Local Time 10:47 19 Jul 2025 Privacy Policy
Forum Index : Microcontroller and PC projects : I2C Address Problem with Micromite
Frank N. Furter
Posted: 01:37pm 14 Jan 2022
Hi to all!
I have a sensor with this address which I want to read out with a Micromite V5.05.05:
  Quote  7-bit slave address of this device is 1111000b (0x78).
But I get always this error:
[26] I2C READ &H78, 0, 4, temp()
Error : Invalid address
It seems that all addresses from &H77 generate this error...
What's going on here? Can anybody help me?
THANKS!
Frank
Posted: 01:53pm 14 Jan 2022
It is what is coded in the Micromite firmware, as to why?......
The PicoMite doesn't have the limitation
Edited 2022-01-14 23:53 by matherp
Posted: 03:26pm 14 Jan 2022
typing "i2c reserved addresses" (without quote marks) into google reveals:
"A seven bit wide address space theoretically allows 128 I2C addresses - however, some addresses are reserved for special purposes. Thus, only 112 addresses are available with the 7 bit address scheme. To get rid of this a special method for using 10 bit addresses is defined.
The following table shows I2C addresses reserved for special purposes:
0000000 0      General Call
0000000 1      Start Byte
0000001 X      CBUS Addresses
0000010 X      Reserved for Different Bus Formats
0000011 X      Reserved for future purposes
00001XX X      High-Speed Master Code
11110XX X      10-bit Slave Addressing
11111XX X      Reserved for future purposes"
https://www.i2c-bus.org/addressing/
what exactly is the device you have that has address 0x78?
rob   :-)
Edited 2022-01-15 01:37 by robert.rozee
Frank N. Furter
Posted: 07:11pm 14 Jan 2022
@robert.rozee:
It's a pressure Sensor from Wuerth Elektronik:
Wuerth pressure sensor
THANKS! I had forgotten that there are "i2c reserved addresses"...
What was Wuerth Elektronik thinking???
Frank
Turbo46
Posted: 08:03pm 14 Jan 2022
Shouldn't that address be &HF1 (write) Hex not Octal?
Bill
Posted: 09:36pm 14 Jan 2022
At which end is the extra "0" meant to go? MSB or LSB?
> ? hex$(&B01111000)
78
> ? hex$(&B11110000)
F0
Turbo46
Posted: 09:41pm 14 Jan 2022
From the data sheet the extra bit is the LSB '1' for read.
  Quote  A slave address is 7 bits long followed by a Read/Write bit.
Bill
Posted: 09:42pm 14 Jan 2022
  phil99 said  At which end is the extra "0" meant to go? MSB or LSB?
> ? hex$(&B01111000)
78
> ? hex$(&B11110000)
F0
From the MMBasic manuals:
  Quote  7-Bit Addressing
The standard addresses used in these commands are 7-bit addresses (without the read/write bit). MMBasic will
add the read/write bit and manipulate it accordingly during transfers.
Some vendors provide 8-bit addresses which include the read/write bit. You can determine if this is the case
because they will provide one address for writing to the slave device and another for reading from the slave. In
these situations you should only use the top seven bits of the address. For example: If the read address is 9B
(hex) and the write address is 9A (hex) then using only the top seven bits will give you an address of 4D (hex).
Another indicator that a vendor is using 8-bit addresses instead of 7-bit addresses is to check the address range.
All 7-bit addresses should be in the range of 08 to 77 (hex). If your slave address is greater than this range then
probably your vendor has provided an 8-bit address.
The MMBasic manuals don't describe the "reserved" range which this device seems to use.
Posted: 10:08pm 14 Jan 2022
The PDF is clear: 7-bit address 78 (hex).
Rather odd.
Turbo46
Posted: 10:19pm 14 Jan 2022
This tells me 7 bit plus LSB. I still read it as &HF1.
Am I mis-reading it somehow?
Bill
Posted: 10:28pm 14 Jan 2022
I wonder if they are using old silicon that predates the introduction of 10-bit addressing? They wouldn't want to change it later as anything designed to work with the old one would break - you couldn't use a new unit as a spare for an old one. They almost certainly wouldn't use that address now.
In a word, yes. You're misreading it.
111 1000 is the address, followed by an extra 0 for write or 1 for read IIRC. 7-bit addressing. Unfortunately 111 10xx is the reserved code to introduce a 10-bit address so that 10-bit units will work on a 7-bit system.
Edited 2022-01-15 08:44 by Mixtel90
Turbo46
Posted: 10:43pm 14 Jan 2022
OK, it's a seven bit ADDRESS followed by a '1' bit for 'read'. Does that mean that you DON'T send it '11110001' to issue a read command for that address?
Bill
Posted: 10:47pm 14 Jan 2022
Yes, you do. You are then supposed to tag on the *actual* 10-bit address.
Posted: 10:55pm 14 Jan 2022
This might help.
Turbo46
Posted: 10:58pm 14 Jan 2022
Thanks, reading Jim's quote from the manual shows I need to read up on the subject a bit more. Sorry if I added to any confusion.
Bill
Posted: 11:09pm 14 Jan 2022
There was discussion about this some years ago when another device appeared to use a "reserved" address.
If I remember correctly (a dangerous assumption), that device had a pin to change the address which did allow it to use valid address, just only one such device on the same data lines.
I think Arduino code allows the bad addresses.
Turbo46
Posted: 11:25pm 14 Jan 2022
Any chance that the CFunction I2CPort might work?
Bill
Posted: 04:22am 15 Jan 2022
the wuerth datasheet links to a philips datasheet, which reads:
"Assignment of addresses within a local system is up to the system architect who must take into account the devices being used on the bus and any future interaction with other conventional I2C-buses. For example, a device with seven user-assignable address pins allows all 128 addresses to be assigned. If it is known that the reserved address is never going to be used for its intended purpose, a reserved address can be used for a target address." (page 16, my highlighting)
https://www.nxp.com/docs/en/user-guide/UM10204.pdf
so wuerth should have been aware that they were using a reserved address, as well as being aware that if they really wanted to they could make use of it at the cost of being 10-bit addressing incompatible.
it may be worth asking Geoff if it is possible to extend the range of allowed addresses on the MX170 et al versions of MMbasic. i do not fully know how this may affect the support of 10-bit addressing in the firmware, but i suspect that the presence of an 8/10-bit flag in the function calls precludes major problems.
i do note that the pico version of MMbasic seems to have had reference to 10-bit addressing removed from the user guide at least. Peter may care to comment about the availability of 10-bit addressing here. note that it does appears that 10-bit addressing never really took off within the industry, so its absence may be of little concern.
rob   :-)
Edited 2022-01-15 14:26 by robert.rozee
Geoffg
Posted: 05:57am 15 Jan 2022
  robert.rozee said  It may be worth asking Geoff if it is possible to extend the range of allowed addresses on the MX170 et al versions of MMbasic.
OK, I will do that in the next release (it does not affect anything else).
Note that the CRoutines library in the Micromite distribution ZIP contains the CFunction I2CPort() which will create additional I2C ports and that does not have any limitations on the address range.
Geoff
Frank N. Furter
Posted: 01:48pm 16 Jan 2022
Thank you so much to all!!!
I will try CFunction I2CPort...
Frank
© JAQ Software 2025
