Local Time 18:13 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Anyone know Assembler language?
     Page 1 of 3
lew247
Posted: 06:03pm 17 May 2023
I want to port across something I only have in assembler to a Pico
But as most of you know I'm hopeless with code
However I'm going to give it a go
If anyone knows how to read assembler could you "PLEASE" tell me what the following subroutines do, as in how the get the values and where from
CHECKTHR  'This check the threshold but where does it get the threshold from
THRSET  'sets the threshold "somehow"
DONETHR 'done setting the threshold?
LEDBAR  'How/Where does is get the dbm values from?
TETRA4S  'I think contains 4 second timer?
MAIN  'Start A/D convert? how does it assign the (RSSI)dbm figure?
CONV0 'I think this reads the analog input and assigns the RSSI(dbm) value but How?
Once I understand how those work, I should be able to do the rest
LIST P=16F818, F=INHX8M
#include <p16f818.inc>
__CONFIG _WDT_OFF & _PWRTE_OFF & _INTRC_IO & _MCLR_ON & _BODEN_OFF & _LVP_OFF & _CPD_OFF &  _WRT_ENABLE_OFF & _DEBUG_OFF & _CCP1_RB2 & _CP_OFF
; Equates
RESET_V EQU 0x00 ; Address of RESET Vector
OSC_FREQ EQU D'8000000' ; Internal Oscillator Frequency is 8 MHz
; Registers
FLAGS EQU 0x20 ; Various flags
THRLVL EQU 0x21 ; Threshold level set via UI
MAXH EQU 0x22 ; LEVEL MAX HOLD value to be shown on LED bar
TEMPBAR EQU 0x23 ; Pattern on LED bar if it's blanked (BRT)
TEMPTHR EQU 0x24 ; Used in threshold set routine
BRITE EQU 0x25 ; LED Brightness
T4S EQU 0x26 ; Tetra 4s timing
I2CDELAY EQU 0x27 ; Used for I2C timing
I2CBUF EQU 0x28 ; Used for I2C data
I2CCNT EQU 0x29 ; Used for I2C bitbanger
DB2 EQU 0x30 ; Stealth byte for prescaler (0x50-0x5F)
TEMPW EQU 0x40 ; Context saving for interrupts
TEMPSTATUS EQU 0x41 ; in all banks
; Defines
#define LEDS PORTB ; 8 LED bar RB0-3 GRN, RB4,5 ORG RB6,7 RED
#define RSSI PORTA, 0 ; A/D input from AD8307
#define ALARM PORTA, 1 ; Threshold Alarm Output
#define THR PORTA, 3 ; Alarm threshhold button input
#define BRT PORTA, 4 ; LED brightness button input
#define SCL PORTA, 6
#define SDA PORTA, 7 ; I2C bus outputs
#define BLANKBAR FLAGS, 0 ; 1: blanked (BRT)
#define BRTBTN FLAGS, 1 ; 1: BRT Button Pressed
#define NITE FLAGS, 3 ; 1: lowest brightness
#define DIM FLAGS, 4 ; 1: low brightness
#define DAY FLAGS, 5 ; 1: mid brightness
#define FULL FLAGS, 6 ; 1: max brightness
   ORG 0
   GOTO START
   ORG 4
; Timer0 Interrupt Handler
BCF INTCON , TMR0IF ; Clear TMR0 interrupt
BCF INTCON , GIE ; Disable global interrupts
MOVWF TEMPW ; Copy W to a Temporary Register (all banks)
SWAPF STATUS , W ; Swap STATUS nibbles and place into W register
MOVWF TEMPSTATUS ; Save STATUS to a Temporary register (DS31008a)
CALL BARBRITE ; BRT Button test
CALL THRSET ; Threshold Setting Routine
MOVLW B'00000001'
XORWF FLAGS , 1 ; XOR BLANKBAR
BTFSC BLANKBAR ; Test if clear
GOTO BLANKLEDS ; Set, blank leds
MOVFW BRITE ; Fetch LED brightness
SUBLW 0xFF ; Subtract BRITE from 0xFF
MOVWF TMR0 ; And load Timer0
MOVFW TEMPBAR ; Fetch LED pattern
MOVWF LEDS ; Write to LEDs
GOTO ENDINT
BLANKLEDS
CLRF LEDS ; Switch off LEDs
CALL TETRA4S ; Check if 4s have elapsed, if so write pattern to TEMPBAR.
