Forum Index : Microcontroller and PC projects : Cmm2 G2 Panel Cutouts
| NickMikhay Newbie Joined: 05/02/2026 Location: United StatesPosts: 8 |
Hello Friends, I have finally decided to build my self a Maximite 2, and downloaded the G2 construction pack, as it is the most current. I was pleased to find that it doesn’t require a seperate programmer, and it seems to have come a long way from the first Maximite. However, I didn’t find the panel cutouts, and thought to check here what people might say, maybe it’s just me. All of the other versions had the panel cutouts, so I thought this was ODD. Thanks to Geoff for sharing all of your great projects, and JLCPCB making things affordable. Nick Mikhay |
There are some STL and gerbers here F4 H7FotSF4xGT |
Thanks, but that does not appear to be the version I have. I think your link is a newer iteration, as the one I had made has full size USB (type B) for power, and dual type A in the rear for KB and Mouse. It has audio jack in the front as well as power switch, and uses a smaller battery for the clock. I suppose I can figure it out though, there are some similar panels in the construction pack, that can be used for reference. |
By the way, Why did someone make a another version? Was there something wrong with the original G2 made for production? |
Hi Nick, The CMM2 G2 was designed pre-COVID. There was a chip shortage so CMM2 could not be sold for 3 years. After the chips became available again, the design was updates by Peter to make is manufacturable by JLC. So the product would be cheaper. Volhout PicomiteVGA PETSCII ROBOTS |
