Local Time 17:12 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Anyone interested in astronomy?
Posted: 07:56pm 13 Dec 2025
I've got some code to test. You would need a Pico with a GPS connected to check it (and preferably a telescope).
Let me know.
Posted: 08:35pm 13 Dec 2025
Sounds interesting. I have a Pico with GPS connected but no telescope.
Frank N. Furter
Posted: 09:20pm 13 Dec 2025
That sounds very interesting!
I should still have GPS receivers - I have a telescope...
Frank
Sasquatch
Posted: 09:25pm 13 Dec 2025
While we are on the subject of GPS,
The GPS code used for the PicoMite is outdated code for 8 bit micro-controllers (i.e. Arduino).  Most modern GPS modules will give a few additional decimal places of precision than will fit in a single precision float.
I submitted updated and tested code in this thread:
https://www.thebackshed.com/forum/ViewTopic.php?TID=15035
See the last post in the thread for the updated GPS.c (zip) file.  I tested the code against several generations of GPS receivers/module.
It seems that the ArmMiteH743 may be the only MMBasic interpreter that was ever updated?
Edited 2025-12-14 07:26 by Sasquatch
-Carl
Posted: 10:43am 14 Dec 2025
UPDATE
I've added two new commands:
LOCATION datetime$, latitude, longitude
This sets an internal memory of where and when you want to calculate for
ASTRO [BODY] altitude!, azimuth! [,J2000RA!] [,J2000Dec!] [,pm_ra!] [,pm_dec!]
This is exactly the same as the STAR command, except that it uses the location data defined by LOCATION
This allows you to use the functions without a GPS
'plot the altitude against the azimuth for the moon for the next two days
a%=Epoch(now)
b%=a%+(86400*2)
Location DateTime$(a%),52.02174,0.28766
Astro moon alt!,az!
'Print alt!,az!
Inc a%,720
Circle az!,(alt!+100)*2,3
Loop Until a%=b%
Here is what I am playing with
STAR [BODY] altitude!, azimuth! [,J2000RA!] [,J2000Dec!] [,pm_ra!] [,pm_dec!]
This function calculates the altitude and azimuth of any celestial object from a given location and at a given time.
It uses the GPS to get the users latitude and longitude and time (UTC). Using this it calculate the sidereal time and the Julian centuries which are then used as input to the main calculations.
The simple form of the command is
star BODY altitude!, azimuth!
This updates altitude!, azimuth with the current location of the body from the observer
It supports the following bodies in the solar system + 85 named stars and galaxies
MOON, MERCURY, VENUS, MARS, JUPITER, SATURN, URANUS, NEPTUNE
The more complex form of the command is:
STAR altitude!, azimuth! ,J2000RA! ,J2000Dec! [,pm_ra!] [,pm_dec!]
This allows calculation for any celestial body based on its Right Ascension and Declination. In order to get better accuracy you can also input the bodies Proper Motion and Precession in arcsecond/year to allow the code to update from the J2000 values.
The objective is to make it trivial to point your telescope accurately to any body in the sky at any time from any given place on earth given a pico and connected GPS
It is currently all working and the output has been tested against authoritative sources. At the moment it is totally linked into the GPS but I will extend the functionality to allow user input of lat/long/time to allow more general use
Below is the analysis of the code and what it does and doesn't do and its limitations.
  Quote  Celestial Navigation Code Analysis
This C code implements a celestial navigation system that calculates the altitude and azimuth of celestial objects (stars, Moon, and planets) from an observer's location on Earth. Here's a comprehensive analysis:
Overview
The system converts celestial coordinates (Right Ascension and Declination) to local horizontal coordinates (altitude and azimuth) that an observer can use to locate objects in the sky. It requires GPS data for observer location and timing.
Key Components
1. Star Catalog
Contains 85 entries including bright stars and deep-sky objects (galaxies, nebulae)
Stored with J2000.0 epoch coordinates:
Right Ascension (degrees)
Declination (degrees)
Proper motion in RA and Dec (arcseconds/year)
2. Coordinate Conversion (localRA function)
Converts equatorial coordinates (RA/Dec) to horizontal coordinates (Alt/Az).
