Local Time 10:27 15 Jul 2025 Privacy Policy
Forum Index : Microcontroller and PC projects : PM: Confused about SYSTEM I2C and SETPIN sda,scl,I2C....
     Page 2 of 3
Posted: 01:47am 26 Aug 2022
RTC command - manual page 113
"These chips are I2C devices and must be connected to the two I2C pins with
appropriate pullup resistors. If the I2C bus is already open the RTC
command will use the current settings, otherwise it will temporarily open the
connection with a speed of 100 kHz."
So 400kHz does not seem to be a problem.
Adapted for System I2C and scanning DS1307 module with 24C32 memory.
Print "System I2C Address Scanner"
' Prep table
Print "     0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F"
' loop col/row
For y=0 To 7
 Print Hex$(y,2);": ";
 For x=0 To 15
  addr = y*16+x               ' calc address
  I2C write addr, 0, 1, &H00  ' write zerp to that adress
  If MM.I2C=0 Then            ' check for errors
    Print Hex$(addr,2);" ";   ' found one!
  Else
   Print "-- ";               ' nothing here..
  EndIf
 Next x
 Print
Next y
00: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
01: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
02: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
03: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
04: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
05: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
06: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- --
07: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
Edited 2022-08-26 13:26 by phil99
Posted: 07:33am 26 Aug 2022
if(Option.SYSTEM_I2C_SDA){
ExtCfg(Option.SYSTEM_I2C_SCL, EXT_BOOT_RESERVED, 0);
ExtCfg(Option.SYSTEM_I2C_SDA, EXT_BOOT_RESERVED, 0);
gpio_set_function(PinDef[Option.SYSTEM_I2C_SCL].GPno, GPIO_FUNC_I2C);
gpio_set_function(PinDef[Option.SYSTEM_I2C_SDA].GPno, GPIO_FUNC_I2C);
if(PinDef[Option.SYSTEM_I2C_SDA].mode & I2C0SDA){
I2C0locked=1;
i2c_init(i2c0, 100000);
gpio_pull_up(PinDef[Option.SYSTEM_I2C_SCL].GPno);
gpio_pull_up(PinDef[Option.SYSTEM_I2C_SDA].GPno);
I2C_enabled=1;
I2C0SDApin=Option.SYSTEM_I2C_SDA;
I2C0SCLpin=Option.SYSTEM_I2C_SCL;
I2C_Timeout=100;
} else {
I2C1locked=1;
i2c_init(i2c1, 100000);
I2C2_enabled=1;
I2C1SDApin=Option.SYSTEM_I2C_SDA;
I2C1SCLpin=Option.SYSTEM_I2C_SCL;
I2C2_Timeout=100;
if(Option.RTC)RtcGetTime(1);
Quazee137
Posted: 08:03am 26 Aug 2022
a little mod to phil99's scanner
Print "System I2C and I2C2 Address Scanner"
' Prep table
print "For I2C"
' loop col/row
For y=0 To 7
For x=0 To 15
 Else
 EndIf
Next x
Print
Next y
SetPin gp3,gp2,i2c2 ' change pins to your usage
I2C2 open 100,1000
print "For I2C2"
' loop col/row
For y=0 To 7
For x=0 To 15
 I2C2 write addr, 0, 1, &H00  ' write zerp to that adress
 Else
 EndIf
Next x
Print
Next y
I2C2 close
I have a box full of 1307's and DHT12's that I'm playing with as room loggers saving
every 20 mins to on board eproms. New windows coming next mid next month and want to
see how much better the are so need old windows ref.
I was running Analog clock on a pico and added the I2C2 to test out the DHT12 code
and had a DS3231 on I2C and a 1307 on I2C2. If I unplugged either and did RTC
gettime both gave me the correct time but only been testing for a week. I had set
the time on them while plugged in to a MM170 both seem to keep ok time.
MM170 boards out in the field started with the 1307's but over time was switched
out for the DS3231's. So now playing with a box full of the 1307's LOL.
So much Thanks to Geoff, Peter and all other's making MMBasic so much FUN.
Quazee137
Edited 2022-08-26 18:26 by Quazee137
Posted: 09:09am 26 Aug 2022
I2C0locked=1;
I2C_enabled=1;
I2C_Timeout=100;
} else {
I2C1locked=1;
I2C2_enabled=1;
I2C2_Timeout=100;
Thanks Peter ! I assumed this was the case, but was mislead by expressions from others. I apologize for not investigating it myself before raising the issue. Happy holidays...
pwillard
Posted: 12:00pm 26 Aug 2022
With a *proper* crystal, the DS1307 only loses about a minute per month.  With the poorly matched crystal most commonly found on DS1307 break-out boards... It's much worse and what gives them a bad reputation (rightfully so).
