Forum Index : Microcontroller and PC projects : PicoMite 6.03.00 betas
| Page 1 of 6 |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12252 |
As recommended I'm updating the release to a full point recognising the amount of changes. V6.03.00B0 PicoMiteRP2040V6.03.00B0.zip PicoMiteRP2350V6.03.00B0.zip Compared to version 6.02.02B8 the changes are as follows: Various bug fixes and tweaks to the editor and filemanager in response to comments on this thread Performance optimisation tools are now enabled on the PICO, PICORP2350, VGA, VGARP2350, HDMI and HDMIUSB builds NB: Performance profiling is available on all builds option-profiling-cache.pdf USB versions have a new tweak. Plug in and remove a device like a keyboard with audio enabled and speakers connected. |
| PhenixRising Guru Joined: 07/11/2023 Location: United KingdomPosts: 2165 |
Hmm, bit of a performance hit for me. Just a bunch of: cntr=cntr+1 In a do loop to see what was happening in the main code while running four PIDs. Old firmware: ~162,000 New firmware: ~158,000 With new performance feature: ~126,000 This is the count value over a period of two seconds. |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9383 |
Is it quicker than INC cntr [,increment] ? Mick Zilog Inside! nascom.info for Nascom & Gemini |
| javavi Guru Joined: 01/10/2023 Location: UkrainePosts: 642 |
@matherp Testing the new PicoMiteRP2350VGAUSBV6.03.00B0 I again tested the ability to load firmware into a Pico connected via USB in boot mode. When connected in boot mode, Pico is read as drive C: I tried copying the Clear_Flash_RP2350.uf2 firmware there and it loaded and worked, clearing the connected Pico2. Next, I tried to download other firmware using FM in the same way, and firmware up to 1 MB downloaded normally, but those that were larger did not download, which is strange. |
That is within the normal range for the effect of a different compilation on the cpu cache hit ratio. Have you run with CACHE DEBUG ON and PROFILING ON? If it is a large program you need to tune which subroutines are included and make sure the number of cache slots specified aren't all used. This functionality isn't so easy to use. Simple programs like the bubble universe can see huge gains. I'm testing on the solar eclipse calculation. Normal run time 13.5 seconds, set cache on with no tuning 17.8 seconds and default no. of cache slots. Identify and cache key subroutines 10.9 seconds |
Hi Mick. I always use Inc but in this case, I have four PID loops running @2ms with related code running in the interrupt callbacks. I am only using the inefficient increment to deliberately load up what is happening outside of the interrupt. Pretty darned impressive. The Picomite is competitive with the TRIO MC308 and they don't have an onboard editor nor video ![]() Footnote added 2026-04-23 02:36 by PhenixRising MC308 should have read MC403 |
One of those things where I quickly checked TBS before I drove off. I ran back inside for a quick test. Will be back there in an hour or so |
| Bleep Guru Joined: 09/01/2022 Location: United KingdomPosts: 886 |
Hi Peter, I think I've found a bug. If I use 'Option Tracecache on 16 Dim Integer maxst=1000:c=42 c=c*(c<=maxst) 'If c>maxst Then c=0 Print c End c is printed as 42, if I remove the comment for Option Trace Cache, c is printed as -42? If I set c to 1001, then in both cases c is printed as 0, which is fine. Kevin. |
Good catch, Conditionals in LET statements aren't currently implemented so either, it should be, or the line should fail compilation and run normally. Will fix one way or the other in the next beta |