Formula Chain:
Calculate Hour Angle: HA = LST - RA
Apply spherical trigonometry for altitude: sin(alt) = sin(lat)·sin(dec) + cos(lat)·cos(dec)·cos(HA)
Calculate azimuth using atan2 for proper quadrant handling
Convention: North = 0°, East = 90°, South = 180°, West = 270°
Corrections Applied:
Atmospheric Refraction Correction (Meeus Chapter 16)
Applied for objects above -1° altitude
Formula: R = 1.02 / tan(h + 10.3/(h + 5.11)) arcminutes
Pressure/temperature factor: 0.986 (standard atmosphere: 1013.25 hPa, 15°C)
Increases apparent altitude due to atmospheric bending of light
Most significant near horizon (can be ~34 arcminutes at horizon)
3. Planetary Positions (getCelestialPosition function)
Calculates apparent positions for Moon and planets using analytical series.
For Planets (Mercury through Neptune):
Method: Simplified VSOP87-based orbital elements with Kepler's equation
Steps:
Calculate orbital elements (varies with time T):
Mean longitude (L)
Semi-major axis (a)
Eccentricity (e)
Inclination (i)
Longitude of ascending node (Ω)
Longitude of perihelion (ω)
Solve Kepler's equation iteratively (5 iterations):
E = M + e·sin(E) where M = mean anomaly
Calculate heliocentric rectangular coordinates
Calculate Earth's heliocentric position similarly
Convert to geocentric coordinates: (xg, yg, zg) = (xh, yh, zh) - (xe, ye, ze)
Transform from ecliptic to equatorial coordinates using obliquity of ecliptic
Topocentric Parallax Correction
Accounts for observer's position on Earth's surface
Uses horizontal parallax: π = arcsin(Earth_radius / distance_AU)
Corrections: δRA = -(π·cos(φ)·sin(H)) / cos(dec)
Most significant for nearby objects (negligible for distant planets)
Accuracy: 2-5 arcminutes for planets
For the Moon:
Method: Meeus analytical series with major periodic terms
Steps:
Calculate fundamental arguments:
Mean longitude (L')
Mean elongation (D)
Sun's mean anomaly (M)
Moon's mean anomaly (M')
Argument of latitude (F)
Apply periodic terms (largest contributions):
Longitude: 6 major terms (largest: 6.29° for M')
Latitude: 4 major terms (largest: 5.13° for F)
Distance: 4 major terms (largest: -20,905 km for M')
Apply nutation correction (Earth's axis wobble)
Convert ecliptic to equatorial coordinates
Nutation (short-period axis wobble)
Longitude correction: up to ~17 arcseconds
Obliquity correction: up to ~9 arcseconds
Much more significant than for planets (Moon is close)
Can shift position by up to ~1° (3600 arcseconds)
Uses Moon's horizontal parallax (~57 arcminutes at mean distance)
Corrections account for:
Observer's latitude (ρ sin φ', ρ cos φ')
Hour angle (H)
Distance from Earth's center
Accuracy: 1-2 arcminutes
4. Proper Motion and Precession (applyProperMotionAndPrecession function)
Corrects star positions from J2000.0 epoch to current date.