ENDINT
SWAPF TEMPSTATUS , W ; Swap original STATUS register value
MOVWF STATUS ; Restore STATUS register from W
SWAPF TEMPW , F ; Swap W_Temp nibbles and return value to W_Temp
SWAPF TEMPW , W ; Swap W_Temp to W to restore original W (DS31008a)
BSF INTCON , GIE ; Re-enable global interrupts
RETFIE
START
; Init stuff
CLRF STATUS ; Do initialization, Select bank 0
CLRF INTCON
BSF INTCON , GIE ; Enable GIE
BSF INTCON , TMR0IE ; Enable Timer0 Interrupt
CLRF PCLATH ; Keep in lower 2KByte
CLRF CCP1CON
MOVLW B'00111111'
BANKSEL TRISA
MOVWF TRISA ; RA7,6 Outputs, 5-0 Inputs
CLRF TRISB ; RB7-0 Outputs
MOVLW B'00000110' ; Timer0, prescaler 1:128
MOVWF OPTION_REG
MOVLW B'01110000' ; 8 MHz clock
MOVWF OSCCON
MOVLW B'00001110' ; AN0 Analog input, AN1-4 Digital IO, ADRESH only (ADRESL discarded)
MOVWF ADCON1
MOVLW B'01000001' ; AD conv ON, AN0 Selected, Fosc/8 (T(AD)=1us)
BANKSEL ADCON0
MOVWF ADCON0
CLRF PORTB ; Make all PORT B outputs low
CLRF TMR0 ; Reset Timer 0
MOVLW 0x04 ; Startup Brightness ("dim")
MOVWF BRITE
BSF DIM
; Restore Threshold from EEPROM
BANKSEL EEADR ; Select Bank of EEADR
MOVLW 0x00
MOVWF EEADR ; Data Memory Address to read (0x00)
BANKSEL EECON1 ; Select Bank of EECON1
BCF EECON1 , EEPGD ; Point to Data memory
BSF EECON1 , RD ; EE Read
BANKSEL EEDATA ; Select Bank of EEDATA
MOVF EEDATA , W ; W = EEDATA
BANKSEL THRLVL
MOVWF THRLVL ; Restored Threshold
BSF SDA ; I2C idle
BSF SCL
MOVLW 0x60 ; Set Prescaler second byte (stealth mode)
MOVWF DB2
CALL DEBOUNCE ; Clock Stabilization delay 16 ms
CALL TUNE ; Set tuner frequency
MAIN
BSF ADCON0,GO ; Start A/D (RSSI)
CONV0
NOP
BTFSC ADCON0, GO ; Test if done
GOTO CONV0
MOVFW ADRESH ; Move 8 bit A/D result to W
SUBWF MAXH,0 ; Subtract W from MAXH
BTFSC STATUS,C ; result larger than MAXH?
GOTO MAIN ; No
MOVFW ADRESH
MOVWF MAXH ; New MAXH
GOTO MAIN
TETRA4S
; Subroutine
; Tests if 4 seconds have elapsed
; Converts MAXH to LED bar
DECFSZ T4S,1
RETURN
MOVLW 0xF2 ; 0xF2 for 4s
MOVWF T4S
CALL LEDBAR
MOVWF TEMPBAR
CLRF MAXH ; Destroy Max Hold value
CALL CHECKTHR ; Check threshold, beep if reached
RETURN
LEDBAR ;
MAXH contains RSSI max value
; LED bar pattern is in W
MOVFW MAXH
ADDLW 0x9A ; LEVEL > -40 dBm
BTFSS STATUS ,C
GOTO LEDS7F
MOVLW 0xFF ; Fullscale
RETURN
LEDS7F
MOVFW
MAXH ADDLW 0xA5 ; LEVEL > -48 dBm
BTFSS STATUS ,C
GOTO LEDS3F
MOVLW 0x7F
RETURN
LEDS3F
MOVFW MAXH
ADDLW 0xAF ; LEVEL > -56 dBm
BTFSS STATUS ,C
GOTO LEDS1F
MOVLW 0x3F
RETURN
LEDS1F
MOVFW MAXH
ADDLW 0xBA ; LEVEL > -64 dBm
BTFSS STATUS ,C
GOTO LEDS0F
MOVLW 0x1F
RETURN
LEDS0F
MOVFW MAXH
ADDLW 0xC5 ; LEVEL > -72 dBm
BTFSS STATUS ,C
GOTO LEDS07
MOVLW 0x0F
RETURN
LEDS07
MOVFW MAXH
ADDLW 0xD0 ; LEVEL > -80 dBm
BTFSS STATUS ,C
GOTO LEDS03
MOVLW 0x07
RETURN
LEDS03
MOVFW MAXH
ADDLW 0xDA ; LEVEL > -88 dBm
BTFSS STATUS ,C
GOTO LEDS01
MOVLW 0x03
RETURN
LEDS01
MOVFW MAXH
ADDLW 0xE3 ; LEVEL > -96 dBm
BTFSS STATUS ,C
GOTO LEDS00
MOVLW 0x01
RETURN
LEDS00
MOVLW 0x00 ; LEVEL at noise floor -108 dBm
RETURN
; Set frequency of tuner TUNE
CALL I2CSTART
MOVLW 0xC0 ; Address
CALL I2CBYTE
MOVLW 0x34 ; Prescaler first byte
CALL I2CBYTE
MOVFW DB2 ; Get Prescaler second byte
CALL I2CBYTE
MOVLW 0xCA ; Control Byte
CALL I2CBYTE
MOVLW 0x90 ; Port Byte (Mid Band)
CALL I2CBYTE
CALL I2CSTOP
BCF INTCON , TMR0IF ; Clear TMR0 interrupt just in case
BSF INTCON ,
GIE ; Enable global interrupts
RETURN
I2CSTART
BCF SDA
CALL DELAY10US
BCF SCL
CALL DELAY10US
RETURN
I2CBYTE
MOVWF I2CBUF
MOVLW 0x08
MOVWF I2CCNT
NEXTBIT
BCF STATUS ,C ; Clear carry
BCF SDA ; Glitch if next bit is 1 again UGLY!
