Forum Index : Microcontroller and PC projects : MMX - solar eclipses
| cdeagle Senior Member Joined: 22/06/2014 Location: United StatesPosts: 269 |
This post is an MMBASIC computer program for the MicroMite eXtreme which can be used to predict the local circumstances of solar eclipses. The software uses a combination of one-dimensional minimization and root-finding to calculate these conditions. Here's a typical user interaction with the software. The program will take a minute or so to run to completion. Be patient, it's performing thousands of hardware-based, double precision calculations looking for the answer. The source code listing is 3200+ lines of comments, white space and actual code. program solar_eclipse ===================== please input the initial calendar date (month [1 - 12], day [1 - 31], year [yyyy]) < for example, october 21, 1986 is input as 10,21,1986 > < b.c. dates are negative, a.d. dates are positive > < the day of the month may also include a decimal part > ? 12,1,2000 please input the geographic latitude of the observer (degrees [-90 to +90], minutes [0 - 60], seconds [0 - 60]) (north latitudes are positive, south latitudes are negative) ? 39,40,36 please input the geographic longitude of the observer (degrees [0 - 360], minutes [0 - 60], seconds [0 - 60]) (east longitude is positive, west longitude is negative) ? -104,57,12 please input the altitude of the observer (meters) (positive above sea level, negative below sea level) ? 1644 please input the search duration in days ? 30 searching for solar eclipse ... Here's the program output for this example. begin penumbral phase of solar eclipse calendar date December 25 2000 UTC time 15 hours 29 minutes 23.91 seconds UTC julian day 2451904.14541560 topocentric coordinates lunar azimuth angle 132 deg 9 min 29.65 sec lunar elevation angle 10 deg 35 min 42.02 sec solar azimuth angle 132 deg 8 min 30.41 sec solar elevation angle 10 deg 4 min 35.03 sec greatest eclipse conditions calendar date December 25 2000 UTC time 16 hours 43 minutes 32.47 seconds UTC julian day 2451904.19690359 topocentric coordinates lunar azimuth angle 146 deg 40 min 53.36 sec lunar elevation angle 19 deg 34 min 59.64 sec solar azimuth angle 146 deg 53 min 27.85 sec solar elevation angle 19 deg 21 min 2.24 sec end penumbral phase of solar eclipse calendar date December 25 2000 UTC time 18 hours 6 minutes 3.54 seconds UTC julian day 2451904.25420764 topocentric coordinates lunar azimuth angle 165 deg 38 min 46.45 sec lunar elevation angle 25 deg 48 min 46.82 sec solar azimuth angle 166 deg 12 min 32.05 sec solar elevation angle 25 deg 41 min 51.62 sec event duration 2.61100903 hours Here's a PDF document for the MATLAB version of the program. 2017-03-14_173057_solar_eclipse.pdf Here's a zip archive of the MMBASIC source code for the solar eclipse computer program. 2017-03-14_173117_solar_eclipse.zip |
Just run it for my house in France for the next 10,000 days and it is matching exactly this site August 12th 2026 we get 90% coverage Fascinating - thanks for posting |
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1102 |
Hi Cdeagle, very nice code, thank you very much! Did you have some code for calculating the position of the planets? Frank |
Yes I do have MMBASIC code for computing planetary positions. I will post it in the near feature. |
My son recently got very interested in space related stuff. It happened after the CRS-10 launch of SpaceX. The day after the ISS was visible from my location and it was great to see it fly over. Now he wants to see it more clear. The idea is to buy a small telescope and try to follow it. Here is where it gets interesting for me. :) Adding a small motor that actually tracks it so that there are no jerky movements that will probably cause it to loose sight of it. Controlling a motor with a micromite would be the plan. Did any of you guys ever do something like that? What is the best place to get more info, my googling is not getting much info. Microblocks. Build with logic. |
I've been using this program to test various MMBasic implementations as it is a very good test of both the resilience and the accuracy of any port. Results so far: Pi-cromite @ 1200MHz: 7.86 seconds - identical answer STM32H7 @ 400MHz: 26.66 seconds - identical answer MMX @ 200MHz 74.98 seconds - identical answer MM+ @ 100MHz 121.75 seconds - small variations (NB software floating point) This gives an interesting insight into the comparative strengths of the ARM core vs the MIPS and it is interesting to speculate where the differences arise. The MMX result vs the MM+ is disappointing. The MMX has a double precision hardware FPU but is not that much quicker. We have always suspected that the limiting factor in MMBasic is the parsing rather than the times for the underlying calculations and that the flash memory access times may be critical in this. The Pi-cromite and STM32H7 are pretty much in-line with their relative clock speeds but significantly faster than the PICs on a per MHz basis. This suggests to me that the cacheing on the ARM core is better than the PIC and to test this I turned cacheing off on the STM32. This then gave results of: STM32H7 @ 400MHz (no cacheing): 95.49 seconds - identical answer STM32H7 @ 400MHz (Instruction cacheing only): 53.29 seconds - identical answer STM32H7 @ 400MHz (Data cacheing only): 86.48 seconds - identical answer As can be seen both types of cacheing are important but instruction caching is essential before the availability of data becomes really relevant So it is clear that the cacheing is absolutely critical to the chips performance. |
I think the STM has a FPU - don't know if it is DP or not though. I agree, at a guess the double-precision of the FPU is probably not going to speed up the parsed eclipse iterative minimisation/root-finding process a lot, at least until the iteration is very close to a solution (?). |
| Boppa Guru Joined: 08/11/2016 Location: AustraliaPosts: 816 |
Basically you are making a goto telescope... GOTO telescope |
| plasma Guru Joined: 08/04/2012 Location: GermanyPosts: 437 |
thanks for the code ! i like this kind of stuff. |
Here's an updated version of the solar eclipse MMBASIC program. It should run on any MicroMite that supports double precision math. It now displays conditions during the total/annular phases of eclipses. The documentation includes the write-up that appeared in Volume 2, Number 2 of Celestial Computing. 2019-04-07_220307_solar_eclipse.zip |
Apart from eclipses, could the earth/moon/sun system positions be used to calculate tide times and strengths ? I guess there would be a calculation assuming the ocean as a large blob of water modified by a local factor for individual locations eg a local phase delay and amplitude scale based on local measurement (?) |
For tide predictions check out https://tidesandcurrents.noaa.gov/tide_predictions.htmlC |
I use wtides http://www.wtides.com/ Jim VK7JH MMedit |
(!) more empirical than I thought |
