Local Time 10:35 19 Jul 2025 Privacy Policy
Forum Index : Microcontroller and PC projects : Introducing the Colour Maximite 2
     Page 14 of 25
Posted: 12:04pm 18 May 2020
  Quote  I would still expect to sometimes need to render 100 polygons per frame, which as you indicate should be within the bounds of possibility.
How about, as an example, 100 trapezoids each containing 7500 pixels in 14.4 mSec?
Coming soon to a release near you
Edited 2020-05-18 22:07 by matherp
Posted: 12:08pm 18 May 2020
That will do.
Now I suppose you'll expect me to write the bl**dy thing - ZMachine first though.
Andrew_G
Posted: 11:57pm 18 May 2020
Ahhhhhh Jim - many thanks.
Spurred on by your reassurance I probed deeper (into the schematic, the pictures AND the parts list). The USB for the keyboard is a vertical Type A - not a Type B as I had interpreted from the photograph. What I thought was an A to its right is in fact the B. It all makes sense now - because it has always been right.
I can use a spare USB A keyboard and swap it out for a male-male to program.
Cheers,
Andrew
Edited 2020-05-19 11:21 by Andrew_G
Chopperp
Posted: 09:17am 19 May 2020
  TassyJim said
If you use a RPi breakout board, make sure it is used the correct way around.
I had to re-terminate the cable on mine to get the orientation correct.
@TassyJim
Did you happen to check if the cable supplied was actually correct for a RPi?
I received a couple of breakout boards similar to yours from a Aussie supplier & it appears that the supplied cable transposes the pins.
I don't have either a RPi or my CMM-2 yet to check things out. Just going by diagrams.
I'd hate to think that incorrectly wired cables are being supplied for the RPi
Brian
ChopperP
cdeagle
Posted: 01:17pm 19 May 2020
I now have a CMM2 that works. The keyboard exchange of " and @ has gone away.
The number-crunching is going well. Sometimes seeing a difference in the last decimal place between the Micromite Extreme version and the CMM2 version.
Thanks again everyone for creating the CMM2.
CircuitGizmos
Posted: 02:42pm 19 May 2020
  cdeagle said  I now have a CMM2 that works. The keyboard exchange of " and @ has gone away.
Glad to hear! Not sure how the universe worked against us on the first CMM2.
Posted: 03:42pm 19 May 2020
Please find attached V5.05.02RC32
CMM2V5.05.02RC32.zip
Geoff will update the official download when he has an opportunity
This has the following changes over V5.05.02RC28
Bug fixes:
Fixes bug in ERROR command
Fixes bug where input$ reads 1 character past the end of a file
Fixes bug in select & delete/copy/cut multiple lines when start line is blank
Fixes bug in code underlying BLIT and SPRITE SCROLLR that could cause a processor hang
Changes:
Change to SAVE IMAGE: new optional parameters
SAVE IMAGE fname$ [,x, y, w, h]
Save the current image on the VGA screen as a BMP file.'file$' is the name of the file.  If an extension is not specified “.BMP” will be added to the file name.The image is saved as a true colour 24-bit image
The x ,y, w, and h parameters  allow you to save a part of the image rather than all of it. The new parameters are optional and the whole screen is saved if not specified. The additional parameters are all or none. x and y are the coordinates of the top left pixel to be saved and w and h are the width and height of the area to be saved.
Change to POLYGON command + huge performance increase
WARNING new syntax will break existing programs
POLYGON n, xarray%(), yarray%() [, bordercolour] [, fillcolour]
Draws a filled or outline polygon with n xy-coordinate pairs in xarray%() and yarray%().
If fill colour is omitted then just the polygon outline is drawn.
If bordercolour is omitted then it will default to the current gui foreground colour.
If the last xy-coordinate pair is not the same as the first
the firmware will automatically create an additional xy-coordinate pair to complete the polygon
The size of the arrays should be at least as big as the number of x,y coordinate pairs
POLYGON n(), xarray%(), yarray%() [, bordercolour()] [, fillcolour()]
POLYGON n(), xarray%(), yarray%() [, bordercolour] [, fillcolour]
Draws multiple polygons.
The size of the n array determines the number of polygons that will be drawn.
The elements of array n() define the number of xy-coordinate pairs in each of the polygons.
e.g DIM n(1)=(3,3) would define that 2 polygons are to be drawn with three vertices each.
The xy-coordinate pairs for all the polygons are stored in xarray%() and yarray%().
The xarray%() and yarray%() parameters must have at least as many elements as the total of the values in the n array.
Each polygon can be closed with the first and last elements the same. If the last element is not the same as the first the firmware will automatically create an additional xy-coordinate pair to complete the polygon.
If fill colour is omitted then just the polygon outlines are drawn.
The colour parameters can be a single value in which case all polygons are drawn in the same colour or they can be arrays with the same cardinality as n. In this case each polygon drawn can have a different colour of both border and/or fill.
For information the polygon fill uses a modified Scan Line Algorithm. This is extremely robust, not always the fastest but will not miss pixels and even copes with crossing lines.
My performance test of polygons
cls
dim c%(99)
dim x%(399)
dim y%(399)
dim fc%(99)
for i=0 to 99:c%(i)=4:fc%(i)=rgb(green):next i
for i=0 to 99 step 2:fc%(i)=rgb(red):next i
for i=0 to 399 step 4: x%(i)=25+i:next i
for i=1 to 399 step 4: x%(i)=75+i:next i
for i=2 to 399 step 4: x%(i)=100+i:next i
for i=3 to 399 step 4: x%(i)=0+i:next i
for i=0 to 399 step 4: y%(i)=0+i:next i
for i=1 to 399 step 4: y%(i)=-1+i:next i
for i=2 to 399 step 4: y%(i)=100+i:next i
for i=3 to 399 step 4: y%(i)=99+i:next i
timer=0
polygon c%(),x%(),y%(),fc%(),fc%()
print timer
cdeagle
Posted: 04:27pm 19 May 2020
Ran several of the astronomy programs for 100,000 days without any problems.
