Local Time 12:36 21 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteVGA DEMO
     Page 6 of 13
Posted: 12:58pm 02 Dec 2024
Very nice !!!
twofingers
Posted: 01:25pm 02 Dec 2024
I think this is a nice example to understand "map" and to play with it.
'Toroidal Reactor by javavi/2024
MODE 2
Map Reset
Dim PicFile$="iter.bmp"
Dim integer cm(15)=(15,7,1,0,0,10,10,10,10,10,10,10,10,10,10,10)'red iter
'Dim integer cm(15)=(0,15,7,1,0,0,0,0,0,0,0,0,0,0,0,0)'dark iter
'Dim integer cm(15)=(15,14,13,12,11,10,9,8,7,6,5,4,3,2,1,0)'colorful iter
Colour Map cm(),cm()
If MM.Info(exists file PicFile$) Then
 Load image PicFile$
Else
 For U=0 To 159
  x1=U/128-1.25
  For V=0 To 239
    y1=V/128-1
    X=0:Y=X:Z=-2.4
      k1=Sqr(X*X+Z*Z)-2
      d1=1-Sqr(k1*k1+Y*Y)
      X=X+x1*d1:Y=Y+y1*d1:Z=Z+d1
    Loop Until d1<.005
    v1=Atn(Z/X):u1=Atn(Y/k1)
    sColor(): Pixel U,V
    v1=3.13-v1
    sColor(): Pixel 319-U,V
  Next
 Next
 Save image PicFile$
EndIf
T=cm(1)
For i=1 To 15-1:cm(i)=cm(i+1):Next
cm(15)=T
For i=1 To 15:Map(i)=cm(i):Next
Map Set
Pause 50
Sub sColor()
p=Sin(Int((u1+v1)*40)*99)*98
c=15 And ((u1-v1+p)*24*Abs(Sin(p)))
Color Map(c)
End Sub
15 WHITE RGB(255, 255, 255)
14 YELLOW RGB(255, 255, 0)
13 LILAC RGB(255, 128, 255)
12 BROWN RGB(255, 128, 0)
11 FUCHSIA RGB(255, 64, 255)
10 RUST RGB(255, 64, 0)
9 MAGENTA RGB(255, 0, 255)
8 RED RGB(255, 0, 0)
7 CYAN RGB(0, 255, 255)
6 GREEN RGB(0, 255, 0)
5 CERULEAN RGB(0, 128, 255)
4 MIDGREEN RGB(0, 128, 0)
3 COBALT RGB(0, 64, 255)
2 MYRTLE RGB(0, 64, 0)
1 BLUE RGB(0, 0, 255)
0 BLACK RGB(0, 0, 0)
javavi
Posted: 03:58pm 02 Dec 2024
Stellarator RP2350 MODE 3  640x480 in colour
MODE 3
Map Reset
For U=0 To 319
 x1=U/256-1.255
 For V=0 To 479
   y1=V/256-1
   X=0:Y=X:Z=-2.4
     k=Sqr(X*X+Z*Z)-2
     d=1-Sqr(k*k+Y*Y)
     X=X+x1*d:Y=Y+y1*d:Z=Z+d
   Loop Until d<.01
   v1=Atn(Z/X)
   u1=Atn(Y/k)
   sColor(): Pixel U,V
   v1=3.13-v1
   sColor(): Pixel 639-U,V
 Next
Next
'Dim integer cm(15)=(0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15)
Dim integer cm(15)=(0,15,14,6,4,2,0,0,0,0,0,0,0,0,0,0)
 T=cm(0)
 For i=0 To 14:cm(i)=cm(i+1):Next
 cm(15)=T
 For i=0 To 15:Map(i)=cm(i):Next
 Map Set
 Pause 50
Sub sColor()
 Color Map(c)
End Sub
javavi
Posted: 08:54pm 02 Dec 2024
Toroidal Reactor  MODE 2  Stellarator
MODE 2
Map Reset
Dim PicFile$="TOR.bmp"
 Load image PicFile$
Else
 For U=0 To 159
   x1=U/128-1.25
 For V=0 To 239
   y1=V/128-1
   X=0:Y=X:Z=-2.4
     k=Sqr(X*X+Z*Z)-2
     d=1-Sqr(k*k+Y*Y)
   Loop Until d<.005
   v1=Atn(Z/X):u1=Atn(Y/k)
   sColor(): Pixel U,V
   v1=3.13-v1
 Next :Next
 Save image PicFile$
EndIf
 For N=0 To 31
   T=cm(0)
   cm(15)=T
   Map Set
   Pause 50
 Next
 For i=0 To 15
   If i<4 Then cm(i)=Map(Int(Rnd*15)) Else cm(i)=0
 Next
Sub sColor()
 Color Map(c)
End Sub
twofingers
Posted: 10:07am 03 Dec 2024
@Vadim: Good idea to add some variety.