RLF I2CBUF ,1
BTFSC STATUS ,C
BSF SDA
CALL DELAY10US
BSF SCL ; Send clock
CALL DELAY10US
BCF SCL
CALL DELAY10US ; Done clock
DECFSZ I2CCNT,1
GOTO NEXTBIT
BCF SDA ; Fake ACK
CALL DELAY10US
BSF SCL
CALL DELAY10US
BCF SCL
CALL DELAY10US
RETURN
I2CSTOP
BCF SDA
CALL DELAY10US
BSF SCL
CALL DELAY10US
BSF SDA
RETURN
DELAY10US
MOVLW 0x14 ; 33 us delay
MOVWF I2CDELAY
LOOP0
DECFSZ I2CDELAY,1
GOTO LOOP0
RETURN
DEBOUNCE
; Subroutine, used in THR setting and INIT
MOVLW 0xFF ; 96 ms outer delay
MOVWF I2CCNT
LOOP1
MOVLW 0xFF ; 0.39 ms inner delay
MOVWF I2CDELAY
LOOP2
DECFSZ I2CDELAY,1
GOTO LOOP2
DECFSZ I2CCNT,1
GOTO LOOP1
RETURN
BARBRITE
; Subroutine (called from within INT handler)
; Modifies BAR brightness after BRT is pressed
; Debounce (every 16 ms)
BTFSC BRT ; Test BRT Button
GOTO NOBRT
BTFSC BRTBTN ; BRT Button still pressed?
RETURN
BSF BRTBTN
BTFSC NITE
GOTO DIMBRT
BTFSC DIM
GOTO DAYBRT
BTFSC DAY
GOTO FULLBRT
BCF FULL
BSF NITE
MOVLW 0x01
MOVWF BRITE
RETURN
DIMBRT
BCF NITE
BSF DIM
MOVLW 0x04
MOVWF BRITE
RETURN
DAYBRT
BCF DIM
BSF DAY
MOVLW 0x20
MOVWF BRITE
RETURN
FULLBRT
BCF DAY
BSF FULL
MOVLW 0xF0
MOVWF BRITE
RETURN
NOBRT
BCF BRTBTN
RETURN
THRSET
; User interface to change threshold for alarm
; All LEDs are full on because the PWM brightness control uses the interrupt
BTFSC THR ; Test THR Button
GOTO NOTHR
THR1
CLRF LEDS ; switch off LEDs
CALL DEBOUNCE ; 0.1 s delay
BTFSS THR ; THR Button still pressed?
GOTO THR1
THR2
MOVFW THRLVL
MOVWF LEDS ; Show threshold
MOVWF TEMPTHR
THR3
BTFSS THR ; THR button?
GOTO DECTHR
BTFSS BRT ; BRT button?
GOTO INCTHR
GOTO THR3
; INC threshold
INCTHR
CALL DEBOUNCE
CALL DEBOUNCE ; 0.2 s delay
MOVFW THRLVL
SUBLW 0xFF ; FF?
BTFSS STATUS,Z
GOTO
INC7F
GOTO DONETHR ; yes, exit INC INC7F
MOVFW THRLVL
SUBLW 0x7F
BTFSS STATUS,Z
GOTO INC3F
MOVLW 0xFF
MOVWF THRLVL
GOTO DONETHR
INC3F
MOVFW THRLVL
SUBLW 0x3F
BTFSS STATUS,Z
GOTO INC1F
MOVLW 0x7F
MOVWF THRLVL
GOTO DONETHR
INC1F
MOVFW THRLVL
SUBLW 0x1F
BTFSS STATUS,Z
GOTO INC0F
MOVLW 0x3F
MOVWF THRLVL
GOTO DONETHR
INC0F
MOVFW THRLVL
SUBLW 0x0F
BTFSS STATUS,Z
GOTO INC07
MOVLW 0x1F
MOVWF THRLVL
GOTO DONETHR
INC07
MOVFW THRLVL
SUBLW 0x07
BTFSS STATUS,Z
GOTO INC03
MOVLW 0x0F
MOVWF THRLVL
GOTO DONETHR
INC03
MOVLW 0x07
MOVWF THRLVL
GOTO DONETHR
; DEC threshold DECTHR
CALL DEBOUNCE
MOVFW THRLVL
SUBLW 0xFF ; FF?
