Local Time 10:31 19 Jul 2025 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite 5.07.00 - Bug Reports
     Page 3 of 4
karlelch
Posted: 10:54am 06 Nov 2021
BUG?
After using
OPTION SERIAL CONSOLE uartapin, uartbpin
to redirect the console, I want to go back to USB. So I entered:
OPTION SERIAL CONSOLE DISABLE
This works, however, at the next reboot the console redirection is back to the UART.
Am I missing something?
Thanks!
karlelch
Posted: 03:52pm 06 Nov 2021
Bug in `xmodem`?
Under some conditions, `xmodem` reports not enough memory:
> xmodem send
Error : Not enough memory
> memory
Program:
 18K (18%) Program (727 lines)
 61K (82%) Free
RAM:
  0K ( 0%) 0 Variables
  2K ( 1%) General
109K (99%) Free
`Clear` does not help here, only `new` and reloading the program from flash:
> flash overwrite 1
> new
> flash load 1
> xmodem send
robscott
Posted: 12:37pm 08 Nov 2021
  robscott said  ok,
so far so good....
( tried for awhile )
I'll continue throughout the day, and let you know if hit an issue
Thanks for the quick turnaround
Rob
I tried through the weekend, and was unable to get it to fail
I think you found and fixed the GPS issue Thanks
Rob
Tinine
Posted: 08:58pm 09 Nov 2021
Posted: 09:26pm 09 Nov 2021
Drat! Data might be better than trying to use a PIO as a time machine.
Geoff?
led-bloon
Posted: 09:47pm 09 Nov 2021
Couple more in same paragraph (area) of text
led
Miss you George
Geoffg
Posted: 01:11am 10 Nov 2021
Thanks.  The next release will have these fixed.
Tinine
Posted: 06:29am 10 Nov 2021
  Mixtel90 said  Drat! Data might be better than trying to use a PIO as a time machine.
Geoff?
Thanks for doing this stuff, Mick! Tha's dun o-reet, owd mon
Would like to investigate further but I need to stay focused on the job-at-hand.
Edited 2021-11-10 16:31 by Tinine
robscott
Posted: 12:12am 11 Nov 2021
Looks like reading the Chip Temp "pin(temp)"
makes the read of the 1/3 VSYS "Pin(GP29)" low
Simple Test Code:
Timer = 0
once = 0
 Print Pin(gp29),Timer
 If Timer>5000 And once=0 Then
   Print "Read Temp " Pin(temp)
   once = 1
 EndIf
 Pause 750
Watch how the Timer goes > 5000 it reads the temp and the PIN(GP29) goes low
run
1.602991453     0.832
1.596007326     752.047
1.602857143     1503.132
1.597887668     2254.135
1.595067155     3005.189
1.604065934     3756.309
1.602991453     4507.371
1.594664225     5258.381
Read Temp  31.72082634
0.6994871795    6010.24
0.6994871795    6761.333
0.6994871795    7512.354
0.6994871795    8263.463
"run" resets the values
Rob
panky
Posted: 12:28am 11 Nov 2021
GUI SWITCH command not changing the on-screen intensity when touched. The control value also does not change.
The command works correctly on MM+ v 5.05.03 (changes the intensity on screen when touched and alters the control value).
MMbasic for Pico  v5.07.01b6 loaded, options are
OPTION COLOURCODE ON
OPTION SYSTEM I2C GP20,GP21
OPTION LCDPANEL ILI9481, RLANDSCAPE,GP2,GP3,GP4
OPTION RTC AUTO ENABLED
OPTION GUI CONTROLS 100
OPTION MEMORY 77, 77, 6
OPTION TOUCH GP5,GP6
GUI CALIBRATE 0, 286, 3964, 1296, -846
The following program demonstrates
font 1,2
gui interrupt t_down
gui switch #1,"touch~me",10,10,100,100,rgb(black),rgb(white)
do
loop
sub t_down
 print "touched", ctrlval(#1)
end sub
When run
> run
touched  0
touched  0
touched  0
Posted: 09:54am 11 Nov 2021
Away til after the weekend. No updates til next week but please continue to post any issues on this thread
panky
Posted: 06:41am 13 Nov 2021
Re GUI swith touch problem, this additional info may prove helpful.
