Local Time 19:06 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PIC32MZ  DM320104
kiaandre
Posted: 01:40pm 27 Apr 2020
Hello
I come back to the forum, because I have been blocking for several weeks concerning the dialogue between the DM320104 PIC32MZ2048EFM100 and MMEDIT card, As indicated on the forum:
https://www.thebackshed.com/forum/ViewTopic.php?TID=9689&PID=106658#106658
I think I have loaded the firmware MMEX5.4.04 hex with MPLAB X IPE ICSP PCKIT3 , I have the correct message, I try to communicate by the console USB / Serial FTDI 232RL which connects well but impossible to load a program - Thank you for your help
Posted: 10:25pm 27 Apr 2020
Doe it module work using TeraTerm or Putty?
Can you use the internal editor?
If so,
make sure that you have a suitable syntax file selected in MMEdit.
The correct syntax file tells MMEdit which commands to use when uploading programs.
You can also try loading programs using "Load" from the Chat window instead of "load and run" in the editor window.
kiaandre
Posted: 03:06am 28 Apr 2020
The pic32mz card is quite difficult to understand, Thank you for helping me, I followed your recommendation but nothing or done, impossible to communicate. Here is the state of my material
The DM320104 card is powered by the USB J12 connector, the Jumper J8 is removed, the jumper J13 is in place, the leds D1 D2 D3 are on, the led LED1 flashes red, to communicate between the PC and the PIC32MZ, I installed a "USB UART Click" module on the Mikro BUS 1
Here is the report of MMEDIT
Starting process...
Chat closed
File manager closed
Connection Handle: 72353864 0
Break...
Break...
Break...
Break...
Break...
Break...
Break...
Break...
Break...
Break...
Break...
Break...
Break...
Break...
Break...
sending NEW
Clearing...
Clearing...
Clearing...
Clearing...
Clearing...
Clearing...
Clearing...
Clearing...
Clearing...
Clearing...
Clearing...
Clearing...
Clearing...
Clearing...
Clearing...
Checking device...
Checking version...
Micromite_eXtreme_5.3
MMBasic Version V  0.0000 detected
Sending C:\Users\ANDRE\Documents\temp.bas
Blocks:1
Failed to start
Saving program
excuse me, I translate with Google
Thanks for your help
Edited 2020-04-28 13:17 by kiaandre
Posted: 04:54am 28 Apr 2020
Do not use MMEdit
Use a terminal program such as TeraTerm or Putty.
When you have that working, we can try MMEdit.
Turbo46
Posted: 06:56am 28 Apr 2020
That report of MMEDIT that you are showing is what you see when MMEdit is not communicating with the board.
You say "it connects well" but what does that mean?
Can you check with Windows Device Manager which serial port the board is connected to?
MMEdit or TeraTerm must be set to communicate over that serial port. The windows port must be set to the correct baud rate (38400 baud, 8 bit, no parity). TeraTerm and MMEdit must be set to the same.
If you have that correct, push the reset button on the board and you should see on TeraTerm (or in the chat window in MMEdit) the MMBasic start message.
I see in that the picture on the link you posted that there is a USB cable plugged into the USB connector (J12) is that the one you are using?
Good luck
Bill
Posted: 07:09am 28 Apr 2020
The correct pins for the console are PF0 (console-RX) and PF1 (console-TX). The Click port doesn't use these pins so it can't work. They appear to be available as pins 2 and 3 on the PHY Daughter Board HDR. You need to connect an external USB/UART to these pins.
Edited 2020-04-28 17:10 by matherp
disco4now
Posted: 07:30am 28 Apr 2020
Which crystal is populated on the board. X2 or Y2. Should have the 24Mhz at X2 position populated.
F4 H7FotSF4xGT
kiaandre
Posted: 12:24pm 28 Apr 2020
I check all this info this afternoon and keep you informed
kiaandre
Posted: 04:41am 29 Apr 2020
Hello, following your advice, I have all checked, removed the UART CLICK USB module, I stayed in USB by J12 and press the MCLR button and the card is connected, then I went through TERATERM and OUF the pic32mz I answered, then went through MMEDIT and it works too. Sometimes it’s just a little detail that gets you stuck, your answers help me and I thank TassyJim, Turbo46, matherp, disco4now for your help, the adventure continues with the pic32mz, see you soon
SWA-Guy
Posted: 04:42pm 03 May 2020
Hello Guys,
I've here also two Curiosity boards working fine with firmware V5.4.04. But if use any later firmware the serial USB-communication with USB-J12 not works.
Is there anything to config or is there a bug? The communication with Console RX/TX over a USB/UART adapter works evertime.
Thanks for a answer.
Posted: 04:50pm 03 May 2020
I made a decision to re-purpose the USB port as a keyboard host rather than a serial console sometime during the various development phases. All my PCBs use an external Microbridge that can act as both a USB serial adapter and a programmer.
In-built USB serial ports are not ideal as the serial connection drops every time the processor is reset
SWA-Guy
Posted: 05:37pm 03 May 2020
Hello Peter,
I understand.
Thanks for your quick a answer and a big thank you to you, Geoff and the others from the team for the Colormaximite 2.
kiaandre
Posted: 05:43pm 03 May 2020
Hello,
Concerning the purchase of development boards in MMBASIC, or buying them in Europe?
Thank you
Posted: 06:04pm 03 May 2020
  Quote  Concerning the purchase of development boards in MMBASIC, or buying them in Europe?
All the gerbers are here. You can also contact Micromite.org (WhiteWizard) who may have some available.
The cheapest way to get high performance MMBasic is either the ArmmiteF4 or the ArmmiteH7 both of which run on widely available commercial stock boards
Edited 2020-05-04 04:07 by matherp
kiaandre
Posted: 09:08am 06 May 2020
The DM320103 ----> firmware Micromite plus --------> PIC32MX470F512H
The DM320104 ----> firmware Micromite Extreme -----> PIC32MZ2048EFM100
