Forum Index : Microcontroller and PC projects : Raycaster for PicoVGA
| gadgetjack Senior Member Joined: 15/07/2016 Location: United StatesPosts: 233 |
I re-wrote an old raycaster I did for QB64 forum. Runs ok, little slow. Could use some optimizing.... DIM SinTable(1795) DIM CosTable(1799) PI = 22 / 7 DIM Mapp(10, 10) FOR z= 0 TO 1795 SinTable(z) = SIN(z * PI / 900) * 100 CosTable(z) = COS(z * PI / 900) * 100 NEXT z FOR y = 1 TO 10 FOR x = 1 TO 10 READ Mapp(x, y) IF Mapp(x, y) = 2 THEN Mapp(x, y) = 0 px = x: py = y END IF NEXT x NEXT y px = px * 1000 py = py * 1000 mode 2 mangle = 0 SkyColor = rgb(0,0,255) FloorColor = rgb(255,0,0) DO Raycast DO kb$ = INKEY$ loop while kb$=("") IF kb$ = "w" THEN px = px - SinTable(mangle) * 5: py = py - CosTable(mangle) * 5 IF kb$ = "s" THEN px = px + SinTable(mangle) * 5: py = py + CosTable(mangle) * 5 IF kb$ = "d" THEN mangle = mangle + 25 IF kb$ = "a" THEN mangle = mangle - 25 IF mangle < 0 THEN mangle = mangle + 1800 IF mangle > 1795 THEN mangle = mangle - 1800 LOOP Sub Raycast s = -1 FOR z = -160 TO 160 s = s + 1 a = mangle + z IF a < 0 THEN a = a + 1795 IF a > 1795 THEN a = a - 1795 ' xx = px: yy = py dd = 0 DO xx = xx - SinTable(a) yy = yy - CosTable(a) m = Mapp(xx / 1000, yy / 1000) dd = dd + 1 LOOP UNTIL m ds = 1000 / dd cr=rnd()*255:cg=rnd()*255:cb=rnd()*255 LINE s, 0,s, 99 - ds,, SkyColor LINE s, 100 - ds,s, 100 + ds,,rgb(cr,cg,cb)'walls LINE s, 101 + ds,s, 199,, FloorColor NEXT z End Sub DATA 1,1,1,1,1,1,1,1,1,1 DATA 1,0,0,0,0,0,0,0,0,1 DATA 1,0,0,1,0,1,1,1,0,1 DATA 1,1,1,1,0,0,0,1,0,1 DATA 1,0,0,0,0,0,0,1,0,1 DATA 1,0,0,0,0,2,0,0,0,1 DATA 1,1,1,1,0,1,0,0,0,1 DATA 1,0,0,0,0,1,0,1,0,1 DATA 1,0,1,1,1,1,0,0,0,1 DATA 1,1,1,1,1,1,1,1,1,1 |
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1459 |
Nice Job, your Sub Raycast looks much simpler than mine... at first view, i found 2 parts to speed things up. first: replace If a < 0 Then a = a + 1795 If a > 1795 Then a = a - 1795 with a=a+1796*(a < 0)-1795*(a>1795) this is more performant scan only every 2nd Ray reduces the nuber of scans from 320 to 160 so in the Sub Raycast For z = -160 To 160 Step 2 inc s,2 and replace the Line routines with Box s, 0,2, 99 - ds,, SkyColor Box s, 100 - ds,2,(101 + ds)- (100 - ds),,RGB(cr,cg,cb)'walls Box s, 101 + ds,2, 199-(101 + ds),, FloorColor -- Maybe you use the Frame Buffer to draw the new screen in the Background Set one Block of Skycolor abd one of Floorcolor befor you start casting then you get rid of the Floor and Sky Color commands in the Loop take a look at my try (maybe we both can improve) Raycast / Pico Edited 2023-01-27 20:22 by Martin H. 'no comment |
so here is my suggestion for optimization. first set OPTION CPUSPEED 378000 FRAMEBUFFER create FRAMEBUFFER write f Dim SinTable(1795) Dim CosTable(1795) 'PI = 22 / 7 Dim Mapp(10, 10) For z= 0 To 1795 SinTable(z) = Sin(z * Pi / 900) * 100 CosTable(z) = Cos(z * Pi / 900) * 100 Next z For y = 1 To 10 For x = 1 To 10 Read Mapp(x, y) If Mapp(x, y) = 2 Then Mapp(x, y) = 0 px = x: py = y EndIf Next x Next y px = px * 1000 py = py * 1000 MODE 2 mangle = 0 SkyColor = RGB(0,0,255) FloorColor = RGB(255,0,0) Do Box 0,0,320,100,,SkyColor,SkyColor Box 0,100,320,100,,FloorColor,FloorColor Raycast Box 0,200,320,40,,0,0 FRAMEBUFFER copy f,n Do kb$ = Inkey$ Loop While kb$=("") Select Case kb$ Case = "w" px = px - SinTable(mangle) * 5: py = py - CosTable(mangle) * 5 Case "s" px = px + SinTable(mangle) * 5: py = py + CosTable(mangle) * 5 Case "d" mangle = mangle + 25 Case "a" mangle = mangle - 25 End Select mangle=mangle+1800*(mangle < 0)-1800*(mangle > 1795) Loop Sub Raycast s = -2 For z = -160 To 160 Step 2 Inc s,2 a = mangle + z a=a+1796*(a < 0)-1795*(a>1795) xx = px: yy = py dd = 0 Do Inc xx,-SinTable(a):Inc yy,-CosTable(a) m = Mapp(xx / 1000, yy / 1000) Inc dd Loop Until m ds = 1000 / dd cr=Rnd()*255:cg=Rnd()*255:cb=Rnd()*255 Box s, 100 - ds,2,(101 + ds)- (100 - ds),,RGB(cr,cg,cb),RGB(cr,cg,cb)'walls Next z End Sub Data 1,1,1,1,1,1,1,1,1,1 Data 1,0,0,0,0,0,0,0,0,1 Data 1,0,0,1,0,1,1,1,0,1 Data 1,1,1,1,0,0,0,1,0,1 Data 1,0,0,0,0,0,0,1,0,1 Data 1,0,0,0,0,2,0,0,0,1 Data 1,1,1,1,0,1,0,0,0,1 Data 1,0,0,0,0,1,0,1,0,1 Data 1,0,1,1,1,1,0,0,0,1 Data 1,1,1,1,1,1,1,1,1,1 with tracing you go a different way than I had in my Program. You look after each step whether the cell is set. That works, but if you're unlucky you'll query the same cell 1000 times. Cheers Mart!n Edited 2023-01-27 23:50 by Martin H. 'no comment |
Martin , thanks for you input. I knew that smarter people than me would get this running better. I tip my hat to you sir. |
I had understood your sentence as an invitation to take a look at it and see where you can optimize it and because I just had the time, I tried out what I could improve. That doesn't mean that I feel smarter than you. The community lives from the exchange of experiences, so don't take my posts as criticism. Cheers Mart!n 'no comment |
Martin , I thank you for your input. Sometimes we just have to look at it from another angle , and folks here are great at that. One of the reasons I hang around on this site. Jack |
