Forum Index : Microcontroller and PC projects : PicoMite/PicoMiteVGA V5.07.04 betas
| Page 1 of 7 |
https://geoffg.net/Downloads/picomite/PicoMite_Beta.zip Fixes bug in datetime$ fixes bug in play wav command skipping a small amount of output at the beginning of playing |
| Amnesie Guru Joined: 30/06/2020 Location: GermanyPosts: 757 |
Thank you a lot wav playback problem is solved! I am so happy :) Greetings Daniel |
| led-bloon Senior Member Joined: 21/12/2014 Location: AustraliaPosts: 209 |
Peter v5.07.04b1 source code - arm-none-eabi-gcc v10.3: I am currently trying to compile your code on a RaspberryPi. In FileIO.c line 1108, you have char buf[PATH_MAX]; However PATH_MAX define is nowhere to be found! Could you please advise. Best Regards led PS Temporarily, I've thrown in #define PATH_MAX=192 in FileIO.h, (file size set at 63 chars?) the code compiles perfectly..THANKS! Slightly smaller uf2 file, hope no introduced bugs with gcc v10.3 Miss you George |
PATH_MAX should be defined in <sys/stat> but this seems to be a strange header and the code you reference doesn't work at all on the Windows build as <sys/stat> contains something completely different |
Peter Do not understand your last response, but assume something more is forthcoming. Just noticed this on v5.07.04b1 (also on v5.07.03) Keyboard buffer problem(s): 1. At the prompt type "option list"<ENTER> 2. Hit <UP_ARROW> key 3. Prompt now shows "Option lis" with cursor positioned on deleted 't' character ... 4. Steps 1-3 above 5. Hit <BACKSPACE> key 6. Entire line moves one char closer to '>' prompt (removes the <SPACE> char). 7. Any further <BACKSPACE> correctly removes chars in the keyboard buffer 8. Complete the original line "option list" (already with one <SPACE> to left) 9. Command accepted ok. led edit: minor correction Edited 2022-02-06 20:03 by led-bloon Miss you George |
It's not. PATH_MAX should be defined in sys/stat.h Which version? your build or mine? Works perfectly on my VGA build and on 5.07.03 with an SSD1963 Edited 2022-02-06 20:25 by matherp |
Peter Will go and look for <sys/stat.h> (to complete my setup) The keyboard errors I am experiencing are with my compile of v5.07.04b1 and your v5.07.03.uf2. I am using minicom so that may be the problem, however I have not noticed it before. Maybe I wasn't looking for it. Thankyou led Edited 2022-02-06 20:35 by led-bloon Miss you George |
led-bloon Please don't post "errors" seen in your own builds unless you can replicate with my released versions. I can't, won't and will never support any build other than my own. Nor will I ever support anyone setting up and building my code as it is completely unrealistic to support toolchains other than the one I use. Sorry |
thwill approaches the field with trepadation, donning his hard-hat and flame-proof underwear .Peter, where exactly should @led-bloon post questions that arise where he is trying to build the public PicoMite source then ? The mistake (if any) is not posting such questions on TBS, but in addressing questions directly to you, posting in your "official release" threads, or expecting you to respond - though you've somewhat made that bed for yourself as (through effort if not intention) you are the high-priest of the recent generation of 'mites and the most prolific participant on TBS. What you've provided for us all is a gift, I personally am sorry it also comes as a burden to you. With respect to PATH_MAX I'm a bit suprised that the PicoMite has any dependency on this at all since it's specific to the O/S file-system and the PicoMite is neither running Windows or Linux/Raspbian, I think it should really be a constant in the PicoMite source code and/or coming from "ffconf.h", though I'm not seeing anything there. @led-bloon, should you want to use them (a mistake I think) then the standard Linux versions are in: #include <linux/limits.h> // 4096 or, #define _POSIX_C_SOURCE 1 #include <limits.h> // 256 With some debate about whether that length includes the byte for the trailing '/0' or not. Best wishes, Tom Edited 2022-02-06 21:40 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
In a separate thread. But how anyone is supposed to help I'm not sure |
They setup a Raspberry Pi tool-chain of their own and download led-bloon's fork (assuming it exists) and start trying to help. Now there may be nobody who is going to do this (I'm afraid I'm not, too much else on my plate), but that isn't your problem, it's led-bloon's. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
hi Led, once you have a build environment set up, i'd be interested in duplicating it on a linux machine. as for finding out the value that happens (randomly?) to be used for PATH_MAX, the simplest solution is to identify where you can cause it to be exceeded in an MMbasic program. ie, it may specify the maximum length of the string passed to a particular MMbasic command; exercise that command with different lengths of string passed in, and see at what length an error is generated by MMbasic. given that MMbasic strings are limited to 255 characters, it is unlikely that any useful value of PATH_MAX is going to exceed 255. or possibly 510 if a path and filename can be concatenated internally. cheers, rob :-) |
I built it without problem on Linux using the pico SDK etc Didn't have issues with PATH_MAX (though I think it's not ANSI C, not that it has to be). Maybe resort to the likes of #ifndef PATH_MAX #define PATH_MAX 256 #endif but I'm puzzled why it worked for me yet not for someone else. John Edited 2022-02-07 01:45 by JohnS |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 5927 |
Are there any strange characters in your path? Doeet the path contain multiple branches? Print it to a file an view in a hex editor. PicomiteVGA PETSCII ROBOTS |
As is CLEARLY stated in my last post, I had the same problem in MY build of v5.07.04b1 AND your v5.07.03.uf2 file on the same piece of hardware (I purposefully tried checking it was not my build in the first instance!). However, since you confirmed that there is no bug, I accepted that it was something funny going on in my setup. Matter closed (with thanks). @thwill - there will be no fork - just amusing myself and seeing if it can be done @robert.rozee - JohnS to the rescue @JohnS - As Peter has stated - everything depends on your tool-chain .. period! Gotta love this forum and the people here Have a great day everyone led Miss you George |
I can dig out details if you wish. John |
what worries me a little, is where does PATH_MAX get picked up from on Peter's builds? and equally importantly, on other folk's builds. the picomite version of MMbasic uses FatFs (by ChaN) according to the credits. yet nowhere in the source tree of the MMbasic source code (including FatFs) is PATH_MAX defined. i would expect PATH_MAX to have been defined within or somewhere close by to FatFs. if (as seems the only alternative) the value is being picked up somewhere outside of the MMbasic source tree, then this is just plain wrong. we are cross-compiling here, and PATH_MAX is in this scenario a constant specific to the target, not the host. if a host has a value for PATH_MAX defined somewhere as 4k (for instance), and this value is used in compiling MMbasic, then the resulting interpreter binary, running on a RP2040, will be 4k short of the expected available RAM. i also worry if there are other constants in a similar position to PATH_MAX, where the value picked up by the compiler is host specific, rather than target specific. is anyone in a position to (or know how to) run a check for this? cheers, rob :-) Edited 2022-02-07 19:57 by robert.rozee |
I believe I said much the same about 7 posts up .Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
God you lot are anally retentive The relevant code is just a, cut and paste from wherever I found it, algorithm for tidying up silly path names e.g. fred/bert/../eric = fred/eric Set it to anything sensible. On my system it is 1024 |
Isn't that practically the definition of an Engineer. You must have been in management / retired too long .Presumably the opposite of "anally retentive" is too noisome to contemplate .Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| Page 1 of 7 |
