.Device$ = "ARMmite F407" Then
   'STM32F407VET6 initialisation
   'OPTION LCDPANEL ILI9341_16, LANDSCAPE
   'TOUCH PB12, PC5
   Const ADC_PIN = 15             ' 15/PC0 for F4
   Const HI_GAIN_HI = 1          ' switch to high gain, PE2/pin1 for F4
   Const HI_GAIN_LO = 5          ' switch to high gain, PE6/pin5 for F4
   GUI interrupt Touch_Int
 ElseIf MM.Device$="RP2040 PicoMite" Then
   'PicoMite initialisation
   'option system spi gp2,gp3,gp4
   'option lcdpanel ili9341,landscape,gp7,gp6,gp5
   'option touch cs,irq,beep - not tested
   Const ADC_PIN = 31 'GP26
   Const HI_GAIN_HI = 32 'GP27
   Const HI_GAIN_LO = 34 'GP28
   SetPin 24,PWM1A 'GP18
 Else
   'PIC32MX170 initialisation
   'OPTION LCDPANEL ILI9341, L, 2, 23, 6
   'OPTION TOUCH 7, 15
   CPU 48                          ' max speed - not needed in ARM F4
   Const ADC_PIN = 24              ' 24 for MX170
   Const HI_GAIN_HI = 10           ' switch to high gain, 10 for MX
   Const HI_GAIN_LO = 9            ' switch to high gain, 9 for MX
   ' enable touch
   SetPin 15, INTL, Touch_Int
 EndIf
 'start board
 SetPin ADC_PIN,ain              ' voltage input ADC1-ch10 (at pin 15)
 PWM 1,120000,50                 ' set PWM to 50% (0Vdc amplifier out)
                                 ' pin 31/PA6 on F4, pin 4 on MX170
 amp_high_gain                   ' set amplifier gain
 ' Define samples each scan
 Const samples = 64
 Const resolution = 1000
 ' external ADC divider (R15=47k into R10=12k//R11=15k)
 Const R10_R11 = 12000*15000/(12000+15000)
 Const resistor_divider = (47000 + R10_R11)/R10_R11
 ' Declare variables -------------------------------------------------
 ' Declare defaults for scaling ADC to 'resolution', these values
 ' are fine tuned in calibration (at powerup)
 Dim integer lowgain=resolution/3.3, highgain=2*lowgain
 Dim gain=lowgain
 Dim integer lowoffset=0, highoffset=-resolution/2
 Dim offset=lowoffset
 ' for user interface, xt/yt are touch coordinates
 Dim integer xt,yt
 ' generic i,j,h are counters, ADC is scaled adc value, adc10 and adc90
 ' are used in calibration
 Dim integer i,j,h,ADCV
 Dim float adc10,adc90
 ' display waveform, x/y are measured waveform, xr/yr are memory reference
 Dim integer x0,y0,x(samples),y(samples),xr(samples),yr(samples)
 ' init coordinates with values that fit the screen
 For i=1 To samples
   xr(i)=MM.HRes-3:yr(i)=MM.VRes/2:x(i)=MM.HRes-3:y(i)=MM.VRes/2
 Next i
 x0=MM.HRes-3:y0=MM.VRes/2
 ' display numerics, xnl/ynl for left side, xnr/ynr for right side
 Dim integer xnr=100,xnl=100,ynr=100,ynl=100,yor=0,yol=0
 Dim float vr,ir,vl,il
 ' generate waveform, pw = pwm value, pc = pwm value scaled to 'resolution'
 Dim pw(samples), pc(samples)
 ' fill waveform with triange wave 0...100%
 For i=1 To samples / 2
   pw(i) = 100 - ( 200 / samples ) * i
   pc(i) = resolution * pw(i) / 100
   pw(i + samples / 2) = ( 200 / samples ) * i
   pc(i + samples / 2) = resolution * pw(i + samples / 2) / 100
 Next
 ' graphics scaling to resolution
 Dim float Vstep = MM.VRes / resolution, Hstep = MM.HRes / resolution
 Dim center = resolution / 2
 ' buttons and line colors
 Dim integer membuttoncolor = RGB(blue), zoombuttoncolor = RGB(blue)
 Dim integer memcolor = RGB(black), linecolor = RGB(yellow)
 'debug
 Memory
 ' initialize screen
 draw_window
 ' timed interrupts
 SetTick 1000, Time_Int, 1
 ' calibrate analog circuits
 calibrate
