Local Time 10:30 19 Jul 2025 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic for Linux (a possiblity - don't get too excited)
     Page 3 of 5
Posted: 05:56pm 25 Aug 2021
The Picromite failed because the RPi version of linux and the GPIO interfacing kept changing with every release. *If* they finally settled down to just keeping up with just the official Debian stable releases then it might be ok, but they don't do that. They have to be bleeding edge all the time. That's not much of a problem for the intended market, or most of those who never use Raspbian, but it's not a stable platform. You *can* "freeze" versions of Rasbian and a GPIO interface and only develop for those, but you can never update the Pi with anything newer if you do that as it's liable to break something (as has been proven).
Posted: 06:31pm 25 Aug 2021
the Raspberry Pi runs Linux.
any application that is written following a few simple guidelines will work on just about any distribution of Linux. i have done this, it works. many other people have been doing the same thing for decades without issue. for example, GFXterm compiles for (and runs on) both Linux Mint and Raspbian, without any change to the source code.
serial ports are accessible to any application once you enter the following incantation (exactly as show) at the command prompt:
sudo adduser $USER dialout
the above is a once-off thing that you never need to enter ever again. your application can even do this for you, but it is rarely built in as it requires the user entering their password when prompted.
talking to the serial ports is no more difficult than it is under windows.
things get a little more interesting when trying to access the I/O pins on the RPi, however if you use the API provided by pigpio and don't try anything too esoteric things will work fine.
for sound, you talk to alsa, a software layer that provides a simple API that sits between your application and the sound hardware. you feed it a mono or stereo digital stream and it plays it. just about every desktop distribution of Linux supports alsa, including the RPi Linux distribution.
none of it is rocket science - or brain surgery!
https://www.youtube.com/watch?v=THNPmhBl-8I
rob   :-)
Edited 2021-08-26 04:38 by robert.rozee
Posted: 07:54pm 25 Aug 2021
It sounds simple.
Except that I have been involved in Puppy Linux for some 15 years. And despite the senior devs there, it takes time and adaptatios every roll of the kernell, every change in gcc, every library update, every change in python, lua, and whatever scripting language. Maybe they where not as senior..?
And maybe peter gave up because he experienced something similar. A change in the priority handler in linux I remember as result of a kernell change.
It will become different now anyway, since 32bit is becomming less supported in the linux world. Appart from pi4, all pi's are 32bit I recall. So you will have to compile the whole shebang. Or rely on Raspbian packages...and these change as Peter experienced.
Posted: 08:58pm 25 Aug 2021
  robert.rozee said   ... any application that is written following a few simple guidelines will work on just about any distribution of Linux. i have done this, it works. many other people have been doing the same thing for decades without issue .. none of it is rocket science - or brain surgery!
Don't tell them that Rob, I was going to use my (touch wood) success on this project as a reason to remove the "Not a Guru" banner from my avatar .
  Mixtel90 said  At the moment anyway it seems to be "MMBasic for Linux" - not for the RPi.
The project is "MMBasic for Linux" c.f. "MMBasic for DOS". The RPi runs Linux so assuming no assumptions about the size of pointers have slipped into the source-code (fortunately x86 and ARM, at least by default, are both little-endian) then it should be trivial to compile the source for both x86_64 and ARM32 - it's not as if the core MMBasic has any dependencies to speak of. Serial comms (OK, I know the DOS version has it) will not be in my initial feature set, and GPIO may never be - sorry.
  lizby said  Not to mention that I thought Tom's not-Windows preferred device was a Pi.
I try to be flexible. At my electronics desk (more of a cubby-hole) my computer is a Pi3 attached to the VESA mounting on the back of a small LG TV/monitor. In my office I have a high-spec 2019 vintage ThinkPad running Win10 with CentOS 7 and Ubuntu 20 Linux VMs. The ThinkPad came on holiday with me so I am doing initial development under Ubuntu 20.
Posted: 10:18pm 25 Aug 2021
  Volhout said  It sounds simple.
Generally, it is.
  Volhout said  Except that I have been involved in Puppy Linux for some 15 years. And despite the senior devs there, it takes time and adaptatios every roll of the kernell, every change in gcc, every library update, every change in python, lua, and whatever scripting language. Maybe they where not as senior..?
I'm not sure why they're having such issues. The way you describe it, they should not have them. Maybe you've simplified or they're doing something extra (I have no idea what or why!).
(Well, the kernel itself is bound to be some fun as is every OS, but they're trying to cope with the many weird hassles and nightmares of actual hardware.)
