Local Time 03:26 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic Programming Challenge 2022
     Page 1 of 7
Posted: 03:16pm 02 Apr 2022
Hi folks,
On behalf of @bigmik, @lizby, @Turbo46 and myself I'm pleased to announce this year's MMBasic Programming Challenge:
   mmbasic-challenge-2022.pdf
Let's hope for many interesting entries.
Good luck,
Edited 2022-04-03 02:14 by thwill
LeoNicolas
Posted: 05:03pm 02 Apr 2022
Thank you thwill
I'm super excited to remove the dust from my CMM2
Posted: 07:02pm 02 Apr 2022
Dust....I will first have to find it bach ;)
thavith
Posted: 10:25pm 02 Apr 2022
One of the first programs I ever tried to write was Yahtzee for the Vic20 with 3k of memory.  I ran out of memory before the program was finished (probably didn't use gosub as much as I should have).
Looking forward to this challenge.  Have to think what to write...
LeoNicolas
Posted: 03:44pm 10 Apr 2022
I'm posting to bring the challenge to the first page.
I'm working on my program. The challenge is to fit it in 5k. Maybe to ambitious, let see
vegipete
Posted: 03:48pm 10 Apr 2022
  LeoNicolas said  The challenge is to fit it in 5k
Yeah, I'm at 11k and climbing...
MauroXavier
Posted: 11:31pm 11 Apr 2022
  LeoNicolas said  Thank you thwill
Me too!!
vegipete
Posted: 05:51am 30 Apr 2022
Let's get the ball rolling:
Stellar Battle in the Seven Green Hills Zone by Vegipete
For the CMM2.
Use the arrow keys to move, any modifier key (shift, ctrl, etc) to shoot. More fuel in the fuel bay, along with slow shield replenishing. Dispatch enough enemies for the stargate to appear. Don't run into stuff, it's rather damaging. With care, you can get the enemies to shoot each other. If you are lucky, you can enter the stargate before it actually appears.
> ls
A:/3D
15:07 16-04-2022        184  memtest.BAS
[snip]
22:26 29-04-2022       5116  SBSGHZv01.bas
20:52 10-04-2022        892  test.bas
20:51 10-04-2022        883  test.bas.bak
0 directories, 14 files
5116 Bytes in current form. This requires LF only at end of lines. If you open the program in the editor and save it, it grows past the allowable size!
The runs well on a 400 MHz CMM2 with the latest beta firmware. The program may hang release firmware. If so, search for the numerical value "150" in the program (line 163) and change it to something bigger such as 220. The graphics won't be quite as nice but it should run.
option angle degrees
option default integer
mode 1,8:cls
B=6E4:BR=5E4:AC=20:A=360:E=300:F=400:G=200
dim di(AC),o(AC,6),c(8)=(&hA52A2A,&hFF00,&hAF00,&h6000,2^14,0,&hC0FF,&hFF00C0,&h404040)
dim dw(AC),l(18)=(0,3,7,2,9,3,6,2,8,12,9,1,6,2,9,3,6,1,0),fv(64),fn(20),ec(20),fc(20),s(G),t(9)
dim float h,fu,sd,ct,st,q(4),v(2,32)
LA "EEDDDDHAAAHAAA>CAAHADCAAEJJLABCCBDBADACDIFEEEEEEEEEEDDDDD8A8JA8JAJ8AJ@S@BS@BSB@SBNTAEFBBFGCCGH"
LA "DDHEAHGFEIF!!!=A=EA=EAE=AE=I=EI=EIE=IEZANKEEEEEEDDDDEEEEEEBBBBAAAAACBBBB<A<FA<FAF<AF?B?CB?CBC?"
