Local Time 16:39 13 Jul 2025 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite Alpha Firmware - a27 onwards - starting on displays
     Page 14 of 14
Posted: 10:53am 11 Jul 2021
Hi Peter,
I'm trying to port some CMM2 code to the PicoMite and was wondering if you might implement the additional MEMORY commands:
Option Base 0
Option Default None
Option Explicit
Dim foo%(9) = (1,2,3,4,5,6,7,8,9,10)
Dim bar%(9)
Dim foo_addr% = Peek(VarAddr foo%())
Dim bar_addr% = Peek(VarAddr bar%())
Dim i%
For i% = 0 To 9 : Print foo%(i%); " " ; : Next
Print
Memory Copy foo_addr%, foo_addr%, 80
For i% = 0 To 9 : Print bar%(i%); " " ; : Next
Print
> run "memory_test"
1  2  3  4  5  6  7  8  9  10
Program:
  1K ( 1%) Program (15 lines)
 79K (99%) Free
RAM:
  1K ( 0%) 5 Variables
  0K ( 0%) General
111K (100%) Free
0  0  0  0  0  0  0  0  0  0
It looks like it just treats MEMORY COPY as if it were the vanilla MEMORY command, and I'm guessing that will be the same for MEMORY SET.
Also any chance of support for:
> Print Mm.Info(Option Base)
Error : OPTION is not declared
Thanks,
Edited 2021-07-11 20:55 by thwill
Posted: 01:00pm 11 Jul 2021
Should it be necessary to re-issue the SETPINs for a uart when re-opening a com port which has been closed?
> SetPin 21,uart0tx:SetPin 22,uart0rx
> Open "com0:115200" As #1
> close #1
Error : Pins not set for UART0
> close #1
Posted: 01:06pm 11 Jul 2021
  Quote  Should it be necessary to re-issue the SETPINs for a uart when re-opening a com port which has been closed?
Yes
Note to all: No updates for the next 3 weeks or so
Posted: 01:37am 12 Jul 2021
An update on Picromite PCBs
I got the PCBs that I posted gerbers for here
Because the PCB without the MCP23017 is identical except for that module, I started with the one which has the module.
I first soldered on the SD module and it tested OK. I soldered in male headers for the RTC module, and it wasn't recognized. I traced it to no ground on the RCT pins. I had run a trace from the middle point on the 3 pads at the bottom of the Pico, which I had somewhere seen was 0V--but I had no pin connecting it to the pad. I soldered a wire to 0V on the SD pins, and the RTC worked.
The other 5 modules all worked--ILI9488 (with MISO snipped off), ESP-01 module, and MCP23017 module. The ESP-01 is upside down, but it doesn't care, even if I do.
And with ILI9341:
These are the modules:
SD
RTC
LCD
ESP-01 module
MCP23017 module
Next will be testing the 2x20 expansion port.
Posted: 06:33am 12 Jul 2021
I am glad to hear there was only 1 missing ground wire.
Any concrete project in mind with this board ? Or is it just for experiments...?
Posted: 11:20am 12 Jul 2021
No particular project. This is the functionality I usually look at for a Micromite (ever since the MM+), and I wanted 2x20 connection compatibility with the CMM2 and with the F4 PCB I produced earlier.
The MCP23017 was just because it's so easy to add, and who knows when the pins will be useful (model railroad controller, dollhouse lighting controller, etc.).
     Page 14 of 14
© JAQ Software 2025