Michael
javavi
Posted: 10:10am 03 Dec 2024
Fire Show Fountain
MODE 2
Map Reset
For I=0 To 2100
If Y>230 Then
 X=160
 Y=240
 x0=X:y0=Y
 x1=Cos(Rnd*Pi)*5
 y1=5+Rnd*16
EndIf
 X=X+x1:Y=Y-y1:y1=y1-1
 Inc C,-1:If C<1 Then C=15
 Color Map(C)
 If X>0 And X<320 Then Line x0,y0,X,Y
 x0=X:y0=Y
Next
For N=0 To 14
  T=cm(1)
  For i=1 To 14:cm(i)=cm(i+1):Next
  cm(15)=T
  Map Set
  Pause 100
Next
For i=1 To 15
  If i<3 Then cm(i)=Map(Int(Rnd*15)) Else cm(i)=0
Next
Geoffg
Posted: 11:41am 03 Dec 2024
javavi, I have to say that your "demo" programs are fantastic.
So much detail generated by such concise code.
Wonderful,
Geoff
javavi
Posted: 07:09pm 06 Dec 2024
  Geoffg said  I have to say that your "demo" programs are fantastic.
Thanks Geoff,
I must say, and I've already said this here, that I don't make up these formulas myself, I just take examples from the Internet and rewrite them in MMBASIC for PicoMite. Some examples had to be completely rewritten, and some I came up with myself, most likely inspired by something I saw.
With respect, javavi
Martin H.
Posted: 02:05pm 07 Dec 2024
  javavi said   Toroidal Reactor  MODE 2  Stellarator
MODE 2
Map Reset
 Load image PicFile$
Else
 For U=0 To 159
   x1=U/128-1.25
 For V=0 To 239
   y1=V/128-1
   X=0:Y=X:Z=-2.4
     k=Sqr(X*X+Z*Z)-2
     d=1-Sqr(k*k+Y*Y)
   Loop Until d<.005
   sColor(): Pixel U,V
   v1=3.13-v1
 Next :Next
 Save image PicFile$
EndIf
 For N=0 To 31
   T=cm(0)
   cm(15)=T
   Map Set
   Pause 50
 Next
 For i=0 To 15
 Next
Sub sColor()
 Color Map(c)
End Sub
if you replace PAUSE 50 with FRAMEBUFFER wait then it really gets going
'no comment
stanleyella
Posted: 01:15am 08 Dec 2024
javavi
Posted: 09:48pm 11 Dec 2024
∞ Lissajous Figures ∞
Option ANGLE DEGREES
FRAMEBUFFER CREATE
FRAMEBUFFER WRITE F
Colour RGB(Cyan),RGB(Blue)
CX=MM.HRes/2: CY=MM.VRes/2
Scale=0.95: AX=CY*Scale: AY=CY*Scale
a=1: b=0: p=0: f=0: c=0
 If p>360 Then p=0: EndIf
 If b>6   Then a=a+1: b=0: c=0: EndIf
 If a>5   Then a=1:   b=0: c=0: EndIf
 If c=50  Then
   f=1
   If a=Fix(b) Then f=0: c=0: EndIf
 EndIf
 If c=130 Then f=0: c=0: EndIf
 CLS
     sx= AX * Sin(p) + CX
     sy= AY * Sin(p) + CY
 For i= 0 To 360
     x = AX * Sin(a*i + p) + CX
     y = AY * Sin(b*i + p) + CY
     Line sx,sy,x,y
     sx=x: sy=y
 Next i
 Print "a ="a: Print "b ="b
 FRAMEBUFFER COPY F,N,B
 Inc p: Inc c
 If  f=0 Then b=b+.02: EndIf
Loop Until Inkey$ <> ""
End
javavi
Posted: 05:46am 13 Dec 2024
3D Dice
MODE 1
TILE 0,0,RGB(RED),RGB(BLACK),16,40
TILE 16,0,RGB(GREEN),RGB(BLACK),16,40
TILE 32,0,RGB(BLUE),RGB(BLACK),16,40
TILE 48,0,RGB(YELLOW),RGB(BLACK),16,40