But they are still horrible when compared to the likes of DS3231 (primarily because they are not leaving the crystal timing issues up to an external part).
Posted: 07:44am 29 Aug 2022
Some extras for Quazee137's upgraded version.
Print "PicoMite System I2C and I2C2 Address Scanner"
Print ' Prep table
print "For System I2C"
' loop col/row
For y=0 To 7
For x=0 To 15
 I2C write addr, 0, 1, &H00  ' write 0 to that adress
   device=addr
  Else
 EndIf
Next x
If device=&H68 Then :Print "RTC DS3232, DS1307 etc"; : device=0 : EndIf
If (device>&H49) And (device<&H58) Then :Print "24Cxx EEPROM"; : device=0 : EndIf
If device=&H3C Then :Print "LCD SSD1306"; : device=0 : EndIf
Print
Next y
Print
I2C2 open 100,1000
print "For I2C2 - SDA = GP2, SCL = GP3 "
' loop col/row
For y=0 To 7
For x=0 To 15
 I2C2 write addr, 0, 1, &H00  ' write 0 to that adress
   device=addr
  Else
   EndIf
 Next x
Print
Next y
I2C2 close
For System I2C
05: -- -- -- 53 -- -- -- -- -- -- -- -- -- -- -- -- 24Cxx EEPROM
06: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- -- RTC DS3232, DS1307 etc
05: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 24Cxx EEPROM
Posted: 06:27pm 29 Aug 2022
  Grogster said  I agree with the others here about the 1307.  It is a HORRIBLE chip by today's standards, and when 3232 or 3231 chips are easy and cheap to get now....
I would personally never use a 1307 in ANY project, cos they are so inaccurate.
They were fine to support at the time that 3232 or 3231 chips were very expensive by comparison, but now they are very cheap.  Most RTC modules on AliExpress or eBay use them now, and while they might likely be clones, I have never had any issues with them and they always work for me, making the drifty-as-hell 1307 a bit pointless now I would think.
My 2c only.
This is a pretty hefty position. I cannot confirm the above.
It is true that the cheap chinese DS1307 boards perform bad, but that is not the chips doing.
It is the board loading that causes this problem, not the chip as such. I just bought another one of these boards, and again noticed exactly the same faults as on earlier boards:
- For some stupid reason there are 2x 3.3k pullup in parallel on each of the I2C lines. As if the 24C32 and DS1307 I2C busses once where separate, each with 3.3k resistors, then connected together, but the resistors remained.
- The battery circuit is designed for a rechargeable battery (Lithium) that can have a voltage fully charged up to 4V. To protect the Vbat of the chip there is a resistor divider (500k/1.5meg) to limit this voltage for the chip to 3V. But the 2uA drawn bij this resistor divider consumes more energy than the DS1307. So battery life is shortened.
- There is no decoupling capacitor at the Vbat of the DS1307. That is not needed when connected to a battery, but when connected to high impedance voltage divider, the chip may act strange.
- The crystal seems off-tuned (the DS1307 seems to go faster than actual time). But there are provisions to solder the can of the crystal to the board. If you actually do that, the time is far more accurate.
Conclusion: Blaming the chip may not do it justice. The circuit around it is not optimal.
Oh, voltage levels on I2C bus. The DS1307 needs 5V, but the I2C lines are perfectly happy with 3.3V (Vhigh = 2.2V). So if you remove all pullups from the DS1307 module, and add pullups to 3.3V on the micromite/picomite, it works flawless. You only need to power the DS1307 from pin 39 of the picomite (Vsys=4.7V).
Posted: 02:28am 30 Aug 2022
Most DS1307 modules use a standard clock crystal. Good ones give about 1 minute per month accuracy over typical temperature ranges. The cheap module are likely to use very poor crystals which could be worst.
DS3231 etc use a TCXO which gives one minute per year over the same temperature range.
The cheap DS3231 modules are likely to use 'second quality' chips but do seem to be reasonably precise compared to the DS1307 modules.
If you are only after short term accuracy and in a controlled environment, the DS1307 is fine. Most of my uses have the data acquisition systems in semi-outdoor, uncontrolled environments and need better than what the DS1307 provides, even with regular time adjustments from the network during data transfers.
Posted: 05:34am 30 Aug 2022
I want to go out and play, but it's raining. I'm bored, so here is another version.