BTFSS STATUS,Z
GOTO DEC7F
MOVLW 0x7F
MOVWF THRLVL
GOTO DONETHR
DEC7F
MOVFW THRLVL
SUBLW 0x7F ; 7F?
BTFSS STATUS, Z
GOTO DEC3F
MOVLW 0x3F
MOVWF THRLVL
GOTO DONETHR
DEC3F
MOVFW THRLVL
SUBLW 0x3F
BTFSS STATUS ,Z
GOTO DEC1F
MOVLW 0x1F
MOVWF THRLVL
GOTO DONETHR
DEC1F
MOVFW THRLVL
SUBLW 0x1F
BTFSS STATUS ,Z
GOTO DEC0F
MOVLW 0x0F
MOVWF THRLVL
GOTO DONETHR
DEC0F
MOVFW THRLVL
SUBLW 0x0F
BTFSS STATUS,Z
GOTO DEC07
MOVLW 0x07
MOVWF THRLVL
GOTO DONETHR
DEC07
MOVFW THRLVL
SUBLW 0x07
BTFSS STATUS,Z
GOTO DONETHR
MOVLW 0x03
MOVWF THRLVL
; There's no lower threshold, that'd be silly
; Done manipulating threshold
DONETHR
BTFSC THR ; THR button?
GOTO THR2 ; No
MOVFW THRLVL
BTFSC THR ; Still THR button?
GOTO THR2 ; Yes, exit and restore THR
MOVFW TEMPTHR ; Restore THR
MOVWF THRLVL
THR4
CALL DEBOUNCE ; to enable releasing THR button
BTFSS THR
GOTO THR4
CALL DEBOUNCE
; Store THRLVL into EEPROM (copied from datasheet)
BTFSC EECON1 , WR ; Wait for write
GOTO $-1 ; to complete
MOVLW 0x00
MOVWF EEADR ; Data Memory Address to write
BANKSEL THRLVL
MOVFW THRLVL
BANKSEL EEDATA
MOVWF EEDATA ; Data Memory Value to write
BCF EECON1 , EEPGD ; Point to DATA memory
BSF EECON1 , WREN ; Enable writes
MOVLW 0x55
MOVWF EECON2 ; Write 55h
MOVLW 0xAA
MOVWF EECON2 ; Write AAh
BSF EECON1 , WR ; Set WR bit to begin write
BCF EECON1 , WREN ; Disable writes
BANKSEL PORTB ; Select BANK0
NOTHR
RETURN
CHECKTHR
; Subroutine called from TETRA4S ; Checks if threshold is reached
MOVFW TEMPBAR
SUBWF THRLVL, 0
BTFSC STATUS,Z
GOTO PIP
RETURN
; Creates "pip"
PIP
MOVLW B'00111101'
BANKSEL TRISA
MOVWF TRISA ; RA7,6,1 Outputs, 5-2,0 Inputs (ALARM output)
MOVLW 0xAA ; 64 ms outer delay
BANKSEL I2CCNT
MOVWF I2CCNT
LOOP3
MOVWF I2CDELAY
LOOP4
DECFSZ I2CDELAY,1
GOTO LOOP4
MOVLW B'00000010'
XORWF PORTA ,1 ; Toggle ALARM
DECFSZ I2CCNT,1
GOTO LOOP3
MOVLW B'00111111'
BANKSEL TRISA
MOVWF TRISA ; RA7,6 Outputs, 5-0 Inputs (ALARM Hi Z to minimize pop)
BCF STATUS, RP0 ; Select bank 0
RETURN
END
Posted: 06:36pm 17 May 2023
My only assembler was a brief dabble with Z80 about 3 years ago.
It's a bit of a big ask Lewis, IMO you need to bite the bullet yourself and go through the code line by line looking up the mnemonics (I think it's the PIC18F instruction set) and commenting as you go,
e.g.
CHECKTHR
MOVFW TEMPBAR     ; Move value from TEMPBAR into W.
SUBWF THRLVL, 0   ; Subtract W from value in THRLVL and store back in W.
BTFSC STATUS,Z    ; If the Z bit of value in the STATUS register is zero (meaning the
                  ; result of the previous subtraction was not zero) then skip the
                  ; next instruction.
GOTO PIP          ; Jump to the PIP routine.
RETURN            ; Return from the CHECKTHR routine.
I *think* the equivalent MMBasic probably looks something like
Sub CHECKTHR
 If TEMPBAR = THRLVL Then PIP() ' Call PIP routine
End Sub
Good luck,
Edited 2023-05-18 04:52 by thwill
Posted: 06:41pm 17 May 2023
If you know what it does and, if there's some sort of user interface, what it looks like when it's running then IMHO it would be *far* easier to start from scratch and write something new in MMBasic that behaves like it. If you don't know what it does then my advice is to forget it. Unless you really love banging your head against walls, that is.  :)
OTOH, PIC assembler doesn't have that many commands (but they do have some horrible register addressing).