For javavi ME: CLAUDE: Root cause: FatFS FAT-window vs. RP2040 bootrom's non-persistent FAT How the RP2040 bootrom handles writes The RP2040 in BOOTSEL mode presents a virtual FAT16 disk. When it receives USB MSC sector writes: If the sector contains a valid UF2 magic (0x0A324655 / 0x9E5D5157): the payload is extracted and programmed to flash. Any other sector write (including FAT, directory, BPB): silently discarded — the bootrom has no backing store for them. The bootrom always returns the original, read-only FAT when those sectors are read back. FatFS uses a single-sector FAT window In ff.c, move_window() keeps exactly one 512-byte sector of the FAT in fs->win[]: static FRESULT move_window(FATFS* fs, LBA_t sect) { if (sect != fs->winsect) { res = sync_window(fs); // flush current window → WRITTEN TO DISK disk_read(fs->pdrv, fs->win, sect, 1); // load new sector ← READ FROM DISK fs->winsect = sect; } } Each FAT sector holds 256 FAT16 entries (512 bytes ÷ 2 bytes/entry). The 1 MB boundary The RP2040 bootrom's 128 MB virtual disk uses 4 KB clusters (8 sectors/cluster — the only cluster size that fits ≤65524 clusters into a 128 MB FAT16 volume). One FAT sector therefore covers: 256 clusters × 4096 bytes/cluster = 1,048,576 bytes = 1 MB exactly For files ≤ 1 MB (≤ 256 clusters): all cluster-chain entries live in FAT sector 1. FatFS keeps it in win[] throughout the write and never needs to swap the window. The FAT flush happens only at f_close(), by which time every UF2 block has already been written to the data area and processed by the bootrom. Result: success. For files > 1 MB (> 256 clusters): FatFS needs FAT sector 2 for clusters 256+. move_window() flushes FAT sector 1 to disk (bootrom discards it) and reads FAT sector 2. Later, when it needs to write the cluster 255→256 chain link (which straddles the sector boundary), it swaps back to FAT sector 1 — and reads the original all-free data. FatFS now believes clusters 2-255 are free and tries to re-allocate them, overwriting data sectors or corrupting the chain. Result: failure. Secondary confirmation You can verify the cluster size yourself. Sector 0 of the C: drive is the BPB. Byte offset 13 (0x0D) is BPB_SecPerClus. If it reads 8, cluster size = 4096 bytes and the analysis above is exact. Fix The FatFS layer is the wrong tool for writing to an RP2040 boot drive: the bootrom ignores FAT structure entirely. The correct approach is to bypass FatFS for this transfer: Read the UF2 source file from SD card normally with f_read. Write each 512-byte UF2 block directly to the USB drive using disk_write(pdrv=1, buff, start_lba + block_idx, 1), starting at an LBA inside the data area (well past the FAT sectors — any LBA ≥ ~300 is safe for the 128 MB layout). The bootrom processes each write as it arrives, regardless of which LBA it lands on. This completely sidesteps the FAT chain management and would remove the 1 MB limit. It would need a dedicated MMBasic command (e.g., FLASH PICO C: B:/firmware.uf2) rather than reusing COPY, since COPY always goes through FatFS on the destination. ME: CLAUDE: The page cache difference When a PC OS writes a file to any FAT volume, it maintains the entire FAT in its page cache (Windows calls this the system cache / FastFAT cache; Linux uses the kernel buffer cache). The flow is: OS reads the BPB, FAT sectors, and root directory — all go into the page cache. OS allocates clusters — updates are made in the page-cached copy of the FAT, never flushed to disk yet. OS writes data sectors to disk — the bootrom receives each sector, sees UF2 magic, programs flash. OS marks the FAT pages dirty — eventually flushed to disk, but that's just metadata cleanup. By the time the FAT is flushed (if at all), all UF2 blocks have already been received and programmed. When the OS needs to find the next free cluster for step 2, it scans its