Proper Motion
Stars move relative to solar system
Linear correction: position += proper_motion × years_since_J2000
Typical values: 0.001 to 10 arcsec/year
Most significant for nearby stars (e.g., Arcturus: -1.09 arcsec/yr in RA)
Precession (Meeus Chapter 21)
Earth's rotation axis precesses with ~26,000 year period
Uses three precession angles (ζ, z, θ) calculated as cubic polynomials in T
Applies rotation matrix to transform coordinates
Approximately 50.3 arcseconds per year
Most significant correction for long time periods
Limitations and Considerations
1. Truncated Series
Planetary calculations use simplified orbital elements
Moon calculation includes only major periodic terms (not the hundreds in full theory)
Missing terms limit accuracy to arcminute level
2. Missing Corrections
Aberration (apparent displacement due to Earth's velocity): ~20 arcseconds
Light-time (position correction for light travel time): varies by distance
Gravitational deflection near Sun: up to 1.75 arcseconds at Sun's limb
Annual parallax for nearby stars: up to 0.77 arcseconds for Proxima Centauri
3. Atmospheric Refraction
Uses standard atmosphere model (fixed pressure/temperature)
Actual conditions vary significantly
Model breaks down below -1° altitude
Error can be several arcminutes in non-standard conditions
4. Time System Simplifications
Uses GPS time without explicit UT1/TT conversions
ΔT (difference between Terrestrial Time and Universal Time) not applied
Acceptable for most navigation purposes but affects precision calculations
5. Geodetic vs. Geocentric
Uses simplified spherical Earth model for topocentric corrections
Earth is actually an oblate spheroid
Error up to ~11 arcminutes in extreme cases
6. Catalog Assumptions
Proper motions assumed constant (actually vary slightly)
Radial velocity effects ignored
Binary star orbital motion not modeled
7. Numerical Precision
MMFLOAT type precision not specified in code
If single precision (float), accumulated rounding errors possible
Double precision recommended for astronomical calculations
8. Iterative Solutions
Kepler's equation solved with only 5 iterations
Usually sufficient but may not converge for extreme eccentricities
Expected Accuracy Summary
Object TypeTypical AccuracyLimiting FactorsBright Stars10-30 arcsecProper motion, precession, refractionNearby Stars1-2 arcminParallax not modeled, proper motionMoon1-2 arcminTruncated series, refractionPlanets2-5 arcminSimplified orbits, missing perturbationsDeep-sky Objects1-2 arcminPrecession, refraction
Use Cases
This code is well-suited for:
Amateur astronomy pointing systems
Educational demonstrations
General sky observation planning
Telescope "goto" systems with arcminute accuracy requirements
Not suitable for:
Precise astrometry requiring arcsecond accuracy
Spacecraft navigation
Occultation predictions requiring sub-arcminute precision
Scientific research requiring full correction modeling
Code Quality Notes
Strengths:
Well-commented with clear mathematical references
Proper use of atan2 for quadrant handling
Includes user-friendly star catalog with binary search
Handles multiple input methods (star names, coordinates, celestial bodies)
Potential Improvements:
Add bounds checking for extreme latitudes
Implement ΔT corrections for historical/future dates
Add error propagation estimates
Consider adaptive atmospheric refraction based on temperature/pressure inputs
Add stellar parallax for nearby stars
Edited 2025-12-15 00:46 by matherp
Posted: 07:51pm 14 Dec 2025
~40 years ago I made an eight inch reflector telescope but never got around to motorising the mount. The main mirror needs attention but this might be a good reason to dust it off.
Posted: 10:09pm 14 Dec 2025
My project is building a 6" reflector from scratch (other than grinding the mirror).
The progress so far is making the tube as a nonagon out of 1cm thick mahogany sawn from my old conservatory roof beams. The mirrors are arriving from China in the next few days: parabolic and supposedly pv1/6-1/8 - we will see. The mount will be fully computerized hence the new code and I'm learning onshape for the mount design. Should keep me busy for a few months now 6.01 is pretty much out of the way.
okwatts
Posted: 10:15pm 14 Dec 2025
Always interested in this kind of thing. One project I should get going to build my MMBasic skills is to translate the code from Caxton Foster's book "Orrery" written for PC basic so I can run them on the Pico or CMM2. Shouldn't be difficult, just need to set aside the time. (Famous last words!)
jwettroth
Posted: 10:54pm 14 Dec 2025
I'm sorry to be so dense.  I'm interested in this topic.  How can I get access to the code?  I wrote a pretty nice sunup and sundown app in MMBasic for some gadgets that play bird sounds based on sun up or sun down- it was for biologists- pretty precise and could run for months.  Lat and Long was a manual input, having a GPS input would be slick.  I still have interest in this and other biologists have mentioned doing monitoring bases on full moons, etc.