LA "BC>G>DG>DGD>GDAIAUdAEFBBFGCCGHDDHEAHGFEIJKLIMJJMKKMLLMINK!EEEEEEGGGGGGGGBBDDDD@A@BA@BAB@AB?M?C"
LA "M?CMC?MCAM7GMAAMK;MAAQAKALIDDDDEEEDEEEEEEEEBBBBCCCEDA9DAI>AI>A9AF:BD@BEJ@EJ@D@AE=AFJU[AEBBECCE"
LA "DADEFGHIFJKGIHKJGKHPNEEEEEDDDDEEEDEEEEEEEEEEEEEEDDDDCCCCBBBEDA9DAJ>AJ>A9ED8EDK=DK=D8AH;BFCBGK@"
LA "GK@FCAG?AHKPoABCDAEFBBFGCCGHDADHEEIFFIGGIHHIEJKLMJNOKMLONKOL  "
j=1:u=0:do:nv=NB():if nv<-32 then exit do
nf=NB():RC fn():RC ec():RC fc():for i=0to nv-1:for k=0 to 2:v(k,i)=NB():next k,i
sc=NB():math scale v(),sc,v():n=NB():if n then for i=0to n:fv(i)=NB():next
draw3d create j,nv,nf,1,v(),fn(),fv(),c(),ec(),fc():inc j:loop
for i=1to 8:read o(i,6):next:data 1,1,1,1,4,5,6,7
P 3
cls
circle F,E,21,,4,c(2),c(2)
circle F,E,15,,4,0,0
blit read 9,370,E,60,30
circle F,E,30,,,c(3),c(3)
blit write 9,370,E,4
image rotate E,G,G,G,E,G,15
blit read 1,315,268,170,64
h=0:fu=100:sd=100:se=0:lv=1
draw3d camera 1,500,0,75
M
settick 25,MM,1
w=0
np=1
do
if keydown(0)then
SK keydown(1)
SK keydown(2)
endif
if keydown(7)then
if np then
np=0
for i=1to 2
if o(i,0)=0 then v2=25:NS i,,,-h:i=3
next
endif
else
np=1
endif
for i=1to 4
if o(i,0)then
inc o(i,0),-sgn(o(i,0))
k=MB(i,7,o(i,4),o(i,5))
if k>6 then
o(i,0)=-o(i,0)
if k<9 then
v1=75
o(k,1)=B/2
o(k,2)=B/k
o(k,3)=rnd*A
inc se
if se>lv*9 and o(6,0)=0 then v4=99:o(6,0)=1
endif
endif
endif
next
inc o(6,3)
TY 7
TY 8
if sd<0 then
P 0:for i=0to 999:line 0,600*rnd,800,600*rnd,,c(0):pause 2:next
text F,E,"GAME OVER",CT,3,,c(0)
do while inkey$<>"":loop:do:loop until inkey$<>"":run
endif
DS
if qx+qy then sprite scroll qx,qy:qx=0:qy=0
do:loop until timer>25
timer=0
page copy w+1,0,D
w=w=0
loop
end
sub SK k
if k=128 then MF 50
if k=129 then MF -50
if k=130 then h=(h+359)mod A
if k=131 then h=(h+361)mod A
end sub
sub NS n,x,y,h:o(n,0)=90:o(n,1)=x:o(n,2)=y:o(n,3)=h:o(n,4)=-sin(h)*151:o(n,5)=cos(h)*151:end sub
sub C2 c,n:c=(c+n+1.5*B)mod B-B/2:end sub
function MB(n,f,dx,dy)
MB=1
x=o(n,1):C2 x,dx
y=o(n,2):C2 y,dy
if n>6 and x^2+y^2<BR then exit function
for j=f to 20
j=j+(j=n)+(n+4=j)
if (o(j,1)-x)^2+(o(j,2)-y)^2<BR then MB=j:exit function
next
MB=0
if n then o(n,1)=x:o(n,2)=y
end function
sub MF r
if fu<0 then exit sub
fu=fu-(fu>0)/G
dx=sin(h)*r
dy=cos(h)*r
i=MB(0,5,dx,dy)
if i<6 then
for i=1to AC:C2 o(i,1),-dx:C2 o(i,2),-dy:next
elseif i=6 then
P 0
for i=1to 999:n=rnd*A:line F,E,F+sin(n)*500,E+cos(n)*500,,c(6):pause 1:next
h=(h+180)mod A
inc lv
M
DS
P 0:for i=1to F:blit F-i,E-i,F-i,E-i,i*2,i*2,w+1:pause 1/i:next
else
v3=2:sd=sd-1
endif
end sub
sub TY n
if t(n)then inc t(n),-sgn(t(n)):o(n,3)=(o(n,3)+sgn(t(n))*2)mod A:exit sub
j=atan2(o(n,1),-o(n,2)):inc j,A*(j<0):i=(o(n,3)-j)mod A
if i=0 and o(n-4,0)=0 then NS n-4,o(n,1),o(n,2),o(n,3)
j=-sgn(i):if abs(i)>180 then j=-j
o(n,3)=(o(n,3)+j)mod A:if MB(n,5,-sin(o(n,3))*o(n,4),cos(o(n,3))*o(n,4))then t(n)=60*sgn(rnd-.5)
end sub
sub M
for i=1to 4:o(i,0)=0:PM i+4:next:o(7,4)=30+lv:o(8,4)=15+lv
for i=9to AC:PM i:o(i,6)=2+(rnd<.5):next
end sub
sub PM n
o(n,0)=(n<>6)
do:x=rnd*B-B/2:y=rnd*B-B/2:loop while x^2+y^2<BR
o(n,1)=x:o(n,2)=y:o(n,3)=rnd*A
end sub
sub DS
for i=1to AC:dw(i)=o(i,1)^2+o(i,2)^2:next
for i=3to 4:if dw(i)<BR and o(i,0)>0 then o(i,0)=-o(i,0):inc sd,-10:qx=rnd*9-5:qy=rnd*9-5:v3=3
next
fu=fu-(fu>0)/G
if dw(5)<BR then fu=100:sd=min(100,sd+sr/500):sr=0
sort dw(),di(),1
ct=cos(h):st=sin(h)
P w+1:cls:line 0,E,800,E,1,c(3)
if h>239 and h<340 then blit write 1,3100-h*9.6,60
circle 800-h*9.6,G,20,0,,,c(3)
circle 800-h*9.6-9,203,20,0,,,0
circle 1440-h*9.6,120,30,0,,,&h80FF00
ix=h\20:n=-(h mod 20)*10
for i=0to 5:j=(ix+i+15)mod 18:line n,E-l(j)*10,n+G,E-l(j+1)*10,,c(3):n=n+G:next
P 3
box 0,0,102,102,1,c(8),0
for i=1to AC
n=di(i)
if o(n,0)>0 then
P 3
x=o(n,1)*ct-o(n,2)*st
y=o(n,1)*st+o(n,2)*ct
pixel 51+x*140/B,51-y*140/B,c(0+6*(o(n,6)=5)+(o(n,6)=4))