'Print "3D Draw"
Dim n=1, nv=24, nf=6+8, camera=1
' Load vertices arrey
Dim v(2,nv-1)
Restore vertices2
For i=0 To nv-1: For a=0 To 2: Read v(a,i):Next :Next
' Load facecount arrey
Dim INTEGER facecount(nf-1), facesize=0
Restore facecount2
For i=0 To nf-1: Read facecount(i): Inc facesize,facecount(i): Next
' Load faces arrey
Dim INTEGER faces(facesize-1)
Restore faces2
For i=0 To facesize-1: Read faces(i): Next
' Load colours arreys
Dim INTEGER c(1)=(0,RGB(GREEN))
Dim INTEGER edge(nf-1)=(1,1,1,1,1,1, 1,1,1,1,1,1,1,1)
Dim INTEGER fill(nf-1)=(0,0,0,0,0,0, 0,0,0,0,0,0,0,0)
Math SCALE v(), 100.0, v()
Draw3D CREATE 1,nv,nf,camera,v(),facecount(),faces(),c(),edge(),fill()
Draw3D CREATE 2,nv,nf,camera,v(),facecount(),faces(),c(),edge(),fill()
Draw3D CREATE 3,nv,nf,camera,v(),facecount(),faces(),c(),edge(),fill()
Draw3D CREATE 4,nv,nf,camera,v(),facecount(),faces(),c(),edge(),fill()
Draw3D CREATE 5,nv,nf,camera,v(),facecount(),faces(),c(),edge(),fill()
nv=84: nf=21: camera=1
Dim v1(2,nv-1)
Restore vertices3
For i=0 To nv-1: For a=0 To 2: Read v1(a,i):Next :Next
Dim INTEGER facecount1(nf-1)
facesize=0
Restore facecount3
For i=0 To nf-1: Read facecount1(i): Inc facesize,facecount1(i): Next
' Load faces arrey
Dim INTEGER faces1(facesize-1)
Restore faces3
For i=0 To facesize-1: Read faces1(i): Next
Dim INTEGER edge1(nf-1)=(1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1)
Dim INTEGER fill1(nf-1)=(1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1)
Math SCALE v1(), 100.0, v1()
Draw3D CREATE 6,nv,nf,camera,v1(),facecount1(),faces1(),c(),edge1(),fill1()
Dim INTEGER viewplane=400
Draw3D CAMERA n, viewplane
Dim INTEGER x=0, y=0, z=6000
'Draw3D SHOW n, x, y, z
'END
Dim FLOAT yaw=Rad(1), pitch=Rad(2), roll=Rad(0.5)
Dim FLOAT q(4)
FRAMEBUFFER CREATE
FRAMEBUFFER WRITE F
 Math Q_EULER yaw, pitch, roll, q()
 Draw3D ROTATE q(),1
 Draw3D ROTATE q(),2
 Draw3D ROTATE q(),3
 Draw3D ROTATE q(),4
 Draw3D ROTATE q(),5
 Draw3D ROTATE q(),6
 Draw3D SHOW  1,x,y,z
 Draw3D WRITE 6,x,y,z
 Draw3D SHOW  2,-1800,y,z
 Draw3D WRITE 6,-1800,y,z
 Draw3D SHOW  3,-3600,y,z
 Draw3D WRITE 6,-3600,y,z
 Draw3D SHOW  4,1800,y,z
 Draw3D WRITE 6,1800,y,z
 Draw3D SHOW  5,3600,y,z
 Draw3D WRITE 6,3600,y,z
 Inc yaw,Rad(4)    '1
 Inc pitch,Rad(8)  '2
 Inc roll,Rad(2)   '0.5
 FRAMEBUFFER copy F,N,b
Loop Until Inkey$<>""
FRAMEBUFFER WRITE N
Memory
FRAMEBUFFER close
End
vertices2:  '24/14
Data -4,3,-4, -3,4,-4, 3,4,-4, 4,3,-4, 4,-3,-4, 3,-4,-4, -3,-4,-4, -4,-3,-4
Data -4,4,-3, 4,4,-3, 4,-4,-3, -4,-4,-3, -4,4,3, 4,4,3, 4,-4,3, -4,-4,3
Data -4,3,4, -3,4,4, 3,4,4, 4,3,4, 4,-3,4, 3,-4,4, -3,-4,4, -4,-3,4