John Wettroth
zeitfest
Posted: 11:47pm 14 Dec 2025
Pluto is going to be miffed.. left out in the cold..
tgerbic
Posted: 12:03am 15 Dec 2025
I have been using Stellarium on a laptop connected to a commercial servo tripod to position and track stars. I can use my Cannon camera with a short or long lens to take pictures, or watch on the laptop screen, or a smaller telescope to look through.
While that is nice, I have a rarely used 6" Dobsonian reflector that just has a position readout. Once aligned, I can move it to a target manually and the readout gives me the position. It does work but there are two problems.  I would prefer to automate the reflector to move based on a program and I would like to mount a telescope camera on it. I have hardly used the reflector because of the effort to point it and having to bend over a lot, at my age, to see things. Of course, the weight and bulkiness make it hard to transport and setup but it can be done.
What I need is an incentive to do something about the shortcomings of using the reflector. A little control panel that allows me to find or enter coordinates, and the reflector points itself would be great. Having a tracker would be nice as well or at least the ability to watch a small view of the sky while fine tuning the position would be good.
damos
Posted: 12:21am 15 Dec 2025
I have an 8" reflector (GSO) and a Skywatcher EQ5 equatorial mount. I have added stepper motors to drive it and written a Picomite program to control the tracking. I have added a database of all the objects brighter than magnitude 9. I have not been able to test it because it has been always cloudy whenever the time is suitable. Maybe over xmas.
I have written code that does similar things to what you have done but have not included the planets - that is next level.
I am thinking of redoing it and your function would be very helpful. The alt-azimuth system suits simpler mounts and works against my mount as I need to covert everything to equatorial coordinates. I am not using a GPS as I know my location (setting in my program) and I am using an accurate RTC to get accurate time. Maybe you could allow these to be optional parameters. This is handy because sometimes you want to calculate for other locations.
Rather than using the Picomite touchscreen, it is better to let it just to the tracking and accept commands using the Skyscan protocol (or others) over Bluetooth. You can then use Stellarium on a mobile phone or tablet to control it. This is far better than what I have done and is a superb program with lots of data and images built in.
damos
Posted: 12:33am 15 Dec 2025
Other things to think about:
In the southern hemisphere we don't have the luxury of Polaris and the best we have is very faint. The advanced mounts allow you to take sighting of multiple stars and then use that data to offset the calculations and the tracking. As long as you point the telescope roughly in the right direction they work fine.
Another option is tracking stars. With a tracking mount, wait 10 minutes and see how far the star has drifted off and use that as a correction.
With equatorial mounts you can move across half the sky and then you need to do a flip to see the other half. So you tend to want to see what is nearby before doing that. For beginners like me you really want to see cool stuff but you need to know what you are looking for, how big it is and what to expect. Even with a large telescope the really cool stuff is faint. You are lucky enough to have Andromeda easily accessible. So you really need cooled cameras with lots of multiple exposures and heaps of compute to see them.
If find the Australian forum very informative:
Ice In Space
Posted: 08:34am 15 Dec 2025
It is very easy to convert altitude/azimuth to equatorial coordinates. I'll find a way to integrate this into the code.
The code will be in 6.01.00 for the rp2350 but I won't include in the manual but will write a separate note on how to use it.
The code already supports calculations based on any arbitrary location and time using the LOCATION and ASTRO commands as in the snippet of MMBasic code in my previous post.
jwettroth: Basic GPS support is already in MMBasic. Have a look at the OPEN command and GPS function.
damos: Does your database include the motion parameters for the stars? If so, could you let me have it and I can integrate any I'm missing - my data is below.