SDA = 4 : SCL = 5 ' I2C2 pins. Change pins to your usage, 0 if no I2C2
' (Do NOT use GP numbers, standard Pico RP2040 module pin numbers only)
Print
again = 1
Print "For System I2C"
Scan
If SDA Then
  SetPin SDA, SCL, i2c2
  I2C2 open 100,1000
  Print "For I2C2 - SDA = Pin("SDA"), SCL = Pin("SCL")"
  again = 0
  Scan
 Else
  Print "I2C2 not configured"
EndIf
Sub Scan
 Print "     0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F" ' Prep table
' loop col/row
 For y=0 To 7
  For x=0 To 15
   If again Then
     On Error Skip 3
    Else
   EndIf
   If MM.Errno = 0 Then
       device=addr
      Else
     EndIf
    Else
     Print " I2C not configured"
   EndIf
  Next x
'  -------------- Add your favorite devices here ------------------
  If device = &H68 Then : Print "RTC DS3232, DS1307 etc"; : device=0 : EndIf
  If (device > &H49) And (device < &H58) Then : Print "24Cxx EEPROM"; : device=0 : EndIf
  If device = &H3C Then : Print "LCD SSD1306"; : device=0 : EndIf
  Print
 Next y
 Print
End Sub
TrevorH
Posted: 06:11pm 18 Sep 2022
I am try to get 2 picos to talk to each other with I2C.
Master sending using GP20 and GP21, Slave using GP16 and GP17.
I have tried the routines  explained in 'Getting started with the Micromite' pages 73 and 74, but all I get is "Slave did not respond" and the LED on pin 1 doesn't flash.
This my first use of I2c other than using RTC.
MASTER:-
OPTION AUTORUN ON
SETPIN GP20, GP21, I2C
I2C OPEN 100, 1000
SSETPIN 1, 8
   SPIN 1, 1
   PAUSE 300
   SPIN 1, 0
' configure an I/O pin on the slave
   SUB SSETPIN pinnbr, cfg
     I2C OPEN 100, 1000
     I2C WRITE &H50, 0, 3, 1, pinnbr, cfg
     IF MM.I2C THEN ERROR "Slave did not respond"
     I2C CLOSE
END SUB
   ' set the output of an I/O pin on the slave
   SUB SPIN pinnbr, dat
     I2C OPEN 100, 1000
     I2C WRITE &H50, 0, 3, 2, pinnbr, dat
     I2C CLOSE
END SUB
SLAVE:-
OPTION AUTORUN ON
Setpin GP16, GP17 I2C
DIM msg(2) ' array used to hold the message
I2C SLAVE OPEN &H50, WriteD, ReadD
DO                                ' the program loops forever
     WATCHDOG 1000               ' this will recover from errors
LOOP
SUB ReadD ' received a message
I2C SLAVE READ 3, msg(), recvd ' get the message into the array
IF msg(0) = 1 THEN        ' command = 1
 SETPIN msg(1), msg(2)   ' configure the I/O pin
ELSEIF msg(0) = 2 THEN    ' command = 2
 PIN(msg(1)) = msg(2)    ' set the I/O pin's output
ELSE                      ' the command must be 3
 s$ = str$(pin(msg(1))) + Space$(12) ' get the input on the I/O pin
End if
END SUB
SUBWriteD 'request from the master
 I2C SLAVE WRITE 12, s$ ' send the last measurement
END SUB                ' return from the interrupt
I wondered if the code needed to be different on the Pico?
Posted: 06:21pm 18 Sep 2022
Check my original post and see if you can get that to work - please report if not
TrevorH
Posted: 06:52pm 18 Sep 2022
@matherp,  that works giving me the time from powering up on the console repeatedly incrementing, so the two chips are talking but why doesn't the code I posted work?
Is the Pico implementation different?
Posted: 08:56pm 18 Sep 2022
You are opening I2C in the main program and again in the SUB without closing it first. I suspect that that is your error.
TrevorH
Posted: 12:44am 19 Sep 2022
Hi Jim, I have tried all the combinations, no opens and closes and use I2C System, I2C open only at the start of the master and no opens and closes. I've tried different addresses all with same result. All I am trying to do is setup 1 I/O pin and toggle it.
TrevorH
Posted: 09:18am 22 Sep 2022
I have these Pico's talking to each other eventually, as I/O, but if I try to use the read I/O pin command (3) from the master it does one iteration in the loop and locks up without passing back the read data.
I must be doing something wrong. Has anyone any ideas??
The first problem I had was that 'setpin 1, 8' did not work (threw an error) although
using this is suggested in the manual.
