Local Time 19:06 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoW Error
palcal
Posted: 10:56pm 04 Apr 2025
My PicoW is stopping with the error....
  Quote  [CYW43] do_ioctl(2, 263, 16): timeout
can someone tell me what is happening. A problem with WIFI ??
palcal
Posted: 11:39pm 04 Apr 2025
I found this POST
So it seems its related to having it connected to TeraTerm. I'll disconnect from TeraTerm and see how it goes.
Posted: 11:57pm 04 Apr 2025
I have been using WebMite + TeraTerm for a long time and so far never had this issue.
TassyJim's solution appears to have worked for OA47.
Edit.
Here is what works for me.
Dim Key$ = "******your key here*****"
Dim City$="****your location here***" ' location, country code
Dim Q$="GET /data/2.5/weather?q="+City$+"&APPID="+Key$+Chr$(10)+Chr$(13)
Dim buff%(4096/8)
Dim float tempr
WEB OPEN TCP CLIENT "api.openweathermap.org", 80
WEB TCP CLIENT REQUEST Q$, buff%()
Pause 200
WEB CLOSE TCP CLIENT
temp = Val(Json$(buff%(), "main.temp")) - 273
Print "Temperature in "+City$+" is:";temp;"C at ";DateTime$(now)
Edited 2025-04-05 10:06 by phil99
palcal
Posted: 12:57am 05 Apr 2025
Thanks Phil but I was only using TeraTerm for debugging. I just left it on to report any errors which seem to come up on the attached display anyway.
Posted: 01:45am 05 Apr 2025
What CPU speed are you running at?
High speeds seem to be a problem. With ~200 or lower I have no problems.
palcal
Posted: 05:56am 05 Apr 2025
Jim, I always use 38400.
Posted: 06:19am 05 Apr 2025
CPU speed, not serial.
OPTION CPUSPEED 133000 is the default
I use OPTION CPUSPEED 200000
ie 200MHz
palcal
Posted: 06:57am 05 Apr 2025
Oh,OK  didn't read your post properly, I am running at the default.