const Star starCatalog[] = {
   {"Achernar", 24.428000, -57.236750, 0.09774, -0.04008},        // HIP 7588"
   {"Acrux", 186.650000, -63.099000, -0.03500, -0.01400},         // HIP 60718"
   {"Alcyone", 56.871250, +24.106111, 0.01900, -0.04500},         // HIP 17702"
   {"Aldebaran", 68.980162, +16.509301, 0.06278, -0.18894},       // HIP 21421"
   {"Algenib", 0.139167, +15.183333, 0.00200, -0.00300},          // HIP 1067"
   {"Algieba", 154.993333, +23.750000, -0.24800, -0.05000},       // HIP 50583"
   {"Algol", 47.042083, +40.955556, 0.00200, -0.00300},           // HIP 14576"
   {"Alhajoth", 14.177500, +60.716667, 0.00200, -0.00300},        // HIP 12390"
   {"Alhena", 116.313333, +14.195000, -0.07100, -0.02000},        // HIP 31681"
   {"Almaak", 2.065000, +42.329000, 0.00400, -0.00200},           // HIP 9640"
   {"Alnair", 332.058333, -46.960000, 0.01000, -0.01200},         // HIP 109268"
   {"Alnilam", 84.053389, -1.201917, -0.00100, -0.00200},         // HIP 26311"
   {"Alnitak", 85.189000, -1.942000, -0.00300, -0.00200},         // HIP 26727"
   {"Alphard", 141.896389, -24.374167, -0.02400, 0.00600},        // HIP 46390"
   {"Alpheratz", 2.096389, +29.090556, -0.13600, -0.05000},       // HIP 677"
   {"Alpherg", 23.079167, +15.205000, 0.02500, -0.01000},         // HIP 11767"
   {"Alrescha", 30.511667, +2.763333, 0.13500, -0.05000},         // HIP 8833"
   {"Alsephina", 114.828333, -30.360000, -0.01800, -0.01000},     // HIP 31592"
   {"Alshain", 296.565000, +6.425000, 0.53600, 0.38500},          // HIP 94779"
   {"Altair", 297.695827, +8.868322, 0.53682, 0.38554},           // HIP 97649"
   {"Aludra", 97.962083, -29.247500, -0.00400, -0.00200},         // HIP 30324"
   {"Andromeda Galaxy (M31)", 10.684708, 41.269167, 0.0, 0.0},    //"
   {"Antares", 247.351915, -26.432002, -0.01016, -0.02321},       // HIP 80763"
   {"Arcturus", 213.915300, +19.182410, -1.09345, -2.00094},      // HIP 69673"
   {"Aspidiske", 122.383333, -47.336667, -0.01200, -0.00600},     // HIP 39953"
   {"Bellatrix", 81.282000, +6.350000, -0.00800, -0.01300},       // HIP 25336"
   {"Betelgeuse", 88.792939, +7.407064, 0.02495, 0.00956},        // HIP 27989"
   {"Bode's Galaxy (M81)", 148.888750, 69.064444, 0.0, 0.0},      //"
   {"Canopus", 95.987875, -52.695718, 0.01993, 0.02324},          // HIP 30438"
   {"Capella", 79.172327, +45.997991, 0.07552, -0.42713},         // HIP 24608"
   {"Caph", 2.294167, +59.149444, 0.00300, -0.00200},             // HIP 746"
   {"Castor", 113.650000, +31.888333, -0.19100, -0.04500},        // HIP 36850"
   {"Cigar Galaxy (M82)", 149.062500, 69.679722, 0.0, 0.0},       //"
   {"Deneb", 310.357979, +45.280338, 0.00146, 0.00129},           // HIP 102098"
   {"Denebola", 177.264167, +14.572056, -0.49700, -0.11400},      // HIP 57632"
   {"Dubhe", 165.460000, +61.751000, -0.13500, -0.03500},         // HIP 54061"
   {"Elnath", 81.572917, +28.607500, -0.00400, -0.00900},         // HIP 25428"
   {"Eltanin", 269.151667, +51.488889, -0.00900, -0.02200},       // HIP 87833"