  Volhout said  as Peter experienced.
I think he mentioned a combination of things but the big issue (which does not apply to the list you stated) is that MMBasic, dealing in its particular ways with I/O and hardware, is far from an ordinary Linux program.
Edited 2021-08-26 08:19 by JohnS
Posted: 06:17am 26 Aug 2021
I guess the difference between my experience, and yours, is that I was involved with people that are building the distribution, you are using it.
Posted: 06:46am 26 Aug 2021
  Volhout said  I guess the difference between my experience, and yours, is that I was involved with people that are building the distribution, you are using it.
Sure - that's very different to what nearly all programmers (let alone users) do with Linux.
Unlike Windows (as an example), Linux keeps APIs across updates so programs go on working. Linus (Torvalds) insists on binary compatibility at the kernel API level.  Windows does not do that, sadly (and stupidly).
Picromite/MMBasic isn't a distro so shouldn't be impacted in the same ways (self-chosen when you decide to make a distro - something most people don't do).  However, MMBasic is close to the hardware (unlike almost every other program) so can expect some grief.
Peter very generously donates his time & effort and got fed up with (something/some things). It happens.
Probably it could be overcome but would need someone to devote time & effort.
Posted: 07:39am 26 Aug 2021
Compatibility across linuxes is pretty good generally - providing you aren't making any demands on anything other than the standard API. Also remember that linux runs as a multi-user system and you have to use special techniques if you need time-critical routines. Remember that it was designed to run time-sliced text-based programs.
Posted: 12:48pm 26 Aug 2021
Hi folks,
I now have a reasonable approximation of non-blocking console I/O, Peek, Poke and Memory Copy/Set implemented - at least enough to get "Yellow River Kingdom" running:
   https://www.youtube.com/watch?v=1C_27NmpoV0
Ironically it craps out at the end due to a BASIC bug ... not sure when that crept in there, but it suggests none of you downloaded and played it for more than 30 seconds .
Having compared my keyboard code with that for the PicRoMite I have a suspicion that mine is too simplistic and won't necessarily survive contact with the enemy. For anyone wondering why I don't just lift vast swathes of the PicRoMite code the answer is that I won't learn as much that way, and also if I write (or at least type in) the code myself I will find it easier to maintain, also NIH .
Next up getting #INCLUDE working so that I can start to bring up my MMBasic unit-tests.
Edited 2021-08-26 23:56 by thwill
Posted: 12:49pm 02 Sep 2021
Latest update:
It's been a bit of a fight but I now have #INCLUDE and 95% of the rest of the CMM2's pre-processor code working for my Linux port - unfortunately this doesn't produce anything I can show a worthwhile video of.
Note that if anyone is interested the CMM2 has an undocumented command "LIST FLASH" which will list the pre-processed code stored in the flash as opposed to the vanilla "LIST" command which just spools the current program file from the disk to the console.
Still plenty of holes to plug and rough edges to file off before there is anything to release though.
Edited 2021-09-02 23:00 by thwill
Posted: 02:13pm 02 Sep 2021
Oh, you've gone and done it now, Tom. Peter will remove it on the next update. ;)
Posted: 03:01pm 02 Sep 2021
Not when we put the command in the user manual ....
Posted: 03:08pm 04 Sep 2021
Well I've got my unit-tests working which (I think/hope) means a very significant part of the non-graphical and non-hardware I/O aspects of MMBasic are now running on Linux (x86_64) including program loading and "chaining":
   https://www.youtube.com/watch?v=zunbYsv7BUs
It's all a bit of a "dog's breakfast" but I'm confident I can iron that out with usage.
I guess it's time to talk to Geoff and Peter about a version number and how they want the alpha "published".
Edited 2021-09-05 01:08 by thwill
Posted: 03:33pm 04 Sep 2021
Question:
Are there any defacto standard tests that have been used to validate MMBasic releases in the past? Can someone provide links? IIRC as a minimum there is some sort of performance benchmark that is occasionally posted.
Edited 2021-09-05 04:38 by thwill
Posted: 07:03pm 04 Sep 2021
  thwill said  ... there is some sort of performance benchmark that is occasionally posted.