in-memory page-cached FAT, which correctly reflects every allocation it just made. It never does a disk round-trip to ask "is cluster 257 free?" — it already knows, from its own cache. FatFS has no page cache. Its win[] buffer is exactly 512 bytes. The instant it needs to switch from FAT sector 1 to FAT sector 2, it must disk_read() sector 1 when it comes back — and the bootrom hands back the original all-free data. Write ordering also helps Windows and Linux typically write data sectors first, then update the FAT and directory entry afterwards (or asynchronously). This means the bootrom has received and programmed every UF2 block before the FAT is even touched. The FAT flush is essentially a no-op as far as the bootrom is concerned — it's just tidying up a virtual disk that's about to disappear anyway (the Pico reboots and unmounts). Why the RP2040 bootrom was designed this way Raspberry Pi designed the bootrom specifically assuming a host with a page cache. The design relies on two properties: UF2 blocks carry their own address (target flash address is in the block itself), so they can arrive at any LBA in any order — no FAT traversal is needed by the bootrom. The virtual FAT is read-only from the bootrom's perspective — it exists only to make the device mountable and to let Windows/macOS/Linux discover free space and allocate sectors. The FAT write-back is always ignored. This design works perfectly for all mainstream OS FAT drivers but breaks FatFS because FatFS is the only common FAT implementation with a single-sector window that forces disk round-trips on every window switch. Summary table Windows 11 / Linux FatFS (PicoMite) FAT backing store Page cache (entire FAT in RAM) Single 512-byte win[] Re-reads own FAT writes? Never — reads from cache Yes — disk_read() on window switch Immune to bootrom's non-persistent FAT? Yes No, breaks at 256 clusters Large UF2 files Always work Fail above 1 cluster-sector boundary The fix for PicoMite is to bypass FatFS for the write direction on the boot drive, writing raw UF2 sectors directly via disk_write() so there's no FAT chain management at all. ME: CLAUDE: FLASH PICO B:/firmware.uf2 ' explicit drive + path FLASH PICO firmware ' current drive, adds .uf2 automatically FLASH PICO A:/stored.uf2 ' from internal flash filesystem PicoMiteHDMIUSB.zip |
Sorry another one :-( Because the TraceCache works with If statments, I converted the Case statment in the below code to a If, ElseIf.... type structure, when I run it without the TraceCache it works fine, stars of various colours, when I enable the TraceCache, 'Almost' all the stars are Blue, as though it is defaulting to the Else statment at the end, strangely there are a few yellow stars? I did try making the Else a ElseIf stz(st) >= 0.8 but then almost all the stars were white, no Blue or Cyan PS, it was considerably faster with the If, ElseIf, than the Case, so that bit works, assuming it's not faster because it's always defaulting to the Else statment? Kevin. 'set mode here if appropriate 'Option TraceCache On 32 MODE 3 'change maxst for more or fewer stars Dim Integer maxst=1250,h=MM.VRES,w=MM.HRES,x,y,st,c Dim Float f,stx(maxst),stxx(maxst),sty(maxst),styy(maxst),stz(maxst) Dim Integer ox(maxst),oy(maxst),oxl(maxst),oyl(maxst),cl(maxst),s(maxst) 'FRAMEBUFFER create 'FRAMEBUFFER write f CLS 'initialise the stars For st=0 To maxst stxx(st)=(Rnd*w>>1)-(w>>2):styy(st)=(Rnd*h>>1)-(h>>2) stz(st)=Int(Rnd*5+5)/10 cl(st)=RGB(White) Next 'initialise array for box size Math Set 2,s() Do 'move stars forward Math Add stz(),-0.025,stz() 'do the calculation (stx/stz)+half width Math C_div stxx(),stz(),stx():Math Add stx(),w>>1,stx() 'do the calculation (sty/stz)+half height Math C_div styy(),stz(),sty():Math