   {"Enif", 333.375000, +9.875000, 0.00400, -0.00300},            // HIP 107315"
   {"Fomalhaut", 344.412750, -29.622236, 0.32995, -0.16467},      // HIP 113368"
   {"Gacrux", 187.791667, -56.363056, -0.04000, -0.01400},        // HIP 61084"
   {"Hadar", 210.955000, -60.373000, -0.03300, -0.01400},         // HIP 68702"
   {"Homam", 326.046667, +9.875000, 0.00300, -0.00200},           // HIP 106481"
   {"Kaus Australis", 283.816667, -34.374167, 0.01300, -0.02500}, // HIP 90185"
   {"Kochab", 222.676667, +74.155000, -0.01700, -0.01100},        // HIP 85670"
   {"Kornephoros", 245.997500, +21.489444, -0.00900, -0.00600},   // HIP 80816"
   {"Large Magellanic Cloud", 80.891667, -69.756111, 0.0, 0.0},   //"
   {"Lesath", 263.733333, -37.103333, -0.00200, -0.00100},        // HIP 85927"
   {"Markab", 346.190000, +15.205000, 0.02500, -0.01000},         // HIP 113963"
   {"Menkalinan", 90.983333, +44.947500, -0.00400, -0.00900},     // HIP 28360"
   {"Mimosa", 191.930000, -59.688000, -0.03695, -0.01342},        // HIP 62434"
   {"Mintaka", 83.001667, -0.299167, -0.00200, -0.00300},         // HIP 25930"
   {"Mirfak", 51.080833, +49.861111, 0.02500, -0.02700},          // HIP 15863"
   {"Nunki", 283.816667, -26.296111, 0.01300, -0.02500},          // HIP 92855"
   {"Peacock", 311.918333, -60.282222, 0.01300, -0.01000},        // HIP 100751"
   {"Polaris", 37.954560, +89.264109, 0.19893, -0.01560},         // HIP 11767"
   {"Pollux", 116.329000, +28.026200, -0.62655, -0.04595},        // HIP 37826"
   {"Procyon", 114.825493, +5.224993, -0.71459, -1.03677},        // HIP 37279"
   {"Rasalgethi", 259.056667, +14.390000, -0.00900, -0.00600},    // HIP 84345"
   {"Rasalhague", 263.733333, +12.560000, -0.13700, -0.23400},    // HIP 84893"
   {"Regulus", 152.093333, +11.967222, -0.24993, 0.05027},        // HIP 49669"
   {"Rigel", 78.634467, -8.201639, 0.00187, 0.00056},             // HIP 24436"
   {"Rigil Kent", 219.902058, -60.835153, -3.67925, 0.48184},     // HIP 71683"
   {"Ruchbah", 10.126667, +60.235000, 0.00200, -0.00300},         // HIP 4427"
   {"Sabik", 250.321667, -15.757222, -0.00800, -0.00400},         // HIP 81266"
   {"Sadalmelik", 322.493333, -0.010000, 0.00200, -0.00300},      // HIP 109074"
   {"Sadalsuud", 330.790000, -0.319000, 0.00300, -0.00200},       // HIP 110960"
   {"Sadr", 305.557083, +40.256667, -0.00200, -0.00300},          // HIP 100453"
   {"Saiph", 86.939167, -9.669722, 0.00400, -0.00200},            // HIP 26207"
   {"Scheat", 345.940000, +28.080000, 0.02500, -0.01000},         // HIP 113881"
   {"Shaula", 263.402083, -37.104167, -0.00200, -0.00100},        // HIP 85927"
   {"Shedir", 10.127500, +56.537222, 0.00200, -0.00300},          // HIP 3179"
   {"Sirius", 101.287155, -16.716116, -0.54601, -1.22307},        // HIP 32349"
   {"Small Magellanic Cloud", 13.158333, -72.800278, 0.0, 0.0},   //"
   {"Sombrero Galaxy (M104)", 189.997917, -11.622778, 0.0, 0.0},  //"
   {"Spica", 201.298247, -11.161322, -0.04235, -0.03173},         // HIP 65474"
