Local Time 23:10 11 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite VGA Keyboard
     Page 1 of 3
palcal
Posted: 04:13am 12 May 2022
Up until now I have been using my Picomite VGA through a terminal because I was waiting on the PS2 socket. Got the socket but found I no longer had a PS2 keyboard, you know, the big cleanup, I'll never need these again. I am using a USB keyboard with a USB to PS2 adaptor, but the keyboard does not work. Before I go looking for a fault this keyboard should work with the adaptor, yes or no.
al18
Posted: 04:24am 12 May 2022
Does the keyboard light blink or remain on?
Posted: 04:31am 12 May 2022
Hi PalCal,
Assuming your KB is PS2 `compatible' I believe there are 2 types of USB-PS2 converters
A GREEN one for a Mouse
and a less common
PURPLE one for Keyboards
I `think' they are wired to different pins on the PS2 side.
This might be your problem but as with many things these days, I may be TOTALLY WRONG.
palcal
Posted: 04:39am 12 May 2022
Thanks for that, I checked and have power to the KB socket but no lights on KB. I'll see if I can dig up a PS2 KB.
palcal
Posted: 04:50am 12 May 2022
Apparently from what I have read, newer PS2 KBs use the USB wiring convention. So I will have to be careful if I buy a new KB. If I get a PS2 plug I should be able to wire it onto the USB KB.
Rickard5
Posted: 05:21am 12 May 2022
  palcal said   I am using a USB keyboard with a USB to PS2 adaptor, but the keyboard does not work. Before I go looking for a fault this keyboard should work with the adaptor, yes or no.
Not all USB KB Encoders are 3.3 Volt tolerant, Like my beloved IBM Model M PS/2 Keyboards Hate Picos, because of the power issue.  I been using these  sometimes they go on-sale for $3 and work with the Green usb-ps2 adapter, and they use to have a PS/2 Version you could do the reverse and go PS/2 to USB, I keep one in the car at all times, never know when you got to work on legacy Junk like Novel servers I built in the 90's (Yes some one just just got $$$$ hit hard to upgrade their Netware 3.11 server to NAS) ;) :) :)
Edited 2022-05-12 15:22 by Rickard5
Posted: 06:47am 12 May 2022
The actual sockets for PS/2 only vary in colour. The socket pins in all of them are identical AFAIK. You can get green, purple and black to my knowledge. I think I've seen grey too.
If a USB keyboard isn't working (with something that's known to work with a PS/2 keyboard) via an adapter then there's usually one of two problems:
1) It's not designed to. Not all USB keyboards can handle the PS/2 protocol, no matter how you connect them.
2) It would do, but you are using a 5V only keyboard on a 3V3 system. This is a common problem with USB keyboards, which never expect a 3V3 supply.
Some PS/2 keyboards are 5V only and won't work on a 3V3 system. Always better to include a 5V keyboard supply and level shifters.
palcal
Posted: 07:38am 12 May 2022
The PS2 socket on the Pico VGA is 5 volt it connects to Vsys. It has got me stumped. The keyboard lights up when connected to my computer. I checked the USB side of the adaptor and have 5 volts on pins 1 and 4, I plug in the keyboard and no go, the same with 2 keyboards that work on my computer. Thinking the USB side of the adaptor has a pin not connecting I plugged in a USB extension cable and have 5 volts on the female end, I plug the keyboard into the extension cable, no go. ????
Posted: 07:42am 12 May 2022
Odd... If it's Peter's version 1.3 VGA board then a few people are using it now. Have you got the mosfet level shifters in right way round?
al18
Posted: 08:24am 12 May 2022
I don’t think there are any  newer PS/2 keyboards - this is an obsolete standard that was dropped years ago. I recently picked-up a nice used Compaq PS/2 keyboard at the Goodwill. Store for $5 that works fine. The sticker on the bottom says 5v 50 mA - so it doesn’t use much power.
palcal
Posted: 08:25am 12 May 2022
Mosfets I used are 2N7000 and have fitted them in opposite to the layout as they should be. I'm using a board that Turbo46 kindly gave me, he used the 2N7000s
The thing is if I have 5 volts to the KB it should light up, shouldn't it ?
Edited 2022-05-12 18:27 by palcal
Posted: 08:36am 12 May 2022
"I don’t think there are any  newer PS/2 keyboards - "
Early in the PicoMite and ArmMiteF4 development it was discovered that new Microsoft basic model keyboards are still PS/2 compatible (and will work down to 3V and don't need pullup resistors). Search there for the model number. Had a go but no luck.
palcal
Posted: 10:31pm 12 May 2022
Well I have checked the voltage around the level shifters and traced every connection, but I can't find a fault. I've tried 3 known good KBs and none work. As a last resort I will grab a 6 pin mini din connector when I'm in town on Saturday and put it on the keyboard instead of the USB plug and if that doesn't work I just don't know.
Posted: 10:43pm 12 May 2022
Do you KNOW that the keyboards are PS/2 capable?
Not many current ones are.
al18
Posted: 11:40pm 12 May 2022
Jim has a point. Ps/2 keyboards are quite different from USB keyboards. Your USB to PS/2 adapter does NOT contain a CPU to convert the signals - this is handled by the CPU inside your keyboard.
FYI the used Compaq KB-0133 PS/2 keyboard I bought recently is in very good condition.  I See they are still being sold on eBay for around $12 if you can’t find them locally.
Edited 2022-05-13 09:41 by al18
Posted: 12:07am 13 May 2022
To check the operation of the level shifters, with KB un-plugged measure the voltages on clock and data pins on the socket. Should be about 5V. Repeat for the Pico pins. Should be about 3V3.
Now link the clock and data pins on the socket to ground. The Pico pins should now be 0V. Repeat grounding the Pico pins and measuring the socket pins.
Trace the PCB tracks to be certain I/O pin GP8 goes to clock and GP9 to data on the socket.
The next thing is to try swapping the clock and data connections to the socket and see if the keyboard works now. Tricky to do on a PCB, perhaps remove the socket and run wires back to the pads.
If none of that helps I guess the keyboards just don't do PS/2.
palcal
Posted: 01:16am 13 May 2022
Probably the KBs I'm using, I also have some old Honeywell KBs with 5 pin DIN socket, I can get an adaptor for those at Jaycar. These KBs have the AT/XT switch on the bottom.
Would they be suitable.
Posted: 01:20am 13 May 2022
  palcal said  Probably the KBs I'm using, I also have some old Honeywell KBs with 5 pin DIN socket, I can get an adaptor for those at Jaycar. These KBs have the AT/XT switch on the bottom.
Perfect.
You need the switch in the 'AT' position.
palcal
Posted: 02:05am 13 May 2022
Thanks all, I can't get an adaptor locally but I can change the plug to Mini DIN.
When this VGA PicoMite appears in Silicon Chip and if it goes well where is everyone going to get PS2 Keyboards. Second hand on EBay there are some but no new ones around.
al18
Posted: 02:37am 13 May 2022
That’s a good question.
I would like to know if attaching a USB keyboard thru a USB on the go cable is possible. I searched the web and there are some Pico projects this implemented.
     Page 1 of 3