When the GUI switch is in split mode, ie. acting like a rocker switch, when touched the control value changes and the switch flips to the alternated side ie. it works exactly as per the manual. Also, when the control value is changed from the command line, the switch flips back and forth, exactly as in the manual again.
When the GUI switch is in the single push switch mode, if the switch is touched, nothing happens - the display does not changed and the control value remains unchanged. The touch is recognised in that it generates an interrupt and shows the x and y co-ords to be in the right place - just doesn't seem to be getting to the  updating the display and control value.  However, if the control value is changed from the command line, both the display and the control value change correctly as per the description in the manual.
Hope this helps. With my (VERY) limited c knowledge, for the life of me I can not see what appears to be wrong. As the split (rocker) switch mode of GUI switch works perfectly, I also can't see how it may be something I am doing wrong or misunderstanding about the GUI switch operation, particularly as it all works perfectly on an Micromite Plus running the latest code.
Doug.
Edit - Late news: The 470 I have tested on is running 5.05.03, not the latest (04). I don't have a copy of the 5.05.03 source but looking at 5.05.02 source, I can see there is a difference in the DrawSwitch function which again, with my very limited knowledge of c is where I think the problem may be. If anyone is running 5.05.04 on a Micromite Plus, could you test the GUI switch functionality and report?
Doug.
Edited 2021-11-13 17:13 by panky
panky
Posted: 02:04am 14 Nov 2021
Confirmed:
- fails under MMBasic v 5.05.04 on a Micromite +.
- works under MMBasic v 5.05.02 on a Micromite +.
Posted: 08:46am 14 Nov 2021
Can I confirm current known bug status?
There is a bug in ADC read after reading PIN(TEMP). This is found and will be fixed in next beta
There is a bug in using GUI switch as found by Panky. This is common to all current versions of MMBasic with GUI support and has been passed to Geoff
There is a report of keys getting stuck in GUI. This is not a bug
  Quote  Backlight 75
GUI NUMBERBOX #1, 100,200,150,35,RGB(YELLOW),RGB(BLACK)
CtrlVal(#1)="##123"
GUI textbox #2, 100,100,150,55,RGB(BLUE),RGB(BLACK)
CtrlVal(#2)="##Hier Text"
That's all, i was just trying to understand and test the commands.
I provoked the behaviour by pressing the virtual key for a long time.
The artifact is caused by the program having terminated. Put DO:LOOP at the end and it won't occur
Anything I've missed?
Kabron
Posted: 09:59am 14 Nov 2021
Though I already set backlight pin in LCD panel option(OPTION LCDPANEL ILI9341, LANDSCAPE,GP15,GP14,GP13,GP17),  I got error concerning to that:
> OPTION AUDIO GP0, GP1
Error : Channel in use for backlight
PS
Sorry, I realized the reason.
Edited 2021-11-14 20:11 by Kabron
electricat
Posted: 07:08am 23 Nov 2021
Picomite(print mm.ver --> 5.07)
What I am doing wrong here?
I always get wrong number no matter what I enter 1,2,3,4 etc
INPUT "Number",nbr
IF nbr <> 1 or nbr <> 5 Then Print "Wrong number"
This works ok. Prints wrong number on all except 1-5
INPUT "Number",nbr
IF nbr < 1 or nbr >5 Then Print "Wrong number"
My MMBasic 'sand box'
Posted: 07:15am 23 Nov 2021
If the input number doesn't equal 1 OR doesn't equal 5
Whatever the number it can't be both 1 and 5 so will always be true.
You should be using AND
Posted: 07:26am 23 Nov 2021
Some consider it nice to put brackets in, even though they aren't required in this case. It's purely a matter of readability, but it can help a lot if the program is modified later.
INPUT "Number",nbr
IF (nbr <> 1) and (nbr <> 5) Then Print "Wrong number"
electricat
Posted: 09:23am 23 Nov 2021
Yes it`s <> not ==
I`m going to take my pills :D
Agree 100% And I`m using this practice in other IDE`s
But in Picomite`s MMB it takes additional bytes of flash storage :o)
Posted: 09:49am 23 Nov 2021
You know the program in flash is tokenised, don't you? Unless you're *really* jamming the program in a few brackets might be ok. :)
I'll send you a fresh batch of dried frog pills.
(Thanks, Terry Pratchett!)
     Page 3 of 4
© JAQ Software 2025