I'm flashing back to the QuickBASIC days. Trying to find the QB program that scaled x-y data for plotting.
Posted: 04:32pm 19 May 2020
  Quote  Ran several of the astronomy programs for 100,000 days without any problems.
Excellent news. I routinely use the solar eclipse program both as a functional and performance test. If it does that OK there can't be too much wrong :-)
cdeagle
Posted: 07:02pm 19 May 2020
I am looking for a case for the Waveshare module version of the CMM2.
Posted: 11:22pm 19 May 2020
  cdeagle said  I am looking for a case for the Waveshare module version of the CMM2.
Element14 have the case as stock number 1526699
G738A -  Plastic Enclosure, Instrument, ABS, 35 mm, 140 mm, 110 mm
Manufacturer Multicomp Pro
In Australia, it is cheaper
Jaycar CAT.NO: HB5970
In US
Newark Part No.: 74M2314
A google search for G738A should give you some options.
cdeagle
Posted: 09:13am 20 May 2020
Thanks Jim.
cTrix
Posted: 04:39pm 20 May 2020
Hey all.  I've just bought the parts for 5 Colour Maximites to build as kits (for some friends as well).  Mainly because I couldn't order half the parts in less than quantities of 5!
I've also rendered a set of Gerbers to layers and rendered them out of Photoshop.  I just hadn't seen the board rendered anywhere yet.  Sorry the holes are slightly out of calibration (probably true to real world!)  Happy to render it again in higher res if it's of any use to anyone.
One thing I noticed in the Parts List:
Thehas the part number "FC1"  (numeral 1) where it should be "FCI" (the letter I).   So it should be the Amphenol FCI 61729-0010BLF. Consequently the Mouser part is 61729-0010BLF.
I made a video about the Maximite 1.0 a few weeks ago which I'm on the fence about if I should release now the 2.0 is coming out.... but I might change the voice over at the start and put it out for legacy.  I literally finished making my 1.0 a week before Version 2 was announced.  I'm extra excited though... only thing I wanted to change was to go from 8 colours to 64 and this is way more.  Can't wait to start making demos on it :-)
Edited 2020-05-21 03:45 by cTrix
Link: YouTube Colour MaxiMite 2 Intro Video   |   ctrix.net
Poppy
Posted: 06:40pm 20 May 2020
Hi cTrix,
... and many of us can´t wait to see your videos and demos!
And about the "old" CMM as well!
Just go on and rock it!
Andre ... such a GURU?
Cyber
Posted: 03:32am 21 May 2020
  cTrix said  I made a video about the Maximite 1.0 a few weeks ago
Share, please.
Posted: 06:00pm 21 May 2020
Please find attached V5.05.02RC35
CMM2V5.05.02RC35.zip
Changes from RC32
Fixed an issue introduced in RC31 where USB keyboard enumeration was less reliable than in previous versions
Fixed bug in array state after running editor and also in other conditions
Improved Circle drawing algorithm
Fixed various bugs in graphics commands when scalar colours are used with arrayed coordinates
Modified POLYGON command so x and y coordinate arrays can each be float or integer as required
cTrix
Posted: 06:43pm 21 May 2020
Hi all!
I just got a pretty interesting email from my PCB peeps.
> Dear Sir,
> For PCB order xxxxxxx, please notice the picture attached, on
> non-plated-hole layer,there is one drill hole is connected with the
> copper trace,should we make it plated hole?
From what I can see of the traces... that's digital ground on top, and a "nothing" plane on bottom - but I figured the two probably don't want to connect?
I advised them not to make it a plated hole.
Although, is there any issue with a screw going down that hole and potentially shorting the two?
For those interested, I put this up an hour ago. https://www.youtube.com/watch?v=mv99JO52FJo
Sorry if it's bit critical of version 1!  I re-edited it to include reference to V2 as the announcement was the morning I was going to release it.  I'll do a video on V2 when all my parts arrive. :-)  Hopefully the info at the end screen is all good.
Edited 2020-05-22 04:46 by cTrix
Poppy
Posted: 06:53pm 21 May 2020
  matherp said  Please find attached V5.05.02RC35
= uploads/matherp/2020-05-22_035449_CMM2V5.05.02RC35.zip]CMM2V5.05.02RC35.zip
Wouldn´t it be better to keep all revisions under the same download-link being constantly updated:
http://geoffg.net/Downloads/Maximite/Colour_Maximite_2_MMBasic.zip
Posted: 06:55pm 21 May 2020
The 4 mounting holes are in the "unplated" drill file so why would they think to plate them?
The copper fill on the top is 3V3, on the bottom it is GND
In a perfect world, the screws should have a fibre washer under the head on the top but the solder mask is pretty robust unless excessive force is used. Unfortunately the mounting holes are too close to the I/O connector to use a bigger safer surround
  Quote  Wouldn´t it be better to keep all revisions under the same download-link being constantly updated:
Yes, of course, but Geoff and I are on different timezones. All key releases will be uploaded to his site and once the SC articles hit the street I will stop posting firmware to TBS
Edited 2020-05-22 04:57 by matherp
Posted: 11:54pm 21 May 2020
  cTrix said  For those interested, I put this up an hour ago. https://www.youtube.com/watch?v=mv99JO52FJo
Great video. Very jealous of what you got the original CMM to do graphically.
     Page 14 of 25
© JAQ Software 2025
