Forum Index : Microcontroller and PC projects : PicoMite/PicoMiteVGA V5.07.05 betas
| Page 1 of 11 |
V5.07.05b1 https://geoffg.net/Downloads/picomite/PicoMite_Beta.zip Fixes bug in PIO READ Allows a single integer variable to be used when nbr=1 in PIO READ Implements DRAW3D command and function (VGA version only) Implements FRAMEBUFFER command (VGA version only) See this thread and related doc for details of the 3D capabilities. The implementation is identical to the CMM2 Another demo The Framebuffer command allow you to allocate some of the variable memory to either a framebuffer, a second display layer, or both and then use these in interesting ways to both avoid tearing artefacts and/or play graphics objects over the background display. Commands: FRAMEBUFFER CREATE 'allocates 38400 bytes to a framebuffer FRAMEBUFFER LAYER 'allocates 38400 bytes to a second display layer. This layer sits on top of the main display. Any pixel set in this layer to something other than black will display on top of the main display. Pixels in this layer are fully opaque NB: This command is only available when the CPU speed is set to 252MHz (OPTION CPUSPEED 252000) FRAMEBUFFER WRITE fb' selects the buffer which all subsequent graphics commands will write to. Valid values for fb are: N - the main display (N for Normal) F - the framebuffer L - the layer buffer In the event that a framebuffer or a layer hasn't been created the command will be ignored and commands will continue to write to the main display FRAMEBUFFER COPY s, d [,b] Copies one framebuffer to another Valid values for a and d are: N - the main display F - the framebuffer L - the layer buffer In the event that a framebuffer or a layer hasn't been created the command will be ignored. The optional parameter B tells the copy to wait for the next frame blanking before starting the copy. If this is specified the copy will compete in frame blanking and no display artefacts will be seeen. FRAMEBUFFER CLOSE [fb] Closes one or more framebuffers and frees up the memory. Valid values for fb are: F - the framebuffer L - the layer buffer If fb is not specified both the framebuffer and layer buffer are closed. In the event that a framebuffer or a layer hasn't been created the command will be ignored. FRAMEBUFFER WAIT Pauses processing until the start of the next frame blanking period If you Ctrl-C out of a program while the FRAMEBUFFER WRITE is set to the FRAMEBUFFER then you will need to execute FRAMEBUFFER CLOSE to get you cursor back. Example program using layer and framebuffer MODE 2 'clear the main screen and create a grid CLS For i=0 To MM.HRes-1 Step 10 Line i,0,i,MM.VRes-1 Next For i=0 To MM.VRes-1 Step 10 Line 0,i,MM.HRes-1,i Next 'Create a framebuffer and a layer buffer 'set graphics commands to write to the framebuffer FRAMEBUFFER create FRAMEBUFFER layer FRAMEBUFFER write f 'create a moving sine wave in the framebuffer ' then copy the framebuffer to the layer buffer in frame blanking ' so it appears on top of the grid j=0 Do y=Sin(Rad(0+j))*MM.VRes\3+MM.VRes\2 For i=1 To MM.HRes-1 yp=Sin(Rad(i+j))*MM.VRes\3+MM.VRes\2 Line i,y,i,yp,1,RGB(green) y=yp Next Inc j FRAMEBUFFER copy f,l,b CLS Loop 3D demo Option explicit Option default none MODE 2 Dim float phi=(1+Sqr(5))/2 ' data for location of vertices for truncated icosahedron of edge length 2 Data 0,1,3*phi Data 0,1,-3*phi Data 0,-1,3*phi Data 0,-1,-3*phi Data 1,3*phi,0 Data 1,-3*phi,0 Data -1,3*phi,0 Data -1,-3*phi,0 Data 3*phi,0,1 Data 3*phi,0,-1 Data -3*phi,0,1 Data -3*phi,0,-1 Data 2,(1+2*phi),phi Data 2,(1+2*phi),-phi Data 2,-(1+2*phi),phi Data 2,-(1+2*phi),-phi Data -2,(1+2*phi),phi Data -2,(1+2*phi),-phi Data -2,-(1+2*phi),phi Data -2,-(1+2*phi),-phi Data (1+2*phi),phi,2 Data (1+2*phi),phi,-2 Data (1+2*phi),-phi,2 Data (1+2*phi),-phi,-2 Data -(1+2*phi),phi,2 Data -(1+2*phi),phi,-2 Data -(1+2*phi),-phi,2 Data -(1+2*phi),-phi,-2 Data phi,2,(1+2*phi) Data phi,2,-(1+2*phi) Data phi,-2,(1+2*phi) Data