'------------------------------ MAIN ------------------------
main:
 ' all comments removed from main loop to speed it up
 ' cycle through all pwm values using pointers i (actual) and j (last)
 ' erase last segment
 ' allways draw memory line, but color decides if it is visible
 ' draw memory line first so actual overwrites memory
 ' measure input value
 ' recalculate new segment (huntron method)
 ' draw new segement
   Timer = 0
   For i = 1 To samples
     j = i - 1 : If j = 0 Then j = samples
     PWM 1,120000,pw(i)
     Line x0,y0,x(i),y(i),1,0
     Line xr(j),yr(j),xr(i),yr(i),1,memcolor
     x0 = x(i) : y0 = y(i)
     ADCV = (Pin(ADC_PIN) * gain) + offset
     y(i)=(ADCV - pc(i) + center) * Vstep
     x(i)= ADCV * Hstep
     Line x(j),y(j),x(i),y(i),1,linecolor
   Next i
   Print Timer
'--------------------------- SUBS ---------------------------
Sub Touch_Int
 xt = Touch(x) : yt = Touch(y)
 'check for MEM button if we should display memory
 If xt < ( MM.HRes / 4 ) And yt < ( MM.VRes / 4 ) Then
   If memcolor = RGB(black) Then
     For h = 1 To samples          'copy live to REF line
       yr(h) = y(h)
       xr(h) = x(h)
     Next
     memcolor = RGB(red)
     membuttoncolor = RGB(red)
   Else
     membuttoncolor = RGB(Blue)
   EndIf
   RBox 10,10,60,30,2,RGB(white),membuttoncolor
   Text 30,18,"MEM",,,,RGB(white),membuttoncolor
 EndIf
 'check for ZOOM button to see if we should zoom in
 If xt > (3 * MM.HRes / 4 ) And yt > (3 * MM.VRes / 4) Then
   If zoombuttoncolor = RGB(blue) Then
     zoombuttoncolor = RGB(red)
     adc_high_gain
     amp_low_gain
   Else
     zoombuttoncolor = RGB(Blue)
     adc_low_gain
     amp_high_gain
   EndIf
     RBox MM.HRes-70,MM.VRes-40,60,30,2,RGB(white),zoombuttoncolor
     Text MM.HRes-55,MM.VRes-32,"ZOOM",,,,RGB(white),zoombuttoncolor
 EndIf
 draw_frame
 Pause 300                 'prevent double touch
End Sub
Sub amp_high_gain
     SetPin HI_GAIN_LO,dout : Pin(HI_GAIN_LO)=0
     SetPin HI_GAIN_HI,dout : Pin(HI_GAIN_HI)=1
End Sub
Sub amp_low_gain
     SetPin HI_GAIN_LO,din
     SetPin HI_GAIN_HI,din
End Sub
Sub adc_high_gain
     gain = highgain
     offset = highoffset
End Sub
Sub adc_low_gain
     gain = lowgain
     offset = lowoffset
End Sub
Sub draw_window
 'clear screen
 CLS
 'draw outside lines
 draw_frame
 'draw buttons
End Sub
Sub calibrate
 'calibrate standard mode ------------
 amp_high_gain
 adc_low_gain
 'measure 10% and 90% points
 PWM 1,120000,10
 Pause 1
 adc10 = Pin(ADC_PIN)
 PWM 1,120000,90
 Pause 1
 adc90 = Pin(ADC_PIN)
 'calculate ADC low gain and offset
 lowgain = 80 * resolution / (100 * (adc90 - adc10))
 lowoffset = - lowgain * (adc10 - ((adc90 - adc10)/8))
 Print adc10, adc90, lowgain , lowoffset
 'calibrate zoom mode --------------
 amp_low_gain
 adc_high_gain
 'measure 10% and 90% values
 PWM 1,120000,10
 Pause 1
 PWM 1,120000,90
 Pause 1
 'calculate ADC high gain and offset
 highgain = 80 * resolution / (100 * (adc90 - adc10))
 highoffset = - highgain * (adc10 - ((adc90 - adc10)/8))
 Print adc10, adc90, highgain , highoffset
 'back to standard mode
 amp_high_gain
 adc_low_gain
End Sub
Sub draw_frame
 'draw outside lines
 Line 1,1,1,MM.VRes-2,2,RGB(white)
 Line 1,MM.VRes-2,MM.HRes-2,MM.VRes-2,2,RGB(white)
 Line MM.HRes-2,MM.VRes-2,MM.HRes-2,1,2,RGB(white)
 Line MM.HRes-2,1,1,1,2,RGB(white)
End Sub
Sub Time_Int
 'check if left marker needs update
