Forum Index : Microcontroller and PC projects : Q: RP2040-LCD-0.96-M and PicoMite?
Page 1 of 4 | |||||
andreas Senior Member Joined: 07/12/2020 Location: GermanyPosts: 187 |
Hello, on amazon I found this: RP2040-LCD-0.96-M Does anyone know whether it runs with PicoMite? -andreas |
Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 5771 |
On first glance I think so. The display uses GP8, GP9, GP10, GP11, GP12, GP25 so no PS2 keyboard. No guarantee for any speed over 133MHz though! Edited 2023-05-29 19:55 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
Probably this. It seems to be an SPI display, uses GP25 for the BL. Is GP25 OK to use once you do OPTION HEATBEAT OFF ? Latest F4 Latest H7 |
Should be able to, yes. There is no LED on that board so there's no other hardware to mess the pin up. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
stanleyella Guru Joined: 25/06/2022 Location: United KingdomPosts: 1655 |
Looks interesting but does it work with mmbasic indeed? and cost? |
I can't see anything that would prevent MMBasic from running on it. However: The display is ST7735S, which has MMBasic support. There is no heartbeat LED. GP25 is connected to the backlight. The only speed specified is 133MHz. It may or may not overclock. If you are willing to take the risk then go ahead. :) Pi Hut list it for 15.10 UKP Edited 2023-05-30 04:28 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
Hmmmm? £15.10 seems ok... if it works ok. Why over clock not work? pi hut... must be ok? cheers stan |
nearly ordered one, £3 postage. the display is £8.10. wow ili9341 £24+. Edited 2023-05-30 06:29 by stanleyella |
I have ordered one (berrybase 17,90€ minus 1€ discount for 100 "Berrys") - let's see how it works -andreas |
Let us know how it goes @andreas It looks nice but someone got to test with mmbasic if it isn't plug n play. not me sorry but if ok I may get one. Looks neat but in reality ??? the display 80 pixels |
160x80 isn't exactly a gaming display, Stan. :) Good for coloured text and simple animations though. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
I think I will get it end of the week and will tell you -andreas |
Hello, the RP2040-LCD-0.96-M is Picomite compatible PicoMite MMBasic Version 5.07.07 OPTION SYSTEM SPI GP10,GP11,GP12 OPTION COLOURCODE ON OPTION HEARTBEAT OFF OPTION DISPLAY 50, 100 OPTION LCDPANEL ST7735S, LANDSCAPE,GP8,GP0,GP9,GP25 (this is out of experimentation, if someone knows a better setup for system spi and lcdpanel I would be very glad to hear!) Brightness can be tuned by "BACKLIGHT N" N=[0..100]. In the picture backlight is 40%. > LIST Box 0,0,160,80,5,RGB(red),RGB(yellow) Text 10,10,Date$ Text 10,30,Time$ Text 10,50,"..it's working ;)" > memory Program: 1K ( 1%) Program (4 lines) 123K (99%) Free Saved Variables: 16K (100%) Free RAM: 0K ( 0%) 0 Variables 0K ( 0%) General 152K (100%) Free > flash list Slot 1 available Slot 2 available Slot 3 available Slot 4 available -andreas |
Great to see it working. :) You've no choice of IO pins for either system SPI or the display IO pins (including GP25) as they are all hard-wired on the module. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
homa Senior Member Joined: 05/11/2021 Location: GermanyPosts: 248 |
Hallo Andreas, das ist fein! Danke fürs teilen / thank you for sharing. Matthias |
Sehr ordentliches Gerät. Ich denke, ich werde mir eins zulegen :) Nice you got it working :) :) |
anymore info for what pins are user...i2c or any pins that can be used with mmbasic picomite non vga? please, Can the display do more than text, like plot/draw? sorry there's a box command so must. oops :( ordering one, tidy module. Edited 2023-06-06 10:37 by stanleyella |
Your original link is $53 with postage, ordered one from pi hut and a spare pico with headers, including vat+p&p £22. |
Hello Mick, yes the pins on the board are fixed, but there is one degree of freedom for the 4th parameter of the OPTION LCDPANEL: OPTION LCDPANEL ST7735S, LANDSCAPE,GP8,GP0,GP9,GP25 I took GP0 to write anything, but I'm loosing a gp port this way. Thank you by the way for the display type tip - it has shortened my experiments considerably. -andreas Edited 2023-06-06 13:59 by andreas |
Who is the first, who writes a barricade game for the tiniest basic computer of the world? -andreas (is it possible to use the two buttons already on the board? ;) no! |
Page 1 of 4 |