phi,-2,-(1+2*phi) Data -phi,2,(1+2*phi) Data -phi,2,-(1+2*phi) Data -phi,-2,(1+2*phi) Data -phi,-2,-(1+2*phi) Data 1,(2+phi),2*phi Data 1,(2+phi),-2*phi Data 1,-(2+phi),2*phi Data 1,-(2+phi),-2*phi Data -1,(2+phi),2*phi Data -1,(2+phi),-2*phi Data -1,-(2+phi),2*phi Data -1,-(2+phi),-2*phi Data (2+phi),2*phi,1 Data (2+phi),2*phi,-1 Data (2+phi),-2*phi,1 Data (2+phi),-2*phi,-1 Data -(2+phi),2*phi,1 Data -(2+phi),2*phi,-1 Data -(2+phi),-2*phi,1 Data -(2+phi),-2*phi,-1 Data 2*phi,1,(2+phi) Data 2*phi,1,-(2+phi) Data 2*phi,-1,(2+phi) Data 2*phi,-1,-(2+phi) Data -2*phi,1,(2+phi) Data -2*phi,1,-(2+phi) Data -2*phi,-1,(2+phi) Data -2*phi,-1,-(2+phi) ' 12 faces with 5 sides Data 0,28,36,40,32 Data 33,41,37,29,1 Data 34,42,38,30,2 Data 3,31,39,43,35 Data 4,12,44,45,13 Data 15,47,46,14,5 Data 17,49,48,16,6 Data 7,18,50,51,19 Data 8,20,52,54,22 Data 23,55,53,21,9 Data 26,58,56,24,10 Data 25,57,59,27,11 ' 20 faces with 6 sides Data 32,56,58,34,2,0 Data 0,2,30,54,52,28 Data 29,53,55,31,3,1 Data 1,3,35,59,57,33 Data 13,37,41,17,6,4 Data 4,6,16,40,36,12 Data 5,7,19,43,39,15 'data 14,38,42,18,7,5 Data 22,46,47,23,9,8 Data 8,9,21,45,44,20 Data 10,11,27,51,50,26 Data 24,48,49,25,11,10 Data 36,28,52,20,44,12 Data 13,45,21,53,29,37 Data 14,46,22,54,30,38 Data 39,31,55,23,47,15 Data 16,48,24,56,32,40 Data 41,33,57,25,49,17 Data 42,34,58,26,50,18 Data 19,51,27,59,35,43 ' Dim float q1(4) Dim float yaw=Rad(1),pitch=Rad(2),roll=Rad(0.5) Dim integer i, j, nf=31, nv=60, camera=1 Dim float vertices(2,59) ' read in the coordinates of the verticies and scale For j=0 To 59 For i=0 To 2 Read vertices(i,j) vertices(i,j)=vertices(i,j)*20 Next i Next j 'math scale vertices(),50,vertices() ' Dim integer faces(173) For i=0 To 173 Read faces(i) Next i Dim integer fc(30)= (5,5,5,5,5,5,5,5,5,5,5,5,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6) Dim integer colours(2)=(RGB(red),RGB(white),RGB(black)) Dim integer edge(30)=(2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2) Dim integer fill(30)=(0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1) Math q_create Rad(2),1,0.5,0.25,q1() Draw3D create 1, nv,nf, camera, vertices(), fc(), faces(), colours(), edge(),fill() Draw3D camera 1,800,0,0 'draw3d diagnose 1,mm.hres\2,mm.vres\2,1000 FRAMEBUFFER create FRAMEBUFFER write f Draw3D show 1,0,0,1000,1 Do Math q_euler yaw,pitch,roll,q1() Inc yaw,Rad(1) Inc pitch,Rad(2) Inc roll,Rad(0.5) Draw3D rotate q1(),1 Draw3D show 1,0,0,1000,1 FRAMEBUFFER copy f,n,b Loop Edited 2022-05-23 04:29 by matherp |
| circuit Guru Joined: 10/01/2016 Location: United KingdomPosts: 309 |
Does your genius have no limits? I live in awe of what you do. |
V5.07.05b2 - VGA only fixes issue on some Pico in VGA mode 1 output at 126MHz PicoMiteVGA.zip |
| TheRockGod Newbie Joined: 01/04/2022 Location: AustraliaPosts: 8 |
Very Cool!!! :-) |
Not strictly related to "this" beta but rather than starting a new thread Is it possible to use a buzzer/beeper without having a display connected? I see from the manual that I can use the GUI BEEP Command but if you have no display connected could you use the same Piezo buzzer on any pin and how could you declare/use it? |
Pulseout |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9136 |
It would have been much better to start a new thread, so I will. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
V5.07.05b3 PicoMite_Beta.zip Fixes bug in BITBANG LCD CMD and BITBANG LCD DATA |
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3881 |
Contains VGA versions b1 & b3. Was it supposed to contain a non-VGA update as well? PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Oops PicoMite_Beta.zip |
Is there a means by which a program can determine when the FRAMEBUFFER COPY operation has completed? (This would be very helpful for the CMM2 also.) I've had a few cases where MMBasic is "too fast" and I've started redrawing the (non-visible) buffer before the previous one was copied to the display. Mostly this applies to the D parameter on the CMM2, which might be nice for the PicoVGA too. Visit Vegipete's *Mite Library for cool programs. |