 If ynl <> y(samples/2) Then
   'erase old text
   Text xnl+12,ynl+yol,"       ",l,,,0,0
   'write markers
   Box xnl-5,ynl-5,10,10,,0
   ' calculate voltage
   xnl = x(samples/2): ynl = y(samples/2)
   vl = resistor_divider * ((xnl - MM.HRes / 2) / Hstep) / gain
   ' repair corrupted frame
   draw_frame
   'write markers
   Box xnl-5,ynl-5,10,10,,RGB(cyan)
   'get new coordinates for writing text, and write
   If ynl > MM.VRes-30 Then yol=-20 Else yol=5
   Text xnl+12,ynl+yol,Str$(vl,0,2)+"V",l,,,RGB(white),0
 EndIf
 ' check if right marker needs an update
 If ynr <> y(samples) Then
   'erase old text
   Text xnr-12,ynr+yor,"       ",r,,,0,0
   'write markers
   Box xnr-5,ynr-5,10,10,,0
   ' calculate voltage
   xnr = x(samples): ynr = y(samples)
   vr = resistor_divider * ((xnr - MM.HRes / 2) / Hstep) / gain
   draw_frame
   'write markers
   Box xnr-5,ynr-5,10,10,,RGB(cyan)
   If ynr < 30 Then yor=5 Else yor=-20
   Text xnr-12,ynr+yor,Str$(vr,0,2)+"V",r,,,RGB(white),0
 EndIf
End Sub
Edited 2021-07-21 17:15 by Volhout
Posted: 05:37pm 21 Jul 2021
V5.07.00b4
PicoMiteV5.07.00b4.zip
Includes pullups on UART RX pins
Fixes bug in READ comamnd when using individual array elements (bug introduced in b3)
Generates error when ADC used as variable name
Edited 2021-07-22 03:38 by matherp
Glen0
Posted: 05:07am 22 Jul 2021
Greenhorn question..
I'm trying to load a simple program into a picomite running b4. It has nothing connected (no SD Card or LCD etc) after loading the program I get;
"ERROR: SDcard not configured"
Failed to start
Saving program
Can I run a pico without an SD card and if so what do I need to do so that I don't get that error. (I haven't successfully loaded any programs into a Pico yet. I have only ever been using micromites.)
Posted: 06:44am 22 Jul 2021
  Quote  Can I run a pico without an SD card
Yes
  Quote  I'm trying to load a simple program into a picomite running b4
More information needed. How are you trying to load the program? If your are using MMEdit you have got the protocol wrong (don't use CMM2 or CMM)
Edited 2021-07-22 18:31 by matherp
Glen0
Posted: 08:34am 22 Jul 2021
Connected with MMEdit and I'm just trying to do a simple A/D conversion on pin 31 and print it to MM Chat.
Glen0
Posted: 08:37am 22 Jul 2021
Sorry, Just re-read your reply and realised I am using the CMM 2 Chat.
I will see what other options there are.
Posted: 08:40am 22 Jul 2021
On the dropdown in MMEDit choose Micromite+
Glen0
Posted: 11:11am 22 Jul 2021
Much appreciated,
I got as far as Micromite 5.05.01 which was more successful, but still had a count argument complaint. I will use your suggestion this weekend if I get a bit of spare time. Looking forward to getting it going.
Posted: 11:53am 22 Jul 2021
  Mixtel90 said  RTF file of a provisional doc for the beta versions. This is a bit more like a manual but still doesn't pretend to be one.
Since the picomite lacks the SERVO command which all of the other micromites have (I think) except DOS, do you think it would be good to add info about the PWM command which can be used to control a standard servo to the documentation?
Peter said the PWM range is between 5 and 10, so, for instance, for pin 25, GP19:
setpin 25,pwm1b
pwm 1,50,,5+(servo_position_in_percent_of_full_scale)*0.05
This code works--20 steps from full counter-clockwise to full clockwise and back in 100ms steps.