Posted: 07:04pm 17 May 2023
The first questions are "What is it?" and "What do you want to do with it?"
Can you provide links for your sources for this code and this module?
CaptainBoing
Posted: 07:07pm 17 May 2023
can't help with the de-assemble (as others have pointed out it is a big ask because you have to be privy to the mental processes of the original programmer), but if you want to write PIC ASM, consider using Great Cow Basic. It is very active and has had several recent updates.  takes all (well, most) the grunt out of assembler. it is compiled and the F818 is one of thousands of PICs and AVRs it directly supports. You can go direct from GCB to programmed PIC if you have your tool chain set up right (I tend to go to a HEX file and manually burn).
You can examine the Assembler it generates and tweak if you need to (I rarely do, it does quite a good job if you ignore the non-pre-emptive setting of bank bits), you can also have inline Assembler in your basic source. No floating point, so all those fixed point tricks you used 40 years ago will benefit.
I use it for simpler projects or where speed is needed.
here is an example of some code of mine to show how easy it is to use (and uses a diminutive 12F508 to do something useful).
' ----- Configuration
 #chip   12F508,4
 #config osc = int, wdt=on
 #define Approx1s 996
 #define ConA  16
 #define ConB  32
START:
 ' assign the prescaler to the WDT
 'ASM [
   movlw B'10001111'
   option
 DIM mm        AS WORD
 DIM nn        AS BYTE
 DIM RLMAP(2)  AS BYTE '  this is the bit pattern to toggle
 DIM DLY       AS WORD
 DIR GPIO b'11001110'
 ' GPIO.0 OUT  ' n/c but could be used as "alive" indicator with an LED
 ' GPIO.1 IN   ' dip switch bit 0
 ' GPIO.2 IN   ' dip switch bit 1
 ' GPIO.3 IN   ' dip switch bit 2
 ' GPIO.4 OUT  ' RL1 - PORTA
 ' GPIO.5 OUT  ' RL2 - PORTB
 Wait1s        ' pause a little after boot
 nn=(GPIO / 2) AND 7 ' read the switches (have to right shift)
 RLMAP(0)=ConA ' preset the most common config to save code
 RLMAP(1)=ConB
 DLY=10
 SELECT CASE nn
   CASE =0     ' disconnect both PORTs
     RLMAP(0)=0:RLMAP(1)=0
   CASE =1     ' PORTA static
     RLMAP(1)=ConA
   CASE =2     ' PORTB static
     RLMAP(0)=ConB
   CASE =3     ' 2 mins toggle
     DLY=120
   CASE =4     ' 10 mins toggle
     DLY=600
   CASE =5     ' 30 mins toggle
     DLY=1800
   CASE =6     ' 60 mins toggle
     DLY=3600
   CASE =7     ' 120 mins toggle
     DLY=7200
 END SELECT
Main:
 FOR nn=0 to 1
   FOR mm=1 TO DLY
     GPIO=RLMAP(nn) + (mm and 1)
     Wait1s
   NEXT
 NEXT
 GOTO Main
 Sub Wait1s
   clrwdt
   PAUSE Approx1s
   clrwdt
 end sub
and the assembler from it
;Program compiled by Great Cow BASIC (1.00.00 2023-04-13 (Windows 64 bit) : Build 1237) for Microchip MPASM/MPLAB-X Assembler using FreeBASIC 1.07.1/2023-04-14 CRC29
;Need help?