   {"Suhail", 131.175000, -42.654167, -0.01000, -0.00500},        // HIP 42312"
   {"Tarazed", 297.042000, +10.613000, 0.53600, 0.38500},         // HIP 94779"
   {"Triangulum Galaxy (M33)", 23.462083, 30.659722, 0.0, 0.0},   //"
   {"Vega", 279.234734, +38.783688, 0.20094, 0.28623},            // HIP 91262"
   {"Whirlpool Galaxy (M51)", 202.479167, 47.195278, 0.0, 0.0},   //"
   {"Zubenelgenubi", 229.251667, -16.202500, -0.01000, -0.00500}, // HIP 72622"
   {"Zubeneschamali", 233.671667, -9.382500, -0.01200, -0.00600}, // HIP 73473"
// Convert Alt/Az to RA/Dec
// Inputs: Alt, Az, latitude, LST (all in radians)
// Outputs: RA, Dec (RA in radians, Dec in radians)
void altaz_to_equatorial(double Alt, double Az, double lat, double LST,
                        double *RA, double *Dec) {
   // Declination
   *Dec = asin( sin(Alt) * sin(lat) +
                cos(Alt) * cos(lat) * cos(Az) );
   // Hour angle components
   double sinH = -cos(Alt) * sin(Az) / cos(*Dec);
   double cosH = (sin(Alt) - sin(lat) * sin(*Dec)) /
                 (cos(lat) * cos(*Dec));
   double H = atan2(sinH, cosH);  // Hour angle, radians
   // Right Ascension
   *RA = LST - H;
   // Normalize RA to [0, 2π)
   while (*RA < 0) *RA += 2.0 * M_PI;
   while (*RA >= 2.0 * M_PI) *RA -= 2.0 * M_PI;
Edited 2025-12-15 18:39 by matherp
jwettroth
Posted: 01:57pm 15 Dec 2025
Below is the Algorithm that I use to calculate sunset and sunrise in various gadgets for biologists.  I coded this is mmbasic and it works quite well.  I can send my mmbasic code if desired- just a straight crib.  This reference is more explanatory for those interested.  I found it to be very accurate for use anywhere in the continental US, never tested in southern hemisphere, etc.  Only problem is that its full of magic numbers- lots of constants that I never quite understood.  I like that I can choose the zenith for civil nautical astronomical, etc.  Might be useful.  I have some interest in doing similar for moon phases.
Thanks for all your work Peter.
I hope that these functions might eventually migrate into the DOS/PC version as well.
john
Source:
Almanac for Computers, 1990
published by Nautical Almanac Office
United States Naval Observatory
Washington, DC 20392
Inputs:
day, month, year:      date of sunrise/sunset
latitude, longitude:   location for sunrise/sunset
zenith:                Sun's zenith for sunrise/sunset
 offical      = 90 degrees 50'
 civil        = 96 degrees
 nautical     = 102 degrees
 astronomical = 108 degrees
NOTE: longitude is positive for East and negative for West
       NOTE: the algorithm assumes the use of a calculator with the
       trig functions in "degree" (rather than "radian") mode. Most
       programming languages assume radian arguments, requiring back
       and forth convertions. The factor is 180/pi. So, for instance,
       the equation RA = atan(0.91764 * tan(L)) would be coded as RA
       = (180/pi)*atan(0.91764 * tan((pi/180)*L)) to give a degree
       answer with a degree input for L.
