Forum Index : Microcontroller and PC projects : CMM2 5.05.06 beta
Page 10 of 12 | |||||
i'm guessing that the two lines: Option Console Screen Print "a"; were resulting in a carriage-return erroneously being sent to the serial console. so what the serial console 'saw' from the program running was: <cr>bc<cr>bc<cr>bc<cr>bc<cr>bc<cr>bc<cr>bc<cr>bc<cr>bc<cr>bc with only the final bc being visible to the casual observer (the previous 9 occurrences each being overwritten). cheers, rob :-) Edited 2020-10-02 23:10 by robert.rozee |
No, much simpler than those explanations. Output is buffered under interrupt control. The Basic code is running so fast that the serial console is disabled before the characters have been transmitted. Print is non-blocking. All that was needed was a short pause after the print before you execute OPTION CONSOLE SCREEN to allow the outgoing serial transmission to complete |
thwill Guru Joined: 16/09/2019 Location: United KingdomPosts: 3865 |
OK ... so calling OPTION CONSOLE SCREEN is now causing a short pause, is that perceivable? I think I can see a short delay as each line of my menu is rendered, it could just as well be something else. No worries, I will change how I do it. Best wishes, Tom Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
It waits for the console serial output buffer to be empty and then waits 10mSec for the last character to complete transmission before returning |
Sasquatch Senior Member Joined: 08/05/2020 Location: United StatesPosts: 296 |
I can report no more watchdog resets changing modes with V5.05.06b15, so that one seems fixed! Thanks for the changes to the file manager pageup/pagedown! Thanks for the photo of the oscillator installed on the Waveshare board! For some reason, b15 seems slightly slower on the "speed test" than b14. I noticed about 10% improvement from v5.05.05 release to b14 and now the improvement is cut about in half with b15. Something going on behind the scenes??? -Carl |
The speed is different every time I do a full compile. Seems like tiny code changes affect the optimiser in unforeseen and unforeseeable ways Speed is also very different (slower) in video modes that have high bit rates and/or use the SDRAM - presumably bus contention Edited 2020-10-03 02:11 by matherp |
Could you check if "SPRITE HIDE ALL" is cancelled correctly when a program is run? I tried "SPRITE HIDE ALL" in a program, which ended with a "sprites are hidden" error. After I edited the program and commented out the "SPRITE HIDE ALL" line, I still got the "sprites hidden" error when I hit F2 to save and run. Waveshare reset button fixed it. (Sorry, no remaining sample code.) Visit Vegipete's *Mite Library for cool programs. |
On the File Menu, I was wondering if typing the first letter of a file/directory could jump the cursor to the first/next entry beginning with that letter? Bill Keep safe. Live long and prosper. |
mclout999 Guru Joined: 05/07/2020 Location: United StatesPosts: 430 |
That would really be a great navagation function. |
It isn't - thanks for the report - will fix |
twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1141 |
Hi Peter or Geoff, I think I found a little bug in the manual regarding the DIR $ () function. The manual (for V5.05.05) says: This example will print all the files in a directory: f$ = DIR$("*.*", FILE) DO WHILE f$ <> "" PRINT f$ f$ = DIR$() LOOP However, it only works for filenames with an extension. The correct pattern for all files would be "*" (eg f$ = DIR$("*", FILE)). Best regards Michael |
Thanks. Geoff Graham - http://geoffg.net |
TweakerRay Senior Member Joined: 01/08/2020 Location: GermanyPosts: 138 |
Hi ! I just updated to the latest firmware and was browsing in the filemenue when the thing crashed I got this error: When was using page up and down a few times and It seemed that when I went down with pagedown the line was not marked anymore where I can select a programm... when I used the up courser again i could see the line ... after a little up and down it crashed with that... O_o Update: I could replicate the error... it seems I got 44 entrys on my sdcard(Programms and directorys) However if I use pagedown when in the filebrowser i am at entry 48 of 44 (which is not the last file on my sdcard) so the courserline vansihes. if i now use the coursor up - it crashes... I updated from CMM2_Beta CMM2V5-05-06b2 to CMM2_Beta CMM2V5.05.06b15 And I also noticed that sometimes my CMM2 froze when I used a simple inkey routine like keyboardkey: ta$=inkey$ if ta$="" then goto keyboardkey this worked fine normally but sometimes the CMM2 gets frozen with this. Thanks Peter for all your afford and updating the firmware. Greets from Germany Tweakerray Edited 2020-10-04 02:24 by TweakerRay http://tweakerray.bandcamp.com |
You are showing a gap between the inkey/goto statements and the label. What is in between? This will happen if you are jumping out of a loop or subroutine. Much better is: do ta$=inkey$ loop until ta$<>"" I can't replicate the filemanager issue - just hammered it and I have 355 files in my directory |
I have made a video so you see the problem and maybe you can see what's happening https://youtu.be/t4r-bRgm4cM Thanks for the other info. Will do the Loop until thing... seems much better ! Cheers http://tweakerray.bandcamp.com |
Thanks - nearly all the problems I've had with the editor and filemanager are when the screen isn't full or is exactly full and it looks like this is another one. Probably created when I changed page up/down to go the the beginning/end of the current page on the first pageup/down press. Serves me right for being helpful Now I need to create a disk with less files to help debug |
TweakerRay Please download 5.05.06b16 again - should be fixed now |
Thanks a lot @Matherp Is there a way to donate something for your hard work ? I mean If you are interested in some of my music I have done (the real music not the chipdrumsynth stuff) then i could give you some downloadcodes so you can enjoy the music ;-) I will download the firmware now. Cheers ! And thanks a lot ! http://tweakerray.bandcamp.com |
No - just enjoy using it |
Thanks @Matherp. I think i might have found another bug in the filebrowser If you have a directory and watch a png file and you get back from that png file your file browser only shows that pngfile which you opened before... if you then scroll up and down it shows all the other files in that directory. I just had the awesome spritedemo from Vegipete in one directory and looked at the png and then i only had the png file showing... when i scrolled up and down i saw the other things again. http://tweakerray.bandcamp.com |
Page 10 of 12 |