;  See the GCBASIC forums at http://sourceforge.net/projects/gcbasic/forums,
;  Check the documentation and Help at http://gcbasic.sourceforge.net/help/,
;or, email us:
;   w_cholmondeley at users dot sourceforge dot net
;   evanvennn at users dot sourceforge dot net
;Set up the assembler options (Chip type, clock source, other bits and pieces)
LIST p=12F508, r=DEC
#include <P12F508.inc>
__CONFIG _MCLRE_OFF & _CP_OFF & _WDT_ON & _OSC_INTRC
;Set aside memory locations for variables
DELAYTEMP                        EQU       7          ; 0x7
DELAYTEMP2                       EQU       8          ; 0x8
DLY                              EQU      14          ; 0xE
DLY_H                            EQU      15          ; 0xF
MM                               EQU      18          ; 0x12
MM_H                             EQU      19          ; 0x13
NN                               EQU      11          ; 0xB
OPTION_REG                       EQU      20          ; 0x14
RLMAP                            EQU      29          ; 0x1D
SYSBYTETEMPX                     EQU       7          ; 0x7
SYSTEMP1                         EQU      21          ; 0x15
SYSTEMP1_H                       EQU      22          ; 0x16
SYSTEMP2                         EQU      23          ; 0x17
SYSWAITTEMPMS                    EQU       9          ; 0x9
SYSWAITTEMPMS_H                  EQU      10          ; 0xA
SYSWORDTEMPA                     EQU      12          ; 0xC
SYSWORDTEMPA_H                   EQU      13          ; 0xD
SYSWORDTEMPB                     EQU      16          ; 0x10
SYSWORDTEMPB_H                   EQU      17          ; 0x11
;Alias variables
SYSRLMAP_0 EQU 29
SYSRLMAP_1 EQU 30
;Vectors
;Start of program memory page 0
ORG 0
;Indirect jumps to allow calls to second half of page
goto BASPROGRAMSTART
Delay_MS
goto SysInd_Delay_MS
INITSYS
goto SysInd_INITSYS
SYSCOMPEQUAL16
goto SysInd_SYSCOMPEQUAL16
WAIT1S
goto SysInd_WAIT1S
BASPROGRAMSTART
;Call initialisation routines
call INITSYS
;Start of the main program
START
movlw 143
option
movlw 206
tris GPIO
call WAIT1S
bcf STATUS,C
rrf GPIO,W
movwf SysTemp2
movlw 7
andwf SysTemp2,W
movwf NN
movlw 16
movwf SYSRLMAP_0
movlw 32
movwf SYSRLMAP_1
movlw 10
movwf DLY
clrf DLY_H
SysSelect1Case1
movf NN,F
btfss STATUS, Z
goto SysSelect1Case2
clrf SYSRLMAP_0
clrf SYSRLMAP_1
goto SysSelectEnd1
SysSelect1Case2
decf NN,W
btfss STATUS, Z
goto SysSelect1Case3
movlw 16
movwf SYSRLMAP_1
goto SysSelectEnd1
SysSelect1Case3
movlw 2
subwf NN,W
btfss STATUS, Z
goto SysSelect1Case4
movlw 32
movwf SYSRLMAP_0
goto SysSelectEnd1
SysSelect1Case4
movlw 3
subwf NN,W
btfss STATUS, Z
goto SysSelect1Case5
movlw 120
movwf DLY
clrf DLY_H
goto SysSelectEnd1
SysSelect1Case5
movlw 4
subwf NN,W
btfss STATUS, Z
goto SysSelect1Case6
movlw 88
movwf DLY
movlw 2
movwf DLY_H
goto SysSelectEnd1
SysSelect1Case6
movlw 5
subwf NN,W
btfss STATUS, Z
goto SysSelect1Case7
movlw 8
movwf DLY
movlw 7
movwf DLY_H
goto SysSelectEnd1
SysSelect1Case7
movlw 6
subwf NN,W
btfss STATUS, Z
goto SysSelect1Case8
movlw 16
movwf DLY
movlw 14
movwf DLY_H
goto SysSelectEnd1
SysSelect1Case8
movlw 7
subwf NN,W
btfss STATUS, Z
goto SysSelectEnd1
movlw 32
movwf DLY
movlw 28
movwf DLY_H
SysSelectEnd1
MAIN
movlw 255
movwf NN
SysForLoop1
incf NN,F
movlw 1
movwf MM
clrf MM_H
SysForLoop2
movlw low(RLMAP)
addwf NN,W
movwf FSR
movlw 1
andwf MM,W
movwf SysTemp1
clrf SysTemp1_H
movf SysTemp1,W
addwf INDF,W
movwf GPIO
call WAIT1S
movf MM,W
subwf DLY,W
movwf SysTemp1
movf DLY_H,W
movwf SysTemp1_H
movf MM_H,W
movwf SysTemp2
btfss STATUS,C
incf SysTemp2,W
subwf SysTemp1_H,F
movf SysTemp1,W
movwf SysWORDTempA
movf SysTemp1_H,W
movwf SysWORDTempA_H
clrf SysWORDTempB
clrf SysWORDTempB_H
call SYSCOMPEQUAL16
comf SysByteTempX,F
btfss SysByteTempX,0
goto ENDIF1
incf MM,F
btfsc STATUS,Z
incf MM_H,F
goto SysForLoop2
ENDIF1
SysForLoopEnd2
movlw 1
subwf NN,W
btfss STATUS, C
goto SysForLoop1
SysForLoopEnd1
goto MAIN
BASPROGRAMEND
sleep
goto BASPROGRAMEND
SysInd_Delay_MS
incf SysWaitTempMS_H, F
DMS_START
movlw 142
movwf DELAYTEMP2
DMS_OUTER
movlw 1
movwf DELAYTEMP
DMS_INNER
decfsz DELAYTEMP, F
goto DMS_INNER
decfsz DELAYTEMP2, F
goto DMS_OUTER
decfsz SysWaitTempMS, F
goto DMS_START
decfsz SysWaitTempMS_H, F
goto DMS_START
retlw 0
SysInd_INITSYS
movwf OSCCAL
;asm showdebug This code block sets the internal oscillator to ChipMHz
;asm showdebug _Complete_the_chip_setup_of_BSR,ADCs,ANSEL_and_other_key_setup_registers_or_register_bits
movlw 199
option
movlw 199
movwf OPTION_REG
clrf GPIO
retlw 0
clrf SYSBYTETEMPX
movf SYSWORDTEMPA, W
subwf SYSWORDTEMPB, W
btfss STATUS, Z
retlw 0
movf SYSWORDTEMPA_H, W
subwf SYSWORDTEMPB_H, W
btfss STATUS, Z
retlw 0
comf SYSBYTETEMPX,F
retlw 0
SysInd_WAIT1S
clrwdt
movlw 228
movwf SysWaitTempMS
movlw 3
movwf SysWaitTempMS_H
call Delay_MS
clrwdt
retlw 0
END
I love to follow the ASM file and see what GCB did with my basic
just a thought
Edited 2023-05-18 05:19 by CaptainBoing
okwatts
Posted: 07:54pm 17 May 2023
I'm not sure if this is any help but oshonsoft.com has a  PIC simulator with a basic compiler that looks quite good for some of the lower and midrange PIC chips. It has a nominal cost but might allow you to analyze the code and it does allow you to see the assembly code generated by the Basic compiler. You might be able to work backward and infer how you would code it in MMBasic. That being said looking at the user interface of your device and what it does is probably a more straight forward approach to getting the same functionality.