pixel 51,51,&hFFFF00
if y>150 and abs(x)<y then
P w+1:math q_euler o(n,3)+h,0,0,q():draw3d rotate q(),o(n,6):draw3d write o(n,6),x,0,y
endif
endif
next
P w+1
blit 0,0,369,497,102,102,3
box 369,497,102,102,1,c(8)
text F,6,"LEVEL:"+str$(lv,2)+"  SCORE:"+str$(se,3),CT,,,c(1)
text F,495,"S F  HEADING: "+str$(h,3,0),CB,,,c(1)
DG 331,sd
DG 346,fu
end sub
sub P n:page write n:end sub
sub DG x,g:box x,497,10,102,1,c(8),0:if g>0 then box x+1,598-g,8,g,4,c(g>25)
end sub
sub RC c():k=NB():if k<>-32 then c(0)=k:for i=1to nf-1:c(i)=NB():next
end sub:function NB():NB=lgetbyte(s(),u)-65:inc u:end function
sub LA z$:longstring append s(),z$:end sub
sub MM
play sound 1,b,n,99,v1/3:D v1
play sound 2,b,p,99-v2,v2:D v2
play sound 3,b,n,G,20*(v3<>0):D v3
play sound 4,b,t,499-99*sin(v4),v4/4:D v4
inc sr
end sub
sub D n:n=n-(n>0):end sub
Posted: 09:39am 30 Apr 2022
  vegipete said  Let's get the ball rolling:
Neat, you made Battlezone.
Thank you for our first entry, the bar is set, and it is high!
And as a reminder to anyone else who is considering entering the closing date is Wednesday 1st June.
Posted: 11:38am 09 May 2022
Just giving this a bump and reminding people that the closing date is Wednesday 1st June.
The only entry so far is Vegipete's "Stellar Battle in the Seven Green Hills Zone".
Posted: 12:18pm 09 May 2022
Yes... the pressure is ON...
I am finalizing my VGA picomite hardware build, so I can start soon.
jirsoft
Posted: 01:28pm 09 May 2022
Because of death in family, I'm slower than was the plan, but I hope anyway I will send my entry on time...
Jiri
LeoNicolas
Posted: 04:03pm 09 May 2022
I'm still working on my implementation. I'm dealing with some MMBasic limitations
Posted: 09:22am 16 May 2022
Only two weeks to go folks ... and we still only have one entry .
TimD
Posted: 12:45pm 16 May 2022
My attempt is well underway, but - like most things I do - I expect it will be right down to the wire to get it all done by the deadline
Tim
Posted: 01:04pm 16 May 2022
  TimD said  My attempt is well underway, but - like most things I do - I expect it will be right down to the wire to get it all done by the deadline
Tim
Posted: 01:17pm 16 May 2022
My attempt is not even well under way, there are still hurdles to take. And time is pressing. Maybe I have to pull an all-nighter...
I just mastered the first 2 major technical challenges in my contribution.
#1 build a working VGA picomite - done
#2 get PIO working to demodulate audio (PIO) - done
#3 decode the video type and sync (MMBASIC)
#4 show the video B/W first, then colour (MMBASIC + PIO)
#5 shrink code to the 5k boundary (last challenge this took most of the time)
#6 some form of leaflet or user manual (OFFICE)
I am fortunate that Peter fixed the bug, and added a new features for MMBasic so fast.
P.S. the PIO is a nasty beast. I am hand assembling the code, since I ran into problems with PASM12a. And when you make a coding error, and run it, it happened twice to me that the system rebooted, the program was lost, and once even all option setting where lost. I had a virgin system. But lost my program. I am saving to SD card often now. Better SAVE then SORRY.....
Edited 2022-05-16 23:18 by Volhout
Posted: 03:54pm 21 May 2022
How about extending the time to June 15th or 30th to be sure we don't just have a unanimous vote in favor of the single entry?
LeoNicolas
Posted: 03:59pm 21 May 2022
My game is 50% implemented. This weekend I will try to reach 80%.
Posted: 04:02pm 21 May 2022
  lizby said  How about extending the time to June 15th or 30th to be sure we don't just have a unanimous vote in favor of the single entry?
I'm happy with any extension that our community agrees upon ... or at least doesn't object to ;-)
     Page 1 of 7