The hardware is a bunch of leds wired to first 10 ports via 240ohm Rs and 2 picos wired together with I2C pins (master 20,21, slave 16,17)
SLAVE
option autorun on
dim as integer msg(2), addr = 69
dim as string s$
setpin gp16, gp17, i2c
'setpin gp26, Ain
i2c slave open addr, tint, rint  'slaves address is HEX 50
do
'print pin(gp26)
   Watchdog 1000
loop
sub rint
   local count
   msg(0) = 0
   msg(1) = 0
   msg(2) = 0
   i2c slave read 3, msg(), count
   'print msg(0), msg(1), msg(2), count
   if msg(0) = 1 then              'check command  is 1
     select case msg(2)
       case 1
         setpin msg(1), Ain        'configure the I/O port
       case 2
         setpin msg(1), din
       case 3
         setpin msg(1), fin
       case 4
         setpin msg(1), pin
       case 5
         setpin msg(1), cin
       case 6
         setpin msg(1), dout
     end select
   elseif msg(0) = 2 then          ' command is 2
     pin(msg(1)) = msg(2)         'set the I/O pins o/p
    ' print msg(2)
   else                            ' command is 3 (read pin)
     a = pin(msg(1))
     s$ = str$((a)
     print s$, len(s$)
     i2c slave write 2, s$
   end if
end sub
sub tint
   local a$ = "PinS O/P"
   i2c slave write 8, a$
   'print "TX"
end sub
MASTER
'OPTION EXPLICIT
'OPTION DEFAULT NONE
Option autorun on
Dim As integer msg(2), count = 1
SetPin gp20, gp21, i2c
I2C open 100, 1000
dim as integer addr = 69     'Address &H45
ssetpin 1, 6
ssetpin 2, 6
ssetpin 4, 6
ssetpin 5, 6
ssetpin 6, 6
ssetpin 7, 6
ssetpin 9, 6
ssetpin 10, 6
ssetpin 11, 6
ssetpin 12, 6
ssetpin 31, 1
do
 spin 1, 1
 spin 2, 1
 spin 4, 1
 spin 5, 1
 spin 6, 1
 spin 7, 1
 spin 9, 1
 spin 10, 1
 spin 11, 1
 spin 12, 1
 pause 300
 spin 1, 0
 spin 2, 0
 spin 4, 0
 spin 5, 0
 spin 6, 0
 spin 7, 0
 spin 9, 0
 spin 10, 0
 spin 11, 0
 spin 12, 0
 pause 100
' print spinR(31)     ' If I uncomment this to read a pin, program locks up
 i2c read addr, 0, 8, a$
 print a$
 pause 200
loop
sub ssetpin pinnbr as integer, cfg as integer   'CMD 1 = configure an I/O pin on the slave
   i2c write addr, 0, 3, 1, pinnbr, cfg
   if mm.i2c = 1 then error "Slave did not respond"
   'print "setpin", pinnbr, cfg
end sub
sub spin pinnbr as integer, dat as integer      'CMD 2  = set output of pin
   i2c write addr, 0, 3, 2, pinnbr, dat
   'print "output"
end sub
Function spinR(pinnbr)                          ' CND 3  = read value on pin
local t$
   i2c write addr, 0, 3, 3, pinnbr, 0
   i2c read addr, 0, 3, t$
   SpinR = val(t$)
end function
Posted: 10:00am 22 Sep 2022
You can't use a number with setpin - use DIN, DOUT etc. Please let me know where it says you can in the manual and I'll get it removed
TrevorH
Posted: 11:35am 22 Sep 2022
I was following the I2C recommendations in "Getting started with the Micromite" p73 where it suggests using
setpin 15, 8 in the I2C section, since this is root of using I2C between processors info.
I did ask if the Picomite firmware handled things differently.
So it's NOT in the Picomite manual(I was just getting confused I think)
Any ideas on the locking up when read a pin???
Posted: 01:43pm 22 Sep 2022
  matherp said  You can't use a number with setpin - use DIN, DOUT etc. Please let me know where it says you can in the manual and I'll get it removed
Micromite Manual version 5.05.05. pages 73-74:
SETPIN pin, cfg [, option]
           Previous versions of MMBasic used numbers for 'cfg' and the mode OOUT.
           For backwards compatibility they will still be recognised.
i feel this may have been discussed a year or two back, but can't remember the exact details.
btw: i assume that "OOUT" should be "DOUT"?
rob   :-)
Posted: 09:02am 23 Sep 2022
I think that's the Micromite, not Picomite.
TrevorH
Posted: 09:51am 23 Sep 2022
Has anyone had a working 2 picomites with one as slave(I/O) on I2C able to read from slave's ADC ports? If so please let me know how.
     Page 2 of 3
© JAQ Software 2025