Bowden_P
Posted: 12:12am 18 May 2023
Hi lew247,
The device is a Microchip PIC16F818. Giving your listing the briefest of scans, it uses an I2C interface to somewhere.
I'm not familiar with this micro, and it has an unusual instruction "MOVFW", probably more likely an older version of "MOVF register-name,W", but I don't have the datasheet and can't check this immediately.
CHECKTHR
MOVFW TEMPBAR
SUBWF THRLVL, 0
BTFSC STATUS,Z
GOTO PIP
RETURN
As per Thwill's explanation, CHECKTHR subroutine compares TEMPBAR with THRLVL and jumps to label PIP if TEMPBAR = THRLVL, otherwise RETURN's back to where CHECKTHR was called from.
The variable THRLVL is written anywhere there is a "MOVWF THRLVL" instruction, such as in the "DONETHR" subroutine.
See also :-
; Restore Threshold from EEPROM ....
or
; INC threshold .... sequence of comparisons,
or
; DEC threshold DECTHR .... sequence of comparisons.
The code isn't strongly structured, using as it does many GOTO's, so would be more difficult to understand for a conversion to MMBASIC.
As Mixtel90 says, if you know how the original worked, I would start from there.
The PIC16F818 would likely have just 35 instructions to understand. Only some are used in your code, so getting the idea of the flow of the code shouldn't be too daunting - if rather time-consuming however!
With best regards, Paul.
Nothing so constant as change.
Andy-g0poy
Posted: 01:15am 18 May 2023
Assembler is simple, and as such it seems complex because you need a lot of it. The big problem is that you have to read it in conjunction with the datasheets for the uP concerned.
You asked where LEDBAR get the dbm values from.
Well I'm impressed with this code, it's actually got some comments in it!
It's also nicely presented. Much better than many coders work.
So LEDBAR does the outputting of the data to the leds.
LEDBAR ;
MOVFW MAXH
Which tells you directly that the data comes from MAXH
Note that MOVFW is a assembler directive not an actual command but it acts like one. It's just a bit of shorthand that saves the programmer typing in a lot of repetitive commands.
W is the PIC "accumlator" register.
If you then search for MAXH you will find that it gets it's data from the A/D convertor ADRESH
There is a long list of code that converts the A/D values into the necessary dbm values...
In mmbasic all of this can be done with the ADC commands which can also be set to generate an interrupt when the conversion is complete and the data is in the specified array.
However as others have said it's pretty much pointless trying to covert this code the Pico MMbasic directly
By all means use it as a guide as to what needs to be done, Just map out what you need to do, and then write the mmbasic routines, which will do a lot more than the assembler code will do and so will be much shorter.
Andy
lew247
Posted: 07:18am 18 May 2023
Thanks everyone
I spent most of the night going through the code with the help of the datasheet and I think I've got it now
Basically it's measuring the voltage from an input and lighting a number of led's depending on the voltage
Can anyone tell me if the ADC of the pic on page 81 of the datasheet here outputs a high number with the highest voltage input and working down as the voltage goes down, or start low and work up?
The values are
HEX  DEC
0x9A 154 is this 2.5v or
0xA5 165
0xAF 175
0xBA 186
0xC5 197
0xD0 208
0xDA 218
0xE3 227 or is this 2.5v
0x00 0
Posted: 07:36am 18 May 2023
Hi Lew,
The only way a higher number from the A/D can relate to a lower voltage is when Vref- and Vref+ are swapped. That is possible with this chip, that both are connected to a external voltage source, in swapped polarity. But highly unlikely.