facecount2:
Data 8,8,8,8,8,8,3,3,3,3,3,3,3,3
faces2:
Data 0,1,2,3,4,5,6,7, 12,17,18,13,9,2,1,8, 3,9,13,19,20,14,10,4
Data 16,12,8,0,7,11,15,23, 11,6,5,10,14,21,22,15, 19,18,17,16,23,22,21,20
Data 8,1,0, 9,3,2, 10,5,4, 11,7,6, 12,16,17, 13,18,19, 14,20,21, 15,22,23
vertices3:  '84/21
Data 0,1,-4,1,0,-4,0,-1,-4,-1,0,-4  '1
Data -2,4,-1,-1,4,-2,-2,4,-3,-3,4,-2, 2,4,3,3,4,2,2,4,1,1,4,2 '2
Data 4,-1,-2,4,-2,-1,4,-3,-2,4,-2,-3,4,1,0,4,0,1,4,-1,0,4,0,-1,4,3,2,4,2,3,4,1,2,4,2,1
Data -4,3,2,-4,2,1,-4,1,2,-4,2,3, -4,3,-2,-4,2,-3,-4,1,-2,-4,2,-1 '4
Data -4,-1,2,-4,-2,1,-4,-3,2,-4,-2,3, -4,-1,-2,-4,-2,-3,-4,-3,-2,-4,-2,-1
Data -2,-4,-3,-1,-4,-2,-2,-4,-1,-3,-4,-2, 2,-4,-3,3,-4,-2,2,-4,-1,1,-4,-2 '5
Data -2,-4,1,-1,-4,2,-2,-4,3,-3,-4,2, 2,-4,1,3,-4,2,2,-4,3,1,-4,2
Data 0,-4,-1, 1,-4,0, 0,-4,1, -1,-4,0
Data 2,3,4,1,2,4,2,1,4,3,2,4, -2,3,4,-3,2,4,-2,1,4,-1,2,4 '6
Data 2,1,4,1,0,4,2,-1,4,3,0,4, -2,1,4,-3,0,4,-2,-1,4,-1,0,4
Data 2,-1,4,1,-2,4,2,-3,4,3,-2,4, -2,-1,4,-3,-2,4,-2,-3,4,-1,-2,4
facecount3:
Data 4, 4,4, 4,4,4, 4,4,4,4, 4,4,4,4,4, 4,4,4,4,4,4
faces3:
Data 0,1,2,3
Data 4,5,6,7, 8,9,10,11
Data 12,13,14,15, 16,17,18,19, 20,21,22,23
Data 24,25,26,27, 28,29,30,31, 32,33,34,35, 36,37,38,39
Data 40,41,42,43, 44,45,46,47, 48,49,50,51, 52,53,54,55, 56,57,58,59
Data 60,61,62,63, 64,65,66,67, 68,69,70,71, 72,73,74,75, 76,77,78,79, 80,81,82,83
Posted: 07:34am 13 Dec 2024
Wauw !!!
Martin H.
Posted: 10:58am 13 Dec 2024
Nice Dice
'no comment
Posted: 11:31am 13 Dec 2024
Great to see the 3d code in use again
stanleyella
Posted: 06:33pm 13 Dec 2024
fast,pico2 hdmi.
which manual is Draw3d explained please?
I found Math Q_EULER yaw, pitch, roll, q().
now found See the document “The CMM2 3D engine” in the PicoMiteVGA firmware
download for a full description.
Edited 2024-12-14 05:02 by stanleyella
Posted: 07:03pm 13 Dec 2024
CMM2 has it, Stan. I'm not sure if it's been in a Pico manual yet.
stanleyella
Posted: 07:45pm 13 Dec 2024
thanks for replying Mick but clueless where, just relevant draw3d info and the 3d dice pico 2 works
Turbo46
Posted: 07:49pm 13 Dec 2024
@Stan,
From the PicoMite manual:
3D Engine
NOT AVAILABLE IN WEBMITE VERSIONS
The 3D Engine includes ten commands for manipulating 3D images including setting the camera, creating, hiding, rotating, etc. See the document The CMM2 3D engine.pdf in the PicoMite firmware download for a full description of these commands and how to use them.
Bill
stanleyella
Posted: 08:59pm 13 Dec 2024
I got a shortcut to the online manual
https://www.c-com.com.au/mmhelp/
Edited 2024-12-14 07:32 by stanleyella
     Page 6 of 13