Add sty(),h>>1,sty() 'reset rouge stars 'Inc c:c=c*(c<=maxst) Inc c:If c>maxst Then c=0 'stx(c)=stx(c)*(stz(c)>0.1) If stz(c)<0 Then stx(c)=0 'loop for all stars 'set star colour and check for star off screen For st=0 To maxst x=stx(st):y=sty(st) ' Select Case stz(st) ' Case < 0.2 ' cl(st)=&HFFFF00'RGB(Yellow) ' Case < 0.6 ' cl(st)=&HFFFFFF'RGB(White) ' Case < 0.8 ' cl(st)=&HFFFF'RGB(Cyan) ' Case Else ' cl(st)=&HFF'RGB(Blue) ' End Select If stz(st) < 0.2 Then cl(st)=&HFFFF00'RGB(Yellow) ElseIf stz(st) < 0.6 Then cl(st)=&HFFFFFF'RGB(White) ElseIf stz(st) < 0.8 Then cl(st)=&HFFFF'RGB(Cyan) Else cl(st)=&HFF'RGB(Blue) EndIf If (x>0 And x<w And y>0 And y<h)Then ox(st)=x:oy(st)=y Else Inc f,0.025:If f>0.09 Then f=0 stxx(st)=(Rnd*w>>1)-(w>>2) styy(st)=(Rnd*h>>1)-(h>>2) stz(st)=Int(Rnd*5+5)/10+f EndIf Next 'blank out last times stars, replace with new stars ' Pixel oxl(),oyl(),0:Pixel ox(),oy(),cl() Box oxl(),oyl(),s(),s(),0,,0:Box ox(),oy(),s(),s(),0,,cl() 'copy this times stars, to last times stars array Math Add ox(),0,oxl():Math add oy(),0,oyl() ' FRAMEBUFFER copy f,n,b Print Timer:Timer =0 Loop Edited 2026-04-23 04:00 by Bleep |
| toml_12953 Guru Joined: 13/02/2015 Location: United StatesPosts: 751 |
I think I've found a bug. If I use 'Option Tracecache on 16 Dim Integer maxst=1000:c=42 c=c*(c<=maxst) 'If c>maxst Then c=0 Print c End c is printed as 42, if I remove the comment for Option Trace Cache, c is printed as -42? If I set c to 1001, then in both cases c is printed as 0, which is fine. Kevin. To be consistent with other conditionals, a true comparison should return 1 ? 5 > 2 1 so c=c*(c<=maxst) should set c to 42. Option Trace Cache should, of course, have nothing to do with the outcome. |
Bleep Try this - should fix both bugs PicoMiteHDMIUSB.zip |
Hi Peter, Not sure what happened there, but this is significantly faster, even before I change the Case to a If,ElseIf? But yes both the above problems are fixed. :-) Kevin. |
Syntax: FLASH PICO B:/firmware.uf2 ' explicit drive + path FLASH PICO firmware ' current drive, adds .uf2 automatically FLASH PICO A:/stored.uf2 ' from internal flash filesystem Yes, it worked! A miracle happened, Pico flashes Pico! Thanks to Peter and his friend Claude I think the name Pico is a special case, and it would be better to specify it in the command something else, for example, like this Syntax: FLASH UF2 B:/firmware.uf2 ' explicit drive + path FLASH UF2 firmware ' current drive, adds .uf2 automatically FLASH UF2 A:/stored.uf2 ' from internal flash filesystem |
FLASH UF2 it will be |
That Claude thing...I am loving this stuff. What a time to be MCU-ing |
| ville56 Guru Joined: 08/06/2022 Location: AustriaPosts: 680 |
Peter, in FM, if listing a file (with "L"), the first character in the first non-empty line is not displayed in the list output. e.g. "option explicit" becomes "ption explicit" in the output. This is only true for the first non-empty line. Leading empty lines do not change the behaviour. Issue found on PicoMite MMBasic RP2350B V6.03.00B0 73 de OE1HGA, Gerald |
| BarryH Regular Member Joined: 05/01/2025 Location: AustraliaPosts: 53 |
Performance profiling and management are not working for a Webmite (RP2350B Pimoroni PPP2W) with v6.03.00B0. OPTION PROFILING ON only works if listed near the top within a program, but does not generate an error if entered on the command line. OPTION TRACECACHE & OPTION DEBUG..., if entered on the command line generate an "Error : Invalid Option", and within a program "Error : Invalid in a program" The older List Collisions in v6.02.02B8 works from the command line or within a program Edited 2026-04-23 16:42 by BarryH BarryH |
Not WebMite That is correct. The manual needs updating |
| Page 1 of 6 |