The 5 benchmarks I ran on the picomite are zipped below, along with the tain.txt file which Paul_L's ta benchmark needs.
bench.zip
The most commonly run bench.bas has had these numbers posted:
BM1 BM2 BM3 BM4 BM5 BM6 BM7 BM8
ABC 800 single precision 0.9 1.8 6.0 5.9 6.3 11.6 19.6 2.9
ABC 800 double precision 1.2 2.2 10.0 10.6 11.0 17.8 26.4 14.4
IBM PC 1.5 5.2 12.1 12.6 13.6 23.5 37.4 3.5
Apple III 1.7 7.2 13.5 14.5 16.0 27.0 42.5 7.5
VIC-20 1.4 8.3 15.5 17.1 18.3 27.2 42.7 9.9
ZX81 in "fast mode" 4.5 6.9 16.4 15.8 18.6 49.7 68.5 22.9
Maximite 0.016 0.144 0.196 0.205 0.354 0.512 0.721 0.310
Maximite with line Nos 0.016 0.131 0.193 0.194 0.245 0.393 0.582 0.241
Maximite without line Nos 0.016 0.111 0.173 0.173 0.192 0.336 0.525 0.220
MicroMite 40MHz 0.028 0.18 0.285 0.289 0.644 0.892 1.346 0.376
MicroMite 48MHz 0.023 0.15 0.237 0.24 0.536 0.744 1.121 0.313
Picromite Pi Zero 0.014 0.058 0.093 0.102 0.184 0.298 0.354 0.127
Armmite STM32H7 0.003 0.023 0.038 0.042 0.067 0.098 0.146 0.065
C-Language (code see above):
Arduino UNO 0.010 0.010 0.058 0.043 0.043 0.043 0.045 0.284
Arduino DUE 0.003 0.003 0.006 0.007 0.007 0.007 0.106 0.014
[/code]
Edited 2021-09-05 05:09 by lizby
toml_12953
Posted: 07:05pm 04 Sep 2021
  thwill said  Question:
One benchmark that's used for both low-end computers and high-end calculators is
Thimet Calculator Performance Index
There's a table on there that compares many different machines.
Here is their benchmark that I converted from their C version and runs on MMBASIC:
timer=0
loops=20000 ' Adjust # of loops so runtime is at least 5 seconds.
for i=0 to loops-1
 r0=10
 do
   x=r0
   x=x+1
   x=x-4.567e-4
   x=x+70
   x=x-69
   x=x*7
   x=x/11
   r0=r0-1
 loop while r0>0
 x=log(x)
 x=sin(x)
 x=sqr(x)
 x=sqr(x)
next
print x
t=timer/1000
print format$(t,"Time:% 3.3f seconds")
print format$(34/t*loops,"Index:% 4.2f")
Edited 2021-09-05 05:15 by toml_12953
Posted: 07:21pm 04 Sep 2021
Bench.bas for MMBasic DOS (100,000 iterations):
MMBASIC DOS 0.0002  0.0017  0.0028  0.0028  0.0073  0.0092  0.0117  0.0058
(Intel(R) Core(TM) i7-3520M CPU @ 2.90GHz)
ArmMite F4 0.011 0.079 0.14 0.149 0.249 0.354 0.528 0.257
Edited 2021-09-05 05:34 by lizby
toml_12953
Posted: 09:24pm 04 Sep 2021
  lizby said  Bench.bas for MMBasic DOS (100,000 iterations):
Where can we find it? Is that the one in the previous post?
Edited 2021-09-05 07:38 by toml_12953
Posted: 10:21pm 04 Sep 2021
Not that it's particularly meaningful ...
Linux x86_64 build running Ubuntu 20 in a VirtualBox VM on an Intel(R) Core(TM) i7-950H @ 2.60 GHz
0.0000  0.0020  0.0040  0.0040  0.0080  0.0130  0.0190  0.0070
This is with CMake's default Release settings so probably not at the highest level of optimisation. Also my Linux build is based off the DOS code and doesn't have the hashed variable/function/sub optimisation of the latest CMM2 firmware.
And if I'm honest I want to look at the TIMER code again as I saw Z-MIM produce a -ve execution time on one occasion .
What's the FLASH RUN 1 statement at the end of each of these benchmarks supposed to be doing ?
Edited 2021-09-05 08:28 by thwill
Posted: 10:34pm 04 Sep 2021
  toml_12953 said  Where can we find it? Is that the one in the previous post?
Yes, it's bench.bas, one of the 5 in the zip file. More starting in 2012 here.
  thwill said  Not that it's particularly meaningful ...
It's at least meaningful in that it ran, and also that results are comparable to MMBasic DOS.
  thwill said  What's the FLASH RUN 1 statement at the end of each of these benchmarks supposed to be doing ?
That was part of chaining all 5 benchmarks on the Picomite as shown here: Picomite benchmarks.
Edited 2021-09-05 08:39 by lizby
     Page 3 of 5
© JAQ Software 2025