Copy on the Pico is synchronous so it has always finished before the next statement. The only option is whether or not to wait for the next blanking period before starting the copy |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3381 |
On the current beta PWM Duty is required, not optional. In the manual it is shown as optional. > setpin 4,pwm1a > pwm 1, 50, 50 <--------OK > pwm 1, 50 <--------Not OK Error: Invalid address - resetting PicoMite MMBasic Version 5.07.05b3 Copyright 2011-2021 Geoff Graham Copyright 2016-2021 Peter Mather > |
One duty is required, wouldn't make sense otherwise, but unlike MM2 needn't be the first one. so pwm 1,50,,50 is OK as is pwm 1,50,50 Shouldn't crash though will fix in next beta |
Thanks for the prompt response. As the manual shows the duty to be optional I imagined there was a default, 50% perhaps but as you show one or the other is optional not both. I shouldn't make assumptions! |
Coming soonish sprites etc. on the PicoMiteVGA |
| Amnesie Guru Joined: 30/06/2020 Location: GermanyPosts: 763 |
Peter, I just saw this first on YouTube! This is so cool that you made this possible, although now I have to rewirte the code for my "fake" Sprite aproach via BLIT :) But this makes things a lot easier, just wonderful! Greetings Daniel |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6118 |
Dear Peter, Since you are adding new functionality to PicomiteVGA, can I suggest 2 changes. 1/ Turn to mode 1 as soon as you enter edit mode. Many programs written for Picomite will use mode 2 for it's ability to show colour. But editting in mode 2 is difficult. I also noticed if I edit in mode 2 through USB (terminal program putty) that it opens a 40x25 window (not 80x25) so you cannot run on VGA in a different resolution and edit through USB terminal in a different resolution. 2/ This may be a major undertaking, but colour coding in the editor would be a real advantage. I think it may even be possible in 640x480 mode using the tiles you implemented. Using a font that is exactly 80x30 on VGA screen, with 40x30 tiles groups of 2 characters can take any colour. Since there is always a white space of colon separating 2 commands, this could work with commands starting on odd X position. Worst case the colon also changes colour. I hope you can consider these changes Volhout Edited 2022-06-02 16:07 by Volhout PicomiteVGA PETSCII ROBOTS |
But you're only supposed to edit programs in green, Volhout. I know this because I've seen it in films on the telly loads of times. ;) Mick Zilog Inside! nascom.info for Nascom & Gemini |
| Witenite Newbie Joined: 02/06/2022 Location: New ZealandPosts: 8 |
Hi Peter, I've been watching this project for some time now, and now own a PIC32 based Maximite, a CMM2 and now have 2 Pico's running MMBASIC. As a lecturer at a local college in the computer science department, I've been really enthusiastic about sharing my experiences with MMBASIC and am really super impressed that this runs on a Pico! That's just my way of saying thank you for all your super hard work on this project. Truly is a blessing. Now I just tried to run this latest Beta version of the code, but for some reason it won't let me setup the SD card or System SPI option. I get told OPTION SPI is an invalid option. The identical setup works just fine for me with an older version. Not to be put off, I then proceeded to copy (line by line) the demo program you have listed here into the editor, via PuTTy. This almost succeeds, except some of the very long lines error out in the editor, where the editor says LINE IS TOO LONG when I hit column 81. I'm curious to know how you go about typing longer lines into the editor. If you can help at all, please let me know. At the same time I am more than happy to be a guinea pig for any new code you release for MMBASIC. Thanks again! |
| Page 1 of 11 |
