Forum Index : Microcontroller and PC projects : I2C Address Problem with Micromite
matherp Guru ![]() Joined: 11/12/2012 Location: United KingdomPosts: 6117 |
Based on limited googling and the address list at i2cdevices.org there are no 10-bit devices hence no support on any of my ports |
Frank N. Furter Guru ![]() Joined: 28/05/2012 Location: GermanyPosts: 599 |
I think I am too stupid for this project! ![]() I have tried the CFunction recommended by Geoff. First of all: If I use an array Option EXPLICIT Option default integer Dim As Integer temp(4) Dim r Do r = I2CPort( 2, 18, 17, &H78, 4, temp() ) If r=0 Then Error "Sensor not found!" Print temp(0),temp(1),temp(2),temp(3) Pause 1000 Loop as in the example I get: [6] r = I2CPort( 2, 18, 17, &H78, 4, temp() ) ???Error : Dimensions Ok, then I'll just take individual variables: Option EXPLICIT Option default integer Dim temA Dim temB Dim temC Dim temD Dim r Do r = I2CPort( 2, 18, 17, &H78, 4, temA, temB, temC, temD ) If r=0 Then Error "Sensor not found!" Print temA, temB, temC, temD Pause 1000 Loop Then I get as error message: [13] Print temA, temB, temC, temD ???Error : TEMB is not declared However, if I additionally declare a temE... Option EXPLICIT Option default integer Dim temA Dim temB Dim temC Dim temD Dim temE Dim r Do r = I2CPort( 2, 18, 17, &H78, 4, temA, temC, temD, temE ) If r=0 Then Error "Sensor not found!" Print temA, temC, temD, temE Pause 1000 Loop I get data - at least one of the addresses can be read out - and the value changes when I change the air pressure... 12 0 0 0 12 0 0 0 12 0 0 0 13 0 0 0 12 0 0 0 12 0 0 0 28 0 0 0 56 0 0 0 90 0 0 0 86 0 0 0 86 0 0 0 86 0 0 0 86 0 0 0 85 0 0 0 85 0 0 0 12 0 0 0 12 0 0 0 12 0 0 0 WHAT AM I DOING WRONG?? (Oh yes, everywhere was of course the complete "CFunction I2CPort( INTEGER,INTEGER,INTEGER,INTEGER,INTEGER ) INTEGER" included!) Frank |
Geoffg![]() Guru ![]() Joined: 06/06/2011 Location: AustraliaPosts: 2949 |
At a quick glance I can see one thing wrong. In your sample code (at the top of your post) you have: Dim As Integer temp(4) when it should be: Dim Integer temp(4) (without the "As"). I'm not sure what MMBasic would do with this faulty syntax but it would at least get confused. Geoff Geoff Graham - http://geoffg.net |
Hi Geoff, thank you very much for your fast response! You are right - the "As" is wrong! (but it is from the section "Example Application" from "I2CPort.pdf". (THANK YOU!!! I would not have found the error!!!) But that was not the only error. r = I2CPort( 2, 18, 17, &H78, 4, te() ) doesn't work, but r = I2CPort( 2, 18, 17, &H78, 4, te()) do the job!!! ![]() The problem was also the space before the last bracket! => [35] r = I2CPort( 2, 18, 17, &H78, 4, te() ) Error : Dimensions Now I can finally read my 4 bytes correctly!!! ![]() 12 213 54 20 Now I only have to convert the values correctly...12 210 54 29 12 213 54 29 12 216 54 23 12 216 54 26 12 213 54 26 THANK YOU VERY, VERY MUCH!!! Frank |
Actually Dim As Integer temp(4) is not an error, it works fine. I rechecked the source and even though the "As" is redundant it will still be accepted without error. My mistake. So, it seems that you found the problem all by yourself. Congratulations. Geoff Geoff Graham - http://geoffg.net |
robert.rozee Guru ![]() Joined: 31/12/2012 Location: New ZealandPosts: 1987 |
hi Geoff, is the difference in how the interpreter handles: r = I2CPort( 2, 18, 17, &H78, 4, te() ) (generating an error), and: r = I2CPort( 2, 18, 17, &H78, 4, te()) (working), itself a bug in MMbasic? i ask because i will often add in extra spaces, as formatting, around sets of brackets to help make an expression easier to understand. i'd expect one or more spaces to be ignored, unless placed within a function or variable name, or within a numeric. cheers, rob :-) Edited 2022-01-18 00:57 by robert.rozee |
JohnS Guru ![]() Joined: 18/11/2011 Location: United KingdomPosts: 2765 |
Sadly, yes, surely a bug. John |
Andrew_G Guru ![]() Joined: 18/10/2016 Location: AustraliaPosts: 594 |
Possibly a silly question but does the I2CPort CSub work on a Picomite? (I get a syntax error) Andrew |
phil99![]() Guru ![]() Joined: 11/02/2018 Location: AustraliaPosts: 483 |
I suspect the inner workings of the different ports of MMBasic (necessitated by the different processors) are sufficiently different to cause problems. Just to see what would happen I tried Peters new CSub LOG for the Pico on a MM2 and got a similar result. |
Andrew: CSubs are compiled for the instruction set of a particular processor (that is why they are so fast). The Micromite and Picomite use completely different instruction sets so you need a CSub compiled for the Picomite. Rob: Good point, that is definitely a bug. I will look into it for the next release. Geoff Geoff Graham - http://geoffg.net |
Phil and Geoff, It stands to reason . . . Many thanks, Andrew |