So the higher number is the higher voltage....if you look at all the bits.
Your numbers are 8 bit numbers, and the ADC is 10 bits. the 2 most significant bits are missing in your list unless the ADC is used in 8 bit mode).
Looking at the application: converting output signal from a logaritmic amplifier (AD8307) most likely 10 bits are used.
I am guessing this is some kind of power meter with LED signal bar. Since the AD8307 is really wide bandwidth (up to 5.8Ghz) this could come from communication equipment, WIFI scanners, satellite receivers, HAM applications, military stuff (military won't use a PIC16F818 though...no military (JAN . . versions..).
Edited 2023-05-18 17:38 by Volhout
IanRogers
Posted: 07:39am 18 May 2023
I made it more readable.
RSSI comes from the ADC  It is saved in MAIN as MAXH then send to the
TETRA4S routine to convert to display. This routine checks to see if the RSSI has reached a threshold to alarm the system.
The donkey work is done in the ISR at the top. When a user presses the button a threshold can be set. It also clears the LED's so the can be updated ( seems to be time dependent, the LEDS can be differing brightness. )
The I2C is a software implementation. BUT.. No label, so a line or two may be missing.
FYI... I cant seem to post code with indentations... Tabs don't work
Edited 2023-05-18 17:41 by IanRogers
lew247
Posted: 08:09am 18 May 2023
  Volhout said  Hi Lew,
I am guessing this is some kind of power meter with LED signal bar. Since the AD8307 is really wide bandwidth (up to 5.8Ghz) this could come from communication equipment, WIFI scanners,military stuff
Yes it is
Does this mean that it's only using 8 bit numbers?
Is there an easy way to explain how you'd get an 8 bit number from a 10 bit input in basic?
BTW am I correct in thinking the output from the AD8307 is a voltage and nothing else?
Edited 2023-05-18 18:11 by lew247
Posted: 08:11am 18 May 2023
  Quote  I cant seem to post code with indentations...
The first leading space gets cropped for some reason so use two or more leading spaces and code boxes indent ok.
 Like
this.
Posted: 10:01am 18 May 2023
  IanRogers said  FYI... I cant seem to post code with indentations... Tabs don't work
Multiple spaces are deleted in normal HTML. To preserve indentation, use the "code" button above the edit box, or put your code within the tags "[ CODE][ /CODE]" without the space after "[" which keeps the tags from being acted on in this post.
IanRogers
Posted: 10:34am 18 May 2023
I did that but it's still HTML.
I always use code tags. I use MANY forums and most see at least the first tab..
Posted: 12:33pm 18 May 2023
  IanRogers said  most see at least the first tab..
I never use tabs, only spaces, so maybe that's why I haven't seen what you saw. Tabs are treated so differently based on program or settings that I find it easier to just use spaces. CODE tags (in upper case on this forum) work for me:
 Some indentation
   Some further indentation
 Back again
Posted: 01:05pm 18 May 2023
Only the devil uses tabs to indent code.
Sure as eggs is eggs you will end up with a mix of tabs and spaces, and then someone will view the code on an editor with a different tab setting (2 vs. 4 vs. 8 characters) and the formatting will look completely screwed up to them - MMBasic firmware source I am looking at you .
I believe every modern IDE has a setting so that the TAB key outputs a configurable number of spaces instead of the actual TAB character - and I *hope* they all default to this.
IanRogers
Posted: 12:39pm 19 May 2023
@lew247
Do you still need the breakdown?
CheckThreshold (CHECKTHR)
Has the threshold in variable TEMPBAR.
This was obtained by reading the ADC and storing in MAXH, then the LEDBAR routine converts to -dbm.
It is compared to the store variable THRLVL. ( which is set in INCTHR or the DECTHR routine called from THRSET from the ISR routine )
The pip routine sounds when its  exceeded.
Threshold set (THRSET) calls the INTHR and DECTHR and sets the level as needed THRLVL.
DONETHR is how you described.. Its the endpoint of the THRSET routine.
LEDBAR sets the LED configuration the variable TEMPBAR derived from MAXH converted to -dbm
TETRA4S checks the 4 seconds have elapsed and updates the LED's if it has.
MAIN is the main of course.. the RSSI (MAXH) is set up the converted when LEDBAR is called.
CONV0 is the conversion loop. The pic is busy converting so it waits until the GO bit is clear before moving on.
The only thing I can't determine is what the I2C is talking to I dont know address 0x60 but he call's it a tuner??
Edited 2023-05-19 22:40 by IanRogers
Quazee137
Posted: 07:31am 20 May 2023
0x060 may be something in this list 0x060
 Quazee137
Posted: 11:14am 20 May 2023
  Quazee137 said  0x060 may be something in this list 0x060
Interesting link there to https://i2cdevices.org/devices
I had a good scan through--thanks.
     Page 1 of 3