1. first calculate the day of the year
N1 = floor(275 * month / 9)
N2 = floor((month + 9) / 12)
N3 = (1 + floor((year - 4 * floor(year / 4) + 2) / 3))
N = N1 - (N2 * N3) + day - 30
2. convert the longitude to hour value and calculate an approximate time
lngHour = longitude / 15
if rising time is desired:
 t = N + ((6 - lngHour) / 24)
if setting time is desired:
 t = N + ((18 - lngHour) / 24)
3. calculate the Sun's mean anomaly
M = (0.9856 * t) - 3.289
4. calculate the Sun's true longitude
L = M + (1.916 * sin(M)) + (0.020 * sin(2 * M)) + 282.634
NOTE: L potentially needs to be adjusted into the range [0,360) by adding/subtracting 360
5a. calculate the Sun's right ascension
NOTE: RA potentially needs to be adjusted into the range [0,360) by adding/subtracting 360
5b. right ascension value needs to be in the same quadrant as L
Lquadrant  = (floor( L/90)) * 90
RAquadrant = (floor(RA/90)) * 90
RA = RA + (Lquadrant - RAquadrant)
5c. right ascension value needs to be converted into hours
RA = RA / 15
6. calculate the Sun's declination
sinDec = 0.39782 * sin(L)
cosDec = cos(asin(sinDec))
7a. calculate the Sun's local hour angle
cosH = (cos(zenith) - (sinDec * sin(latitude))) / (cosDec * cos(latitude))
if (cosH >  1)
 the sun never rises on this location (on the specified date)
if (cosH < -1)
 the sun never sets on this location (on the specified date)
7b. finish calculating H and convert into hours
if if rising time is desired:
 H = 360 - acos(cosH)
 H = acos(cosH)
H = H / 15
8. calculate local mean time of rising/setting
T = H + RA - (0.06571 * t) - 6.622
9. adjust back to UTC
UT = T - lngHour
NOTE: UT potentially needs to be adjusted into the range [0,24) by adding/subtracting 24
10. convert UT value to local time zone of latitude/longitude
localT = UT + localOffset
John Wettroth
zeitfest
Posted: 12:04am 17 Dec 2025
Didn't CDEagle  create these programs in MMBasic ?
That would be a good test - are the results different ?
MaryB_MN
Posted: 12:29pm 17 Dec 2025
This has a use for ham radio too, I do moon bounce(EME Earth Moon Earth), I bounce signals off the Moon's surface to make long distance contacts on VHF/UHF/Microwave frequencies! Means az/el control of antennas!
If you also add satellite tracking that is another ham radio use... there are a bunch of ham radio sats in orbit!
My 144mhz antennas(Four 20 foot long yagis) tracking the moon and echo testing
damos
Posted: 10:55pm 17 Dec 2025
  Quote  damos: Does your database include the motion parameters for the stars? If so, could you let me have it and I can integrate any I'm missing - my data is below./QUOTE]
Because of space limitations I cut the database right down to what I need, so stuff in southern skies of magnitude 9 or brighter and just names, constellations and locations. This gets read into BASIC arrays and I can lookup constellations and NGC objects.
There are some huge databases on the Internet but I have found the quality is not brilliant and you need to do a lot of editing to make it usable. For example they use a mix of western and greek letters and upper and lower case on the star identifications. 99% of the stuff is too dim to see with an amateur telescope and certainly not without a dark site. Australia is one of the few places with genuinely dark regions but they tend to be 5 hours drive from capital cities.
Then you have the issue of Starlink and other constellations which are basically ruining astronomy. I see lots of images covered with trails.
With my project the key goal was tracking. Without a tracking telescope photographs won't work, and even using the telescope with higher magnification is really annoying as you only have seconds to see the image. The equatorial mount makes it easy as once it is setup, you only need to do tiny movements on the drive to keep it tracking. If you are planning on an alt-az mount, you need to adjust both drives at least once per second, so you may want to factor this in.
As you are only doing a 6" mirror, you probably won't do magnifications above 100, which is enough to see Saturn quite clearly, but it will be small - if you take a photo using a DSLR, it will occupy a few percent of the image.
cdeagle
Posted: 11:32pm 17 Dec 2025
For verifying astronomy test cases I recommend the MICA (multi-year interactive computer almanac) software.
I have ported many of my astronomy programs to MATLAB. They are available in the File Exchange area of the Mathworks web site.
https://www.mathworks.com/matlabcentral/fileexchange/my-file-exchange
QuickBasic software from Celestial Computing is located at
https://celestialandorbitalmechanicswebsite.yolasite.com/
Posted: 12:05am 18 Dec 2025
  Quote  ... few places with genuinely dark regions ...
The most stunning night sky I have seen is in Sturt's Stony Desert during summer.
The prevailing south westerly wind stops in summer and in the upper atmosphere the jet-stream moves far to the south.
The air is still from the ground to the stratosphere, all dust and haze settles out.
A few minutes after sunset the sky is black. The Milky Way blazes brightly and is densely covered in stars.
However it is a long two day drive from Adelaide, or perhaps three from Brisbane via Birdsville.