SetPin 25,pwm1b
do
For j=1 To 40
  If j < 21 Then
    PWM 1,50,,5+j*.25 ' swing clockwise
    Print 5+j*.25;" ";
  Else
    PWM 1,50,, 10-(j-20)*.25 ' swing counter-clockwise
    Print 10-(j-20)*.25;" ";
  EndIf
  Pause 100
Next j
loop
Posted: 03:11pm 22 Jul 2021
Done, lizby. :)
Latest version:
PicoMite Beta docs 00b1.zip
It's getting a little large, I suppose, but I doubt if it'll get a lot bigger now.
Posted: 04:19pm 22 Jul 2021
V5.07.00b5
This version now allows you to use different pins for the SPI for the SDcard and the LCD/TOUCH
OPTION SDCARD CSpin [,CLKpin, MOSIpin, MISOpin]
If the optional pins are not specified the SDcard will use the pins specified by OPTION SYSTEM SPI
NB: the pins specified by OPTION SYSTEM SPI must be a valid set of H/W SPI pins (SPI0 or SPI1), however, the pins specified by OPTION SDCARD can be any pins. Obviously the pins specified by OPTION SYSTEM SPI and OPTION SDCARD can't be the same.
The reason for the change is to increase flexibility and allow the use of some of the Waveshare display boards for the Pico that use different pins for the two functions.
This beta version completes all my outstanding functional enhancements and subject to further testing will become the first release candidate
Posted: 04:45pm 22 Jul 2021
is the SD card speed option still valid, Peter?
Posted: 05:35pm 22 Jul 2021
  Quote  is the SD card speed option still valid, Peter?
No: the SDcard is now always bitbanged for reliability
Posted: 05:52pm 22 Jul 2021
I thought it was. I've not checked the latest betas, but 00b1 was still showing it on OPTION LIST.
Posted: 07:06pm 22 Jul 2021
Servo always has been a strange thing in control languages. This is partly because the RC servo's had brand specific specification.
The Graupner servo's had a mid position of 1.5ms rotating CW
The Robbe/Futaba servo's also had a 1.5ms mid position but rotate CCW
The Multiplex servo's had a 1.6ms mid position rotatin CW
Of coarse the gains (angle change per ms) was different, as was the operating range of the PWM input.
Currently servo's have a mid position of 1.5ms, and they operate +/- 60 degrees between 1ms and 2ms. Generally the operating range is 0.75ms....2.25ms, allowing the servo's to rotate -90/+90 degrees maximum.
1/ This is what is implemented in the PICAXE basic, where you set the servo in degrees (actually 0...180 degrees)
2/ In MMBasic you program the servo in ms. There is technically no limitation, so you can rotate the servos to positions that are beyond it's control.
If we include an example routine in our documentation how to control servo's with using PWM, I suggest to use one of the above definitions. A simple mathmatical formula that either converts degrees to %, or ms to %.
For MMbasic formula: simply multiply with 5
/for a servo connected to PWM1A, tested on CMM2
SERVO_MS! = 1.5   'value in ms
PWM 1,50,SERVO_MS!*5
Those are my 5 ct....
P.S. what is agains simply adding the servo command ? Do we exceed 256 commands ?
Edited 2021-07-23 05:19 by Volhout
Posted: 07:19pm 22 Jul 2021
I know nothing whatsoever about servos. I've never even handled one. If anyone wishes me to add servo stuff to the doc I'm afraid they are going to have to tell me *exactly* what they want. I'm not going to guess on this one. :)
It appears to me that the PWM system is far more flexible than any SERVO command could be. What you need are some standard subroutines that can be used to suit whatever limits you want for particular servos. But then, what would I know?  :)
Edited 2021-07-23 05:21 by Mixtel90
Posted: 09:54pm 22 Jul 2021
Hi Peter,
The PicoMite seems to be limited to 64 Functions/Subs ?
Is this a hard limit or something the code has inherited from earlier Micromites and could be upped ?
Fingers crossed it is the latter otherwise it rather kibosh's my attempt to get my unit-tests and SAAINT running on the PicoMite  .
panky
Posted: 10:40pm 22 Jul 2021
Hi All,
Beta 5 does not come up as a link for me - anyone else have this problem?
Doug.
palcal
Posted: 10:47pm 22 Jul 2021
Yes, I noticed that earlier, was waiting for someone else to confirm.
     Page 3 of 13
